德国德巴马格Demag DES 10-C 77335245 行车手控拿维修不灵
PULSAFEEDER NP170030-THY
sick C2MT-01814BBC03BE0
PULSAFEEDER NP160076-PVD
PULSAFEEDER NP140067-ALU
R. STAHL 9002/00260138-001
HYDROPA Z6 DR1-AB; Pmax 300bar
VOITH NO.H01162119 VOITH
VOITH NO.H01019999 VOITH
VOITH NO.H86003089 VOITH
VOITH NO.H86003090 VOITH
VOITH NO.H86002556 VOITH
VOITH NO.410003694 VOITH
WIBOND SZP104-100TD/1.0916
SUNON EEC0382B1-0000-A99
MOOG D661Z571C CH09HOGBENC07
JOKAB SAFETY TINA 4A(VER.D)
JOKAB SAFETY TINA 8A(VER.F)
JOKAB SAFETY TINA 1A
Alcatel OME 40 S
JVM Antriebe GmbH + Co. KG JV248-1800 AM1800Kgcm T-Nr0172583 M-Nr0314115 P1 3.60KW
rexroth A4VG125DA2DM8/32R-NAF02F071PP, SN:00171815
rexroth A4VG90DA2DM8/32R-NSF02F071PP, SN:00161978
rexroth YZ09-01-08-B8
rexroth A2FE45/61-VZL100
rexroth GFT26T2B37-01; 737008065914
rexroth VT-DFP-A-21/G24K0/0/V;
rexroth VT5041-25/3;MNR:R900749983;SN:E823571.031.0.6;CS:11110269
rexroth VT-VSPA1-1-11E/V0/0;
EMILE MAURIN 2021112X45
EMILE MAURIN 92-282-B40-S-11-BL
EMILE MAURIN 32-401-5
EMILE MAURIN 31-520-8-25
EMILE MAURIN 32-075-12
EMILE MAURIN 32-760-6-15
EMILE MAURIN 32-070-10
EMILE MAURIN 32-013-6
EMILE MAURIN 23-405-12
EMILE MAURIN 23-401-12
EMILE MAURIN 32-210-536
EMILE MAURIN 3203012
EMILE MAURIN 2021112X80
EMILE MAURIN 92-192-B40-B40-56-11-BL
EMILE MAURIN 92-146-B40-56-1-BL
EMILE MAURIN 210213-10X30
EMILE MAURIN 67703*32
EMILE MAURIN 32-230-616
EMILE MAURIN 31-500-6
EMILE MAURIN M6-DIN463
EMILE MAURIN 410207-6X35
EMILE MAURIN 20211B16X80
EMILE MAURIN 32-230-8-24
LAP 1HDL-HDL-00030
Meusburger E1695/30
Corino i=60 MVF49/P MRIDB3P600 FOR SOFTENING UNIT
herzog 2201-004-004
Corino Z=40 m=2 FOR SOFTENING UNIT
Tiefenbach M10 74X31X19
Tiefenbach WK17 48X85X35
Corino 25*34 BIKON 8000 MMIOC80020 FOR SOFTENING UNIT
merck BR13532
merck BR13532
merck BR13908
merck BR13908
Corino 28/38 S070031B FOR SOFTENING UNIT
merck BR13906
merck BR13906
merck BR12013
merck BR12013
Duplomatic HC2 F-160/70-2000-K0-S-21/2/20
BUCSH SB0140 D0 HO UCXX 0.7kW
HYDRO-LEDUC XP108 108cc/r 350bar
duesen-schlick 150.050.17
duesen-schlick 150.013.17
FUJIFILM Deutschland RPHE206A
Mival Fig.50 DN50 PN16
EMOD EEX-Z22B160L/2T,Nr.7384394
ROSSI GMBH MR2I40 FC1A 71C 4F.C.B5 R=1:9.41 1.04KW
UTC DP721R
Wieland 57.806.1053.0
Te.ma. srl MB801 D=100 0-6 bar DN 1/2M
JWFROEHLICH MFL200
Aris EF1-1 220VAC 30Nm PN40 DN20
JWFROEHLICH MPS250
Aris EF06,Nr.0940-74237-01004
Hubner-berlin HOGS 14 DN 5000R SN2150361 U=+9~26V
STAUBLI RBE 11-2103- VD/PP
STAUBLI RBE 11.6103
westlock 2249ABYONCS22AAA-AR1
tecsis TEP11*121802
Hoffmann TFP62 230VAC 18AMP
LEGRIS 1025U06 04
Hoffmann XR200426012 for NG100
LEGRIS 1025U08 03
LEGRIS 1025P14 04
LEGRIS 1100U08 04
LEGRIS 1025U06 03
BERGER LAHR LS 220921-00-01D
LEGRIS 1025P10 04
LEGRIS 1025P10 03
LEGRIS 7776 08 00
LEGRIS 3889 12 13
LEGRIS 3609 10 13 (REMPLACE 3679
KSB NORI320,ZXSV,DN15,PN320
LEGRIS 3608 14 21
KSB NORI500,ZXSV,DN15,PN500
LEGRIS 3889 12 21
KSB NORI320,ZXSV,DN32,PN320
LEGRIS 3166 08 14
PILZ SISWP
LEGRIS 3609 14 21 (REMPLACE REF
LEGRIS 3313 13 21
MP FHP0651BAG1A06NP01E7
LEGRIS 3601 10 13
MP FHP0653BAG2A06NP01E7
LEGRIS 0673 00 13
Norgren Silencer 1/4 for SINOARP CURING
ina KUVE20 L W2 V2 RRTF/420 - 40/20
ina KR 35 PP
INA ECROU EN TéMUM8X8 POS
INA MKUSE 25 ZR AL-1176-670-0
INA Retaining rings external 35 X 1.5
INA Ball bearing 6007 2RS1
VETEC VETEC 359 WCC DN23PN40 1.0619
OMRON S8JX-N10024CD 24V 100W
OMRON S8JX-ND1505CD 5V 15W
OMRON relay.8-0689C
OMRON E32-G14
Zero-Max Flex Disc-M/N6A45
Zero-Max Flex Disc-M/N6A90
CET S.R.L MVMC CET 202
A.O. Smith European Headquarters SD-020208-1 OD TYPE SHAFT SEAL 13.945 SEAL DIA*0.220
VOITH NO.H01162119
VOITH NO.H01019999
VOITH NO.H86003089
VOITH NO.H86003090
VOITH NO.H86002556
VOITH NO.410003694
AXXON A-L-K08
BAUMUELLER Impeller for motor :GDM 12Z-858/0400 Nr:00411855
BAUMER HUEBNER GMBH HOG10 DN2048I/74006G-3-HOG10
heidenhain 359 575-27
heidenhain 631 222-27
hawe EM21V-G24
NORMA COBRA 10.5/7 W4 11-12
NORMA COBRA 12/8 W4 12.5-14
Leonardo Leonardo Code D2000
Kendrion Binder--Germany typ:3343311A13 Nr:B00539/S4
BAUMULLER NURNBERG TYP ODF 90-S2 Nr.10104071
Black Box ACS253A-SM
ECKERLE EIPH2-011RK03-1X
BUSCHJOST 8432800.8404(230 40-60HS 45VA 0,5-16BAR
burster 2408-z006
Ravioli S.p.A ETLA61-4
Ravioli S.p.A ETL40MP4
PHD C5565
VEGA VEGABAR17 1430271/001
MARECHAL DS6,90A
MARECHAL DS3,50A
union Instruments GmbH UTS-4520305/E9/230V
rexroth 4WE6J73-62/EG24N9K4/A12B
Phoenix NO:1772104
Phoenix NO:1772094
FUJIFILM Deutschland AR30G3L green
T&B electronic GmbH BM6-2,Art.Nr.3130
T&B electronic GmbH H4/B4,Art.Nr.2200
T&B electronic GmbH FST-3,Art.Nr.3183
T&B electronic GmbH KK3,Art.Nr.3187
heidenhain 586643-03
heidenhain 586643-19
siemens 6SL 3054-0AA01-1AA0
micro-weld Anneal die lower bar M/N:Drawing No.62009
METREL Metrel Taster typ TL 410, Kode Nr. 1.10.140.00, Vorschub 2,3
micro-weld Upper toggle shoe M/N:32030
micro-weld Anneal shoe spring M/N:80005
micro-weld Mounting screw M/N:91028
K&N CH10 D-204V*06FT2
AREVA P344
Datapaq ORT-155-62
Datapaq SW5006-P
Datapaq TB0021
Datapaq TP2016
Datapaq TM21-OBRS
CONTITECH F60-XHP,60mm
Datapaq PA0054
