微型无风扇 支持高清播放,大屏壁挂式一体机的首选
| System information: | Technical Data: | ||
| CPU Type: | Intel Atom N2600 core Duo 1.6GHz | Dimensions: | 213.5x124x62.4mm |
| Graphics: | Support Directx 10.1 compliant pixel shader and OGL 3.0 | Material: | Aluminum |
| Memory: | On board 2G DDR3 | Color: | Black |
| Hard Disk: | 2.5inch/CF | Weight: | 0.8kg |
| Display Port: | VGA+HDMI | ||
| IO Ports: | USBx2,RS232 x2(option) | ||
| LAN: | 10/100/1000Base-TX RJ45 x1 | ||
| LED: | Power Button with blue LED | ||
| DC-Input: | External 12V/5A adapter | ||
| Support OS: | Windows 7,XP,linux | ||
| Operation Temp: | -25-65℃ | ||
| Operation Humidity: | 5-95%,non-condensing |
