欧洲工业备件厂家直供之T4VH 336—02—M20系列产品
Heinrichs TAG:FIT-2111 Ser-Nr:00237136 BGN S 121C T000 9 S26-0 TAG:FIT-2111 Ser-Nr:00237136 BGN S 121C T000 9 S26-0
Karl Dungs TAG NUMBER: PSH 4.771; MODEL NO.: GGW 150A4/2; TAG NUMBER: PSH 4.771; MODEL NO.: GGW 150A4/2;
GRASSLIN TACTIC111.2 TACTIC111.2
Will-Burt TACSTICK TACSTICK
DEUTSCHMANN TA58-C260-GYE-ID .10-30VDC=/100mA TA58-C260-GYE-ID .10-30VDC=/100mA
DEUTSCHMANN TA58-4096-GYE-1D10-30UDC/100ma S997686/001/0710 TA58-4096-GYE-1D10-30UDC/100ma S997686/001/0710
brinkmann TA303/220+001 TA303/220+001
TEWS TA302-10 TA302-10
baumer ivo TA202.012AXA1 TA202.012AXA1
Baumer IVO TA202.012AX01 TA202.012AX01
Baumer GmbH TA200.002AXA1 TA200.002AXA1
Baumer IVO TA200.002AX01 TA200.002AX01
Brinkmann TA160/350+001 TA160/350+001
Brinkman TA160/200+001 TA160/200+001
10 TA064-21y TA064-21y
Schmersal TA064-12Y TA064-12Y
SCHOTT TA 20 PLUS 285211054 TA 20 PLUS 285211054
Autorotor TA 15.3.270 MATR S.numb.37201 26010 VA/ANO CREMACCO TA 15.3.270 MATR S.numb.37201 26010 VA/ANO CREMACCO
SCHOTT TA 10 PLUS 285211046 TA 10 PLUS 285211046
schmersal TA 064-12Y-GB-985 TA 064-12Y-GB-985
Sherborne Sensors T99-AS3503-202 T99-AS3503-202
baumer T9143.0 T9143.0
ALBERTI T90CN-3.5 (Torque 35NM) T90CN-3.5 (Torque 35NM)
REX T-8700 T-8700
FAIRCHILD T8600 T8600
luebbering T80102003 T80102003
Turck T8.5862.1422.2002 T8.5862.1422.2002
kuebler T8.5860.4432.3001 T8.5860.4432.3001
turck T8.3720.2030.1000.0006 T8.3720.2030.1000.0006
schmersal T7V7H336-11Z-RVA-2272 T7V7H336-11Z-RVA-2272
Calpeda T76E 3.6m3/h T76E 3.6m3/h
Norgren T70C4800 T70C4800
DENISON T6ED-062/017/1R00/B1M0 T6ED-062/017/1R00/B1M0
DENISON T6DCC0420250141R00A101 T6DCC0420250141R00A101
DENISON T6DC-038-003-2R00-01 T6DC-038-003-2R00-01
parker T6D-B35-1R00-A1 T6D-B35-1R00-A1
DENISON T67CB 012 B08 (ROOALL) T67CB 012 B08 (ROOALL)
Norgren T65C1800 T65C1800
NERI MOTORI S.R.L T63C4 0.22KW 380V 50HZ T63C4 0.22KW 380V 50HZ
NERI t63b4b3 t63b4b3
Flir T610 T610
herl T-5R.5 d=5mm T-5R.5 d=5mm
ABB T5L630 PR222DS/P-LSI R630 FFC 3P 1000VAC T5L630 PR222DS/P-LSI R630 FFC 3P 1000VAC
HERL T5F DN40 PN40 T5F DN40 PN40
HELUKABEL T5-75 91127 T5-75 91127
GLOBAL T56.SR.0 5.R.L.12.401.E.07.31.58.91 T56.SR.0 5.R.L.12.401.E.07.31.58.91
HELUKABEL T5-50 91126 T5-50 91126
Saltus T55 NR 5320105560 T55 NR 5320105560
rexroth T5-225-16 ALPHA-F L=225MM T5-225-16 ALPHA-F / #1627060 T5-225-16 ALPHA-F L=225MM T5-225-16 ALPHA-F / #1627060
eku Kabel & Systeme t51343192 t51343192
eku Kabel & Systeme t51343111 t51343111
EKU t51310012 t51310012
Mettler T50M Titrator T50M Titrator
Peter T501 F T501 F
HBM T50 T50
Schmersal T4VH 336—02—M20 T4VH 336—02—M20
Schmersal T4VH 335-11z-RMS T4VH 335-11z-RMS
nadella T4PFV-35-18-150 T4PFV-35-18-150
SCHMERSAL T4D064-21Y-R r=2x90-M25 T4D064-21Y-R r=2x90-M25
Schmersal T4D064-12Y T4D064-12Y
SCHMERSAL T4D.064-21y r=90° SL11、SL21 T4D.064-21y r=90° SL11、SL21
Schmersal T4D 250-11Z-R=1x90GR-RMS T4D 250-11Z-R=1x90GR-RMS
Schmersal T4D 064-21Y- R=2x90GR T4D 064-21Y- R=2x90GR
Thermibel T49988/1.2 DDG T49988/1.2 DDG
norgren T40C8800 T40C8800
Norgren T40C4800 T40C4800
IFE Aufbereitungstechnik Gmbh T40-40 S-00 T40-40 S-00
JAQUET T402 T402
Telergon T-401.T-12E T-401.T-12E
JAQUET T401.00 14V (Three-year warranty) T401.00 14V (Three-year warranty)
JAQUET T401(0-10V/0-60,000),0.00.6-93.42.00.57 T401(0-10V/0-60,000),0.00.6-93.42.00.57
JAQUET T401 0-1KHz/4-20mA 383Z-05307(4-20mA) T401 0-1KHz/4-20mA 383Z-05307(4-20mA)
Adixen T3R00000B820 T3R00000B820
EUPEC T3801N36TOF 23R9 T3801N36TOF 23R9
autorotor T3504300 serial:38852 T3504300 serial:38852
MAGNETROL T35-002N-B1B T35-002N-B1B
HELUKABEL T3-35 91123 T3-35 91123
thorsman-schneider T3262003 T3262003
Banner T30UXIC T30UXIC
banner T30RW3LPQ1 T30RW3LPQ1
LEDUC t3 6.3*9*160 t3 6.3*9*160
tele T2X02-W T2X02-W
MLS Lanny T2SVB42 ID 0135151 SN 8305 T2SVB42 ID 0135151 SN 8305
Barksdale T2H-H251(-73℃~-149℃) T2H-H251(-73℃~-149℃)
ANSALDO T2A203456BR1 T2A203456BR1
schmersal T2A067-11Y-2512-4 T2A067-11Y-2512-4
parker T28LCFX T28LCFX
Econosto T27-DN200 T27-DN200
ECCO T278 FIX4 6102 3991 74 T278 FIX4 6102 3991 74
BIAX T27-65 T27-65
RECTUS T2520RV2 T2520RV2
RGS T2519PK00B T2519PK00B
Flir T250 T250
autorotor T25 08 300 SERIALNO.35950 T25 08 300 SERIALNO.35950
Watlow GmbH T24-2-508 T24-2-508
Herl T23V DN40/50 22BAR With flange T23V DN40/50 22BAR With flange
ZIEHL T236076 TMU 300 T236076 TMU 300
ZIEHL T222175 T222175
HBM T22-1KN.M T22-1KN.M
NILFISK T22 L100 Ref. no 4030500072 T22 L100 Ref. no 4030500072
Tally Genicom T2150 L4504A T2150 L4504A
EBRO T211-A DN150 PN10 GG40.3PTFECOATED 1.4469 with EB12.1 SYD T211-A DN150 PN10 GG40.3PTFECOATED 1.4469 with EB12.1 SYD
GOMETRICS T210-IS T210-IS
HBM t20wn/10nm t20wn/10nm
HBM T20WN 200N.M ≤0.2 T20WN 200N.M ≤0.2
E.L.B. T200F2"V24 T200F2"V24
BARKSDALE T1X-M351S-25-A T1X-M351S-25-A
Schmersal T1R 236—20z—M20 T1R 236—20z—M20
RACO T1N7 230/400VAC 50 Hz 3 kW 1500 min-1 40 kN 800 mm T1N7 230/400VAC 50 Hz 3 kW 1500 min-1 40 kN 800 mm
RACO T1M4/13671 T1M4/13671
herl T19 DN12 /25bar T19 DN12 /25bar
ALTMANN GmbH T18-182Z T18-182Z
ALTMANN T18-182 K13053 5KΩ F05032 CE T18-182 K13053 5KΩ F05032 CE
ALTMANN T18-182 D2K13053 T18-182 D2K13053
WEH T17H-W9031-025 T17H-W9031-025
parker T15LCFX T15LCFX
Parker T15LA3C T15LA3C
kollmorgen T13-B4020MW110 T13-B4020MW110
Gessmann T130C Nr.4 2x4.5279kOhm T130C Nr.4 2x4.5279kOhm
pneuto T-125-2 300Nm/5bar T-125-2 300Nm/5bar
