GENERAL ELECTRIC C781N406 400 Watt BALLAST, NNB
MODICON DEP 209 INPUT MODULE, NIB
ASI ACH28X1U ROTARY COMPRESSOR, NIB, SEALED
COPELAND JRN1 0025 IAA-958 HERMETIC COMPRESSOR, NIB, SE
COPELAND JRL4-0100-PAV-900 HERMETIC COMPRESSOR, NIB, SE
AMP-TRAP 600V AJT1 TIME DELAY FUSE LOT OF 23 IN BAG
NEC Multisync 1550VM LCD MONITOR
ALLEN BRADLEY 1792D-48VT4D SERIES B ARMOR BLOCK MAXUM I
NSK LH55 LINEAR GUIDE, 8" X 4" 2.5", NNB
VICKERS DG4V-3-2C-M-FTW-B6-60, DIRECTIONAL VALVE, 1/2"
BALLUFF, BES-516-705-U1.1,PROX SWITCH CONTROLLER, 120 V
ALLEN BRADLEY 1494V-DS30 NON-FUSIBLE DISCONNECT SWITCH
NUMATICS F608C-06 3/4" PORT 300 PSIG PNEUMATIC AIR FLOW
SENSOTEC 060-3147-01 0-5 VDC DIGITAL INDICATOR
CONTINENTAL HYDRAULICS VS5M-3F-GB-60L-J, DIRECTIONAL VA
NUMATICS S32C-04BKMP SOFT START VALVE, 1/2" NPT, 24 VDC
ALLEN BRADLEY 1794-0B16 24VDC SOURCE OUTPUT
SQUARE D CLASS 9007 A0-1 INDUSTRIAL SNAP SWITCH, LOT OF
BARKSDALE CONTROLS 305H3-14CG-11-L 4000 PSIG 12-67 VDC
INTERMEC 1470 BAR CODE SCANNER, NNB
PARKER, CJ2ATV14C, HEAVY DUTY PNEUMATIC CYLINDER, 2" BO
FANUC A03B-0819-C154 #D AOD 16D I/O MODEL A, NIB
KEYSTONE F79U-065U PNEUMATIC ACTUATOR, NIB
NORDSON HP051 / HP05I-NN15-2506-852 PRECISION FLOW UNIT
NUMATICS 554BA43AM000061 SOLENOID PILOT ACTUATED VALVE
CONE DRIVE MHU25-1, GEAR REDUCER, 10:1, 1800 RPM, NNB
MILLER 178103, CABLE, 14-PIN MALE/FEMALE PLUG, 30 FT, N
LARCO ZONE MONITOR 3000, 120/240 VAC, 24 VDC, 1 PH, 0.1
ROTOREX, K48A111AS-DOML, AC COMPRESSOR, 115 V, 56.6 LRA
ALLEN BRADLEY 837 A3A TEMPERATURE CONTROLLER, NIB
SIEMENS SIMATIC S7 PLC SERIAL INTERFACE MODULE 6ES7 138
ALLEN BRADLEY F 87 033 2.5 VOLT LITHIUM BATTERY, LOT OF
LAMINA SCB200S SC STYLE SELF LUBE BRONZE BUSH. INCLUDES
