01-18368
802-00205-19
P03-208385
03-20717
02-16649 REV:A
ASM
802-00281 REV:A
ASM
ASM
802-00254 REV:C
ASM
ASM
01-18368 REV C
ASM
ASM
802-00206 REV:D
ASM
ASM
802-00205 REV-B
ASM
ASM
03-20742-02 REV B-P1
ASM
ASM
03-20717 REV D
ASM
ASM
03-20601 REV D-P3
ASM
4504B500B1N3
MHD 093C-035-NG0-AN
K01450682 6800uf 450vdc 76*143
D282A
KK10-BCV-423 L328
WK5007904 KE 70-20
66RNS1011251213
D-143B, Pressure spring 0,9x10x29,1
VD-143A, Pressure spring 1,25x11,25x29,5
D-192
BZFM 1.6V 11 Art:401-03516
MP5.4-H37
CN-87.213.050 End-User: Huaneng Luohuang Power Plant
4740AWY2XOB0
KSM301660-5
KSM036438
KSM313720-5
KSM036457-5
OTT RLS Radarsensor zur Wasserstandsmessung Ausgang SDI-12
Flowmeter: FLOWTEST 3925-0160 INCL. PROFIBUS DP interface
Lockable, glazed front door
Special paint different from standard RAL 7035
Maintenance unit Filter regulator with presure gauge Fine filter with automatic condensate drain
UR-5-2 10-30V/5.5W 4605814
9323A/5073A111
B420B-XMD-NN-RN-JL-1400KP
SC1DD2315
JK9000N1/TELIS9000U1 (Temperature sensors + instrument + wiring base)
4.3820.01.310 0810132
1694.915215 0-1600Pa
Art.Nr:02.01.117
7KG2131-1UN21-0AA0
7KG6113-2BN21-0B
7KG6113-2AN24-OB
7KG2131-1BN21-0AA0
2.2-DF-88-22 FILTERN
S037SKVR1261.5SS(D12X2/d6x1.5)
S037SKVR16122SS(D16X2/d12x2)
VPB-B/12/6/0/0/20/20/20/20/20/20/V
GMF-B/25/60/N/0/0/1/0/0/8/0/1/K:400V/50HZ
3236433
3236233
3236333
3236133
1029700A
200-510-SSS-1Hh MPC4
200-560-SSS-1Hh IOC4T
200-124-000-02X-A2-B3 GSI124
204-040-100-012
200-582-X00-013
200-595-OSS-32h
200-566-000-1Hh IOC-N
200-582-911-02h
200-582-916-01h
200-124-000-02X-A2-B2 GSI124
VCO,2F1PS 285710/10-1 G-90
CDT3ME5/63/45/25/Z1X/B2/HDMW +Inductive sensors On the position of the piston
typ.816000 Nr.021206
TZ10051ASP2.5
TZ10051ASP2.5-1/2
DRS 125
PART NO.24610
PART NO.24612
RV5715.5122.27
RA5614.1786.23
5715.2230.44
EX ZR 335-11Z-3G/D
G-NS-AM-K10-L1=3000
IDM3587T BALDOR 2HP MOTOR CAT.NO IDM35877 SPEC. 05E535054G
MOTOR C1811ATZ/T18R1333A
SHD5W-1-EF3-1
SHD5W
PML6300-NFB60
FPD06KEZ
DD/162S
DA|081
DKL011
DKL012
DTO161
ME2-6-H-B05C-2-3-D-B68
FS5033-CHOP SEM-1 C 48/200
KA-WPSK 15KN 0810259
0280 D 005 BH4HC
0500 D 020 BN4HC
XV-252-57MPN-1-10 100300005912
LD6000P30-06513311-0200 2??(DN50) 304 CV=50
LD6000P31-07513311-1200 2-1/2??(DN65) 304# CV=72
BAMOPHOX 322 TOR/M
sensor BF1200C=1 PG=13.5 9054+COAX connector BRG-58 PT100 9094+measurement area 9500 2e DN25+CONNECTOR+CABLE10ML WIRE:10M
BAMOPHOX 322 CM
SENSOR TCS 100 PPH-3/4 + MEASUREMNET AREA 9500 1 E-3/4'' WIRE:10M
CS 5624
Type??PM19517-86 VAC:230 Hz??50/60 A??0.76 W??70 Pmax??2.5 bar Motortyp??M35
Type??N026AN9E VAC 230 Hz:50 A:0.7 W:100 Pmax??2.5 bar Motortyp??I56
ES12Z-110-UC
OP6-A-40-SX-F20-R
Fe-CuNi TYP L L-Nr.R 9-1301
DL300K/S327D-TX-T-88:6M