Lenze MDERAXX-063-12J Mat NO.13047125 NO.06040043
Datapaq PA0056
Datapaq CC0051
COSEL NAC-06-472
speck DS-450.0021
speck DS-360.0700
Buehler NT63-KN-MS-M3/220;L=220mm,L1=25mm(20mA)/L2=185mm(4mA)
STAUBLI 31104900
westlock 3047RBYN00022F-ARI
Buehler NT63-KN-MS-M3/520;L=520mm,L1=25mm(20mA)/L2=485mm
Buehler NT63-KN-MS-M3/670;L=670mm,L1=25mm(20mA)
rueger S81
hiross-parker HDF-120-A
LUMBERG ASBS8/LED5-4
LUMBERG RST3-RKWT/LED A4-3-224/3M 24VDC M12X1 WITH LED
LUMBERG RKMWV4-225/5M 24VDC M8X1
KabelSchlepp UNTFLEX 0455
bucher AP1007D818
FSM Elektronik GmbH TYP.DPS S/N.00234104C
Norelem 03070-04
TRELLEBORG BP4900402 40.2*50*1.7 PTF
Calpeda T76E 3.6m3/h
HAWE BVG3R-G24-PYD
Groschopp Nr8052823
ASM WS10-1000-420A-L10-SBO-D8
Buehler EK2-G1/2-VA-M3/500/0-100℃
ranco LM5P7003
ranco L07-P1034-000
Parker CE016C04S00V
Parker CE016C04S00N
Parker C016CA08001099V
Parker C016CA08001099N
Parker PR25M175S1PN9XS02V
Parker PR25M17S1PV9XS02
Parker D31FH-B32C4 S00V
Parker D31FH-E02-C-2-V-S-00
Mini Motor MC230P3T 817710
himmel 601670050
Parker D41FH-B32-C-2-V-S-00
Parker D41FH-B32C4VS00
Parker D41FHB32E4S00V
Parker D41FH-E02-C-2-V-S-00
Parker D81FH-B32-F-2-V-S-00
hydac HN60-01-E 63 16/G 1/4B
STRAUB 37472060109
STRAUB 37472060109
vahle KK10-8AN Nr:142635
NORELEM NLM07560-03
IMC CI-ET
IMC CI-ET
Sauer danfoss ERR-130B-RP-21-20-NN-N-3-S-4-C-P-A-1-N-NNN-NNN-NNN
Sauer danfoss ERR-130B-PR-21-20-NN-N-3-S-1-N-P-A-1-N-NNN-NNN-NNN
SCHNEIDER SKR FIL092/25.5
ALTMANN DP113 Ze KL K12775 OHM:5K TOL:+-3% WEG;280°/360°
celesco PTIMA-50-FR-420E-M6-SG
rexroth HED 8 0A 20/200 K14S R901102727 250VAC 2A
MPFILTRI HP3203A10AN
AMA HPTDVB25V COMPLETE WITH 5L
ROTOCLEAR P1620400
Flowserve FV-24043 S/N:212249.002 P.O:4506732775
HAHN+KOLB 31950015
HAHN+KOLB 31950020
HAHN+KOLB 33172005
Stahl DH210.01B
CONTATTA SITME S.P.A. HIR M35X1,5
CONTATTA SITME S.P.A. HIR M12X1
CONTATTA SITME S.P.A. HIR M60X2
CONTATTA SITME S.P.A. HIR M45X1,5
CONTATTA SITME S.P.A. HIR M40X1,5
CONTATTA SITME S.P.A. HIR M15X1
CONTATTA SITME S.P.A. HIR M17X1
Baumer Group (THALHEIM) itd 21 a 4 y822048 tnikrlf141 p 5421
CONTATTA SITME S.P.A. HIR M20X1
Baumer Group (THALHEIM) itd 21 a 4 y821024 tnikrlf141 p 5421
CONTATTA SITME S.P.A. HIR M20X1,5
CONTATTA SITME S.P.A. HIR M25X1,5
CONTATTA SITME S.P.A. HIR M30X1,5
CONTATTA SITME S.P.A. HIR M80*2
CONTATTA SITME S.P.A. HIR M95*2
vahle DKSW 4/80 S-2
CONTATTA SITME S.P.A. GUK 50*1.5
REGLUS SET.NR.423B 0-360°
Hydac 0660R005BN4HC/-B6
METONE BAM1020 2.5cm 0.2 micron
Eberle Design Inc. (EDI) LMA-1250-LV
PINTSCH BUBENZER PB-Nr.008091700249 80634101
STAHLWILLE E3300520
STAHLWILLE E3300520
GEDORE 7691500
RHEINTACHO SHN9.GK00.K6
IKA C-MAG HS4
HAZET-WERK 2-12Nm 6391-12
HAZET-WERK 15-35Nm 5-50 6391-35
HAZET-WERK 50-200Nm 6391-200
HAZET-WERK 60-320Nm 6392-320
Elektromotorenwerk Brienz AG 90-MK-FA2/7.5KW/400V/50-60HZ
ZIMMER TPS 050/01
GEFRAN ACOME LPLA06DFRRV213 GEFRAN ACOME
R+W BKC 300-¢35-¢55
SNR USFD.205
SNR UC.205.G2
SNR UC.206.G2
coax MCF08NC 542893
coax MCF08NO 542894
coax MCF-H08NO 542895
coax MCF-H08NC 542896
LEESON 113021
LEESON 113021
heidenhain ID 531980-03 ECN1313-2048
waycon SM50-HYD-SG-SA-F18
waycon 1MCA-24V-10V
Sempell PT-3D-J
VIPA CP5-BG74
SAMSON 6111-01811/9040
Roehm GmbH K08 MK 4 ID.5469 0944 1766
VESTAS 107751
ott 95.600.001.3.6
OTT-JAKOB 95.601.014.9.2
OTT-JAKOB 95.101.993.1.2V06
OTT-JAKOB 95.250.032.2.0
RLS 08L318 LM10ICPRGAA50A00
OTT-JAKOB 95.600.467.9.2
OTT-JAKOB 95.600.497.9.2
Bremas Ersce S.p.A. E400-07TBM K
Hawe SWPN8-G-G24
Hawe MVE6B-350
rexroth 3842518058
rexroth 3842519004
Becker U4.100 Drawing.181 018302 26200
Becker U4.250 Drawing.76 727505 99628
WOERNER VPA-C18/P Nr:500291
Vulcan Refractories Ltd VULCATHERM V2 1581127
wieland 25.320.0853.1
FRER STV S 9 SB FOR AUX.XOLYAGE
VEM 0768369001711H KPER 112M2 TPM130 II2G EN 60034-1
ELTECOM s.r.o. 4 FP 153 22
ELTECOM s.r.o. 5 FP 153 27
ALTMANN D32001 DP113 Ze Si KL K12775
Schenck Process GmbH type.pws D1 Emax=100kg Cn=2mv/v P/N.V058895.B04
DANAHER AKM63N-ANCNR-00 SR072519087
Schenck Process GmbH TYPE. F3210343013006 SER-NR.692298 200KG SIANAL. 0-10V
INTERNORMEN HP.171.10VG.30.E.P. -. G.5.40
INTERNORMEN TEF.625.25VG.16.S.P.-.FS8.-.E1
INTERNORMEN HP.361.10VG.30.EP-.G.5 - - AE
alco TX6-N16MM-PCN801669
VEM KPER 112 M 2 TPM130 NO:0768269001811H
Gressel walrus code grip 5A-100
ELAU SH070/60020/0/1/00/00/00/01/00
parker WV10L0MDA3C
SIKO IG06-0732
ifak isHRT USB HART USB interface L46
wandfluh WDPFA06-ACB-S-5(-G24)
Woerner WYKJD220-550 S/N:SO47YKJD220550
BRINKMANN TH180/760+001 NO.0210805172-27720003
rexroth REXRO_R0442_813_01
rexroth REXRO_R0445_803_31_72
K. H. Brinkmann GmbH & Co. KG KTF 25/270-X+053
Friedrich Schwingtechnik GmbH F150-4-2.4
AKEMI 12M ART-NR.90610
VibraSens VS_125.01_mA
JOLA HMW/1
maxon 43.032.000-22.00-133
bedia cls-40 NR.318159
ROEMHELD 3829-201
ROEMHELD 3829-201
dunkermotoren 3 42*26 u15 V S/N.88632 01005
SKF HSK100-1GZ
SKF HSK100-1GZ
INDUGA 24vdc G1/4 0.01-2BAR 10232H-DD30AO
EUROTHERM 2500B/S04/C04/ENG/XXXXX/XXXXX
EUROTHERM 2500B/SOO\NONE/ENG/XXXXX/XXXXX
EUROTHERM 2500E/S/8L00PUWIPROFIBUS/CFGKEYxxxxxx
EUROTHERM 2500T/IOC/S/PROFIBUS/RJ45/XXXXX