Seneca T120 PL100 0-500Degrees Celsius T120 PL100 0-500Degrees Celsius
tuenkers T12 for V80.1 T12 for V80.1
Norgren T1100C2800 T1100C2800
parker T10LCFX T10LCFX
Peter Hirt GmbH T101 T101
SIBA T1.6A H500V 7006565 T1.6A H500V 7006565
TUNKERS T08T FOR V 63.1 T08T FOR V 63.1
TUNKERS T08T FOR V 50.1 T08T FOR V 50.1
Moeller T0-5-8346/E/SVB T0-5-8346/E/SVB
Moeller T0-3-8342/I1/SVB-SW T0-3-8342/I1/SVB-SW
Moeller T0-2-15679 T0-2-15679
euroswitch T0.3D 27211207 T0.3D 27211207
GEA T0,8A DIN 41662 ID NR 902687 T0,8A DIN 41662 ID NR 902687
ABB T/NHME0300D T/NHME0300D
EMG T.Nr. 224397 TOPFMOTOR TM4.0104/Y380V/0.77COS/1.9-2.2A T.Nr. 224397 TOPFMOTOR TM4.0104/Y380V/0.77COS/1.9-2.2A
SCHMERSAL T.441-11YUE-243 IEC60947-5-1 T.441-11YUE-243 IEC60947-5-1
schmersal T.064-21Y-R r=2*90 Grad T.064-21Y-R r=2*90 Grad
schmersal T.064-12Y-R R=1X90GR IEC60947-5-1 T.064-12Y-R R=1X90GR IEC60947-5-1
Ruhrgetriebe T 71 A4 Nr:1189E6466 T 71 A4 Nr:1189E6466
RGM Ruhrgetriebe KG T 71 A 4;1189E6466;220-240/380-415 T 71 A 4;1189E6466;220-240/380-415
GEA T 0.8A DIN41662 T 0.8A DIN41662
schleicher SZT320 Nr.05701244 433 011 SZT320 Nr.05701244 433 011
WIBOND SZP104-100TD/1.0916 SZP104-100TD/1.0916
Flender SZN500 Nr.437 707 406-1-3 SZN500 Nr.437 707 406-1-3
wibond SZL105-120TD/1.0008 see the pdf SZL105-120TD/1.0008 see the pdf
WIBOND Informationssysteme GmbH SZL104-100TD/1.0524-2SPZ WN:3.5934 SZL104-100TD/1.0524-2SPZ WN:3.5934
TUENKERS SZK40 T08 40 SZK40 T08 40
Mafag SZ-GL 240/140-400DHh SZ-GL 240/140-400DHh
HBM SZC-2Q/20T SZC-2Q/20T
EGE SZA 400 EX-230 SZA 400 EX-230
Siko GmbH SZ801-0172 SZ801-0172
SIKO SZ80/1-0156 N80I1S-C1 VK-11428 Nr.SZ80R-8 SZ80/1-0156 N80I1S-C1 VK-11428 Nr.SZ80R-8
SIKO SZ80/1-0011/N-2/5-1-I-S-VK09453-C1 SZ80/1-0011/N-2/5-1-I-S-VK09453-C1
PITTAL SZ-50K-U SZ-50K-U
RITTAL SZ4315.500 SZ4315.500
rittal SZ4127.010 SZ4127.010
RITTAL SZ4103350 SZ4103350
rittal SZ2540.009 SZ2540.009
rittal SZ2533.000 SZ2533.000
Danfoss SZ240-A4MBI SZ240-A4MBI
Rittal SZ2402.000 SZ2402.000
lechler SZ1-402.723.17(3/8"BSPP) SZ1-402.723.17(3/8"BSPP)
lechler SZ1-402.722.17(3/8"BSPP) SZ1-402.722.17(3/8"BSPP)
Hesmor SZ1210-A-10000-I420-L15-K SZ1210-A-10000-I420-L15-K
danfoss bauer SZ1-10/D044-141LS 189482-20 SZ1-10/D044-141LS 189482-20
Boellhoff SZ05-50-100-30 NR.08/091844 SZ05-50-100-30 NR.08/091844
PITTAL SZ-018K SZ-018K
PITTAL SZ-016KA SZ-016KA
STEINEL SZ 8460.06,PUR SZ 8460.06,PUR
STEINEL NORMALIEN AG SZ 8030.25X076 SZ 8030.25X076
Sonepar SZ 4127.010 SZ 4127.010
Rittal SZ 2370.520 SZ 2370.520
KSB SYT 150-400.1 SYA8 321 SYT 150-400.1 SYA8 321
KSB SYT 150-400.1 SYA8 230 SYT 150-400.1 SYA8 230
KSB SYT 150-400.1 SYA8 210 SYT 150-400.1 SYA8 210
KSB SYT 100-250 SYA8 321 SYT 100-250 SYA8 321
KSB SYT 100-250 SYA8 230 SYT 100-250 SYA8 230
KSB SYT 100-250 SYA8 210 SYT 100-250 SYA8 210
INA Système de guidage KUVE45LW4G4/2950/57,5/57,5 Système de guidage KUVE45LW4G4/2950/57,5/57,5
GREGORY SYS-FLOW-007 SYS-FLOW-007
Crouzet syrelec 10108 syrelec 10108
Aerzen SYN drawing; LSU 10-4.3 SYN drawing; LSU 10-4.3
binder SYN 75 AT10/1080 SYN 75 AT10/1080
Stucke Elektronik GmbH SYMAP-F SYMAP-F
SMC SYJ714M-4G SYJ714M-4G
skf SY40TF SY40TF
schmalz SXMP25NOVM12PNP SXMP25NOVM12PNP
schmalz SXMP 30 IMP H M12 PNP 10.02.02.02330/4 SXMP 30 IMP H M12 PNP 10.02.02.02330/4
GMC SXI552VT DC220V 0~5A/4~20mA SXI552VT DC220V 0~5A/4~20mA
NORGREN SXE9573-A76-00 SXE9573-A76-00
Norgren SXE9573-A50-00 SXE9573-A50-00
norgren SXE 9575-Z70-81/33N SXE 9575-Z70-81/33N
Norgren SXE 9573-A76-00 Ser.no B/0403 SXE 9573-A76-00 Ser.no B/0403
WayC GmbH SX50-1250-420A-SA 1250mm 4-20mA SX50-1250-420A-SA 1250mm 4-20mA
SIEBERT SX45-220/12-E SX45-220/12-E
PRATISSOLI SX3 SX3
SARCLAD SX2638(SARCLAD)22 102/22 OptionB 20mm SX2638(SARCLAD)22 102/22 OptionB 20mm
SARCLAD SX2638(SARCLAD) LVDT 102/25 SX2638(SARCLAD) LVDT 102/25
SARCLAD SX2638(SARCLAD) 102/22 OptionD 14mm SX2638(SARCLAD) 102/22 OptionD 14mm
INA SX011818-VSP SX011818-VSP
LEONARD SWV100-09 MNST V CEV58M SWV100-09 MNST V CEV58M
BUCHER SWUVPA-INCG-AT-F-10-24VDC SWUVPA-INCG-AT-F-10-24VDC
SWR SWR DSKFJ-S SWR DSKFJ-S
hawe SWR 1A 7-UD-1-G 24 SWR 1A 7-UD-1-G 24
Hawe SWPN8-G-G24 SWPN8-G-G24
hawe SWPN2V-G24 SWPN2V-G24
hawe SWPN 2D-G24 24V-1, 25A, 350 Bar max PAB 10 BAR SWPN 2D-G24 24V-1, 25A, 350 Bar max PAB 10 BAR
VAHLE SWN(T) NO.0254903 SWN(T) NO.0254903
VAHLE SWN(T) C/W SWN(T) C/W
VAHLE SWN NO.0257716 SWN NO.0257716
VAHLE SWN 7 BCS SWN 7 BCS
SCHUNK GMBH&CO KG SWK 020-021-060 SWK 020-021-060
SWITCH,PIEZO,M22 SWITCH,PIEZO,M22 1241.3428
SCHURTER Switch, Piezo, Square 1241.3582 Switch, Piezo, Square 1241.3582
Brockhaus Messtechnik Switch SSt500x500 S/N BM1005127794 for SPS-150P-24 Switch SSt500x500 S/N BM1005127794 for SPS-150P-24
JAKOB Switch selector-JS HD4-23P Switch selector-JS HD4-23P
SCHAKO Swirl diffusers D315 Swirl diffusers D315
vega SWING61. XXGAVXPRL SWING61. XXGAVXPRL
Roemheld swing direction cw swing angle 60° (1883-124) swing direction cw swing angle 60° (1883-124)
STAHL CraneSystems GmbH SWH5302-063EX SWH5302-063EX
TWK SWH3-01 Ser 8314959 SWH3-01 Ser 8314959
coax SWG-10-BCD SWG-10-BCD
TWK SWF5B-FK-01+CRE58-4096G24CE01 SWF5B-FK-01+CRE58-4096G24CE01
TWK SWF03-B 3M SWF03-B 3M
Elbe SWC-I90A-1750 SWC-I90A-1750
ELbe SWC-I90A-1500 SWC-I90A-1500
ZANDER SWC 01 150 +G2 XP Air dryer 200 l/min to 8 bar abs. SWC 01 150 +G2 XP Air dryer 200 l/min to 8 bar abs.
