| Item | Nominal Voltage | Nominal Capacity *1 | Standard Charge/Discharge Current | Max Pulse Current*2 | Charge/Discharge Cycle Characteristics | Charging Method | Dimensions | Weight | |
| (V) | (mAh) | (mAh) | (mA) | (discharge depth of 20%) | (mm) | (g) | |||
| Constant Voltage Charge | Diameter | Height | |||||||
| (D) | (H) | ||||||||
| ML414U | 3 | 1.2 | 0.005 | 0.6 | 300 cycles | 2.83.25V | 4.8 | 1.4 | 0.07 |
| ML421 | 3 | 2.3 | 0.005 | 0.6 | 4.8 | 2.1 | 0.1 | ||
| ML614 | 3 | 3.4 | 0.015 | 1.5 | 6.8 | 1.4 | 0.16 | ||
| ML621 | 3 | 5.8 | 0.015 | 1.5 | 6.8 | 2.1 | 0.22 | ||
| ML1220 | 3 | 15 | 0.1 | 5 | 12.5 | 2 | 0.8 | ||
| ML2016 | 3 | 30 | 0.3 | 20 | 500 cycles | 20 | 1.6 | 1.8 | |
| ML2430 | 3 | 100 | 0.5 | 20 | 24.5 | 3 | 4.1 | ||
