维修ADVANTEST电路板维修,修复率80%以上。limit fail 维修
** T5365 SYSTEM DIAGNOSTICS REV 6.04 **
** SYSTEM ID. MEC3 **
** START AT 2013/07/28 17:03:32 **
** TEST MODE : MAINTENANCE & PASS PRINT **
** SPEC : 100.0% **
** PIN : 1-24,29,30,33-50,97-114<A1> 1-4,13-16,29,30<A3> **
** : 1-24,29,30,33-50,97-114<B1> 1-4,13-16,29,30<B3> **
** : 1-24,29,30,33-50,97-114<C1> 1-4,13-16,29,30<C3> **
** : 1-24,29,30,33-50,97-114<D1> 1-4,13-16,29,30<D3> **
** UNIT : TH1 **
TH1 DIAGNOSTIC PERFORMANCE BOARD IS NOT MOUNTED
TEST 5301 TH1 ( 3) DR OFFSET ADJUST CHECK ***PASS
TEST 5302 TH1 ( 3) DR OUTPUT VOLTAGE & select CHECK FAIL**
VIH CHECK
IN1 IN2 IN3 IN4
SET -1.500V -1.000V 0.000V 2.000V
ULMT -1.451V -957.0MV 32.00MV 2.054V
LLMT -1.548V -1.043V -32.00MV 1.946V
IN5 IN6 IN7 IN8
SET 4.000V 6.000V 8.000V 9.000V
ULMT 4.076V 6.098V 8.120V 9.131V
LLMT 3.924V 5.902V 7.880V 8.869V
VIL CHECK
IN1 IN2 IN3 IN4
SET -4.000V -2.000V -1.000V 0.000V
ULMT -3.924V -1.946V -957.0MV 32.00MV
LLMT -4.076V -2.054V -1.043V -32.00MV
IN5 IN6 IN7 IN8
SET 1.000V 2.000V 3.000V 5.000V
ULMT 1.043V 2.054V 3.065V 5.087V
LLMT 957.0MV 1.946V 2.935V 4.913V
112<B> -3.920V * -1.986V -984.0MV 18.00MV
1.016V 2.018V 3.014V 5.016V FAIL*
TOTAL COUNT= 6912 FAIL COUNT= 1
TH1 SLOT 105B BGL-018817 IS DOUBTFUL
VIO SLOT 23 BGR-018824 IS DOUBTFUL
VIO SLOT 25 BGR-018822 IS DOUBTFUL
VIO SLOT 31 BGR-018821 IS DOUBTFUL
THC1 SLOT CLAB BGL-018831 IS DOUBTFUL
TEST 5303 TH1 ( 3) DR OUTPUT CURRENT & IMPEDANCE CHECK ***PASS
TEST 5304 TH1 ( 3) DR OUTPUT CURRENT LIMIT CHECK ***PASS
TEST 5401 TH1 ( 4) VT OFFSET ADJUST CHECK ***PASS
TEST 5402 TH1 ( 4) STANDARD VT OFFSET ADJUST CHECK ***PASS
TEST 5403 TH1 ( 4) VT OUTPUT VOLTAGE & select CHECK ***PASS
TEST 5404 TH1 ( 4) VT OUTPUT CURRENT & IMPEDANCE CHECK FAIL**
SINK SOURCE
ULMT 57.12R 57.12R
LLMT 49.22R 49.22R
113<A> 57.16R * 57.12R FAIL*
TOTAL COUNT= 288 FAIL COUNT= 1
TH1 SLOT 97A BGL-018817 IS DOUBTFUL
VIO SLOT 24 BGR-018824 IS DOUBTFUL
TEST 5405 TH1 ( 4) VT OUTPUT CURRENT LIMIT CHECK ***PASS
TEST 5501 TH1 ( 5) PL OFFSET ADJUST CHECK ***PASS
TEST 5502 TH1 ( 5) PL OUTPUT CURRENT & select CHECK
/LOG OFF
苏州三岩芯电子科技前身为苏州工业园区三源芯辉电子科技有限公司,是一家致力于电子应用
技术与维修的一家高新技术企业,三源电子始创于1995年服务于电子半导体产业和化工业、机
械制造业及军工产业设备的维修与维护。我司技术力量雄厚,主要技术人员均来自各电子工程
研究所和研究院,现有维修工程师14人,业务工程师11人,客服人员3名。我公司在电子工程
、通信、微波、毫米波、自动控制、信号处理、无线电计量、电子结构、高精度传动结构等高
新技术领域的开发应用有着较强的技术实力。我司始终保证维修的电路板品质和新板如一,真
正的为客户创造价值、节省费用,实现“设备永续、设备无忧”,为客户设备的正常运行提供多