LUFFT Swarco-lufft Swarco-lufft
HOHNER SWA90X-004-1X128 3# SWA90X-004-1X128 3#
SCHUNK GMBH&CO KG SWA 020-021-060 SWA 020-021-060
Datapaq SW5006-P SW5006-P
AFM SW400H-RW4-S4.2 SW400H-RW4-S4.2
SERVOMEX UK SW2000925 SW2000925
BARKSDALE SW2000-13-N-2 SW2000-13-N-2
Barksdale GmbH SW2000-0428-017+0499-016 SW2000-0428-017+0499-016
barksdale SW2000/10b/2SP/G1/4E/F 15~32VDC with Plug SW2000/10b/2SP/G1/4E/F 15~32VDC with Plug
barskdele SW2000/100BAR/1SP/4-20mA 0-100BAR SW2000/100BAR/1SP/4-20mA 0-100BAR
PRECISION SW2000 cod.0428-017 SW2000 cod.0428-017
barksdale SW2000 20B 2SP G1 2FR SW2000 20B 2SP G1 2FR
APEX SW13F-13MM45 SW13F-13MM45
APEX SW13F-13MM45
stoeber SW107.2 18M8Z224 8A/Ph SW107.2 18M8Z224 8A/Ph
alstom SW-01 SW-01
alstom SW-01 SW-01
SERVOMEX UK SW0001161 SW0001161
WANDFLUH SVYPM33-AB-G24/L15 SVYPM33-AB-G24/L15
SIE SV-X2L-LDG12 04010 SV-X2L-LDG12 04010
hofmann SVW 6134 SVW 6134
HOERBIGER SVS221BEO8PD SVS221BEO8PD
bielomatik SVS1000 SVS1000
bielomatik SVS0800 SVS0800
bielomatik SVS0630 SVS0630
bielomatik SVS0500 SVS0500
bielomatik SVS0400 SVS0400
bielomatik SVS0250 SVS0250
ETA SVS02-16-P310-L50S15E00B10 SVS02-16-P310-L50S15E00B10
ETA SVS02-12-P310-L50S15E00B10 SVS02-12-P310-L50S15E00B10
ETA SVS02-08-P310-L50S15E00B10 SVS02-08-P310-L50S15E00B10
ETA SVS02-04-P310-L50S15E00B10 SVS02-04-P310-L50S15E00B10
bielomatik SVS0160 SVS0160
Hypertac SVRA 17G NNNN 261 SVRA 17G NNNN 261
HOERBIGER SVN222BE12WDH SVN222BE12WDH
HOERBIGER SVN222BE12PDH SVN222BE12PDH
Hoerbiger SVN221BE12PD SVN221BE12PD
Hoerbiger SVN 222 BE12PDH SVN 222 BE12PDH
Sovem S.r.l. SVM/MS80B6 SVM/MS80B6
parker SVLDS46P20N SVLDS46P20N
parker SVLCV206P04 SVLCV206P04
Bosch Rexroth AG. SVL40G/10MV20C3D2H16-0 SVL40G/10MV20C3D2H16-0
single SVL21 SVL21
Hyfra SVK220/1-S, 50Hz SVK220/1-S, 50Hz
ITT Lowara Deutschland GmbH SVI4650-06N185T SVI4650-06N185T
ITT Lowara SVI3304-05 S110T SVI3304-05 S110T
ITT Lowara SVI202/20S03T SVI202/20S03T
ITT Lowara SVI1603/12S30T SVI1603/12S30T
parker SVH161S50 SVH161S50
Svendborg Brakes A/S SVENDBORG/490-2047-001/BE 3521/34/0+ SVENDBORG/490-2047-001/BE 3521/34/0+
VESTA SVE552100 24VDC SVE552100 24VDC
Rittal GmbH & Co. KG SV9343.110 250A SV9343.110 250A
KTR SV932099/ELASTOMER/ROTEX 90-98SH-A SV932099/ELASTOMER/ROTEX 90-98SH-A
becker SV7.430/1-01 4.0KW SV7.430/1-01 4.0KW
Leybold SV65B SV65B
Leybold SV65B SV65B
PARKER SV5201-8-24 SV5201-8-24
Becker Gebr. GmbH & Co. SV5.1050/1 +300mbar max.=550m3/h SV5.1050/1 +300mbar max.=550m3/h
ITT Lowara Deutschland GmbH SV4604N150T/P SV4604N150T/P
Kollmorgen Danaher SV3403-01000 SV3403-01000
Rittal SV3401.000 80A SV3401.000 80A
LOWARA SV3306F150T SV3306F150T
rexroth SV30PA3-4X SV30PA3-4X
Leybold SV300B SV300B
LEYBOLD SV300(71436200) SV300(71436200)
PRATISSOLI SV3 SV3
servida SV2316D-PB-SGG SV2316D-PB-SGG
IMAV SV2-20N-C-0-240AG SV2-20N-C-0-240AG
Dietz SV180 SV180
Vickers SV13-16-0P-0-00 SV13-16-0P-0-00
Vickers SV13-10-CM-0-240AGH SV13-10-CM-0-240AGH
IMAV SV1-16V-C-0-210AG SV1-16V-C-0-210AG
IMAV SV1-16N-C-0-240AG SV1-16N-C-0-240AG
EMG SV1-10/48/315/6 SV1-10/48/315/6
EMG SV-1-10/32/100/6 NR 226696 SV-1-10/32/100/6 NR 226696
emg SV-1-10/32/100/6 SV-1-10/32/100/6
emg SV1-10/16/315/6 SV1-10/16/315/6
CA-VERKEN SV10-21-0-N-00 SV10-21-0-N-00
Busch SV1008C SV1008C
parker SV08ZLA3C SV08ZLA3C
parker SV06ZLA3C SV06ZLA3C
riegler SV.05-882.8.D/G.0.65 G 1/4 1.50 bar SV.05-882.8.D/G.0.65 G 1/4 1.50 bar
riegler SV.05-882.8.D/G.0.65 DN 8 / G1/4 4.50 bar SV.05-882.8.D/G.0.65 DN 8 / G1/4 4.50 bar
Becker SV 5133/1 SV 5133/1
BECKER SV 5.90/1-01 SV 5.90/1-01
EMG SV 1-10/16/315/6 SV 1-10/16/315/6
BUSCH SV 1025 C MONO 230V SV 1025 C MONO 230V
DOSEURO SUS304 CE A-250N-54/112 S/N:45325 6L/MIN SUS304 CE A-250N-54/112 S/N:45325 6L/MIN
STAUFF SUS P102B24F2001253 SUS P102B24F2001253
Enerpac SURDL352E002 SURDL352E002
KUEBLER Support coupling for 8.5800.2165.2000 encoder Support coupling for 8.5800.2165.2000 encoder
HELUKABEL SUPER-PAAR-TRONIC 340-C-PUR 6*2*0.5 49853 SUPER-PAAR-TRONIC 340-C-PUR 6*2*0.5 49853
HELUKABEL SUPER-PAAR-TRONIC 340-C-PUR 2*2*0.5 49849 SUPER-PAAR-TRONIC 340-C-PUR 2*2*0.5 49849
matisec SUPERBLINDE 2000 cLASS:NF A 84.430/ AIR COMPRIME SUPERBLINDE 2000 cLASS:NF A 84.430/ AIR COMPRIME
DEHN Super (electric) pressure protector DG M WE 600 Super (electric) pressure protector DG M WE 600
ELETTRONICA SANTERNO Sunway TG610 1000VTE Sunway TG610 1000VTE
celduc relais sul867070 sul867070
Moeller Suitable for DIN-rail to EN 60715 for front mounting(216400) Suitable for DIN-rail to EN 60715 for front mounting(216400)
bender SUD472 (3AC 400V) SUD472 (3AC 400V)
bender SUD472 (3AC 230V) SUD472 (3AC 230V)
Bender SUD142 B933557 SUD142 B933557
BENDER SUD/42 SUD/42
schmalz SUC-OVA-SAOB-70x140-F3/8 SUC-OVA-SAOB-70x140-F3/8
schmalz SUC-OVA-SAOB-55x110-F3/8 SUC-OVA-SAOB-55x110-F3/8
schmalz SUC-OVA-SAOB-40x80-F3/8 SUC-OVA-SAOB-40x80-F3/8
schmalz SUC-OVA-SAOB-30x60-F3/8 SUC-OVA-SAOB-30x60-F3/8
schmalz SUC-CIR-SAB-80-F3/8 SUC-CIR-SAB-80-F3/8
schmalz SUC-CIR-SAB-60-F3/8 SUC-CIR-SAB-60-F3/8
schmalz SUC-CIR-SAB-50-F3/8 SUC-CIR-SAB-50-F3/8
schmalz SUC-CIR-SAB-125-F3/8 SUC-CIR-SAB-125-F3/8
schmalz SUC-CIR-SAB-100-F3/8 SUC-CIR-SAB-100-F3/8
REXROTH Subplate 302683(REXROTH) Subplate 302683(REXROTH)
APC SUA3000R21CH SUA3000R21CH
Bender SUA145 , AC10-30V , B93015508 SUA145 , AC10-30V , B93015508
WATT SUA 506A SA130 1:40 SUA 506A SA130 1:40
WATT SUA 506A SA130 1:10 SUA 506A SA130 1:10
JWFROEHLICH SU101 213909 SU101 213909
TRIPP LITE SU1000XLA SU1000XLA
IMO SU1/B1-0E SU1/B1-0E
siemens stype W used for motor 1LA2083-4AB1280 stype W used for motor 1LA2083-4AB1280
siemens stype C used for motor 1LA2096-1AA1190L stype C used for motor 1LA2096-1AA1190L
ELAN STW-SL-005 STW-SL-005
ZIEHL STWA2AH ACO.20A/0.100A DC4.20MA STWA2AH ACO.20A/0.100A DC4.20MA
Bender STW2 STW2
Bender STW2 STW2
single STW 150/1-24-45-KS7 STW 150/1-24-45-KS7
