Model RD52 Inline System
RD52型在线汽相回流焊
De
介绍:
High volume inline type vapor phase reflow oven with adjustable pin chain conveyors, 4 zone preheat section, horizontal reflow position, left to right product flow, full graphics touch screen operation, fully integrated controls, SMEMA upstream/downstream interface, password protection, bar code capability and all the standard features you've come to expect from R&D Technical Services / Vapor Works.
高容量的在线式汽相回流炉,链式导轨自动调宽、4段预热区、平层汽箱回流、产品从左到右进行输送、全触摸屏操作及控制、SMEMA上下料接口、密码保护、程序编号和所有的标准功能,R&D提供这些所有的基本功能。
Application:
应用:
The RD52 is a high volume, fully automatic, inline vapor phase reflow oven designed specifically to move easily into your manufacturing line.
RD52是一个高容量,全自动,在线式汽相回流炉,组线容易。
Features:
特点:
· Left to right product flow
· 从左到右产品流向
· 450mm x 380 mm working envelope
· 450X380mm工作空间
· 4 zone preheat section
· 4段预热
· Adjustable pin chain conveyor
· 导轨自动调宽
· SMEMA communications
· SMEMA
· Adjustable top and bottom cooling zone
· 上下冷却区域可自动调整
· Password protection
· 密码保护
· 250 recipe storage
· Vapor preheat function
· 汽相预热功能
· Working fluid filtration
· 液体过滤
· Working fluid auxiliary tank
· 辅助油箱
· Unsurpassed reflow profile control
· 非常好回流温度控制曲线
· Perfect for high volume automated inline vapor phase processing
· 适合大批量自动化在线气相处理
· Custom working envelopes available
Specifications:
规格型号
· Maximum Product Size: 18" (450 mm) x 15" (380 mm)
· 最大产品尺寸:18" (450 mm) x 15" (380 mm)
· Unit Dimensions: 162" (411 cm) x 46" (116 cm) x 46" (116 cm)
· 机器尺寸:162" (4110 mm) x 46" (1160 mm) x 46" (1160 mm)
· Power Requirement: 480 VAC, 3 Phase, 80 Amps, 50/60 Hz. or 400 VAC, 3 Phase, 80 Amps, 50/60 Hz.
· 电源要求:480V,3PH,80A,50 / 60HZ。或400V,3PH,80A,50 / 60HZ。
· Main Heater: Immersion Tubular Heater
· 主加热器:浸入式加热器
· Preheat: Individually Controlled 4 Zone Preheat Section
· 预热:4个独立预热段
· Operating Temperature (Reflow): 200 °C - 320 °C dependant on vapor phase fluid used
· 温度(回流):200 °C - 320 °C ,取决于汽相液
· Water Requirement: 3-5 GPM supplied at 20 °C - 30 °C with 40-60 PSI
· 水的要求:20°C 30 C°,40-60 PSI,3-5加仑
· Working Fluid Capacity: 3 Gallons
· 汽箱液容量:3加仑
· Product Flow: Left to Right
· 产品流向:从左到右
联系人:陈先生13602588976