方位全程保障,以优质、快捷、可靠的专业电路板维修服务为用户赢得生产、配送和运营的宝
贵时间,提高企业应对市场灵活变化的需要。凡我公司维修的工控产品和电路板专业销售大型
进口各种品牌DCS系统模块备件:ABB Advant OCS,ABB MOD 30/MODCELL,ABB MOD 300,ABB
Bailey INFI 90,ABB Procontic,ABB Procontrol,H&B Contronic,Moore APACS,Moore
Panel Controllers,Rosemount RS-3,Siemens Iskamatic,Siemens Simatic S5,Siemens
Simatic C1,Yokogawa Centum XL,Yokogawa microXL,FOXBORO I/A,
Westinghouse,Ovation,Honeywell QCS,Honeywell TDC系列,Honeywell S9000,HITACHI,
Mitsubishi PLC,Motorola MVME,ALSTOM MVME,Other VME,TOSHIBA等大型模组,有着充足的
库存,交货期快,欢迎来电查询。
ADVANTEST 备件 特价销售维
PE-CARD (BGL-019917) VIO_IO (BGR-018824)
PPS BOARD (BGL-016796)
ADVANTEST(T3324)测试机的PINCARD 型号BIK-012107
相关型号
T7315 TESTER Q"ty:3座
R8240 DIGITAL ELECTROMETER
R6581T DIGITAL MULTIMETER Q"ty:1
WORK STATION V0713+KEYBOARD MODEL:TYPE 6 Q"ty:3
H3-7707 Q"ty:2
KH3-6070 USER I/F UNIT+BLP-OII855 Q"ty:1
BGK-011702 REV.BCD UNIVERSAL BUS I/F Q"ty:1
BGK-017719 REV.BAA 2ND BPIB Q"ty:1
KH3-71149 Input:AC200V 50/60Hz 3PH 50A MAX+Hitachi EX50B EARTH-LEAKAGE BREAKER 3P
Q"ty:1
KH3-71150 AC POWER CONVERTER Q"ty:1
KH3-91532 MAIN
KH3-93239 Q"ty:1
WUN-H391989X02AIR Q"ty:1
WUN-MONITORBOX Q"ty:1
SBM I/F BGR-012894 Q"ty:1
DATA DISTRIBUTOR BGR-015372 Q"ty:1
AQM BGR-015428 Q"ty:4
PC GBR-015683 Q"ty:1
DELAY CONT GBR-015820X02 Q"ty:1
PG CONTROL BGR-015933 Q"ty:1
HSB2 BGR-015940 Q"ty:1
GBR-015941X02 Q"ty:1
CPU2 BGR-015947 Q"ty:1
MATCH CONTROL BGR-016840 Q"ty:2
VGC1 BGR-017015 Q"ty:1
VGC2 BGR-017016 Q"ty1
CPU&MEM BGR-017575&BGR-017577 Q"ty:1
SBM BOARD 128MB BGR-017613 Q"ty:1
SBM CONT BGR-017615 Q"ty:1
PG I/F BGR-018002X02 Q"ty:1
DPU I/F BGR-018100 Q"ty:1
BGR-018213 Q"ty:2
BGR-018214 Q"ty:1
FM CONT BGR-018255 Q"ty:1
TRIGGER(SPARE PARIS) BGR-018256X40 Q"ty:1
BGR-018312 Q"ty:1
BGR-018971 Q"ty:1
UDC BGR-019748X04 Q"ty:1
FT I/F BGR-020490 Q"ty:1
FT 40MHZ-1MW(SPARE PARTS) BGR-020491X01 Q"ty:7
AP GBR-020492X02 Q"ty:1
CLOCK DIST(SPARE PARTS) BGR-020494 Q"ty:2
BGR-020621 Q"ty:4
BGR-020692X02 Q"ty:1
TH I/F BGR-020842 Q"ty:1
BGR-022423X02 Q"ty:1
TP4B CH I/F BOARD BGR-024436 Q"ty:1
BIQ-013750X02&BGR-013749X02 Q"ty:4
8CH ADC BOARD BIR-014509X01 Q"ty:1
BIR-021808X02 Q"ty:1
D1960 Q''ty:17
D1990 Q"ty:9
BGD-020850 Q"ty:4
BGR-015467 Q"ty:1
Advantest D3186-10-D3286 Digital Transmission Tester 12
Advantest Equipment Travel Locking Case NICE
ADVANTEST U3751 SPECTRUM ANALYZER 9KHZ-8GHZ
TESTED AND CALIBRATED-90 DAY WARRANTY
ADVANTEST R-3267 SPECTRUM ANALYZER 100KHZ-8GHZ
