| 产品尺寸 | 15 | |
| 分辨率 | 800*600/1024*768可选 | |
| 亮度 | 330cd/㎡ /150cd/㎡ | |
| 色彩 | 16.2M/255K | |
| 对比度 | 450:1 | |
| 触摸系统 | MapleTouch-J 5线军工电阻触摸屏(单点可达3500万次、USB/RS232可选) | |
| 主板 | Mini-ITX MP-270L | |
| CPU | Intel ATOM N270 | |
| 内存 | 1GB DDR2-800 SDRAM | |
| 存储体 | 1*2.5 " SATA II HDD-320G | |
| 系统参数 | ||
| 芯片组 | Intel 945GSE+ICH7M Chipset | |
| SATA | 2*SATA II 3GB/s HDD/SDD | |
| LAN | 1*realtek RTL8111DL (100/1000Mbps) | |
| Audio | ALC 662 2-channel Audio | |
| 储存体 | 1*2.5 " SATA II HDD-320G/SSD-32G | |
| I/O | ||
| I/O接口 | 2*DB9 RS232 (最大扩展4*RS232/含1*RS422/485) | |
| 3*USB-2.0 | ||
| 1*DB15-VGA | ||
| 1*DB25-LPT | ||
| 1*LAN | ||
| 1*Audio | ||
| 1*PS2 (KB/MS) | ||
| 扩展总线 | 1*PCI Expansion slots | |
| 1*Mini PCI-E Expansion slots | ||
| 工作环境 | ||
| 操作温度 | -10~60℃ | |
| 储存温度 | -30~80℃ | |
| 操作湿度 | 20~85% | |
| 防震性能 | 3 Grms/5~450Hz | |
| 敲击和碰撞 | Operating 20G(11ms),Non-operating 320G with HDD | |
| Operating 80G(11ms),Non-operating 32G with SSD | ||
| 资格证书 | ||
| 获证证书 | CB、CE、FCC、ROHS | |
| 电源器 | ||
| 电源输入 | 100-240VAC ~ 50~60HZ 1.5A | |
| 电源输出 | 12VDC 5A MAX | |
| 产品规格 | ||
| 材料结构 | 全金属(铝材) | |
| 安装方式 | 面板、架式,壁挂式、台式、VESA悬臂安装 | |
| 净重/毛重 | ||
| 体积规格 LWH |
