万利涛电子材料有限公司常年供应韓国进口卷装SKC 绝缘PET SB00黑色.原包装上附有SKC公司的原装出厂标签(保証原装合格货)厚度为:0.05mm/0.075mm/0.1mm/0.125mm/0.188mm.(不透光)具有SGS認証合于歐盟ROHS环保要求,可提供MSDS及性能測试表.
欢迎各商界朋友來电查詢.15818637711谢生 QQ:361858021
SKC Skyrol SB00
基材:PET
表面顏色:黑色 厚度規格:25μ,38μ,50μ,75μ,100μ,125μ,175μ,188μ |
Skyrol SB00 is a black polyester film with low contents of carbon black. It has high optical density, so light can hardly be transmitted through. And it has no large surface protrusion. SB00 is applicable in various industrial applications including speaker vibrator, drum and ETC. It is available in the thickness ranging from 25um up to 188um.
Property
Unit
Value
Gauge
#500
Thickness (ASTM D882)
MMV
μm
125
Tensile strength (ASTM D882)
MD
Kg/mm2
17
TD
Kg/mm2
22
Elongation at Break (ASTM D882)
MD
205
TD
110
Shrinkag (ASTM D1204)
MD
1.1
TD
0.2
Gloss (ASTM D523)
90
Light Transmission (ASTM D1003)
0
Dielectric Strength (ASTM D527)
kV
17