OPTIONS INSTALLED- 001/021/062/064 TESTED -CALIBRATED
ADVANTEST R-3465 SPECTRUM ANALYZER FREQ-9KHZ-8GHZ
TESTED CALIBRATED-90 DAY WARRANTY- READY FOR SHIPMENT
ADVANTEST R-3265 SPECTRUM ANALYZER 100KHZ-8GHZ
OPTION-71- TESTED-30 DAY WARRANTY
ADVANTEST U3641N SPECTRUM ANALYZER-75-OHM
9KHZ-3GHZ- OPTIONS 72/74-TRACKING/TV OPTION
Advantest R3265 100Hz to 8 GHz Spectrum Analyzer
Unit Tested & Guaranteed w/ ROR! Option 71 Installed!
Advantest R3465 Mod. Spectrum Analyzer Operation Manual
ADVANTEST R3465 8 GHz SPECTRUM ANALYZER PDC PHS NADC
Advantest Q8384/25 Optical Spectrum Analyser (Tested)
ADVANTEST R3265 100 Hz TO 8 GHz SPECTRUM ANALYZER
ADVANTEST U3361 (9MHZ TO 26.5 GHZ) SPECTRUM ANALYZER
Advantest R3767AH 40MHz - 8GHz Network Analyzer
Unit Tested & Guaranteed Functional w/ ROR! REDUCED!!
Advantest Q8381 Optical Spectrum Analyzer 350nm-1750nm
Optical Spectrum Analyzer 350nm to 1750nm, Great OSA
ADVANTEST R-4870 COMMUNICATION ANALYZER-BLUE-TOOTH
BLUE-TOOTH TEST ANALYZER-TRANCIVER-DUPLEX
Advantest R3267 Spectrum Analyzer, 100Hz - 8GHz
*Opt. 01,61,62,65,67* Cal'd w/ CERT, 7 Day ROR
Advantest AVS R6142 DC Voltage/Current Generator
Advantest R3271 26.5 GHz RF Microwave Spectrum Analyzer
100Hz to 26.5GHz RF Spectrum Analyzer 26 GHZ
ADVANTEST R3132N SPECTRUM ANALYZER 9kHz-3GHz 75ohm
Advantest AVS R3561 Cdma Test Source
Advantest R3263/15/55/77 Spectrum Analyzer 9 kHz-3 GHz
Tested working, new calibration 14-day right of return
Advantest R6142 DC Voltage/Current Source Refurb NIST
Advantest R4131D Spectrum Analyzer
Advantest AVS R6871E/DC 7 1/2 Digit Digital Multimeter
Advantest R6871E/DC 7 1/2 Digit Digital Multimeter
ADVANTEST TQ8346 OPTICAL SPECTRUM ANALYZER
ADVANTEST R3964A 8 GHZ DUPLEXER 3 PORT ADAPTER ~ R3765C
advantest r9211c fft servo analyzer
Advantest Keyboard N860-3730-T002 Hand Held Programmer
Advantest D3286 Error Detector Options 70/72 Very Nice
Advantest R3267
Advantest R5362B Frequency Counter - 3GHz + Accessories
ADVANTEST U3641 Microwave Spectrum Analyzer
Advantest Q7750 Optical Network Analyzer w/ opt. 10
Perfect working order, Cables included
ADVANTEST Q-8221 OPTICAL MULTI POWER METER
TESTED AND CALIBRATED- 90 DAY WARRANTY
Advantest TR5821 Universal Counter
Advantest R3265/3271 Spectrum Analy Instruction Manual
Advantest D3286 12.5 Gb/s Error Detector 70 - Working
ADVANTEST D3286 /70 Digital Transmission Tester
Advantest R6441A Digital Multimeters