EUROTHERM 2500M/AI2/XXXXX/XXXXX
Dynamotor De Coster ESCF200-DT5 05010338
EUROTHERM 2500T/A12/UNIV\NONE
EUROTHERM 2500T/D04\NONE
EUROTHERM 2500M/DO424V/EXTPWR/XXXXX/XXXXX
Ensto Group KKB4.16 2519702
PILZ Order Number:779220
AUMA SAH07.1-125A
Amazon 84012UHN30C1EV02
WESTLOCK 2007XBYN-RS
Reckmann 2*NiCrNi TYPK φ3 L=1400with φ9*1*300
Ge measurement&control solutions 666501 msc sep 372-000501 ge
WIKA WIKA TRONIC LINE 891.23.510
Baumer BFG 0G.24P360/403559
hydac EDFR-BN/HC-160-G-20-0-N without indicator
hydac PFM-1-G-0-V-0 without indicator
hydac PMRF 1 E/1D10 40F00 without indicator
VEGA WEGAWAVE 61.XXANDRKMX
ELSO Elbe 0.107.133-0.14
IPF KN180 /120 M 18X1 10-35V
ELSO Elbe 0.11.45013.03G
Heidenhain 586646-10
INA RWU25DFEG2
WITT 077.001.NV V 0237
VEM K21R 100 LX 4 3KW Nr.232410611
SITI FC90-4
Magirus 500269843
Magirus 500269825
Magirus 41737500
Magirus 41635051
Magirus 41630037
Magirus 41630039
Roemheld 1942-000
HUBNER TDP0 2 LT-4 60V SER.NR.L.1636129
HUBNER POG9D 1024 +9…30V SER.NR1644611
ALFA 24K PN40-641 DN40 G1/2IN
ALFA 24K PN40-641 DN32 G1/4IN
M+W Instruments GmbH MFM D-6270/LDP SN1709-12C13295-D
baumer GBMMS.420EPA6
HYDROTECHNIK HT-PD 3403-15-D5.39
heidenhain ERN1020 1000 01-03 IDNr.317 750-06
SCHENCK DN25/G1/0-10BAR/8254401.9150
Calpeda A50-125-CE
HBM F3210343013006 SER-NR 6092298 MESSB 200KG
weishaupt DK 08/F2 652020
FISCHER DE45560041PK03MW
TECNINT HTE input card TSR20
TECNINT HTE output card TSR31
Flex
RELAY GmbH RJ1A60D90EP
RELAY GmbH RJ1A60D70E
MINIMAX FMZ4100GAB24
MINIMAX FMX3501 EX BG
LEBER HP3201
Dickinson 150,050,17
Dickinson 150,013,17
MAYSER SL/WL.2/L=2150MM/GP50CR--3017532
Rotor Elektromoten UD 0810/1176744-014-3 5RN63M08
TR LA46H profibus-DP Art Nr:321-00173 0.005mm
HBM HH76461/20T
HBM C16BD1/20T
Voith Volth Turbo MTS EM61D 10/1S
EMG DIMR 30-B3-16 SN:266730
IBA-Automation GmbH PDADPM13.121000
SCA 529.0088
SCA 503.0537
SCA 508.1026
Helios AB32-10/1E230 32601012
IBA-Automation GmbH ibacom-L2B-8-8
IBA-Automation GmbH 30.610240ibaPDA-V6-1024
systec Controls Mess- und Regeltechnik GmbH DF44FDCF 10320-02 9.8BAR 210degrees Celsius 614MM 8MM
Ringfeder 992771 RFN 8006 160x178 STEEL
W&H PN.35004001 MESC Code.4453754483
WALTHER-PRAEZISION sp-006-0wr017-11-2
WALTHER-PRAEZISION sp-006-2wr017-11-2
MOELLERS PN.02814068 MESC Code.4453751223
Peter TX1000 440/220-60HZ 3108-1994
SICK STEGMANN DGS66-HAZO-S01
KSB H222H 3G6K6VC DN80 PN10
Dopag 20029050/0 C-505-10-71
E+H FMR250-A4(D)E1APJBA3K
TELCO LT110TB58J
FISHER DVC6020 0019332044
FISHER DVC6025 0018289546
ElektroPhysik MINITEST 730 Resolution:0.0001
FISHER 4211 4-20MA 19521826
Staubli SPX06.1152 G3/8
Staubli SPX06.7152 G3/8
TELCO LT101SG5
TELCO LR101SG5
TELCO PA10/503
Nadella GmbH RKUR75A00 PATENT-500
Antriebstechnik KATT Hessen GmbH K21 NR 617 855
Lust Antriebstechnik GmbH FLP11/0045-30AN1 ORDERNR.714832 FABNO.0907143 ARTNO.68000815
Absolent 1S1/914 92110901
Absolent 2S10B3/914 92110903
Absolent S1/650DB 92110702
Absolent HEPA H13 595X292 92630606
Absolent HEPA H13 1000X914 92630906
Lust Antriebstechnik GmbH 1-100835-00006 182-02764
HPI P1BAN2008BL10B02N
POCLAIN HYDRAULICS GMBH MSE05-2-113-R05-2A50-EHKO CODE.005343847E UP00015616
ASM Gmbh 26-E96800 LM GUIDE MODIFIED 24-00541 IS868LA2
SIEMENS 7MF4033-1FY00-2DC6
SIEMENS 7MF4920-1SJ02-5B
SIEMENS 7MF4433-1FY02-2DC6
SIEMENS 7MF4923-1SJ02-8B
SIEMENS 7MF4433-1FY02-2DC6-Z=A01+Y15
SIEMENS 7MF4923-1SZ02-7B V03 K1Y:GOLD
SIEMENS 7MF4433-1EY02-2DC6
SIEMENS 7MF4433-1FY02-2DC6 H=3.0M L=8.0M
SIEMENS 7MF4923-1MA01-9B-N1Y
SIEMENS 7MF4433-1EY02-2DC6 H=3.0M L=5.0M
SIEMENS 7MF4433-1EY02-2DC7 B16.5 300LB 2"RF
SIEMENS 7MF4913-1ZA01-6B-J1Y
SIEMENS 7MF4033-1EA10-2DC6
SIEMENS 7MF4033-1FA10-2DC7
SIEMENS 7MF4433-1HY02-2DC6-Z=A01+Y01+Y15
SIEMENS 7MF4923-1ZZ02-6B=J1Y+K1Y/J1Y(H:3"C600.L:no flange)K1Y:gold
STROMAG HS2-2048
SIEMENS 7ME4100-1CD11-1AB1
SIEMENS 7ME4110-2CA20-1AA1
SIEMENS 7ME4100-1FC22-1AC1
SIEMENS 7ME4110-2EA11-1AA0
SIEMENS 7ME4100-1GC23-1AC1
SIEMENS 7ME4100-1FC22-1BA1
Clifford & Snell YL50/D50/R
AERZENER GM 10 S
AERZENER 153485000
AERZENER 119688000
AERZENER 175239000
AERZENER 161386000
AERZENER 160755002
AERZENER 1727844000
AERZENER GM 15 L
AERZENER 163548000
AERZENER 123276000
AERZENER 172783000
ZELO Typ: GSV-11H; Nennspannung: 24,0 V 49112
KERN Typ KTP150; W?gebereich 150 KG NEU KFP 150V20 NLM
BOHL Typ: FLANSCH-KOMPENSATOR EINTEILIG
siemens 6GT2000-0CA10
KANT 802-100-2110
KANT 802-200-2110
Atlas 1621865100
Atlas 1621875000
Atlas 1621-5743-99
BUSCK ME100LA4 B5 1111-035 460
Wuerth 71442032
Wuerth 71442032
Wuerth 71443033
Wuerth 71443033
Wuerth 71442026
Wuerth 71442026
Wuerth 71442028
Wuerth 71442028
Wuerth 7144201
Wuerth 7144201
Wuerth 7144201
Wuerth 7144205
Wuerth 7144205
Wuerth 71469201
Wuerth 7032340
Wuerth 7032340
Wuerth 585805280
Wuerth 585805280
Wuerth 67203060
Wuerth 67203060
Wuerth 583576120
Wuerth 583576120
STAUBLI Modul No.male part:34.0192
BERNSTEIN 6607921353 KCN-T18PS/012-KLPS12V
RSF Elektronik Nr.24829223 17 MS 6075-3GK H7 SIGNAL OU 5V
siemens 6FC5 511-0CA00-0AA0 62800210986 9707035 RS00
siemens 6AV6671-8XB10-0AX0
Gestra BAE46 DN25 PN40
