尺寸/Size |
15" |
分辨率/Resolution |
1024*768 |
亮度/Brightness |
250cd/M2 |
色彩/Color |
16.7M |
对比度/Contrast |
600:1 |
触摸系统/A touch system |
多点电容式触摸屏/MapleTouch-J五线军工电阻触摸 屏(单点可达3500万次)(有USB/RS232触摸卡可选) Multi point capacitive touch screen MapleTouch-J five line military resistance touch screen (single point up to 35000000 times) (USB/RS232 touch card optional) |
系统参数/System parameters |
主板/Host board |
Mini-ITX MP-H61 |
处理器/CPU |
Intel Celeron G∽Core i7 |
内存/RAM |
2GB DDR3-1333 SDRAM |
芯片组/Chip set |
Intel® H61 Express Chipset |
SATA |
1×SATA II 3GB/s HDD/SDD/1×SATA III 6GB/s HDD/SDD/1×M-SATA |
LAN |
1×Realtek RTL8111DL (100/1000Mbps) |
Audio |
Realtek ALC887 HD Audio Codec integrated |
储存体/Hard disk |
1×2.5 " SATA II HDD-320G/SSD-32G |
输出/入端口 The output/Input port |
1×RS232 6×USB 2.01×DVI 1×HDMI 1×Audio Out 1×MIC In 1×E SATA(2.0) |
扩展总线/The expansion bus |
1×PCI Express×1 1×Mini PCIE |
工作环境/ Work environment |
操作温度/ Operating temperature |
-10~60℃ |
储存温度/Storage temperature |
-30~80℃ |
操作湿度/ Operating humidity |
20~85% |
敲击和碰撞/ Knock and collision |
Operating 20G(11Ms),Non-operating 320G with HDD Operating 80G(11Ms),Non-operating 32G with SSD |
其它/Other |
电源输入/Power Input |
100-240VAC ~ 50~60HZ 1.5A |
电源输出/Power output |
12VDC 5A MAX |
材料结构/Material structure |
铝材 Aluminum |
安装方式/Installation mode |
壁挂式、台式、VESA悬臂安装 hanging type、desktop、VESA cantilever installation |
净重、毛重/ Net weight、gross weight |
5.65KG/3.9KG |
体积规格/Size specification |
350mm*234mm*268mm |
你还可以了解其他的触摸广告机、一体机产品请登陆我司官网:www.gzyulian.com
