可直接用条码秤纸打印。
Print method: Thermal line printing
Print speed: 速度127mm/sec. (Max.); 101mm/sec. (Min.)
Paper width: 16mm~82mm 纸宽
Dot density: 203dpi(8dots/mm)
Interface: Parallel/RS232C+USB,网口,并口,串口,usb口
Reliability print: 100Km
Power supply: DC 24V
Cash Drawer: DC 12-24V/1A
Temperature: 0~50oC
Paper thickness: 0.06~0.08mm
Dampness: 10~80%
Barcode mode:
CODE128, EAN128, ITF, CODE39, CODE93, EAN13,
EAN13+2, EAN13+5, EAN8, EAN8+2, EAN8+5,
CODABAR, POSTNET, UPC-A, UPCA+2, UPCA+5,
UPC-E, UPCE+2, UPC-E+5, CPOST, MSI, MSIC,
PLESSEY, ITF14, EAN14
Drivers:Win9x/WinME/Win2000/WinNT/WinXP/Vista
Print command: compatible with TSC command set
External dimension:220*150*150mm( L*W*H)