FRER STV S 9 SB FOR AUX.XOLYAGE STV S 9 SB FOR AUX.XOLYAGE
ABEL stuffing/box/packing/993-001/H41 Copper stuffing/box/packing/993-001/H41 Copper
alfa STu-60-2-1-mo-r-220DC-2-4-b STu-60-2-1-mo-r-220DC-2-4-b
alfa STu-40-2-1-mo-r-220DC-2-4-b STu-40-2-1-mo-r-220DC-2-4-b
alfa STu-20-2-1-mo-r-220DC-2-4-b STu-20-2-1-mo-r-220DC-2-4-b
FEMA honeywell STT171-00-BS STT171-00-BS
TOX STSB11010811 102317 STSB11010811 102317
Strothmann RoundTack Strothmann RoundTack 40 Strothmann RoundTack 40
Bornemann StromaufteilungsdrosselKDD2,5/S/600V/290A/50HZ StromaufteilungsdrosselKDD2,5/S/600V/290A/50HZ
STRAUB Straub-GRIP-L 48.3mm Straub-GRIP-L 48.3mm
ALLEN BRADLEY Stratix 8000 1793-MS067 Stratix 8000 1793-MS067
SAT STRAINER/43014517 STRAINER/43014517
MP FILTRI STR-140-2-S-G1-M90 SUCTIONFILT STR-140-2-S-G1-M90 SUCTIONFILT
MP FILTRI STR140/2SG1M90 STR140/2SG1M90
MP FILTRI D GMBH STR-100-3-B-G1-M90 STR-100-3-B-G1-M90
REBS STR 25/4/15L A/B/C/D=1.3/1/1/1.3 STR 25/4/15L A/B/C/D=1.3/1/1/1.3
STPI STPI 25949 STPI 25949
STPI STPI 245TCR-4(T2 24530035) 125VCC STPI 245TCR-4(T2 24530035) 125VCC
GIA S.p.a. STP 75 COD.085300 Pz.1 STP 75 COD.085300 Pz.1
GIA S.p.a. STP 63 COD.085200 Pz.1 STP 63 COD.085200 Pz.1
alfa STOL-60-2-1-mo-r-220DC-2-4-b STOL-60-2-1-mo-r-220DC-2-4-b
alfa STOL-40-2-1-mo-r-220DC-2-4-b STOL-40-2-1-mo-r-220DC-2-4-b
alfa STOL-20-2-1-mo-r-220DC-2-4-b STOL-20-2-1-mo-r-220DC-2-4-b
Gasbarre Stoepsel blue WPC Stoepsel blue WPC
single STO 2-D0 STO 2-D0
single STO 1-D0 STO 1-D0
single STO 1-6-12-DM STO 1-6-12-DM
MOELLER S-TO S-TO
LUKAS STNI-46 PN1600 1/4 STNI-46 PN1600 1/4
LUKAS STMU-46 PN1600 1/4 STMU-46 PN1600 1/4
berger STM40 Q15.51/8 2NL Pot435 305 171 06 STM40 Q15.51/8 2NL Pot435 305 171 06
Cooper Power Tools GmbH & Co. OHG STM34 STM34
Berger Lahr STM30/24Q15.51/6 41NLP No43530517136 STM30/24Q15.51/6 41NLP No43530517136
berger lahr STM30/24Q15 51/6 41NLP/230V 50/60HZ IP54/Nr 43530517136 STM30/24Q15 51/6 41NLP/230V 50/60HZ IP54/Nr 43530517136
WELBA STM110、24VDC STM110、24VDC
BARGER LAHR STM 6Q 5.54/8 5 NL Nr 435 2 5 170 69 STM 6Q 5.54/8 5 NL Nr 435 2 5 170 69
Martens Elektronik GmbH stm 40 stm 40
Wolverine Bronze Company STL-SAB-2010-M STL-SAB-2010-M
Wolverine Bronze Company STL-SAB-2008-M STL-SAB-2008-M
Wolverine Bronze Company STL-DAB 6000M STL-DAB 6000M
Wolverine Bronze Company STL-908RM STL-908RM
Wolverine Bronze Company STL-908LM STL-908LM
Wolverine Bronze Company STL-900RM STL-900RM
Wolverine Bronze Company STL-900LM STL-900LM
Mink-Buersten KG STL8005-238120 or STL2015-236719 STL8005-238120 or STL2015-236719
Mink-Bürsten KG STL2011-K1623 STL2011-K1623
Tellabs STL2007 STL2007
brinkmann STL141/580+001 STL141/580+001
brinkmann STL141/230-MV+211 STL141/230-MV+211
BRINKMANN STL141/230 STL141/230
HWS STK E40.42550 STK E40.42550
HWS STK E40.42544 STK E40.42544
HWS STK E39.90989 STK E39.90989
HSW STK E39.60017 STK E39.60017
HWS STK 01-85616 STK 01-85616
Brinkmann STH90/540-MV+211 STH90/540-MV+211
Honeywell STG97L-E1A-00000-00,1C,HC,SM,MB,F1 STG97L-E1A-00000-00,1C,HC,SM,MB,F1
Honeywell STG94L-E1A-00000-00,1C,HC,SM,MB,F1 STG94L-E1A-00000-00,1C,HC,SM,MB,F1
Honeywell STFF-932-E1H-0J1F0-3D (STFF-932-E1H-0J1F0-3C,,H6 HART) STFF-932-E1H-0J1F0-3D (STFF-932-E1H-0J1F0-3C,,H6 HART)
Honeywell STF924-E1A-0J1F0-3D (STF924-E1A-0J1FO-3C,H6 HART) STF924-E1A-0J1F0-3D (STF924-E1A-0J1FO-3C,H6 HART)
schmalz STF-60-P-4.5 11.04.03.10159 STF-60-P-4.5 11.04.03.10159
SED Steripur 207 E-106302-A DN4-12 EPDM / FDA Code 18 Steripur 207 E-106302-A DN4-12 EPDM / FDA Code 18
BAUTZ Stepping motor/802-D3437 F 03-5 AUSL-NR 942106500 Stepping motor/802-D3437 F 03-5 AUSL-NR 942106500
THERMONIE STEMCO 402-6178 STEMCO 402-6178
Bioengineering Stem,DN65,24Kvs,Control valve Stem,DN65,24Kvs,Control valve
spieth STELLMUTTER SPIETH MSR 24X1.5 CHECKING NUT STELLMUTTER SPIETH MSR 24X1.5 CHECKING NUT
spieth STELLMUTTER MSR 35X1.5 CHECKING NUT STELLMUTTER MSR 35X1.5 CHECKING NUT
Steimel Steimel LDM80-4S-B35EL Steimel LDM80-4S-B35EL
Sauer-Danfoss Steering OSPLX 520LS 150-7173 (Sauer-Danfoss) Steering OSPLX 520LS 150-7173 (Sauer-Danfoss)
Char-lynn/Eaton Steering 282-1013-003 (Char-lynn/Eaton) Steering 282-1013-003 (Char-lynn/Eaton)
Char-lynn/Eaton Steering :282-1004-002 Steering :282-1004-002
STRICKER STEEL5X3.6MM;TYP.S1000-GS-5-GI-SF;THICKNESS12.50+/-1MM;WIDTH STEEL5X3.6MM;TYP.S1000-GS-5-GI-SF;THICKNESS12.50+/-1MM;WIDTH
KENNEDY steel seal(figure);KEN-560-2100K kennedy steel seal(figure);KEN-560-2100K kennedy
STRICKER STEEL 5X3.6MM; TYP.S 1000- GS-5-GI-SF;THICKNESS12.50+/-1MM; STEEL 5X3.6MM; TYP.S 1000- GS-5-GI-SF;THICKNESS12.50+/-1MM;
STRICKER STEEL 14X3.1MM;TYP.S-1500-GS-13-GI-SF;LENGTH L=13500MM STEEL 14X3.1MM;TYP.S-1500-GS-13-GI-SF;LENGTH L=13500MM
STRICKER STEEL 14X3.1MM;TY.S-1500-GS-13-GI-SF;LENGTH L=9800MM STEEL 14X3.1MM;TY.S-1500-GS-13-GI-SF;LENGTH L=9800MM
Norgren STECK-30 DIN/A3-POL+E STECK-30 DIN/A3-POL+E
Stearns Stearns Brake;105603100BQF Stearns Brake;105603100BQF
Block STE2500/4/23(Trafo 2500VA 400/230V) STE2500/4/23(Trafo 2500VA 400/230V)
Honeywell STD974-E1A-00000-00,1C,HC,SM,MB,F1 STD974-E1A-00000-00,1C,HC,SM,MB,F1
Honeywell STD930-E1A-00000-00,1C,HC,SM,MB,F1 STD930-E1A-00000-00,1C,HC,SM,MB,F1
Honeywell STD924-E1A-00000-00,1C,HC,SM,MB,F1 STD924-E1A-00000-00,1C,HC,SM,MB,F1
SEW STD3016-8/2 4/2 E32/000343 STD3016-8/2 4/2 E32/000343
ATOS ST-COE-230AC ST-COE-230AC
Givatec STC-250,NR:13700300 STC-250,NR:13700300
Setra STC1SI11MR210MG1 STC1SI11MR210MG1
brinkmann STC160/580-740+314 STC160/580-740+314
brinkmann STC 160/580-MVX+314 STC 160/580-MVX+314
banner STBVP6 STBVP6
htt STB-R-230 110-240V AC 4A 0-280℃ STB-R-230 110-240V AC 4A 0-280℃
PMA STB55-5000-000 STB55-5000-000
Engelsmann STAV II STAV II
Status Pro Maschinenmesstechnik GmbH STATUS SEN1500/TC STATUS SEN1500/TC
Kiesel stator of SP10 stator of SP10
vogel STATIONARY SEAT MOUNT, NI-RESIST TYPE 2,POS.158 - 90727100 STATIONARY SEAT MOUNT, NI-RESIST TYPE 2,POS.158 - 90727100