ADVANTEST Digital Multimeter GP-IB Adapter TR13217
ADVANTEST R3272 SPECTRUM ANALYZER
Advantest R6441D 5 digit DIGITAL MULTIMETER DMM
ADVANTEST Q8221 OPTICAL MULTI POWER METER
Advantest Optical Power Meter TQ8210
Advantest Q8163 Optical Polarization Scrambler
PC board for Advantest Optical Power Meter TQ8210 Parts
Advantest Q8230 Optical Power Meter
Advantest 5361-Power Supply BX05300
Advantest 5361-Power Supply BX05450
Advantest 5361-Power Supply BX02600
Advantest 5361-Power Supply BX05600
Advantest 5361-Power Supply SR200-24/56
Advantest 5361-Power Supply SR50-15/5G
Advantest R3261C Spectrum Analyzer 9KHz to 2.6GHz
Advantest 5361-Power Supply SR300-2/5G
Advantest - R6441B Digital Multimeter Dual Channel
Advantest 5361-Power Supply SR600-36/5G
Advantest 5361-Power Supply SR50-5/5G
Advantest 5361-Power Supply SR200-18/5G-011-929388-0008
Advantest 5361-Power Supply SR600-5G/-011-914367-0014
Advantest 5361-Power Supply SR100-12-5G/011-921430-0002
Advantest 5361-Power Supply SR300-16-5G/011-929323-0019
Advantest 5361-Power Supply SR300-10-5G/011-929322-0012
Advantest 5361-Power Supply SR300-5-5G/011-929329-0018
Advantest 5361-Power Supply SR600-12-5G/011-914370-0020
4. BGR-018931 CPU7 (ADI)
3. BGR-017579 TP4 CONT
2. BGR-017578 BUS CONT
1. WBL-017575 8MB CPU 8MB
55. BGR-017418 HV PPS
54. BGR-017418 HV PPS
53. BGR-017417 HV PPS CONT
52. BGR-020765 16V PPS
51. BGR-020765 16V PPS
50. BGR-016796 PPS
49. BGR-016796 PPS
48. BGR-016796 PPS
47. BGR-016796 PPS
46. BGR-021096 PPS CONT
45. BGR-016796 PPS
44. BGR-016796 PPS
43. BGR-016796 PPS
42. BGR-016796 PPS
41. BGR-021096 PPS CONT
40. BGR-019486 DC 3
9. BGR-019486 DC
38. BGR-016797 DC CONT
37. BGR-019486 DC
36. BGR-019486 DC
35. BGR-016797 DC CONT
34. BGR-019486 DC
33. BGR-019486 DC
32. BGR-016797 DC CONT
31. BGR-019486 DC
30. BGR-019486 DC
29. BGR-016797 DC CONT
28. BGR-016794 I/F ANA
27. BGR-016793 I/F LOGIC
26. BGR-020765 16V PPS
25. BGR-020765 16V PPS
24. BGR-016796 PPS
23. BGR-016796 PPS
22. BGR-016796 PPS
21. BGR-016796 PPS
20. BGR-021096 PPS CONT
19. BGR-016796 PPS
18. BGR-016796 PPS
17. BGR-016796 PPS
16. BGR-016796 PPS
15. BGR-021096 PPS CONT
14. BGR-019486 DC
13. BGR-019486 DC
12. BGR-016797 DC CONT
11. BGR-019486 DC
10. BGR-019486 DC
8. BGR-019486 DC
7. BGR-019486 DC
6. BGR-016797 DC CONT
5. BGR-019486 DC
4. BGR-019486 DC
3. BGR-016797 DC CONT
2. BGR-016794 I/F ANA
1. BGR-016793 I/F LOGIC
31. BGR-020851 VIO I/F
