美国RPS“PRELUDE”202浸渍和观察系统
“Dip & Look Test” - The Prelude provides precise handling of electronic components for the automated process of a flux and solder dip of the component terminations. After the dip process, the operator inspects the terminations (i.e., “look”) for the adequate presence of solder. If adequate, the component is validated for authenticity and solderability with the selected solder alloy.
“浸渍和观察”可焊性测试仪 - “前奏”202可焊性测试仪能够在零件终端浸渍助焊剂和焊锡的自动化加工工序里面准确地对电子零件进行输送。浸渍之后,工人可以对终端进行检查(那就是“观察”),确认焊锡浸渍是否合格。如果合格,就证明零件对所选择的焊锡合金是真实的、可焊的。
BENEFITS
优点
Easy Set-up & Immediate Results
容易设置,立马可用
Precise Process Control & Repeatability
工艺控制准确,可重复性高
Superior Results vs Hand Dipping
比手工浸渍更加优越
Large Solder Bath Maintains Thermal Mass
焊锡槽非常大,保证不会断料
Space-Saving Footprint
体积更加紧凑,节省厂房空间
No Programming Knowledge Required
不需要编程知识
Meets IPC, ANSI, Mil Specifications
符合IPC、ANSI、Mil等标准的要求
COMBINE WITH STEAM AGER FOR FULL TEST OFFERING
与蒸汽老化试验机一起形成一个更加全面的测试系统
The Prelude can be combined with an RPS Cadence Steam Ager to provide artificial aging prior to the dip and look test. The combination of aging and dip & look testing provides full compliance with the objective IPC, ANSI and MIL solderability test standards.
“前奏”202可焊性测试系统与RPS的“节奏”蒸汽老化试验
机让我们能够在浸渍和观察之前对零件进行人工老化试验。
这种老化与浸渍和观察相结合的方式更加全面符合IPC、ANSI、MIL等标准的要求。
FEATURES & OPTIONS *
特点和可选方案 *
PID Temperature Controls
PID温度控制系统
Solder Station & Flux Station
一个焊锡系统和一个助焊剂系统
DX with 2nd Alloy Station
具有两个焊锡炉的DX双焊剂可焊性测试系统
Multi-Axis Motion Control
多轴运动控制系统
Automatic Dross Wiper
自动控制的焊渣刮
High Precision | ± .001”
精度高达±0 .001”
Prelude 202 Solderability Test System | The Prelude 202 is designed for standards compliant solderability “dip & look” testing of electronics components. The Prelude 202 features high precision PLC motion X & Z axis motion control, advanced touch screen programming, a solder pot and flux station. Customer must select and purchase tooling to hold components. NOTE: System is designed to industry standard using static solder pot and testing of a sample of component terminations (leads). Testing all terminations (especially, fine pitch, QFN, QFP components) may require N2 inertion and a dynamic solder pot, which are inconsistent with testing standards.
“前奏”202可焊性测试系统用于对电子零件进行“浸渍和观察”测试,看是否符合标准规定的可焊性要求。“前奏”202可焊性测试系统的特点是:高度精密的X轴和Z轴PLC运动控制机构;先进的触摸屏编程系统;具有一个焊锡炉系统和一个助焊剂系统。客户必须另行选购夹持零件的模具。备注:该系统是根据静态焊锡炉和单一零件终端(脚)测试要求的行业标准来设计的。如果需要测试的是所有零件终端(特别是小脚距、QFN、QFP等零件),也许还需要氮气惰化装置、动态焊锡炉等非标准配件。
联系人:陈先生
手机:13602588976