SCHMERSAL T4D064-21Y-R r=2x90-M25
Socafluid MK.3V.06.14 0-6BARS
Socafluid RA30 12 38 3/8 D=12
Socafluid RA12 38 38 M/M 3/8
Socafluid RA025 18 18 1/8
Socafluid MV 11 00 18 1/8
Socafluid RA 22 14 14 1/4
finder 99.01.0.230.98
finder 56.32.8.230.0000
Siemens 1FL4044-0AF21-0AA0
HEITRONICS D65205 WIESBADEN KT15.82IID 0.3S 150°C 24V
Lenze EVS9325-EP
Lenze EVS9325-EP
MONTECH US/USE-1/2 nr:505102
Herion DBS10HG70001300 6015321000000000
Herion DBS25HG70001200 6015389000000000
Herion DBC6HS470001100 6014199000000000
PHOENIX NS 15 PERF 250MM
vahle DSWK 4/80 S-2 hs
Mahle PI 0121 MIC/UM/TS/PUTZMEISTER 7.932.668.7
DROPSA 234250R40
STEINEL BHG360
STEINEL BHG360
INTERNORMEN DU1050.40G.10.B.P.-.FS.B.AE70 01NR1000.40G.10.B.P
INTERNORMEN DSF3605.10VG.10.E.P.-.FD1.D.-.AE70 01E.1201.10VG.10.E.P.-
INTERNORMEN DSF6005.10VG.10.E.P.-.FD1.E.-.AE70 01E.2001.10VG.10.E.P.-
INTERNORMEN DSF2405.40G.10.E.P.-.FD1.C.-.AE70 01E.1201.40G.10.E.P.-
INTERNORMEN HP450.10VG.HR.E.P.-.FS.7.-.AE70 01E.450.10VG.HR.E.P
INTERNORMEN TEF210.10VG.16.S.P.-.G.7.-.E1.O 01E.210.10VG.16.S.P
INTERNORMEN DTEF.320.10VG.16.S.P.-.G.7.-.E1.O 01E.320.10VG.16.S.P
INTERNORMEN DTEF.320.25VG.16.S.P.-G.7.-.E1.O 01E.320.25VG.16.S.P
Magnet-Schultz WZAW 080 X00 D15 2264986
01E.631.25VG.16.S.P DTEF625.25VG.16.S.P.-.FS.8.-.E1.O 01E.631.25VG.16.S.P
INTERNORMEN DTEF625.25VG.16.S.P.-.FS.8.-.E1.O 01E.631.25VG.16.S.P
INTERNORMEN DTEF952.25VG.10.S.P.-.FS.A.-.E1.O 01E.950.25VG.10.S.P
INTERNORMEN TEF952.25VG.10.S.P.-.FS.A.-.E1.O 01E.950.25VG.10.S.P
INTERNORMEN TEF952.6VG.10.S.P.-.FS.A.-.E1.O 01E.950.6VG.10.S.P
INTERNORMEN HP61.6VG.HR.E.P.-.G.4.-.AE70 01E.60.6VG.HR.E.P
INTERNORMEN US321.10VG.10.B.P.- 01NR.1000.10VG.10.B.P
LEINE&LINDE 533899-01
INTERNORMEN DU1050.40G.10.B.P.-.FS.B.AE70 01.NR1000.40G.10.B.P.-
hawe V30D-95BKN-1-0-03LLS
INTERNORMEN DU635.40G.30.E.P.-.FS.9.AE70 01NL.630.40G.30.E.P.-
INTERNORMEN DU2050.10VG.10.B.P.-.FS.B.AE70 01.NR1000.10VG.10.B.P.-
hawe R 8,4
INTERNORMEN DSF10005.10VG.10.E.P.-.FD1.E.-.AE 01E.2001.10VG.10.E.P.-
hawe PMV4-43-24
01.NR630.40G.10.B.P.- UM80.40G.10.B.P 01.NR630.40G.10.B.P.-
hawe MVP4BR
PARKER MC27A8510
ELETTROTEC LM1FA300-T60
heidenhain LS1378C ML 419 mm ID737751-08
ELETTROTEC LM1FA200-T60
Speck TOE/CY-6091.0367 Nr.50HZ 207994
GMC SINEAX U539 \ 0-100V 50Hz \ 4-20mA
EBM R2D190-AC22-12
EBM R2D225-AT26-15
PMA KS40-100-0000F-000
EBM R2E220-AB06-54
Brusa NLG513-U1-02A
kuebler 8.7231.8852.1024-DC24V
LECHLER 212.004.17.AC
EPRO PR6424/010-140 CON021\EPRO
FLOWTEC KHN7314
FLOWTEC KHN7314
Ashcroft Instruments GmbH 45-1279-SSL-04L 0-8509SI
Ashcroft Instruments GmbH D-52499/100=F5503=S=50=L=0/AN=CS=SS=PN100/0-30PSI
Ashcroft Instruments GmbH D-52499/100=F5503=S=50=L=0/AN=CS=PN100/0-50PSI
SCHLEICH GLP2-e/HV
HBM K-U10M-50K0-SB-N-1-S-N-U-
ERICHSEN 234 R/II(0-50um)
fibro 52.81.2.501
fibro 52.25.3.0050
H.Schreiner LPC 850-6476A 4Bar
H.Schreiner LPC 850-6477A 200mBar
Oilgear PVG130E1BVLDF1P1NN/H050NN--BN ID:02489601
loher anga-225se-04m
loher anga-250se-04m 3348064
schunk 10359037
schunk 10359037
STENFLEX R-1 DN40 rot-DN40/PN16 part no.13136010-00
STENFLEX R-1 DN65 rot-DN65/PN16 part no.13136030-00
STENFLEX R-1 DN80 rot-DN80/PN16 part no.13136040-00
hydac EDS410-060-4-062
fibro 2131.15.012.036
fibro 2131.15.016.036
fibro 2131.15.020.050
fibro 2131.15.024.050
fibro 2131.15.030.065
fibro 2131.11.020
HOERBIGER HCM-370-PC04-P Pmax=320bar 486-0078.509 0301/01
fibro 2131.11.024
Hegwein ZTO-132W ERDGAS 50~150~mbars ac220~230v 100va
heidenhain 290079-16
heidenhain 312211-03
KRACHT KF3/63 F10B NOA 7GP 55/153 WITH KUPPLUNG
KRACHT RA38-Z45/38-Z45/38
HEIDENHAIN AE LS 323C 310728-20 E A3
schmersal AZ16-02ZVRK-M16
schmersal AZ15-16-B2KPL
staubli C type 3/4"
STROMAG SHD5W-1-EF3-1
staubli C type 5/8"
NORELEM 0 3199-10200
staubli C type 3/8"
DRUAG MVD507 500mbar
staubli C type 1/4"
staubli C type 1/2"
Steimel 5AP90S-4 666698
Magnet-Schultz GDAY 05C X20 B23
CALPEDA MXV32-418 Q MIN/MAX 2.5/8 m3/h H MAX/MIN 187/68 M n 2900/mi
WEISS OT6S-140DSL12 WITH DISPLAY MODULE
WEISS WT6S-160DSL12 WITH DISPLAY MODULE
schmalenberger GmbH+Co.KG K32R200L3DSD FDS-SR/10040,Nr.0867532040002
VEM F2F40.13/2,2010001329/10
Montech GPU-14
huebner OG71DN-1024TTL
Wieland G3PB-215B-VD
knoll TG32-09/75400
Wieland SNZ4052K
Wieland SNZ4052K
knoll KTS40-96-T
Wieland SND4003K
Wieland SND4003K
Wieland SA-IN-S1-K-A DC 24V
Wieland SA-BM-S1-4EKL-A 5S DC 24V
Starmix GS-3078 220V 3600W
siemens A5Q00001644
ADDA FC 71 FE-4 Serien-Nr. B1 302862
kraus&naimer AT11G CG4 3 file transfer switch Without the key
LUMINA F0-150
PUCEL LK3000HAB/400 R134A 2935W 400V+
KSR Kuebler AEV-M65(ASEPTIK)-VK5-L245/14-SV
banner SM312FPQD
Universal Hydraulik GmbH EKM-505-T-CN-UH 10000008924/84195000/81 ABZ-10015945
mono C15KC11RBM/M372
mono C16KC11RMB/M371
GEFRAN 1000-R0-3R-0-1
internormen 02.0950.10VG.30.HC.S.V
internormen 02.0950.6VG.30.HC.S.V
Avery Weigh-Tronix 17960 - 0010
Rittal GmbH & Co. KG SK3218.109
Erhardt+Leimer GmbH Typ AG2591 N210896 V-24V DAI=2.9A 25mm
Bosch-Rexroth R911295322
CAREL code:RITCUSR001 ,ROHS:255737 , S/N:007319
STOBER C402N0310MR30(1659840)
Rexroth 4WE 6J51/AW110-50NZ4V