vogel STATIONARY SEAT (XP171), POS. 383B 907281062 STATIONARY SEAT (XP171), POS. 383B 907281062
ESSKA Static mixed element 19.9mm-PTFE white Static mixed element 19.9mm-PTFE white
AGRAMKOW start=grey/stop=red 140-0000002 start=grey/stop=red 140-0000002
REXROTH STAR GR65 1805-662-61 47.5/13*75/47.5 STAR GR65 1805-662-61 47.5/13*75/47.5
EMILE MAURIN Star button M8 x 20 - 15 695 40 Star button M8 x 20 - 15 695 40
STPI STANDARD938 supporting with 280-68 DC220V STANDARD938 supporting with 280-68 DC220V
VSE Standard plug and 5 m cable Standard plug and 5 m cable
striebig STANDARD type 6206A no29491 STANDARD type 6206A no29491
SPIR STAR Stainless steel G1 / 4 internal thread , 60 ° outer cone Stainless steel G1 / 4 internal thread , 60 ° outer cone
STAHLWILLE STAHLWILLE 415SGB STAHLWILLE 415SGB
brinkmann STA607/670+001 STA607/670+001
K. H. Brinkmann GmbH & Co. KG STA601/560-52Z/-Z STA601/560-52Z/-Z
schneider STA5 B0.36/8 3N23 L STA5 B0.36/8 3N23 L
brinkmann STA460/530-870+314 STA460/530-870+314
brinkmann STA403/605-AX+198 STA403/605-AX+198
EUCHNER STA3D-2131A024MC1743 STA3D-2131A024MC1743
Berger Lahr GmbH & Co. KG STA13 B0.36/8 3N30L(230V 50HZ) STA13 B0.36/8 3N30L(230V 50HZ)
brinkmann STA1004/1000+001;Brinkmann STA1004/1000+001;Brinkmann
Staubli STA06.1101/OSHA STA06.1101/OSHA
Staubli STA06.1101/MIK STA06.1101/MIK
Staubli STA06.1101.SIL STA06.1101.SIL
BRINKMANN STA 404/700+001 No 0209800441-7068001 STA 404/700+001 No 0209800441-7068001
LAFERT ST80S6 ST80S6
Raytek GmbH ST-80 ST-80
Steinel ST7366.30.25x027 ST7366.30.25x027
Steinel ST7366.26.20x027 ST7366.26.20x027
Steinel ST7366.26.20x022 ST7366.26.20x022
Steinel ST7366.20.16x036 ST7366.20.16x036
Steinel ST7366.20.16x027 ST7366.20.16x027
Helmut Schimpke Industriekühlanlagen GmbH + Co. KG ST73-31.10FP 6204499 ST73-31.10FP 6204499
stork ST73 A/N:6204499 24VDC 3VA 250VAC 16(2.2)A ST73 A/N:6204499 24VDC 3VA 250VAC 16(2.2)A
Lafert GmbH ST71C4 0.26KW 1390r/min 380V ST71C4 0.26KW 1390r/min 380V
hilliard st718-00-03zxco st718-00-03zxco
stoerk ST710-1BAV.10FPHV2.0 PT100 ST710-1BAV.10FPHV2.0 PT100
Metrix Instrument Co ST5484E-121-412-00/4-20ma/SN:4180703 ST5484E-121-412-00/4-20ma/SN:4180703
EGE st521/1KH (1/2inch) st521/1KH (1/2inch)
RTK ST5114-17 220VAC/50Hz RE3447 0~10V IP65 ST5114-17 220VAC/50Hz RE3447 0~10V IP65
Regeltechnik Kornwestheim GmbH ST5113-35 ST5113-35
RTK ST5113-07 ST5113-07
RTK REGELTECHNIK ST5112-32 W.Nr:6102177/010 ST5112-32 W.Nr:6102177/010
Regeltechnik Kornwestheim GmbH ST5106-60 ST5106-60
PMA ST500-Ex-ia-10-5 ST500-Ex-ia-10-5
martens ST500EX-10-0-00 ST500EX-10-0-00
PMA ST500EX - 10-05-00 ST500EX - 10-05-00
PMA ST500-10-5-00 ST500-10-5-00
Stoerk ST48-WHDVM.04FP(24V) ST48-WHDVM.04FP(24V)
stork tronic ST48-WHDVM.04FP ST48-WHDVM.04FP
Stoerk ST48-IHUV.100FP(24V) ST48-IHUV.100FP(24V)
Schimpke ST48-31 02FP174730(nr6204458) ST48-31 02FP174730(nr6204458)
Stoerk ST48-31 02FP174730(nr:6204458) ST48-31 02FP174730(nr:6204458)
ABB ST4.0.1.6.1.40.D.A.1.5.C.2.E.X.0.A.A.A.1 ST4.0.1.6.1.40.D.A.1.5.C.2.E.X.0.A.A.A.1
VISHAY ST37060L2K IE3 ST37060L2K IE3
Raytek GmbH st-20 st-20
IFM ST1611 SCM12ABAFNKG ST1611 SCM12ABAFNKG
Lafert GmbH ST160LE8 NR090908 10HP/7.5kW 18.9FLA ST160LE8 NR090908 10HP/7.5kW 18.9FLA
knoll ST132SL2/5.5kw ST132SL2/5.5kw
heidenhain ST1288 38397901 ST1288 38397901
VOLLMER ST12553 ST12553
Desoutter GmbH ST1220-VcskL ST1220-VcskL
Desoutter GmbH ST1220-LowrpmVL ST1220-LowrpmVL
Rottmann Technik ST1.00SDC ST1.00SDC
Richter ST-01 ST-01
Richter Elektrotechnik GmbH & Co KG ST01 ST01
Single ST0 1-6-0-DM ST0 1-6-0-DM
EDAG ST_09_03_30 ST_09_03_30
Stemmann-Technik GmbH St. Nr. 2385 Typ: 19361430BA-4505 Nr.: 337834 St. Nr. 2385 Typ: 19361430BA-4505 Nr.: 337834
Lumberg ST. MALE 5 PIN CONNECTOR RSC 5/7 ST. MALE 5 PIN CONNECTOR RSC 5/7
MURR ST B11 Z-DIODE 3P 5M BK 3*0. ST B11 Z-DIODE 3P 5M BK 3*0.
murr ST A18 Z-DIODE 3P 5M BK 3*0. ST A18 Z-DIODE 3P 5M BK 3*0.
KNOLL Maschinenbau GmbH ST 80 S2 N G1410 ST 80 S2 N G1410
RTK REGELTECHNIK ST 5112-33 ST 5112-33
Knoll ST 1325 L2 ST 1325 L2
EGE st 101 kh st 101 kh
SSZ-GmbH SSZ-SMC 24V AC/DC SSZ-SMC 24V AC/DC
UNICONTROL ELECTRONIC GmbH S-SW-4A S-SW-4A
Rexnord SSW1000-18 899.08.21.MCC SSW1000-18 899.08.21.MCC
Rexnord SSW1000-18 899.08.10.MCC SSW1000-18 899.08.10.MCC
INAT SST-PFB-CLX-RLL SST-PFB-CLX-RLL
ALSTOM SST-PFB3-VME SST-PFB3-VME
WOODHEAD SST-PB3 CLX RLL SST-PB3 CLX RLL
dynalco SST2400A-354 0-100HZ SST2400A-354 0-100HZ
HepcoMotion SSSJ25ENS ECCENTRIC SSSJ25ENS ECCENTRIC
Hosco SSRV-4-316 SSRV-4-316
Hirschmann GmbH SSRCP 16 SSRCP 16
THK SSR20XW1UU SSR20XW1UU
Dittel SSR/AP-OA SSR/AP-OA
Hosco SSQD-6-316 SSQD-6-316
ENGLER SSPP.2.A2.B4.205.305.RST SSPP.2.A2.B4.205.305.RST
GMC-I Messtechnik SSP-240-40 SSP-240-40
M.D. Micro Detectors S.p.A. SSP/CP-1H SSP/CP-1H
M.D. Micro Detectors S.p.A. SSP/AP-1H SSP/AP-1H
LENZE SSN31-1FHCR NR.02432164 SSN31-1FHCR NR.02432164
REBS SSM2.A5.B5.350.420.6 SSM2.A5.B5.350.420.6
EES SSM16-R/110VDC SSM16-R/110VDC
REBS SSM.2.A5.B5.350.420.1.S1 SSM.2.A5.B5.350.420.1.S1
engler SSM.1B5.123.5.S1 SSM.1B5.123.5.S1
engler SSM.1.B5.550.5.S1 SSM.1.B5.550.5.S1
Berg & Co. GmbH Spanntechnik SSKE40JIS SSKE40JIS
Stromag SSG 460/8 A.Nr: 431-0062 S.Nr:10-00755-AB/146 SSG 460/8 A.Nr: 431-0062 S.Nr:10-00755-AB/146
Dittel SSE/OO-OA SSE/OO-OA
M.D. Micro Detectors S.p.A. SSC/LP-0E LOT.2510 SSC/LP-0E LOT.2510
Hosco SSBV-6-4T-316 SSBV-6-4T-316
Hosco SSBV-4T-4-316 SSBV-4T-4-316
itt SS5-7P SS5-7P
siemens SS31/6DD1688-1AC1 SS31/6DD1688-1AC1
schuf SS304 DN150 DN15 1.4/-0.1mpa SS304 DN150 DN15 1.4/-0.1mpa
MD SS3/LP-1E,03514041 SS3/LP-1E,03514041
micro Detectors SS3/LP-1E 03514041 SS3/LP-1E 03514041
BICKER SS-250FS-B1 CJ03-307100209 SS-250FS-B1 CJ03-307100209
M.D. Micro Detectors S.p.A. SS2/CP-1H SS2/CP-1H
M.D. Micro Detectors S.p.A. SS2/AP-1H SS2/AP-1H
IFE SS10-40S(R-S 400V max10A50HZ) small plate –A10 SS10-40S(R-S 400V max10A50HZ) small plate –A10