30. BGR-018822 VIO I/F ANA
29. BGR-018823x03 DR VIO
28. BGR-018823x03 DR VIO
27. BGR-018823x03 DR VIO
26. BGR-018823x03 DR VIO
25. BGR-018822 VIO I/F ANA
24. BGR-018824x03 IO VIO
23. BGR-018824x03 IO VIO
22. BGR-018824x03 IO VIO
21. BGR-018824x03 IO VIO
20. BGR-018822 VIO I/F ANA
19. BGR-018824x03 IO VIO
18. BGR-018824x03 IO VIO
17. BGR-018824x03 IO VIO
16. BGR-018824x03 IO VIO
15. BGR-018822 VIO I/F ANA
14. BGR-018823x03 DR VIO
13. BGR-018823x03 DR VIO
12. BGR-018823x03 DR VIO
11. BGR-018823x03 DR VIO
10. BGR-018822 VIO I/F ANA
25. BGR-018125 CBOX I/F
24. BGR-020771 FTU I/F
23. BGR-020773 CHILD VD
22. BGR-020773 CHILD VD
21. BGR-020773 CHILD VD
20. BGR-020773 CHILD VD
19. BGR-021176 FC DIST
18. BGR-020773 CHILD VD
17. BGR-020773 CHILD VD
16. BGR-020773 CHILD VD
15. BGR-020773 CHILD VD
14. BGR-021176 FC DIST
13. BGR-020812 TG
12. BGR-020772 FC
11. BGR-020814 ALPG
10. BGR-020815 FM CONT
9. BGR-020774 SC
8. BGR-020816 AFM
7. BGR-020774 SC
6. BGR-020816 AFM
5. BGR-020774 SC
4. BGR-020816 AFM
3. BGR-020774 SC
2. BGR-020816 AFM
1. BGR-020853 TERM
ADVANTEST T5335 T.H. LOCATION AND BOARD LIST
CAL/SIG BGL-018831
CHILD A BGL-020768
CHILD A BGL-020768
CHILD A OP1 BGL-021040
CHILD A BGL-020768
CHILD A BGL-020768
CHILD AB OP2 BGL-021040
CHILD B BGL-020768
CHILD B BGL-020768
CHILD B OP1 BGL-021040
CHILD B BGL-020768
CHILD B BGL-020768
CAL/SIG BGL-018831
CHILD C BGL-020768
CHILD C BGL-020768
CHILD C OP1 BGL-021040
CHILD C BGL-020768
CHILD C BGL-020768
CHILD CD OP2 BGL-021040
CHILD D BGL-020768
CHILD D BGL-020768
CHILD D OP1 BGL-021040
CHILD D BGL-020768
CHILD D BGL-020768
CHILD E BGL-020768
CHILD E BGL-020768
CHILD E OP1 BGL-021040
CHILD E BGL-020768
CHILD E BGL-020768
CHILD EF OP2 BGL-021040
CHILD F BGL-020768
CHILD F BGL-020768
CHILD F OP1 BGL-021040
CHILD F BGL-020768
CHILD F BGL-020768
CAL/SIG BGL-018831
CHILD G BGL-020768
CHILD G BGL-020768
CHILD G OP1 BGL-021040
CHILD G BGL-020768
CHILD G BGL-020768
CHILD GH OP2 BGL-021040
CHILD H BGL-020768
CHILD H BGL-020768
CHILD H OP1 BGL-021040
CHILD H BGL-020768
CHILD H BGL-020768
CAL/SIG BGL-018831
CLAMP D/A BGH-018830
DC MUX2 BGH-019207
DC MUX2 BGH-019207
DC MUX2 BGH-019207
DC MUX2 BGH-019207
DC MUX2 BGH-019207
DC MUX2 BGH-019207
DC MUX2 BGH-019207
DC MUX2 BGH-019207
CONT C2 BGH-018827
CONT C1 BGH-018826
CONT A BGH-020852
DC MUX1 BGH-018829
DC MUX1 BGH-018829
Advantest D5115 multimedia protocol analyzer Great !!!!