PRODAN GmbH 59-06-8600-D=45-D=45-MS
DATASENSOR S5-B3-87 10-30VDC PN8 OUT 150MA with mirror
EGE 400-STS-104-S-P11167
BURKERT W38LU 0124C 4.0 FKM.PD Nr:00019078
FAT DR 255-3-3035,PMAX:0.8MPa
ALTMANN DMG 18/05 Zelt me
STM RMI 85 S SEF 90BS
MUT Stockerau BG50-11/D09SA4
GSR AU610549, G1 DN25,SS304,0.3-20Bar
HERKULES 86310 FC3101-4 FC2001-4A C9900-A159-1
MRW New operator and panl 70013
MRW special packing operator 8113
MRW MRW Vib Control 04 990004
MRW customs documents 990037
Ravioli E TLD18A1-526
parker FM.26-132-312
hydac HMG 3000
SIEMENS 6FC5403-0AA10-0AA1
NORD SK63L/4 0.18KW 31719400 12830807
R+W Antriebselemente GmbH BKL10/10/12/PFN D1=10H7-D2=12H7mit DIN 6885
balluff BTL7-E170-M1500-B-S32
AFL s/n.59948-06-08.01 typ.E315/100-25M-B GL360
kaltleiter MOT.3-TFCP 80B-4 0.75KW 25.72020539.15.0002.11.45
AFL S/N.59948-06-08.02 TYP.E315/100-25M-B GL270
TELEMECANIQUE XPS-AL/SerieB Ref. XPSAL5110
ALTMANN DMG 18/05
Cognex 335-112694
Cognex 335-112693
VISHAY PhMKP 550-30IBR
herl DN6-40 PS28
Stieber CSK30-PP-2RS-C3
Beck GmbH 901.10111D4 5-200mbar
FAG FAG 29272
FAG FAG 29272
Kraus & Naimer AT11U28755/000400 A178
Beck GmbH 901.11111M4 5-200mbar
Bieri WV700-6-2/2-VO-24-P-A*00
Beck GmbH 901.11111Q4 5-200mbar
Rexroth R412006273
Rexroth R412006273
VEM K21R 160L4 KR VL HB HW Nr:108428/0002
Rexroth R412006289
Rexroth R412006289
Rexroth R412006279
Rexroth R412006279
Rexroth R412006232
Rexroth R412006232
Rexroth R412006251
Rexroth R412006251
Rexroth R412006257
Rexroth R412006257
Rexroth R412004417
Rexroth R412004417
Rexroth R412007979
Rexroth R412007979
ARMSTRONG 2415HLAR
Mitutoyo Deutschland GmbH 572-600
Bieri WV700-6-4/2-D-24-P-A*00
R. STAHL 8581/21/507 and need supporting plug
R. STAHL 8581/21/407 and need supporting plug
GAT E80
ARI-Armaturen Albert Richter GmbH & Co KG DP32 DN20
ARI-Armaturen Albert Richter GmbH & Co KG DP33 DN20
ARI-Armaturen Albert Richter GmbH & Co KG DP34 DN20
ARI-Armaturen Albert Richter GmbH & Co KG DP34T DN20
Kendrion KOM929 A7 WS6B/29 230V 50HZ 110VA S=1.5mm S100%ED
Cavotec GSK 03.04-98.12-340-KL
SIEMENS 6SE7012-OTP50 F2UD013431
SIEMENS 6AV65450DA100AX0
SIEMENS 6SN1123-1AB00-0HA1 GWE566018901070
OMAL D424405
BIRKENBEUL 5AP80M-4K 380V 50HZ 0.55KW 1395RPM IP55 B5
OMAL S424405
OMAL D424408
OMAL S424408
OMAL D161005
OMAL S161005
westlock 2249ABYNOCS22AAA-AR1
Elster A17000 3P4W; 3x1(1.2)A; 3x58/100...240/415V, class 0.5s; hav
Schonbuch TX18 3014 BK-PNP/N0 WH-NPN/NC
ITV ITV-2050-312N-X153 (0~10VDC 0.005~0.9mpa)
VSE VSI 0,04/16 GPO12V 32W15/3 10..28 VDC
VSE VSI 2/16 GPO54V 32W15/4 10..28VDC
SIGMATEK DT0161
SIGMATEK DKL042
herion 146 040 210
herion 146 040 210
NANOTEC PD3,5-T5618C4004-D23-04 A-NR.A401954 SERIAL NO 843 684
BEP 2214039
SIGMATEK DDI161
SIGMATEK DCC080L
SIGMATEK DKL091
Bihler 100-08-0662.012
INFICON GmbH VSA100A
SIGMATEK DKK023
CS Valve INC CSPSCS2121500561 DN65
tuenkers 202806
tuenkers 202805
CS Valve INC CSPSCS101500563 DN10
bucher UP100K4G2-01/AP100/4.3-CN
ABB 51111.318.162 16A(10A) 250VAC MM:10012462
SBA-TrafoTech GmbH DGPT 3×360V-500V DC24V 40A DC
keb Art.-Nr.12.SM.20X-62XX Nr.205180
emoteq QB01701-C04-H NO.040622 Q37
Wandres INGROMAT SPRAYER SQ46 1227-727
K&N DH11B A295 600EF
K&N DH11B A791 600EF
SIEMENS 1LG0166-2AA70-Z 1011/800004797606/014
brevini EM1046/MN1/5/00 i=5.17:1
heidenhain 329992-85
Datalogic TL46-WLF-815/09(9MM)
ELETTA S2-FA65
brinkmann 3LASEOSI-S00081( SFL1150/460+001 Pump Accessories)
MEN 0751-0008 128MB
MEN 0751-0009 128MB
MEN 01A012B00 A12
MEN 01A012B00 A12
TWK VP12
B+S B+S AT 80 96 8
B+S B+S AT 80 96 8
Siebert S102-W6/14/0R-000/0B-TM
elbe 0.109.400.0201
B+S B+S AT 45 58 7
B+S B+S AT 45 58 7
COAX RSV12
BANNER OTBVP6LQD
ALSTOM RELAY 0.002-1 ION, VX-48P220C00F11100 VDC
Barksdale DIH-A80SS
ALSTOM RELAY, VX-48-110VDC, P343212E2B0060C
FEMA TH-D26-417 0.2-0.6bar
ALSTOM RELAY VX=48-125 VDC , P444212B2A0070A
ALSTOM RELAY, VX=48-110 VDC 30-1P541212E2A0120B
Barksdale DIT-A80SS
ALSTOM RELAY, VX=48-250 VDC , P83284140B2BF6921
ALSTOM RELAY, VX=48-250 VDC P63284140B2C6921
ALSTOM RELAY , VX=48-250 VDC P63384140BCBF6921
ALSTOM RELAY VX=48-150 VDC P9230ASF111
ALSTOM RELAY, 24-125 VDC KAVS10001L12JEM
ALSTOM RELAY, 110-125 VDC PRS12N04TH
ALSTOM RELAY, 48-150VDC, MICOM P12, P121A00F111
ALSTOM RELAY, 48-150 VDC, MICOM P12" P123A00F111
ALSTOM RELAY , 48-150 VDC, MICOM P92 , P9210ASF111
ALSTOM RELAY, 48-150VDC, MICOM PP225CA0F111A2
Barksdale T2H-H251(-73℃~-149℃)
ALSTOM RELAY, 48-250VDC, MICOM P6313400040AH00E00
ALSTOM RELAY , 48-250VDC, MICOM PP323491194AG00E00
ALSTOM RELAY , 64-300VDC , MX3DVZ3A- MX3DVZ3A.72
IPF MZ07A724
parker H06-1039
Absolent 92110600 S3/595 ODF/A-Mist
GE Healthcare blades-IR/50 QTY:50
BONETTI SGA0334
STARLINE 113-S6S-6
asosafety SK41-32 RLU
EOPCOS B43310A5568M
E+H M FMU41 ARB2A2+FAU70E 1547
E+H PMP75-ABA1M21YYABE1
REXROTH R900925642
REXROTH R900925642
REXROTH H-4WEH 25 J6X/6EG24N9ETK4/B10D3
REXROTH R901278744
REXROTH R901278744
E+H PMC71-ABB1P2GAAAA
E+H PMC71-ABB1S2GA2AA
E+H TR10-AAD1BHRXH3000
E+H 50103479
E+H 10507976
E+H 10494663
E+H 10494665
NORGREN S/ 1340/ 8
NORGREN 8.04E+15
NORGREN 3063702
NORGREN V61 B4D7A- XA090