IFE SS10-40S SS10-40S
equflow SS0125 SS0125
heater SRY6-5 4KW 220V SRY6-5 4KW 220V
EA SRY6-5 4KW 220V SRY6-5 4KW 220V
FLUTEC SRVR-12-01.1/0 SRVR-12-01.1/0
Schunk SRU+30-W+180-3-VM-4 0361842 SRU+30-W+180-3-VM-4 0361842
SCHUNK SRU+30-W 361830 SRU+30-W 361830
SCHUNK SRU 20.2 357430 SRU 20.2 357430
VARVEL SRT05028 G318 SN122701 SRT05028 G318 SN122701
VARVEL SRT04020 SN122230 SRT04020 SN122230
Futaba S-RSL28X140 S-RSL28X140
SICK SRS50-HZA0-S36 SRS50-HZA0-S36
menzel SRS4/9500000002 SRS4/9500000002
VARVEL SRS02856G314 I=56 SN92406 SRS02856G314 I=56 SN92406
VISHAY SRPS 250DH 3k 9 ±5% 9830 ZA3 SRPS 250DH 3k 9 ±5% 9830 ZA3
Hypertac SROC 12T MRSN005 SROC 12T MRSN005
HYPERTAC SRNA-12V-MRSN-169 12PIN SRNA-12V-MRSN-169 12PIN
HYPERTAC SRNA-12C-MRBN-169 12PIN SRNA-12C-MRBN-169 12PIN
BERNSTEIN SRM-U1Z/U1Z-LU-175-E Nr:6012921090 SRM-U1Z/U1Z-LU-175-E Nr:6012921090
SICK srm50-hza0-s05 srm50-hza0-s05
sick SRM50-HXA0-K01 SRM50-HXA0-K01
SICK SRM50-HWZ0-S01 SICK SRM50-HWZ0-S01
SICK SRM50-HHZA0-S01 1034141 SRM50-HHZA0-S01 1034141
Wolfgang Warmbier SRM-110 SRM-110
ECKARDT SRIP90-BIMS7ZZZ-R SRIP90-BIMS7ZZZ-R
EUROMEC SRI990-BIQS7EAA-Y ,NO:06/041705 SRI990-BIQS7EAA-Y ,NO:06/041705
Foxboro SRI990-BIQS7EAA-Y SRI990-BIQS7EAA-Y
阀门定位器 SRI990-BIMS7EAA-Y SRI990-BIMS7EAA-Y
ECKARDT SRI986-BIDS7ZZZNA FABR No 49 SER No 056354 SRI986-BIDS7ZZZNA FABR No 49 SER No 056354
bucher SREZ-AB-6-1 S310C SREZ-AB-6-1 S310C
bucher SRE817/22-TV/23-HC SRE817/22-TV/23-HC
ECKARDT SRDPP1-BHFS7EA4NY-V01 SRDPP1-BHFS7EA4NY-V01
ECKARDT SRD992-B1MS7EA4 SRD992-B1MS7EA4
biax SRD8-30/2 SL SRD8-30/2 SL
BIAX SRD6-45/2 SRD6-45/2
BIAX SRD3-55/2 S SRD3-55/2 S
BIAX SRD3-55/2 SRD3-55/2
ELAN SRB-NA-R-C.39/ST2 SRB-NA-R-C.39/ST2
ELAN SRB-NA-R-C.35/WE 0.45s SRB-NA-R-C.35/WE 0.45s
Schmersal SRB-NA-R-C.20-24V SRB-NA-R-C.20-24V
schmersal SRB-NA-R-C ZHK 24V /SRB,201,ZH SRB-NA-R-C ZHK 24V /SRB,201,ZH
schmersal SRB-NA-R-C 14-24V SRB-NA-R-C 14-24V
pizzato SRBD40AN2-B02F SRBD40AN2-B02F
ATB Laurence Scott Ltd SRB3102 SRB3102
SCHLEICHER SRB.STECKFASSUNG-B7 SRB.STECKFASSUNG-B7
SCHMERSAL SRB 402 EM-24V SRB 402 EM-24V
bauer SR-A-S-230-004-S11 SR-A-S-230-004-S11
BERNARD SRA6,0.1KW,380V,3PH,50%,0.6A,50HZ,60Nm/FCS,26tr/min,11C05577 SRA6,0.1KW,380V,3PH,50%,0.6A,50HZ,60Nm/FCS,26tr/min,11C05577
ATB Laurence Scott Ltd SRA18 ND080B002 538404E265 SRA18 ND080B002 538404E265
Dayton Progress GmbH SRA 70-N.C-L 2NC 61511 4/4 NO.124 SRA 70-N.C-L 2NC 61511 4/4 NO.124
OMAL SR90 F05-F07 S526H005-NPT-SRPB;DN20;PN420 SR90 F05-F07 S526H005-NPT-SRPB;DN20;PN420
Spellman High Voltage GmbH SR6N6X2217 SR6N6X2217
MUT-Tschamber SR5D7F-45 TDSL-100 with Seal SR5D7F-45 TDSL-100 with Seal
MUT-Tschamber SR5D7F-45 TDSL-100 SR5D7F-45 TDSL-100
MUT-TSCHAMBER SR5D7F-45 TDSL-100 SR5D7F-45 TDSL-100
ITT Flygt SR4680-167721A(We need Mechanical seal repair kit) SR4680-167721A(We need Mechanical seal repair kit)
IFE SR35-38S\E303887-30\380V\50HZ\35A for SN 606-162-1403 SR35-38S\E303887-30\380V\50HZ\35A for SN 606-162-1403
OMAL SR30 F03-F05 S101H007M SR30 F03-F05 S101H007M
B&R SR2VB5HDN P92417 SR2VB5HDN P92417
M&C SR25.2 SR25.2
M&C SR25.1 EX SR25.1 EX
M&C SR25.1 SR25.1
DELTA SR-12A-E Art-Nr 815850 SR-12A-E Art-Nr 815850
Cavotec SR1-00558-000 SR1-00558-000
SR SYSTEM-ELEKTRONIK GmbH SR System-El,TFT-Display,R-FLAT 17/3-D SR System-El,TFT-Display,R-FLAT 17/3-D
Instron SR 104821 TYPE STATIC 2630-111 SR 104821 TYPE STATIC 2630-111
aquasant SQV 83/15 SQV 83/15
SIEMENS SQL36E60 SQL36E60
CELTRON SQB-2.5tCT S/N.W87408 O/P.3.0005 SQB-2.5tCT S/N.W87408 O/P.3.0005
HAWE SQ17G N.D.6920 SQ17G N.D.6920
Staubli SPX06.7152 G3/8 SPX06.7152 G3/8
Staubli SPX06.1152 G3/8 SPX06.1152 G3/8
STAUFF SPW3156 083 001 SPW3156 083 001
emg SPW2 SPW2
EMG SPW 2 SPW 2
KRACHT SPVF40A2F1A12 SPVF40A2F1A12
kracht SPVF40 E2F1A 02S13-15 SPVF40 E2F1A 02S13-15
schwarzer SPV700EC-HP NR.7E53000 230V 50HZ TP120℃ SPV700EC-HP NR.7E53000 230V 50HZ TP120℃
BIERI SPV2.5-25750 SPV2.5-25750
KRACHT SPV10A1G1A05 3bar SPV10A1G1A05 3bar
BAUER SPUR GEAR SYSTEM/G13-20/DK56-143L SPUR GEAR SYSTEM/G13-20/DK56-143L
BEKA SPULE 24V EL03270201 3WEG E-VENTIL SPULE 24V EL03270201 3WEG E-VENTIL
Hypertac SPUC 17H MRSN005 SPUC 17H MRSN005
profitec SPS12103 SPS12103
FLEXA SPR-PU-AS/DN25/ SPR-PU-AS/DN25/
BINKS SPRING/COMPMEANDIA.275"SWG21 No. 160379 BINKS SPRING/COMPMEANDIA.275"SWG21 No. 160379 BINKS
ERICHSEN GmbH & Co. KG Spring for (hardness test pencil model 318)20N Spring for (hardness test pencil model 318)20N
GUTEKUNST SPRING D-245 SPRING D-245
parker SPRA510P15S SPRA510P15S
Dr. Erich TRETTER GmbH SPR 1-320 SPR 1-320
SOFIMA SPP804TS1DPC72 SPP804TS1DPC72
AUTOROBOT SPOTTER/HP2 Nr 190155 AUTOROBOT SPOTTER/HP2 Nr 190155 AUTOROBOT
HYPERTAC SPNA-12D-FRKN-169 12 PIN SPNA-12D-FRKN-169 12 PIN
Walther SPMT120408-F55 WKP35S SPMT120408-F55 WKP35S
Walther SPMT120408-D51 WKP35S SPMT120408-D51 WKP35S
SMW SPM90A SPM90A
SMW SPM60A SPM60A
Hagglunds SPLL85A-15VDC14-30 SPLL85A-15VDC14-30
Haegglunds SPLL85A-10 SPLL85A-10
OSRAM SPL2F81-2S SPL2F81-2S
OSRAM SPL PL90-3 SPL PL90-3
Walther SPKN1504EDR WKP35 SPKN1504EDR WKP35
Grundfos SPK4-15/7 A-W-CUUV NO:C39Z92067B19948 SPK4-15/7 A-W-CUUV NO:C39Z92067B19948
WITTENSTEIN alpha GmbH SPK100/MF2/5-041-000/Patent NO 5.791.191.05 SPK100/MF2/5-041-000/Patent NO 5.791.191.05
precise technologies GmbH spindle:SC2063 spindle:SC2063
Pfaff-silberblau Hebezeugfabrik GmbH Spindle: M4,i=28,type GK Spindle: M4,i=28,type GK
SW Spindle of the machine (Machine Model : DA400-4) Spindle of the machine (Machine Model : DA400-4)
KSB Spindle 210 for pump Spindle 210 for pump
SPIETH SPIETH AM 30X1.5 MIT GEWINDESICHERUNG TENSION NUT SPIETH AM 30X1.5 MIT GEWINDESICHERUNG TENSION NUT
Haegglunds SPIDER main board 4.1.32760020-410 SPIDER main board 4.1.32760020-410
HIRSCHMANN spider 4TX/1FX spider 4TX/1FX
ATOS SP-G2-CK-80/56 SP-G2-CK-80/56
ATOS SP-G2-CK-100/45 SP-G2-CK-100/45
