移印PP油墨,PP移印油墨,PP油墨
品牌: 欧莱斯
型号: SPPA
规格: 1千克
单价: 180.00元/千克
起订: 1 千克
供货总量: 10000 千克
发货期限: 自买家付款之日起 2 天内发货
所在地: 上海
最后更新: 2013-05-14 07:53
油墨特性: 拥有和德国彩丽宝一样的颜色,主要用于PP、PE、BOPP等材料上,具有高色泽、高色彩、高遮盖力、高稳定性、耐酒精及耐磨擦之特点。 印刷:丝印移印均可。 表干及实干时间:表干时间自然挥发5-10分钟;实干时间在24小时以内。 稀释及清洗:SV3慢干开油水、UVK1(移印开油水)同时可使用718洗网水清洗。 测试方法(完全干燥后): 1、3m胶纸粘在画有百格的油墨表面,45度角迅速拉起不脱油; 2、纯度99%的工业酒精,一千克砝码用棉布包住在油墨表面,以水平力来回拉200次无脱色; 3、 耐磨:橡皮擦500g力水平来回擦500次。 使用方法: 1、使用前应充分搅拌,用后随时封闭; 2、搅拌时加开油水10-15%,稀释到印刷粘度; 3、网板塞网时可用洗网水清洗; 4、不得与其它类型油墨混合使用。 注意事项: 1、塑胶材料的外观相似,但可能会是不同的材料,客户需试印确定其符合要求后,再批量印刷; 2、在移印过程中,如出现拉丝或散开,可适当加入一些慢干膏即可; 3、环境温度过高,将会影响油墨原有质量; 4、根据气候变化,请远离火源,阴暗环境下存放。 The characteristics of ink:Have and Germany Caili treasure the same color, is mainly used for PP, PE, BOPP and other materials, with a high color, high color, high covering power, high alcohol and wear resistance, high stability.Printing: silk screen printing can be.Table dry and work time: surface dry time natural volatile 5-10 minutes; work time within 24 hours.Dilution and cleaning: SV3 slow dry open water, UVK1 ( printing open water ) can be simultaneously used 718 washing network water cleaning.Test method ( completely dry):1, 3M gummed paper with ink surface adhesion in the painting, the 45 degree angle quickly pulled off the oil;2, purity 99% of industrial alcohol, one kilogram of weight of cotton pack in the ink surface, the horizontal force and pull 200 times without decolorization;3, wear resistance: the eraser 500g force level wipe 500 times back and forth.Method of use:1, before the use should be fully mixing, use at any time after the closure;2, mixing an additional 10-15% in oil and water, diluted to printing viscosity;3, mesh plug mesh can be used when washing network water cleaning;4, shall not be mixed with other types of ink.Matters needing attention:1, the plastic material similar in appearance, but may be of different materials, customers need to try to determine its requirements, and then batch printing;2, in the printing process, such as drawing or spread out, may be appropriate to add some cream to slow drying;3, the ambient temperature is too high, it will affect the quality of the original ink;4, according to the climate change, please stay away from fire, stored in a dark environment.
免烘烤金属自干油墨 免烘烤自干金属油墨 供应耐冲压金属油墨,耐冲压金属油墨,金属油墨 耐高温金属油墨-供应耐高温金属油墨 PP免处理油墨,免处理PP油墨,PP油墨 丝印PP油墨,PP丝印油墨,PP油墨 移印PP油墨,PP移印油墨,PP油墨 PE免处理油墨/免处理PE油墨/PE油墨