NORGREN 9037700.0156.02400
SCHENCK D726176.04
HACH 09135=A=0020
HACH P/N:08362=A=2000
HACH 2760345
HACH DR2800 P/N:LZV611
Buschjost 8274114.9136 TUV 06 ATEX 553414 X
Hydac FCU2110-1M with REU
REXROTH R900909245
REXROTH R900909245
REXROTH LC 32 A20D7X/-004
REXROTH LC 40 A20D7X/
REXROTH R900425661
REXROTH R900425661
REXROTH R900424158
REXROTH R900424158
REXROTH ZDB 10 VA2-4X/315V
REXROTH R900593530
REXROTH R900593530
REXROTH R901086052
REXROTH R901086052
REXROTH R900483371
REXROTH R900483371
REXROTH R900587559
REXROTH R900587559
REXROTH R900587560
REXROTH R900587560
REXROTH R900407394
REXROTH R900407394
REXROTH R900407424
REXROTH R900407424
REXROTH R901148053
REXROTH R901148053
REXROTH Z2S22B1-5X/
REXROTH Z2S22B1-5X/
REXROTH R900328797
REXROTH R900328797
REXROTH R900344919
REXROTH R900344919
Buhler NT64ej-MS-S6/370/2KT70NC/MAX.1bar/80
Kulite ETM300-375M 1.7bar
Kulite ETM300-375M 17Bar
Kulite ETM300-375M 140 bar
PAVONE SISTEMI DAT400
Kulite ETM300-375M 210 bar
Kulite ETM300-375M 120bar
Kulite ETM300-375M 7bar
Rico-Werk Eiserlo & Emmrich GmbH SD25ST-SD25BU NR.584810 2m
Rico-Werk Eiserlo & Emmrich GmbH SD09ST-SD09BU NR.584812 2M
Rico-Werk Eiserlo & Emmrich GmbH 545747 duplex
MOOG D123-075-A013b/UNS-18001-202
rexroth CDT3 MX2/100/70/25Z20 B11HEUSWW
rexroth CDT3 MX2/125/56/25Z20 B11HEUSWW
Twiflex Ltd LA12142/60FH A34078
CARLOGAVAZZI DIB01CD485A
AMISCO EA/MA22/24V/3W
tecsis GmbH 55T F53084540006-1.03
FUCHS CHEMPLEX 710 we need 600L
FUCHS CHEMPLEX 710 we need 1800L
FUCHS CHEMPLEX 710 we need 7200L
Kuhnke M5*3 50.130
Kuhnke M5*3 50.130
Kuhnke MSM 6/55261 GTAF 032N20A01 100% ED 24DC
igus 1400.068,100
Schubert & Salzer GmbH BM24C/IOS-R ARTIKEL.4064191 s/n.1244860001/2
Ephy Mess GmbH XESWT-EM24 4-20mA,8000mm,EL=30m
kraus & Naimer CHR10B1DD929 KD1
WOODHEAD microenble Ⅲ
WOODHEAD CIO-QUAD/4
Stabilus GmbH LIFT-O-MAT 094331 0400N
WOODHEAD PCU-DPIO V4.6.3
kuebler 8.7231.8852.1024-DC24V-1024
kuebler R1-43H3858-281024-C-DC24V-1024
fanal FF4-4DAH-G 0.22-4BAR
ANKER GETRIEBE 042079 CA43 47192
voith EM61 D 1O/1S;61.1.21.9.01 10672530
HERL T5F DN40 PN40
ZOLLERN Slewing mechanisms Zollern ZHP 3.27
NORELEM 03199-10200
Ashcroft 593-53
VISHAY CAM130/N24-00-0-8WSE
systec Controls Mess- und Regeltechnik GmbH IT9000
systec Controls Mess- und Regeltechnik GmbH CPU 10CPU002
Avintos MTB-632-CNP No.060 4525081
igus 14.3.75 L=1050(Includes a pair of connectors: 14.3.12PZ)
IGUS 340.175.100.0 L=5800(Includes a pair of connectors: 3175.12P
KRAUS & NAIMER KG 41 T204/D-A003 PFD
Telcomec 24V.C.C.03008
KRAUS&NAIMER S-6832-600EL1
Contitech S-125-SX-33CE-GIK L=11M B=105MM
jahns MTC-2-1-6-A180 2GS-4501383060 D0-112955020-99970964441030
Contitech S-125-SX-33CE-GIK L=12M B=180MM
Contitech S-125-SX-33CE-GIK L=18M B=180MM
SNT UP 1000PVPS24IS
Spohn + Burkhardt ROE8G5-30VDC
DELIMON D2819
htt STB-R-230 110-240V AC 4A 0-280℃
igus CF300.UL.350.01.D
igus CF9.25.25
igus CF35.UL.250.04
igus CFLG.12G.62.5/125.TC
igus FLOATING HEAD
igus P94.31.HRP.01.E
igus P94.30.NR.01.E
Ebm S3G500-BE33-01
K&N CA10-A214-600-FH3-G411
K&N CA10-A214-608-FT2
SCHNEIDER LC1BR33M22
k&n CA10-A230-614-FT2
leine & linde 685004211 12605295
Robatech 114896
Robatech 115471
norelem NLM03030-04 Spring-loaded pressure piece M4*10mm
BEI IDEACOD und BEI TECHNOLOGIES INC. DHM5S10/DGSI/1000/GIR/22/VF
WATLOW PM 6L,1AJ-AAAAAA,120-240VAC,50/60HZ, 10VA
Eltra EH115A1024Z8/24L/1024Z8/24L11X3PR
Hyvair 2AH-C1/C3 AC110V
Jahns MTO-2-6-RVL180
Jahns MTO-2-8-RVG
Borries Markier-Systeme GmbH 233.727.010.4c
Pallmann Order no.:117511 machine no.:0891.2007.0008
Bonfiglioli VF/VF 30/49 P1 600 P63 B14 B3 CW4
pizzato FL525
KEB ARTIKEL-No 12.SM.20X-62XX ,Nr:205180
ebmpapst 40*40*10 24V 0.1A 414 F
TRAFAG 900.9172.850
ROHM MT4 MK4 K08H ID:5469
Valvole 125/28.1
heidenhain 557645-01
Beckmann Elektronik GmbH 0FS 1000-400/230 1KVA 400/230VAC
VEM K21R100LX4KR 01T1S000110211 IP55F
JABSCO JABSCO-24950-2310 NO:25696
ILME GmbH 310109-33 24 PINS 1-24
Rexroth MNR:R900731499, 4WS2EM10-51/10B11ET315K310V
ILME GmbH 310105-33 24 SOCKETS 25-48
SEW SEW-R57DT90L 1410r/min116.79 Nr.25.25.1204740.5.10.001
woehner 3573
woehner 3531
Renold A2060X25P C4F4(2060 L*25P) L=952.MM
Nilos 33212 AV
Havells Sylvania Germany GmbH CCD light sources-65W12VDC
VIBRO-METER 913-402-000-012-1-090-0-0
MAPAL KS 63-08 0.005.52.495.00
Tollok TLK 200 (Diam.=25XDiam.=50)
TOLLOK TLK 500 (Mt=550Nm Tightening torque 17Nm) D60d30L60
WENGLOR 113-232-202E10
TOLLOK TLK 500 (Diam.=20xDiam.=50)
STOCKO mkh5131-1-0-200
COREMO A3N, Code A1872
Chamberlain GmbH DKN100240440CN (0.37KW400V) 1580
elco NI15-M30-OP6L
LINE&LINDE 861-028456-1024
BARKSDALE BFS30-N 20-60L/MIN 20-60L/MIN
BARKSDALE X1T-4000-10/K214295-001 15~100BAR Screw fixed
turck PKG3Z-2-RS 4T/S90
bitzer CSH7561-80
bitzer CSH7561-80
bitzer CSH7561-80
bitzer CSH7561-80
bitzer CSH7561-80
mini motor PC 440M3T i = 30 B5, P=180 W n2=93 M=14
AGR Europe GmbH ASSY,Valve,servo,item code:8159212
AGR Europe GmbH Filter,cartridge,item code:2002692
DEUTZ AG 0001 230 006 2V 1580 for BF6M1013EC or BF6L914
murr 87766
murr 87766
KISTLER 1708 A0 Q100
KISTLER 1710 A0 Q100
vahle 1064-12636/0