RT-03.1.3.99.0025.99.-HEAD SN.167310 08/08
ATB-CM100/50K/AIN7T2 110276/2
ATB-CM100/10K/AIN7T3 100736/3
8003/141-726-2-r
8003/311-AL
8003/111-010
8003/141-726-3-RT
C33 0.5~10 bar G1/2"
C06 0.5~3 bar G1/4"
DP 120 CP Art.120-004 Fabr.Nr.3052
90248
90241
RO20P
6.430.01-1111-41
6.430.01-1111-38
6.430.01-1111-17
2.841.01-1011-41
6.430.01-111-47
AU108145 D43240802.702XX
512945
CH10BA176-600*GK1
A178 Q53190/001
DataVS2-08-DE-OBJ
NTM-MS-M3/256-1K-TM70NC
KTR-B/2/M300/T5/T5/T5
LAA65421 03/00 MOD.A65 6(5)A-250V
MASTERGUARD A1000-19 MLFB.6SU5082-2BB00 FSC-NO.9071R-P107
MZ 2D 26577706
type.MU Caliper Part Number. 7680918
Watergates SA005 SD103701
DUM/A-250 G 6/4''
MX2030-74-00-50-10-05
MX2031-040-01-05
TXR5521-33500-01-008000
MX2030-04-00-50-10-05
MX2031-040-01-05
MX2034-01-01-05-05-01-13
MVSI 3/3200-S90 SN.100831462
T63B4 05006399001
Deutronic DBL800-14
Siata V230??only body??
572-451 sn.W001817
572-451 sn.W001817
TYP Compacta MS 12(6-12-MS 12K) Nr.36960
RS200/0/5/3/Linear/C/1/N-4063132.10.1.111
WDS-1000-P60-SR-I
fscb22a
ST98-B25MTOWCOCBA
26085
PS18C714??Ersatz PS991378??
SKP3-L/S90 5M
WWAK3-L-Q 5M
LH3002 2301000LTK001000100SB
63262000 DIN 12240-4-M20*1.5-Form
2979 KIESEL-stator SP 10/1
LC481/20uM ML570 ID: 372 849-05
TR 060 2 9 STD IS S1 or SB KE
VITON 52X3.5
FPM 10.77X2.62
VITON 50X5
VITON 94X5
VITON 112X5
VITON 130X5?
ISO 3601-1-53X5.3 EPDM ??
ISO 3601-1-128X5.3 EPDM ??
40X5.3 N EPDM
125X5.3 N EPDM
63X5.3N EPDM
144X5 NBR
ISO 3601-1-C1250 EPDM(125X3.35)
ISO 3601-1-C1250 EPDM(87.5X3.55)
ISO 3601-1-C1250 EPDM(140X5.3)
M05742 U6 2600008 SN3585
M05743 2903002C6
21852-4128
UMS 18 KDS
UMS 8 KDSA
DINA 62011
DNDS1ES7-1
786990
787000
PVP16304R26A212
4D02 D201 0302 D1G0Q G3 026-57491-H
TE0165MP260AAAA
A4D01 3151 0101 C1W01 026-43725-P
GT400S
3619131310
SVH121S10
M4B01512S20NB
PRH121S20V
RAH081S50V
D3A20BN
3619141306
PVP23362R21
PVP23302R6A121
CPOM2BB25V56
D1VW020BVUPG
PV202R1EC02
D1VW001CNYPF
TG0785HV460AAAB
H06SDV
4D01 3208 0302 C1G0Q 026-54185-H
D1VL001CN4K
T201349 type:TEO 21-50 SOF2 SPEZ+EMBW 1022160 F132M-2M
T51-80HF4LB2 Q=70m3/h H=7.5m N=3kw ??100
HC34/1.5-A1/400
OMX-39AC-1A3
OM-402PWR
OM-652UC
RV300/155/200
X130-20L
TE144/220+001
RS20-0800M2T1SDAPHC
RS20-0400M2M2SDAPHC
K300
SAFE 4.1 24VAC/DC 50-60HZ
03527/01257/NG205/D4/3 4/5
PSV551/320-3-41H63/63/H-42L80/80C200/H-42H25/25/E-42H25/25/E-41L63/63/E-E1-G24
seal for SCV01 60945
SQ07996
RDOP001G2P
RDOP005G2P
102290PE
BVZP1-G22/CZX/OR/2-X24
5122-45-2F
SK77303-A1ND S0178429
GR55??60????120??20mm
BS10Z-21V/D06LA8/SP 25172928-9
BG04-31/DU04LA4/SP 1904158-9
311178
01.E 950.10VG.10.S.P.- 300300
01.E 450.3VG.30.E.P.- 317318
01.E 240.3VG.30.E.P.- 319965
S60-02 180*112*15S MFG NO.051127
57250WD N.31766-4
KF 0/1 S10K POA ODL32/107
KF 0/4 S10K POA ODL32/107