ATOS SP-G1-04K0093 CC-9-200/125 SP-G1-04K0093 CC-9-200/125
stuff SPG063-00400-01-S-B04 SPG063-00400-01-S-B04
stuff SPG063-00250-01-S-B04 SPG063-00250-01-S-B04
stuff SPG063-00060-01-P-B04-F SPG063-00060-01-P-B04-F
stuff SPG063-00016-01-P-B04-F SPG063-00016-01-P-B04-F
STAUFF SPG063 00100 06 P G1/4 SPG063 00100 06 P G1/4
NORGREN SPG/99172/22/ME/10 24V-DC.5Watt SPG/99172/22/ME/10 24V-DC.5Watt
NORGREN SPG/99102/6123/ME/10 24V-DC.5Watt open center SPG/99102/6123/ME/10 24V-DC.5Watt open center
MECATRACTION SPFC-3.9R SPFC-3.9R
STAUFF SPF100-00400-06-P-M08-F SPF100-00400-06-P-M08-F
ALLWEILER SPF 10RR5668.8-W16 SPF 10RR5668.8-W16
DURR SPEED SE 7C DDL M54060027 SPEED SE 7C DDL M54060027
Speck Pumpen speck pumpen V155-55.0041 speck pumpen V155-55.0041
Lumatic Specification: 20414.981 M10×1 Specification: 20414.981 M10×1
MRW special packing operator 8113 special packing operator 8113
STAUFF SPE510-1003R15M003001000 SPE510-1003R15M003001000
Stauff SPE 511954603542 SPE 511954603542
hagglunds SP-DB1-1000-378 SP-DB1-1000-378
HAGGLUNDS SPDB1-1000 with Mounting Kit SPDB1-1000 with Mounting Kit
parker SPD24 25A 12.8KW SPD24 25A 12.8KW
parker SPD23B910 SPD23B910
Hagglunds SPD1B-1000 ,With mounting accessories NO:5W406 SPD1B-1000 ,With mounting accessories NO:5W406
TR SPCP-C600-S7416-IB-P-OS3-K SPCP-C600-S7416-IB-P-OS3-K
TR-Electronic GmbH SPCP-C600-C7-416-PF-P-OS3-K SPCP-C600-C7-416-PF-P-OS3-K
SCHMALZ SPCP15SVD - SO spring for 4 (external) 9 mm (wire diamete SPCP15SVD - SO spring for 4 (external) 9 mm (wire diamete
ATOS SP-COUR-230AC/10,V=230,I=0.17A SP-COUR-230AC/10,V=230,I=0.17A
ATOS SP-CART M-5/350 SP-CART M-5/350
ATOS SP-CART M-5/210 SP-CART M-5/210
ATOS SPCA1-230/50/60/80 SPCA1-230/50/60/80
ATOS SP-C01-230/50/60/80 SP-C01-230/50/60/80
EMG SPC 16.0517 Nr.2192473 233414 1/N/PE 230V/50HZ SPC 16.0517 Nr.2192473 233414 1/N/PE 230V/50HZ
emg SPC 16.0517 SPC 16.0517
coax SPB-S 15 RA15-210/ODC 24D 24VDC 0-64BAR 204956-01 SPB-S 15 RA15-210/ODC 24D 24VDC 0-64BAR 204956-01
Oglaend System BV SPB-RF40-50 SPB-RF40-50
Oglaend System BV SPB-RF40-300 SPB-RF40-300
Oglaend System BV SPB-RF40-200 SPB-RF40-200
Oglaend System BV SPB-RF40-150 SPB-RF40-150
Oglaend System BV SPB-RF40-100 SPB-RF40-100
coax spb-h15 spb-h15
coax SPB-H 15 RA 15 210/0DC 24D 120 SPB-H 15 RA 15 210/0DC 24D 120
Ventapp SPB-4000LW SPB-4000LW
Ventapp SPB-3550Lw SPB-3550Lw
danfoss spare-pare no 02826857 vole 24v dc spare-pare no 02826857 vole 24v dc
SERVOMEX spare parts for O2 analyzer model 1100H P/N 5981-3888 spare parts for O2 analyzer model 1100H P/N 5981-3888
IBC SPANNMUTTER PR?ZISIONS-SPANNMUTTERMBA 35 TENSION NUT SPANNMUTTER PR?ZISIONS-SPANNMUTTERMBA 35 TENSION NUT
Fife-Tidland SPANNKOPF593 SPANNKOPF593
Ventapp SPA1107 SPA1107
ALPHA SPA075S-MF3-100-1E1 SPA075S-MF3-100-1E1
KUHNKE SP768.0019 24VDC 3.4W P=-0.5-0bar SP768.0019 24VDC 3.4W P=-0.5-0bar
KUHNKE SP767.3357 SP767.3357
KUHNKE SP767.025424VDC SP767.025424VDC
KUHNKE SP767.0063 SP767.0063
Montech SP-64-D-40 41133 SP-64-D-40 41133
Leybold SP630 400V/50HZ SP630 400V/50HZ
Andritz SP600-700,21.6mH20 SP600-700,21.6mH20
Andritz SP600-700, 25mH20 SP600-700, 25mH20
Andritz SP600-700, 19.6mH20 SP600-700, 19.6mH20
SPMS/EMAG SP422479XD SP422479XD
LUKAS SP310 SP310
SPONSLER SP3/4X1-MB-PHL-A-4X SP3/4X1-MB-PHL-A-4X
hawe SP3 G-ND SP3 G-ND
M&C TechGroup Germany GmbH SP-2K S/N;AS20228R SP-2K S/N;AS20228R
SMW SP280-92 SP280-92
Hagglunds SP-250-SR-V-EP-2430562 SP-250-SR-V-EP-2430562
Alpha SP210-MF2-20-011-000/SN 1547896/Art. Code 20007568 ratio:20 SP210-MF2-20-011-000/SN 1547896/Art. Code 20007568 ratio:20
M&C SP210-H SP210-H
DR.TRETTER SP20S L=350 SP20S L=350
M&C SP2000-H 230V 20S2000 SP2000-H 230V 20S2000
Spirax Sarco SP2 SP2
SPONSLER SP1-MB-PHL-A-6X SP1-MB-PHL-A-6X
Leroy Somer SP1-9,SPM,MP Drive Number:2214-1007-03 SP1-9,SPM,MP Drive Number:2214-1007-03
HAGGLUNDS SP-180-SR-V-EP-2433977 SP-180-SR-V-EP-2433977
EMOD SP180L/4WU 28/34KW 380V S3-40%/15% 8111622 SP180L/4WU 28/34KW 380V S3-40%/15% 8111622
WITTENSTEIN alpha GmbH SP140S-MF2-28-1EO SP140S-MF2-28-1EO
alpha SP140S-MF1-10-0K1 SP140S-MF1-10-0K1
EMERSON SP1405 3.0/4.0KW SP1405 3.0/4.0KW
KIESEL SP10F/1/B Power 1.5KW Flow 1200L/MIN Speed?? 1440r/min SP10F/1/B Power 1.5KW Flow 1200L/MIN Speed?? 1440r/min
alpha SP100S-MF2-50-1E1 SP100S-MF2-50-1E1
WITTENSTEIN SP100S-MC1-3-1G1-2K i=3 SN.2268886 SP100S-MC1-3-1G1-2K i=3 SN.2268886
Alpha Getriebebau GmbH SP100-MXI-4 163846 MAX.4500 SP100-MXI-4 163846 MAX.4500
BBH SP100.02/PB SP100.02/PB
LUKAS SP0816.03A brasive material RKD SP0816.03A brasive material RKD
WITTENSTEIN SP075S-MF1-7-1G0 MPL-B4540F SP075S-MF1-7-1G0 MPL-B4540F
airtec SP011-G;24V4.2W;175mA 10bar 100%ED SP011-G;24V4.2W;175mA 10bar 100%ED
airtec SP011 24V 4.2W SP011 24V 4.2W
WALTHER-PRAEZISION sp-006-2wr017-11-2 sp-006-2wr017-11-2
WALTHER SP-006-1-WR513-11 SP-006-1-WR513-11
WALTHER-PRAEZISION sp-006-0wr017-11-2 sp-006-0wr017-11-2
VOGEL SP/SMB 8/24-1883-3005-2007 SP/SMB 8/24-1883-3005-2007
VOGEL fluidtech SP/SFE30/5 SP/SFE30/5
JAKOB SP Code 10100165910 6m SP Code 10100165910 6m
JAKOB SP Code 10080165910 6m SP Code 10080165910 6m
Hagglunds SP 355 SR-V-EP-2430560 SP 355 SR-V-EP-2430560
ALPHA SP 180S-MF1-10-0K1-2 SP 180S-MF1-10-0K1-2
SAACKE SP 150 flame scanner fls 09-uv for SKV J-M SP 150 flame scanner fls 09-uv for SKV J-M
wandres SP 14 WS SP 14 WS
SAACKE SP 115 ignition electrode block for SKV J-M SP 115 ignition electrode block for SKV J-M
SAACKE SP 104 Poly-v-belt(60Hz) for SKV J-M SP 104 Poly-v-belt(60Hz) for SKV J-M
ALPHA SP 100S-MF2-50-1C1 GearBox SP SP 100S-MF2-50-1C1 i=50 SP 100S-MF2-50-1C1 GearBox SP SP 100S-MF2-50-1C1 i=50
WITTENSTEIN alpha GmbH SP 100S MF1-4 1E1-2S SN:2095795; DMF:47/08 SP 100S MF1-4 1E1-2S SN:2095795; DMF:47/08
alpha SP 100-MF2-28-111-000 SP 100-MF2-28-111-000
alpha SP 100-MC1-10-151-000 20013909 SP 100-MC1-10-151-000 20013909
