尺寸/Size |
12.1" |
分辨率/Resolution |
800×600/1024×768可选 |
亮度/Brightness |
330cd/M2 /150cd/M2 |
色彩/Color |
16.2/255K |
对比度/Contrast |
450:1 |
触摸系统/A touch system |
MapleTouch-J五线军工电阻触摸屏(单点可达3500万次) (有USB/RS232触摸卡可选) MapleTouch-J five line military resistance touch screen (single point up to 35000000 times) (USB/RS232 touch card optional) |
端口/ Port |
输入端口 TheInput port |
1×DB15-VGA、1×USB/RS232 |
工作环境/ Work environment |
操作温度/ Operating temperature |
-10~60℃ |
储存温度/Storage temperature |
-30~80℃ |
操作湿度/ Operating humidity |
20~85% |
防震性能/ Shockproof performance |
3Grms/5~450Hz |
其它/Other |
电源输入/Power Input |
100-240VAC ~ 50~60HZ 1.5A |
电源输出/Power output |
12VDC 5A MAX |
材料结构/Material structure |
铝材 Aluminum |
安装方式/Installation mode |
壁挂式、台式、VESA悬臂安装 hanging type、desktop、VESA cantilever installation |
净重、毛重/ Net weight、gross weight |
3.7/4.3kg |
体积规格/Size specification |
318mm*238mm*40mm |
你还可以了解其他的触摸广告机、一体机产品请登陆我司官网:www.gzyulian.com