Type FBPA 112M-4 0709018692
M72 CHN456-NDA5-44-09705/regulationvalve with electric driven unit MV5214-K+ST5112-32+RE3442 DN40 flange DIN 2635 KVS 7,6 Hub
M56 CHN456-NDA5-44-09755/
M55 CHN456-NDA5-44-09745/
M55-M65 CHN456-NDA5-44-04022/
M242-M243 CHN456-NDA5-44-04025/VBC011
RE3442/M55-M65 CHN456-NDA5-44-04022
ADXL322-E102.102
Freqcon_AS4
Overspeed module R1.1
FREQEON_OM 1.2/6-2008
MWG61-DS S.n.00114.0508 2m
SU/5B-100 S.n.08210.0408
AT.203R-MX S.n.04465.0408
MWG61-MX S.n.02420.0408
HD67552
634.1 230v 50HZ
634.3 230V 50HZ
GT050B001.00 24V 6.2W 750N
26.4025/20L
26.4025/20R
K205.3/160/11 5752-M-5.5.11A 0412L 2008
CL80LFECC-2
TYPE 18.1, SIZE 4-80, MATERIAL TYPE III
ADAS-ICV150/D-14/4/256 I S/N.21071194
MT-ST160W/TT 63520-414
GFK 15R10-6
GFK 25R10-6
GFK 25R40-6
GFK 40R10-6
GFK 50R10-6
CY8/B-320403
CY17/B-2204101
CY17/E-2425000
P/N S2720902A
MC2 106-O-40A0
MC2 245-O-40A1
MC2 930-H-10B1
DP-11/4"-50-32-5
PT100L40
PSTM16F4
EPN100.0A
F79U065 SINGLE ACTING 420KPa FAIL CLOSE
24VDC,60-100W telmar lnc 57704-2.75 Cat:XIHFGCX 2L Serial No: 3.06 01584 input:0-200?H output 4 to 20MADC Power: 24VDC
7043.1.FK-J.DD.e.10.tin.240.g.2000.A.400
8.5020.4850.1024.s083
INFO-4KP 94161
EMP-II 16043PV10FPGLPV990103
52112(010,020,030,040,050,060)
52005916
52248130
53440560
52157020
53232805
53232965
53580500
53579004
53117020
53450912
53450918
53450924
53450936
53642500
62300305
51284500
50535516
50535519
50535534
50535529
54420120
54420210
73594612
75032220
51151020
75014240
75002215
11115010
11115012
11115016
11063085
11063165
13010(060,080,100,120,160??200??240+13013300)
11067900
11150900
13399312
57001500
53841(014,019,022,027,030,035,038,041,046,052,057,060)
21316240
13557420
13545040+13545050
35185070
35213021
35350080
51315500
35350580
46999073
42160115
46135020
75024335
50019920
50111830
50027108
50203999
51045050
55400010
59499831
56925760
56926760
76102115
76102180
76109115
76109180
79100030
70574050
78042010
69791010
54202115
54031100
54031230
54031240
54031250
54031260
54031270
54031280
54031410
54041010
54068010
54070010
54077060
54079010
54201045
54201315
54201060
75736010
69780901+69780902
29501023
29502002
29502009
77995036
77995040
77995010
50268140
55023010
55023020
55023030
55043010
55043020
55043030
55026020
55026090
50260310
50260370
57560025
77180010
56305010
56235005
56235200
56235210
58999010
56070020
56077110
56830070
69729110
56580005
69767101
69666010
75240040
75534040
56036250
51551035
51550135
DR62.0X80-4 88183 03451
DK-10t-SU/II1 /270*48*48 with 5m cable
HARTING for (Han 4A-M 10A.230/400V)
H32-F-HS3025/1 220KDC 100%ED
CA10A005-600E
LCPOSO8.2 LZB33.5600 U PM
LC5POSO8,6 LZB33-LCS
500066.tif;M120;K-031.185.600N
55SSM16RMEN
K113-1
114270
E 25183018-6
P1BAN3040HL10B03
DKL042 01540660 05-024-042