ALPHA SP 060S-MF2-20-1C1 Gearbox SP060S-MF2-20-1C i=20 26 Nm SP 060S-MF2-20-1C1 Gearbox SP060S-MF2-20-1C i=20 26 Nm
Buhler SP 04 G/03;63-003-05;Schlauch 3,2*1, 9124030104 SP 04 G/03;63-003-05;Schlauch 3,2*1, 9124030104
metal work SOV36SOSOC 220V SOV36SOSOC 220V
METAL WORK SOV 35 SOS 00 G1/4in 220VAC 50HZ SOV 35 SOS 00 G1/4in 220VAC 50HZ
HASLER Sound1 Sound1
Comax Signaltechnik AG SOP.024.26 SOP.024.26
ELmo SOL-WHI15/60E04 SOL-WHI15/60E04
LEROY SOMER Solution SP Syn IO 10 U8 Solution SP Syn IO
J.P.SAUER&SOHN SOLENOID VALVE;037 6802;STARTING AIR COMPRESS SOLENOID VALVE;037 6802;STARTING AIR COMPRESS
Leybold SOGEVAC SV30B SOGEVAC SV30B
Leybold SOGEVAC SV25B SOGEVAC SV25B
FAGOR Software options Software options
Sankyo SOBF 16-22-15 SOBF 16-22-15
Sankyo SOB 30-40-50 SOB 30-40-50
Sankyo SOB 25-33-30 SOB 25-33-30
Sankyo SOB 15-21-20 SOB 15-21-20
Sankyo SOB 10-14-15 SOB 10-14-15
VECTOR SOA-H1T1 Waterproof SOA-H1T1 Waterproof
LEROY-SOMER SO6 PMB 500-S SO6 PMB 500-S
STW SO4-54227 SO4-54227
KEB SO2CVDL71K4/0.25KW vertical SO2CVDL71K4/0.25KW vertical
Serto SO NV31A21E-6-6 SO NV31A21E-6-6
serto SO 6240-15-12/3/4 INCH/BALL VALVE SO 6240-15-12/3/4 INCH/BALL VALVE
serto SO 6240-15-12/1/4 INCH /BALL VALVE SO 6240-15-12/1/4 INCH /BALL VALVE
serto SO 6240-15-12/ 1.5INCH/FEMALE/FEMALE /BALL VALVE SO 6240-15-12/ 1.5INCH/FEMALE/FEMALE /BALL VALVE
serto SO 6240-15-12 /ST 37/OD 15 X 12 MM/WP 160 BAR SO 6240-15-12 /ST 37/OD 15 X 12 MM/WP 160 BAR
serto SO 6240-15-12 /1/2 INCH /BALL VALVE SO 6240-15-12 /1/2 INCH /BALL VALVE
serto SO 6240-15-12 3/8 INCH /BALL VALVE SO 6240-15-12 3/8 INCH /BALL VALVE
serto SO 46221-10-10 SO 46221-10-10
SERTO SO 37421-6 PA, PN10 f.Schlauch 6x4 SO 37421-6 PA, PN10 f.Schlauch 6x4
serto SO 1011 (INCH)/ OD 10 MM INCH /WP64BAR/ NO 04.4501.010 SO 1011 (INCH)/ OD 10 MM INCH /WP64BAR/ NO 04.4501.010
Serto SO NV 21N21-12/9-12/9 PTFE SO NV 21N21-12/9-12/9 PTFE
Wieland SNZ4052K SNZ4052K
FAG SNV140-L+22216E1+DH216+FRM140/12.5+DKV140 SNV140-L+22216E1+DH216+FRM140/12.5+DKV140
Telco SNR6306 SG T3 0804 SNR6306 SG T3 0804
STW SNR05 016885 33 output.0-16bar 4-20mA SNR05 016885 33 output.0-16bar 4-20mA
KEB S-Nr:300072154/1020010 Mat.NO:07F5B3A-0A0A S-Nr:300072154/1020010 Mat.NO:07F5B3A-0A0A
AERZENER SNR:160 755 002 SNR:160 755 002
AERZENER SNR:123 482 000 SNR:123 482 000
danaher s-nr:00820313874S3030 s-nr:00820313874S3030
SNR Waelzlager GMBH SNR ZLG316AC 1 SNR ZLG316AC 1
DRUMAG SNR 4083544.10.0.5 Typ 80 ZLS-3099117 060684099 SNR 4083544.10.0.5 Typ 80 ZLS-3099117 060684099
danaher S-NR 073912799 S-NR 073912799
danaher S-NR 071316327 S-NR 071316327
Sauer SNP3NN/055RN01BAP1F6F6NNNN/NNNNN SNP3NN/055RN01BAP1F6F6NNNN/NNNNN
Sauer-Danfoss SNP2/11 DSC 06 REP G,Art-Nr:111.20.186.00 SNP2/11 DSC 06 REP G,Art-Nr:111.20.186.00
SAUER DANFOSS SNP 2NN 1011RN01BA P1C3C3NNNN/NNNNN SNP 2NN 1011RN01BA P1C3C3NNNN/NNNNN
EUCHNER SNO3D12-2514-M SNO3D12-2514-M
renishaw S-No.9U1550 S-No.9U1550
renishaw S-No.07F077 S-No.07F077
MR S-No.:1047143 Typ:DU III 2022-170-06 05 0ME S-No.:1047143 Typ:DU III 2022-170-06 05 0ME
Sandvik SNMM250724-QR4215 SNMM250724-QR4215
skf SNH515-612 SNH515-612
Z-LASER SNG-HD-4-3.5V PRI.AC85-265V PRI.AC60mA V Ser.Nr.:021362 SNG-HD-4-3.5V PRI.AC85-265V PRI.AC60mA V Ser.Nr.:021362
ALLWEILER SNG40R38 0A-W61 ID:S7014089/S7014090 SNG40R38 0A-W61 ID:S7014089/S7014090
ALLWEILER SNF440ER46U3-W1-FA5.0 PN16/PN40+DS44A-8%ANF SNF440ER46U3-W1-FA5.0 PN16/PN40+DS44A-8%ANF
ALLWEILER AG SNF1300ER42-U12.1W1 Nr.11019118 SNF1300ER42-U12.1W1 Nr.11019118
ALLWEILER AG SNF1300ER38 U12.1W1 Nr.11061426 SNF1300ER38 U12.1W1 Nr.11061426
Wieland SND4003K SND4003K
stauff SNA254B-S-T-10 SNA254B-S-T-10
Stauff SNA-254-B-N SNA-254-B-N
Ruhrgetriebe SN9FLV 50:1 27Nm SN9FLV 50:1 27Nm
Ruhrgetriebe SN9FLV 25:1, 24.4Nm SN9FLV 25:1, 24.4Nm
Bernard Controls Deufra GmbH SN6-46 0.5KW 380V 1.6A 46r/min SN6-46 0.5KW 380V 1.6A 46r/min
VEGA SN61.XXAGHKMXX power.supply 16-36v 4-20mA ord.no.112663/00 SN61.XXAGHKMXX power.supply 16-36v 4-20mA ord.no.112663/00
vega SN61.XXAGHKMX SN61.XXAGHKMX
ELAFLEX SN544NB25x630 SN544NB25x630
ELAFLEX SN544NA20x1250 SN544NA20x1250
wandfluh SN-445D-M29-40 SN-445D-M29-40
Leroy Somer Marbaise GmbH SN3s7200lk01 SN3s7200lk01
Rexroth SN2-GM160/110-1850Dh SN2-GM160/110-1850Dh
Ruhrgetriebe SN2F ,25:1 ,18Nm SN2F ,25:1 ,18Nm
rollon SN28-210-280-530 SN28-210-280-530
coax SN-253-SB1002 SN-253-SB1002
mel SN1208013 M2-ICW-75/30/40 SN1208013 M2-ICW-75/30/40
EGE SN10544 SN10544
EMB SN0-G20-S SN0-G20-S
Euchner SN08R12-514-MC1985 SN08R12-514-MC1985
QASS Sn0078.07 CPU1.2 Sn0078.07 CPU1.2
WILDEN SN:PSG0095922, ITEM:04-0122 SN:PSG0095922, ITEM:04-0122
Wittenstein AG(alpha) SN:2291193 LP 090-M01-10-111-000 DMF:16/10 SN:2291193 LP 090-M01-10-111-000 DMF:16/10
SN:2101303373 SN:2101303373 JOB NUMBER:6372.17
hohner SN:151102 PN:E3A19A/A0 SN:151102 PN:E3A19A/A0
Aerzener SN:1027911 CODE:034420 GMa13 F7 HV Stage SN:1027911 CODE:034420 GMa13 F7 HV Stage
Indukey SN.634227773 KS08273 SN.634227773 KS08273
coax sn.528407 sn.528407
维修排除.找徐工13913148881 给你最低的价格及最快的服务 苏州三岩芯电子科技前身为苏州工业园区三源芯辉电子科技有限公司,是一家致力于电子应用
技术与维修的一家高新技术企业,三源电子始创于1995年服务于电子半导体产业和化工业、机
械制造业及军工产业设备的维修与维护。我司技术力量雄厚,主要技术人员均来自各电子工程
研究所和研究院,现有维修工程师14人,业务工程师11人,客服人员3名。我公司在电子工程
、通信、微波、毫米波、自动控制、信号处理、无线电计量、电子结构、高精度传动结构等高
新技术领域的开发应用有着较强的技术实力。我司始终保证维修的电路板品质和新板如一,真
正的为客户创造价值、节省费用,实现“设备永续、设备无忧”,为客户设备的正常运行提供多
方位全程保障,以优质、快捷、可靠的专业电路板维修服务为用户赢得生产、配送和运营的宝
贵时间,提高企业应对市场灵活变化的需要。
公司主营品牌:ABB、AB、西门子、FOXBORO、霍尼韦尔、施耐德(MODICON)、OMEGA、
BALDOR 、瑞恩
北美部:提供罗克韦尔AB,Honeywell霍尼韦尔,OMEGA欧米茄,莫迪康(modicon),BALDOR葆德
电机,波斯顿BOSTON,GE,丹纳赫-科尔摩根,安捷伦Angilent,N-TRON恩畅交换机,SST、红狮,
派克液压,泰克,FLUKE福禄克,邦纳,巴士德,ASCO,巴斯曼BUSSMANN,艾默生,ACOPIAN ,
HUBBELL,威格士,SQUARE-D ,瑞恩RELIANCE ,MTL,MAGNETEK,西屋Westinghouse,思科,
ACME、S+S,KAMAN,SOLA,颇尔 power-one,SOR
欧洲部:伦茨 赫斯曼 E+H P+F 威托 aron 霍伯纳 沃申道夫 康茂盛
亚太部:三菱,横河,欧姆龙,安川,日立Hitachi, 东芝TOSHIBA 多摩川
产品详细信息及其订购,欢迎来电查询!
将会给您优质的服务!优惠的价格!
用诚信的心,真诚的为您服务!
通过中国触摸屏网金牌会员认证