Advantest Q82227 Optical Sensor Module
ACCESSORIES WARRANTY and CALIBRATION
advantest R4945A EPROM Programmer with R49451A adapter
has option 07: thermal printer
ADVANTEST RF TEST EQUIPMENT DETECTOR
Advantest R17052A 20GHz Automatic Calibration Kit
Advantest Q8347 Optical Spectrum Analyzer 350nm-1750nm
Michelson Interferometer, Maximum resolution of 0.001nm
Advantest R6871E Digital Multimeter,7?
Advantest Q81204 LED Source Module
T5365 boards list: 2006.Jan.12
1. BGR-018824
2. BGR-018821
3. BGR-018824
4. BGR-018836
5. BGR-018824
6. BGR-018823
7. BGR-018823
8. BGR-018823
9. BGR-018823
10. BGR-018197
11. BGR-018198
12. BGR-018207
13. BGR-018823
14. BGR-018840
15. BGR-018840
16. BGR-018822
17. BGR-019382
18. BGR-015470 x2
19. BGR-019381
20. BGR-018200
21. BGR-019383
22. BGR-018201
23. BGR-015466 x02
24. BGR-019379
25. BGR-018200
26. BGR-018824
27. BGR-018837
28. BGH-018825,
29. BGR-018824
30. BGR-018824
31. BGR-019382
32. BGR-019379
33. BGR-018824
34. BGR-018841
35. BGR-018203 x2
36. BGR-018839
37. BGR-018824
38. BGR-015466 x2
39. BGH-018828,
40. BGH-018828
41. BGH-018828,
42. BGR-019390
43. BGR-018839
44. BGR-018840
45. BGR-015466 x2
46. BGR-015839
47. BGR-018834
48. BGR-010442 x5
49. BGR-015839
50. BGR-019378
51. BGR-018834
52. BGR-018199
53. BGR-019390
54. BGR-019380
55. BGR-019383
56. BGR-018837
57. BGR-018840
58. BGR-015470 x2
59. BGR-018840
60. BGR-018837
61. BGL-018817,
62. BGL-018817
63. BGL-018817,
64. BGL-018817
65. BGL-018817,
66. BGL-018817
67. BGL-018817
68. BGL-018817
69. BGL-018817,
70. BGL-018817
71. BGL-018817,
72. BGL-018817
73. BGL-018817
74. BGL-018817
75. BGL-018817,
76. BGL-018817
77. BGL-018817
78. BGL-018817
79. BGL-018817,
80. BGL-018817
81. BGL-018817,
82. BGL-018817
83. BGL-018817
84. BGL-018817,
85. BGL-018817
86. BGL-018817
87. BGL-018817
88. BGL-018817
89. BGL-018817
90. BGL-018817
91. BGL-018817
92. BGR-018837
93. BGR-015554
94. BGR-016795
95. BGR-017575,
96. BGR-017577
97. BGR-015467
98. BGR-018201
99. BGR-018823 x3
100. BGR-019383
101. BGR-017570
102. BGR-018823
103. BGR-018824
104. BGR-018840
105. BGR-018836
106. BGR-018823
107. KH9-90571(0),
108. KH9-90571(0)
109. BGR-018198
110. BGR-018842
111. BGR-019383
112. BGR-015466
113. BGR-019378
114. BGR-018837
115. BGR-018824
116. BGR-018842
117. BGR-018824
118. BGR-018841
119. BGR-017379
120. BGR-017578
121. BGR-018824
122. BGR-018837
123. BGR-018837
124. BGR-018829
125. BGR-015466
126. BGR-018199
127. BGR-019609
128. BGR-018824
129. BGR-018821
130. BGR-018822
131. BGR-016795
132. BGR-018824 x2
133. BGR-018824
134. BGR-019486
135. BGK-011704
136. BGK-011704
137. BGR-018837
138. BGR-019786
139. BGR-017579
140. BGR-018317
141. BGR-018200
142. BGR-016795
143. BGR-018836
144. BGR-015466
145. BGR-018371