KISTLER 6182B Q100
KISTLER 1712 A0 Q100
KISTLER 1714 A0 Q100
ENERPAC ENERPAC CR400
Legris 18270600
Legris 18240800
Legris 18100800
Roemheld 3887-066 (max.350bar)
Rotork IQML12F10A5010-100
hainzl 247341
rexroth MNR:0821300350
SAMPI SM_07B_0100
INA KUSE45W2G2V2/1200
hawe MVE4E
Kueenle 291146311102 KDGN2W 180M4MSWEIRIE2
noshok 300-1-2-15/225-8 3/red com
EA Elektro-Automatik GmbH & Co. KG EA-PS 8080-*** *U 19`` 150v30A4500W
Ac-motoren FCA132M-4/HE 10125229
MARECHAL PN 2P+E 01N8082
MARECHAL PN 2P+E 01N4082
MARECHAL PN? 01NA013
MARECHAL DS1 1P+N+E 3118015
MARECHAL DS1 1P+N+E 3114015
MARECHAL DS1? 311A013
MARECHAL DS3 3P+E 3138013
MARECHAL DS3 3P+E 3134013
MARECHAL DS3? 313A013
MARECHAL DS6 3P+E 3168013
MARECHAL DS6 3P+E 3164013
MARECHAL DS6? 316A013
MARECHAL DSN6 3P+E 6168013
MARECHAL DSN3 3P+E 6138013
epro PR9376/010-011
epro PR6424/000-040+CON021
epro PR6426/000-040+CON021
epro PR6423/000-040+CON021
epro PR6423/011-110+CON021
epro PR9268/200-000+CON021
epro PR9350/04
epro MMS6210
COPELAND ZR11M3E-TWD-561
JAKOB ESM-A 28-Φ20K-Φ20K
LOVATO LMS25 4T 2.5-4A
EMOD Nr.8111622 SP180L/4WU 28/34KW
woerner GFMN/2.08A/P
woerner W-OAM-6F/NBR/2
woerner W-OAM-10J/NBR/2
Neugart PLE60-320
bucher HDM18/1 C.17 4N
FROMM System GmbH P32.2078
ENERPAC ENERPAC-C604
ENERPAC ENERPAC-CR-400
EAO 704.062.2/900.3.3.2/925.0/110
EAO 704-012.518/900.1
KOBOLD Messring GmbH VKG-2102ROR08
EAO 704-012.2/900.3.3/925.0
Foxboro FBM04 B 4-20MA DC C p 4-20MADC 4 channel
RIELLO UPS SEP700; CSEP7001RU
berger lahr brs368n130aca 0052224016000
Kraus & Naimer CA10-A232-614-FT2
VSE EF0.1ARO 12E-NPN
GRUNDFOS NO 96150043 N.3.1202
ELAU VIA0702D11A0000
ELAU VPM02D20AA00
ELAU VCA05AAAA0AA00
GESSMANN 424NAIU100B
GESSMANN H100B5D3VZEVXEX0
INSIZE 6866-150
Schlick 556 Gr=4, hole ?10.5mm 3/4 BSP , PVC
HAHN+KOLB 33042
GMC-I Gossen Metrawatt GmbH SINEAX V604-112
HAHN+KOLB 33300-020
HAHN+KOLB 33301-020
DEUBLIN 557-130-199 with Elbow thread Inside and outside
BAUER BG40-11/D11MA4-TF/C3 3~Mot -No. E 25090934-1 A/171Z6463
Eurotec MNF532...-EA
INDUSTRONIC 16DT002 ;301-447-100,With 3m connecting cable and socket
PMA STB55-5000-000
INDUSTRONIC 32DT002,301-447-200;With 3m connecting cable and socket
INDUSTRONIC 48DT002,301-447-300;With 3m connecting cable and socket
DEUTSCHMANN TERM 24-KETTNER IP65 Art V1588 Serial No 15880187
airflow Ptlnr-k1000
Hamworthy PCH1566C
HAEHNE AME2-C 114971
bauer BS02-34H/DU06LA4-TF-G-K/E003B9
bauer BS02-37V/D04LA4
HBM t20wn/10nm
ott-jakob 9560000136
Elau Mc-4/11/22/400
Elau Mc-4/11/22/400
lumasense IS50-L0/GL
pall LVXIN&HCY-01E2001FKN20HE
pall LVXIN&HCY-01E2001FKS20HE
pall HC8904FKS26H(HH303DJ03KSVBR 24D7-CH0050)
Braun GmbH A5S33T120-10m
Braun GmbH D1553.120U1M
pall LVXIN&HC8904FKS26H(HH303DJ03KSVBR 24D7-CH0050)
pall LVXIN&HCY-8300EOM26HYK 3μm
pall HC8314FKS39H(HH381DJ03OMVWR 24D7-CH0043)
pall LVXIN&HC8314FKS39H(HH381DJ03OMVWR 24D7-CH0043)
pall HCY-8300EOM26HYK(HH381DJ03KSXBRR 24D7-CN)
pall LVXIN&HCY-8300EOM26HYK(HH381DJ03KSXBRR 24D7-CN)
Demag DES 10-C 77335245 77336944
HEIDENHAIN EQN1325,512,586654-55
hydac GYLYQLX&DFBN/HC500QE5D1.X-L24-B6
hydac HYGLQLX&RFBN/HC950DO5D1.X/-L24
hydac HYGLQLX&RFBN/HC660DN20D1.X/-L24
flender K108-LA132 I:89.85 N1:1455/MIN N2:16.2/MIN T2:32444N.M
VAHLE 915461/00
kuebler VN1-40.5E/1250-25KA DC220
Sprecher + Schuh CA7-23-10 220V
Sprecher + Schuh cep7S-eesb C 5.4-27
EMG LIC1075/11
EMG EVK2-CP/1000-71/L/R
EMG CPCSM1-HE/750/2400/1800/200
THK RE15030 UU
omron PYF08A-E
omron MY2N DC24
omron G6B-4BND
Molex 39-01-2081 / WM3603-ND
Molex 39-01-2080 / F/N: 151-869
Molex 39-00-0039 (F: 9732195)
Molex 39-00-0041
Kraus & Naimer CA20-A203-V840F
KEB G12A DL71G4B02 #02-2007/14086101.015 0.37KW 230/400V 500Hz
Banner T30UXIC
VEM 1894780001H IE2-W21R 315MX6 KL NS TPM VL WE HW
KNF N023.3ANE 018927
ABB SN.261GS 66000 43005 LKPN21 OPT L1M1
KNF 016712 Septum
Kroeplin GmbH H102
basler electric BE3-27/59 3A1N
Leybold 11406 D 16 c-DOT
Bauser 631.20 0~99999.99H 400VAC 0HZ 48*48 grey colour 7-digits
HORIZON RLA050-40N
PFLITSCH PIK D 60 S
PFLITSCH PIK D 40 S
PFLITSCH PIK K 60/60 S
PFLITSCH PIK K 40/40 S
EBM M3G055-B121-22
EBM M3G055-B121-22
MEGATRON MS30 1 LD 0312-12015
SIKO IG09M-0336
EATON SBF-0102-AD16-080D-11BON
IMAV Hydraulik MPZ-10A-P+T-B02
P+F PCV80-F200-R4-V19
BIERI BRK11-3.14-700-P-A*00
P+F V19-G-ABG-PG9
KSB ETANORMG040-200 G10
MTL MES-30-100
Zumbach Electronic GmbH B.N2.267.400
ITT Water & Wastewater Deutschland GmbH 2630.180-0012
KEB QB01701-CO4-H+HEDL-5540A12
stahl 8146/ 1051-3D-2TS15+1M X K4
dunkermotoren PLG52 36:1 8585101762
Rollon NTE28
stahl 8118/111-503
stahl 8571/11-406
danfoss LYP2122.09 OMV630 CODE No.: 151B3103
HEIDENHA LS 187C ML= 2840527392-23
SIPOS 2SA5521-2TE00/GS3S41+R72
SIPOS 2SA5031-2TE00/GS200.3
SIPOS 2SA5521-2TE00/GL60.3-S41+R72
SIPOS 2SA5531-2TE10/GR60.3+S41+R72
Coperion GmbH ZVB 250 DXSR280K
heidenhain 557642-25
heidenhain 571613-25
heidenhain 557644-18
heidenhain 557644-15
BIELOMATIK 30016932
ATOS RAMO-AE-030/315/I
heidenhain 226270-02
ATOS SP-CART M-5/350
heidenhain 291697-26
ATOS DLOH-2C-U SP-667 24DC
ATOS E-ATR-7/400/I
WOLKE type m600advanced code 5.GC108.37.
