系统参数/System parameters |
主板/Host board |
Mini-ITX MP-H61 |
处理器/CPU |
Intel Celeron G∽Core i7 |
内存/RAM |
2GB DDR3-1333 SDRAM |
芯片组/Chip set |
Intel H61 Express Chipset |
SATA |
1*SATA II 3GB/s HDD/SDD 1*SATA III 6GB/s HDD/SDD 1*M-SATA |
LVDS |
18/24Bit Single channel |
LAN |
1*Realtek RTL8111DL |
Audio |
Realtek ALC892-GR 7.1 channel Audio Codec integrated |
储存体/Hard disk |
1×2.5 " SATA II HDD-320G/SSD-32G |
输出/入端口 The output/Input port |
1*RS232 8*USB2.0 1*DVI 1* VGA 1*LAN 1* LPT 1*Audio/Output |
扩展总线/The expansion bus |
1×PCI Express×1 1×Mini PCIE |
工作环境/ Work environment |
操作温度/ Operating temperature |
-10~60℃ |
储存温度/Storage temperature |
-30~80℃ |
操作湿度/ Operating humidity |
20~85% |
防震性能/ Earthquake performance performance performance performance |
3 GrMs/5~450Hz |
敲击和碰撞/ Knock and collision |
Operating 20G(11Ms),Non-operating 320G with HDD Operating 80G(11Ms),Non-operating 32G with SSD |
其它/Other |
电源输入/Power Input |
100V-240VAC 1.5A/DC 19V 7A |
设备功耗/ Device power consumption |
70W(MAX) |
电源适配器/ The power adapter |
130W AC/DC |
材料结构/Material structure |
铝材 Aluminum |
安装方式/Installation mode |
壁挂式/导轨安装 Wall hanging type / rail mounting |
净重、毛重/ Net weight、gross weight |
2.1kg/2.6k |
体积规格/Size specification |
250mm*58mm*195mm |