146. BGR-017418
147. BGR-018824
148. BGR-018364
149. BGR-018202
150. BGK-017719
151. BGL-017031
152. BGL-017031
153. BIL-014300
154. BIR-015398 x2
155. BGC-020527,
156. BGH-018827,
157. BGH-018827
158. BGH-018828,
159. BGH-018829
160. BGR-015467 x2
161. BGR-018836
162. BGR-018836
163. BGR-015554 x2
164. BGR-016795
165. BGL-018817
166. BGR-018840
167. BGR-015839
168. BGR-018836
169. BGR-018836
170. BGH-018828
171. BGR-018840
172. BGR-018839
173. BGR-018823
174. BGR-018838
175. BIR-013610
176. BGR-015839
177. BGR-018824
178. BGR-018824
179. BGR-018823
180. BGR-018824
181. BGH-018828
182. BGR-018822
183. BGR-018837
184. BGR-018824
185. BGR-018823
186. BGR-018836
187. BGR-018822
188. BGR-018839
189. BGL-018817,
190. BGL-018817
191. BGR-018842
192. BGL-018817
193. BGR-018836
194. BGL-018817,
195. BGH-018830
196. BGL-018817
197. BGL-018817
198. BGL-018817,
199. BGL-018817
200. BGR-015839
201. BGL-018817
202. BGL-018817
203. BGL-018817
204. BGL-018831
T5335P boards list: 2006.Jan.12
1. BGR-020771
2. BGR-020816
3. BGR-020774
4. BGR-020771
5. BGR-020774
6. BGR-020771
7. BGR-020816
8. BGR-020816
9. BGR-021096
10. BGL-020768
11. BGL-020768
12. BGL-020768
13. BGL-020768
14. BGR-018822
15. BGH-019207
16. BGH-018831
17. BGH-019207,
18. BGH-019207
19. BGR-018822
20. BGL-018831
21. BGH-018827
22. BGH-019207
23. BGH-018827
24. BGH-019207 x2
25. BGH-019207
26. BGH-018829
27. BGL-018831
28. BGR-018125
29. BGR-019267
30. BGH-019207
31. BGR-018931
32. BGH-019207
33. BGL-018831
34. BGR-018822
35. BGR-018125
36. BGH-018829
37. BGL-018831
38. BGH-018827
39. BGH-018830,
40. BGH-019207
41. BGH-019207
T5581H boards list: 2006.Jan.19
1. BGR-021800
2. BGR-020765
3. BGR-020785
4. BGR-020765
5. BLN-027527
6. BGM-021557
7. BGN-022117
8. BGR-020765
9. BGM-021558
10. BGH-019207
11. BGN-021941
12. BGR-021619
13. BGM-021557
14. BGM-021557
15. BGL-021557
16. BGM-021558
17. BGR-016797
18. BGR-019486
19. BGR-019486
20. BGR-016797
21. BGR-016793
22. BGR-017418
23. BGR-016794
24. BGR-019486
25. BGR-016797
26. BGR-019486
27. BGR-017418
28. BGR-019486
29. BGR-019486
30. BGR-016797
31. BGR-017418
32. BGR-019486
33. BGR-017418
34. BGR-021321
35. BGR-017418
36. BGR-016794
37. BGR-016793
38. BGR-016797
39. BGR-017417
40. BGR-017418
41. BGR-019486
42. BGR-017418
43. BGR-016797
44. BGR-016797
45. BGR-016797
46. BGR-016797
47. BGR-016797
48. BGN-016797
49. BGN-016797
50. BGN-016797
51. BGR-017418
52. BGR-019486
53. BGR-019486
54. BGR-019486
55. BGR-017418
56. BGR-017417
57. BGR-016793
58. BGR-019486
59. BGR-016794
60. BGR-019486
61. BGR-016797
62. BGR-016794
63. BGR-017417
64. BGR-019486
65. BGR-016797
66. BGR-019486
67. BGR-016797
地 址:苏州工业园区星港街263号
联系人:徐生 先生
电 话:86-512-13913148881
邮 编:215021
网 址:http://www.suzhou-pcb.com
通过中国触摸屏网金牌会员认证
