| De |
XPM200, 24 VDC, USB, 203 DPI XPM200-S2U24I-P0R11000-TS0-DFP1-0200-000 |
| Technology | Direct Thermal |
| Paper width | 210-220 mm |
| Print witdh | 216 mm |
| Resolution | 203dpi |
| Interface | USB |
| Voltage | 24 VDC |
| Cutter | Standard Pizza-cutter type |
| Environmental | 0ºC - +50ºC, 25% - 80% RH, without condensation |
| Print speed | up to 150 mm/sec |
| Output type | Standard Output Type |
| PPE Sensor | No Paper Pre-End Sensor included |
| Sleep Mode | Sleep Mode not included |
| Presenter | Metis Bundler |
| Barcode scanner | No |
| Paper entry sensor 1 | Reflex sensor Pos. 11 |
| Paper entry sensor 2 | none |
| Controller | XPM / TPM Controller |
| Connector location | Standard |
| Feeder | Double Feed Unit |
| Presenter bundler | Metis Bundler |
| Printer chassis+paper roll holder | Metis Chassis |
| Extended warranty | none |
| Special | No |
