* 高度的适应性不受电流、电压和静电干扰,适宜某些恶劣的环境条件
* 高透光性无中间介质,高透光性,最高可达100%
* 使用寿命长高度耐久,不怕刮伤;触摸密度可达4096*4096,触控寿命极长
* 使用特性好触摸无需力度,对触摸体无特殊要求,无
论触摸物是否是硬物、触摸物是否导电,都不影响正常使用;
*铝合金框颜色:拉丝氧化亮黑、喷漆闪银灰(可选)
| 尺寸 | 型号(点击查看图纸) | 类型 | 厚度 (mm) |
外形尺寸(mm) | 无碍可视区(mm) | 有效触摸区(mm) | |||
| X | Y | X | Y | X | Y | ||||
| 19" | EIR-019.0-A-U | 19"LCD | 10.4 | 478.4 | 325.4 | 416.2 | 263.2 | 412.0 | 259.0 |
| EIR-019.0-A-R | 10.4 | ||||||||
| EIR-019.0-A3C-U | 13.4 | ||||||||
| EIR-019.0-A3C-R | 13.4 | ||||||||
| EIR-019.0-A4CS-U | 14.4 | ||||||||
| EIR-019.0-A4CS-R | 14.4 | ||||||||
| 18.5" | EIR-018.5-A-U | 18.5"LCD | 10.4 | 475.4 | 296.8 | 413.4 | 234.8 | 411.4 | 232 |
| EIR-0185-A-R | 10.4 | ||||||||
| EIR-018.5-A3C-U | 13.4 | ||||||||
| EIR-018.5-A3C-R | 13.4 | ||||||||
| EIR-018.5-A4CS-U | 14.4 | ||||||||
| EIR-018.5-A4CS-R | 14.4 | ||||||||
| 21.6" | EIR-021.6-A-U | 21.5"LCD | 10.4 | 537.2 | 327.8 | 475.2 | 266.2 | 471.2 | 263.2 |
| EIR-021.6-A-R | 10.4 | ||||||||
| EIR-021.6-A3C-U | 13.4 | ||||||||
| EIR-021.6-A3C-R | 13.4 | ||||||||
| EIR-021.6-A6CS-U | 16.4 | ||||||||
| EIR-021.6-A6CS-R | 16.4 | ||||||||
| 22" | EIR-022.0-A-U | 22"LCD | 10.4 | 536.8 | 358.8 | 474.6 | 296.6 | 470.4 | 292.4 |
| EIR-022.0-A-R | 10.4 | ||||||||
| EIR-022.0-A3C-U | 13.4 | ||||||||
| EIR-022.0-A3C-R | 13.4 | ||||||||
| EIR-022.0-A6CS-U | 16.4 | ||||||||
| EIR-022.0-A6CS-R | 16.4 | ||||||||
| 23" | EIR-023.0-A-U | 23"LCD | 10.4 | 585.6 | 351.6 | 523.4 | 289.4 | 519.2 | 285.2 |
| EIR-023.0-A-R | 10.4 | ||||||||
| EIR-023.0-A3C-U | 13.4 | ||||||||
| EIR-023.0-A3C-R | 13.4 | ||||||||
| EIR-023.0-A6CS-U | 16.4 | ||||||||
| EIR-023.0-A6CS-R | 16.4 | ||||||||
| 23.6" | EIR-023.6-A-U | 23.6"LCD | 10.4 | 588.6 | 360.4 | 526.4 | 298.2 | 522.2 | 294.0 |
| EIR-023.6-A-R | 10.4 | ||||||||
| EIR-023.6-A3C-U | 13.4 | ||||||||
| EIR-023.6-A3C-R | 13.4 | ||||||||
| EIR-023.6-A6CS-U | 16.4 | ||||||||
| EIR-023.6-A6CS-R | 16.4 | ||||||||
| 24" | EIR-024.0-A-U | 24"LCD | 10.4 | 585.6 | 389.2 | 523.4 | 327 | 519.2 | 322.8 |
| EIR-024.0-A-R | 10.4 | ||||||||
| EIR-024.0-A3C-U | 13.4 | ||||||||
| EIR-024.0-A3C-R | 13.4 | ||||||||
| EIR-024.0-A6S-U | 16.4 | ||||||||
| EIR-024.0-A6S-R | 16.4 | ||||||||
| 26" | EIR-026.0-A-U | 26"LCD | 10.4 | 642.1 | 388.4 | 579.9 | 326.2 | 575.4 | 322 |
| EIR-026.0-A-R | 10.4 | ||||||||
| EIR-026.0-A3C-U | 13.4 | ||||||||
| EIR-026.0-A3C-R | 13.4 | ||||||||
| EIR-026.0-A6CS-U | 16.4 | ||||||||
| EIR-026.0-A6CS-R | 16.4 | ||||||||
| 第1页 下一页 共3页 | |||||||||
| 042.0 表示尺寸;A 表示 铝合金外框;C 表示普通玻璃;6CS 表示防暴玻璃;U 表示USB接口;R 表示COM接口;3,4,6mm 表示玻璃厚度 | |||||||||
| 触摸屏分辨率 | 4096×4096 |
| 透光率 | 加装强化玻璃,光学透光率大于90%;未加装玻璃体,光学透光率100% |
| 扫描速率 | >50Scans/S |
| 响应速度 | <12ms |
| 触摸点精度 | 0.625mm |
| 最小触摸体 | >=5mm |
| 耐久度 | >承受超过60,000,000次以上的单点触摸 |
| 适用操作系统 | DOS、WINDOWS9X/ME/2000/XP/2003/VISTA、LINUX |
| 工作电压 | DC 5V ±5% |
| 供电方式 | 键盘口 |
| 功率 | <1W (工作电流<200mA) |
| 通信方式 | RS-232、USB |
| 抗光性 | 全角度抗强光照射 |
| 防暴性 | 防暴玻璃(玻璃厚度6mm),用质量1kg表面光滑的钢球,1米的高度自由落下,屏体无损 |
| 通信方式 | RS-232、USB |
| 工作温度 | -41°C ~70°C |
| 贮存温度 | -50°C ~85°C |
| 海拔高度 | 3000米 |
| 噪音 | 无 |
| 漂移 | 无漂移,不随环境产生变化 |