Regina S.I.C.C S.P.A typ.26/90R
KRACHT KF40RF1-D15
KRACHT KF/80/RF/1/193/D15
WATT KSA 60A 81N6-BR10
DRAGO Messtechnik GmbH DK-8000 ±15mV / 0-20mA
Meister SG30X70
KISSLING 26.08.08 24V
WESTPHAL WAVETEC E3-00340 G640 6119
sew BW039-026
sew R47 DT80 N4/ASB1
sew DFT80N4/ASB1
sew WF30 DT71D8/BMG
BIRKENBEUL 6AP280MK-06
HMS Industrial Networks GmbH ABC-PDP-B AB7029-C 0000B0C4 CBV.2.1.1 24VDC ROHS
Pommier Nr380513
Pommier Nr380513
WATT KUA 77A 91S4-TH-BR20-SG
WATT ASA 56A 91L4-BR20
WATT KSA 70A 101LA4-TH
VOGEL fluidtech SP/SFE30/5
Georgii Kobold GmbH KOD346-1A MB 0.09KW Nr.1005280000 3-MOTOR Nr.545572
DRIVE-SYSTEM DSMP420-24-504-BF 24V DC
SIEMENS 6DD1645-0AE1
SIEMENS 6SE7038-6WK86-3AE0-Z(G93+K11+)
SIEMENS 6SE7038-6WK86-4AE0
HBM U15/1MN
HBM U15/500KN
ROSS D2771B3001,AC110V ROSS
BEFELD-SYSTEME GmbH 80934106RS
Demag Cranes & Components GmbH MOTOR ZBA180A4B280 18.5KW
Demag Cranes & Components GmbH Brake coil FOR ZBA180A4B280 18.5KW
Demag Cranes & Components GmbH Brake coil ZBA100B4B050
LAFERT B63G5P-02408
LAFERT B71091-03307
LAFERT COMAU CR82309745 325Vac 3PHASE 16.26A 27Nm 24V 0.93A
LAFERT COMAU CR82309750 325Vac 3PHASE 18.75A 41Nm 24V 1.03A
PLARAD F32-050-3-02202
PLARAD K20-127-4-07201
plarad K20-501-403001
plarad K32-050-4-00701
plarad KOO-002-4-09101
plarad K25-048-4-00601
TR-Electronic GmbH LP-46*50
TEK TRANSFORMATOREN 400/24V AC 63VA +/-5%
BAUMULLER DSD100 S64U45-5 Nr 21029427,Art Nr 380400
BAUMULLER DS71-M Nr 21029797,Art Nr 258484
EPCOS B43456-S0568-M1
TSCHAN NOR-MEX 265-010
Liebherr M=3 Z=22 LP20/05 drive main carriage gear box SEW-BSF 402
Haug KG18.D-70771
Staubli RBE.08.6151
FISCHER 6401993
HBM S40A/50KG
ASM CLMS2-2ABS71015000
volvo V3 0B /128 RK/ 1 0/APL0
STAFFA 83963 OUAD90120
STAFFA 60675 OUAD10513
Kelviplast GmbH & Co. KG F61B9100
PMV EP5XX-HPGU23K01-PV9DA-4Z
MANN+HUMMEL H15190-16E
HBM C2 1000N
PHOENIX 2900445
PHOENIX 2961105
LEGRIS 1025U03 01 18
EL-O-MATIC ES0100M1A06A00K0
EL-O-MATIC ES0100MM1A066A00K0
EL-O-MATIC ES0040M1A04A14K0
EL-O-MATIC ES0200M1A06A22K0
EL-O-MATIC PS2500M0A14A00K0
EL-O-MATIC Model:E65 Double -D 9.5 X 13,valve size:2"
EL-O-MATIC Model:E65 Square shaft 11 x 11,valve size:2"
EL-O-MATIC Model:E100 Double-D 9.5 x 13,valve size:2"
EL-O-MATIC Model:E100 Double-D 10.5 x 16.5,valve size:4"
EL-O-MATIC Model:E100 Square shaft 11 x 11,valve size:2"
EL-O-MATIC Model:E100 square shaft 14 x 14,valve size:6"
EL-O-MATIC Model:E200 Double -D 10.5 X 16.5,valve size:4"
EL-O-MATIC Model:E200 Double-D 16 x 22,valve size:8"
EL-O-MATIC Model:E200 square shaft 14 x 14,valve size:6"
EL-O-MATIC Model:E200 Square shaft 17 x 17,valve size:8"
EL-O-MATIC Model:E350 Double-D 12 x 19,valve size 8"
EL-O-MATIC Model: E350 Double-D 16.5 x 24.4,valve size:8"
Micro-Epsilon WDS-10000-P115-CR-TTL
ELME E14-A542H
siemens 6FC5357-0BB12-0AE0
siemens 6FC5357-0BB14-0AA0
EA SMART NAMUR VALVE Art:SNMF
EA TM62××07
Hoerbiger AZ5080/300
EA ZA64-EE85/TM24DC
ORIGA PD 38853-0320 AZZ5100 10bar
Hoerbiger DZ05063-100
E ZD311508-HE621432+TM621207+RE13030310S
cembre V131C
Saltus T55 NR 5320105560
Klann E14 KL-4046-3614
DELACHAUX 106729/02
DELACHAUX 106729/02
tecsis GmbH P3297B084001
THALHEIM CPS37-14 K14/K20 L=24
Mcmaster 1/2" ID, 29/32" OD, 600 PSI, Yellow 53065K21(Full Coil)
Mcmaster 1/2" ID, 15/16" OD, 150 PSI, White 5286K78(Partial Coil)
AMK RAS4-1-6-000
Parsytec Computer GmbH S10-9070-03
Parsytec Computer GmbH S10-9070-02
Parsytec Computer GmbH S10-9085-02
hawe LHDV 33-25 W-B 6-130/130-100/100
Mcmaster 1/2" ID, 1-1/16" OD, 250 PSI, Black5301k11(Full Coil)
hawe PSV 4S1/370-3-38 L 63/80/EA 2-32 0 63/63/EA 2-32 J 80/63 EA
Mcmaster 1/2" ID, 1-1/32" OD, 250 PSI, Red53045k61(Partial Coil)
Hengstler RI58-D/40ED,32KB, CABLE:1.5M 24V,40PTS/TR
INA RSHE 20
INA GE40-DO-2RS
Mcmaster 1/2" ID, 1-1/32" OD, 250 PSI, Red53045k61(Full Coil)
INA FAG HFL2530
INA FAG 608-2RSR
TEKEL PWS8061.1024.5.FS.SAL.D5
TEKEL TK561.F.1500.24/05.S.K4.10.L10.LD.X419
NSK 6003 2RS
NSK 6002 2Z
NSK 6205
NSK HR30206J
ADOS GmbH Module UE10
ADOS GmbH Module DDS
ALSTOM HTCT445105R0002
ALSTOM HTCT445105P0001
ALSTOM HTCT445105P0003
ALSTOM HTCT471410P0001
HBC FST716 MICRON 220/110/48VAC with 16 control point,1 receiver
Hawe EM41v-3/4 NR.3504
rohrlux 191123-02
dinse DIX3-2-1.0/KA
dinse DIX3-2-1.2/KA
garos PF100D
RHEONIK RHE11 24V DC
ABB AX430
ABB AX430B
AGME 20.000.341
LYTEST 20.000.557
LYTEST 25.000.185
LYTEST 1.01.001.231
LYTEST 20.000.556
LYTEST 20.000.357
LYTEST 20.000.559
LYTEST 25.000.113
LYTEST 30.000.819
LYTEST 25.000.100
LYTEST 25.000.010
LYTEST 25.000.030
LYTEST 20.000.560
LYTEST 20.000.561
LYTEST 25.000.115
LYTEST 25.000.029
一. 德国巴马格FK6-1000加弹机变频器维修
M131-1U-AC电源维修
1. BVS-25-444ZV211
22KVA变频器及其相关电子线路板:EA59F EA60D ED376 ED377 ER125C ER136
2. BVS-25-442ZV211
11KVA 变频器及其相关电子线路板:EA88 EA51E EB114A ED376 ER125C ER136 ED377B (EA50A)
3. BVS-25-446ZV211
50KVA变频器及其相关电子线路板:EA62C EA63C ED376 ER125C ER136 ED377
4. BVS-25-400ZV10
巴马格动程修正程控变频器及其相关电子线路板:EA42L ER113M
5. BVS-25-53ZV12
1.5KVA巴马格油辊变频器及其相关电子线路板:EA57B/1Z ER119B/1Z
二 .巴马格FK6-1000加弹机BCAS系统电子线路板维修
EL305F/1Z EL333B/1Z ED445/1Z ED441/1Z EL310/2Z ED457/1Z ED434/1Z ED491/1Z EC182
ED411/1Z ED292/3Z ED292/4Z EC201/1Z ED381/1Z
EL249/1Z ED437/1Z EL299/1Z EL234/1Z ED414/1Z
ED397/1Z ED342/4Z EL249/1Z EL285/1Z ED346/1Z
三.巴马格DC-BUS内部直流电源维修
BVZ-25-22Z(80KW)及其相关线路板EL314A ED275A
BVZ-25-23Z(80KW)及其相关线路板EL314A ED275A
1. BVS-25-444ZV211
2. BVS-25-442ZV211
3. BVS-25-446ZV211
4. BVS-25-400ZV10
5. BVS-25-53ZV12
苏州三岩芯电子科技前身为苏州工业园区三源芯辉电子科技有限公司,是一家致力于电子应用
技术与维修的一家高新技术企业,三源电子始创于1995年服务于电子半导体产业和化工业、机
械制造业及军工产业设备的维修与维护。我司技术力量雄厚,主要技术人员均来自各电子工程
研究所和研究院,现有维修工程师14人,业务工程师11人,客服人员3名。我公司在电子工程
、通信、微波、毫米波、自动控制、信号处理、无线电计量、电子结构、高精度传动结构等高
新技术领域的开发应用有着较强的技术实力。我司始终保证维修的电路板品质和新板如一,真
正的为客户创造价值、节省费用,实现“设备永续、设备无忧”,为客户设备的正常运行提供多
方位全程保障,以优质、快捷、可靠的专业电路板维修服务为用户赢得生产、配送和运营的宝
贵时间,提高企业应对市场灵活变化的需要。
公司主营品牌:ABB、AB、西门子、FOXBORO、霍尼韦尔、施耐德(MODICON)、OMEGA、
BALDOR 、瑞恩
北美部:提供罗克韦尔AB,Honeywell霍尼韦尔,OMEGA欧米茄,莫迪康(modicon),BALDOR葆德
电机,波斯顿BOSTON,GE,丹纳赫-科尔摩根,安捷伦Angilent,N-TRON恩畅交换机,SST、红狮,
派克液压,泰克,FLUKE福禄克,邦纳,巴士德,ASCO,巴斯曼BUSSMANN,艾默生,ACOPIAN ,
HUBBELL,威格士,SQUARE-D ,瑞恩RELIANCE ,MTL,MAGNETEK,西屋Westinghouse,思科,
ACME、S+S,KAMAN,SOLA,颇尔 power-one,SOR
欧洲部:伦茨 赫斯曼 E+H P+F 威托 aron 霍伯纳 沃申道夫 康茂盛
亚太部:三菱,横河,欧姆龙,安川,日立Hitachi, 东芝TOSHIBA 多摩川
产品详细信息及其订购,欢迎来电查询!
将会给您优质的服务!优惠的价格!
用诚信的心,真诚的为您服务!
通过中国触摸屏网金牌会员认证