DST021 01497302 05-014-021
TB40 9404-407-46021
transmitter LT 110 AP38-15
RECEIVER LR 110 AP38-15
amplifier PA 11 D 303
BGE 28-1-2-AB3-4
Art.no.296381/12..240VAC/DC-4A
HAS10 810-635879 283322 11....30V
69-00056
eioh-00 ASM 02-59716-01
mark ?? se board 03-21322-25
SMPS09 motion drive 02-88132
24-01182
24-31036
05-03081
DKL021 01539825 05-024-021
404100
407200
409200
PG100 i=10??000 P??L??NO.4152018189 S.NO.025720
1213-0001-P1
1121-0463-5P
50*50*10CM
1121-0462-P5
VP1P-WG230
PSL31D140/70-3
V 671.1 sn.83 880
158.13 D0 Nr.95037658
G-NS-AM-K10/1100,1100mm
G-NS-AM-K10/1300,1300mm
G-NS-AM-K10/1500,1500mm
UMPC45TVK2
B13AXCP00N
BG20-11/D09XA4-TF Art.no.170Z2335
0MB-8M12-5P3-2/S366
415.01.50.F(0.15258)+415.01.30.B(0.14756)
45549 sprocknovel DN15 PN40 AB10-66327.01/0001 Dichunoen/Seds PTFE Ferti Qungs-NrWH951 DNFL 020.0113 07/2004
TROVIS 6493 Model No:6493-011L01 serial no:202957 230VAC 50/60HZ 6VA
TROVIS 6493 Model No:6493-021L01
MSP0 I=4.0
930/7-1-S45 D4.1065/5
090490/0119H K21R 200LX2 TWS HW
z-FISCHERSCOPEX-RAY XDL240
28.07.2010
GM1X3-000-06.0-0050-00
mbs 25 1.6-2.5A e-nr.910-201-206-000 ref.no.254220
rsm 110/25 43991-40 sn.1650 id.no.312936R1
K-002.270.610NM200X4203/215
MTCA-0311 input 220VAC output +5 ??15VDC
ERN1381026-2048 5V 366962-91
MU60-11/4
P-0.2-11/4 ww-70-140
Order no.210 098 910
Order no.210 099 710
MFE time sector 1s-100h time vavle 1-10
V30D-140RKN-1-1-01/PD4
INT2000 PT100-6 13G112
BG40-11/D09SA4-TF NO:1975398-02 1.1KW 0.78 4.75A n1/n2=1400/min/29/min IP65 IM B6 400V 50Hz F 380V/50HZ
XV-1P-D/C 9.8ML/R
0975 254 101/2m
0975 254 103/3m
0906 UTP 201
RSU 6-RKU 6-204/0,6m
RKU 6-204/3m
0979 PTX 101
ASBS 2 M12-5
RST 5-RKT 5-259/2m
RST 4-RKWT/LED P4-251/2m
RST 3-RKMWV/LED A 3-224/2M
734PZH 1141 23 750 88575/1/1/1.11
TIPO QS0332.7038.SE188
AN.05300000005 Ser.Nr.05/D/00473
art-nr.16952-220
Graugub GG 25-Spane Best-Nr.03-39
8040/1180X-10L07BA05
8040/1180X-26M01XA05
ASM
4504B500B1N3
MHD 093C-035-NG0-AN
D282A
KK10-BCV-423 L328
WK5007904 KE 70-20
66RNS1011251213
D-192
MP5.4-H37
4740AWY2XOB0
KSM301660-5
KSM036438
KSM313720-5
KSM036457-5
9323A/5073A111
SC1DD2315
Art.Nr:02.01.117
7KG2131-1UN21-0AA0
7KG6113-2BN21-0B
7KG6113-2AN24-OB
7KG2131-1BN21-0AA0
3236433
3236233
3236333
3236133
1029700A
204-040-100-012
200-582-X00-013
200-595-OSS-32h
200-582-911-02h
200-582-916-01h
TZ10051ASP2.5
TZ10051ASP2.5-1/2
DRS 125
PART NO.24610
PART NO.24612
RV5715.5122.27
RA5614.1786.23
5715.2230.44
EX ZR 335-11Z-3G/D
G-NS-AM-K10-L1=3000
SHD5W-1-EF3-1
SHD5W
PML6300-NFB60
FPD06KEZ
DD/162S
DA|081
DKL011
DKL012
DTO161
0280 D 005 BH4HC
0500 D 020 BN4HC
BAMOPHOX 322 TOR/M
BAMOPHOX 322 CM
CS 5624
ES12Z-110-UC
OP6-A-40-SX-F20-R
8003/141-726-2-r
8003/311-AL
8003/111-010
8003/141-726-3-RT
C06 0.5~3 bar G1/4"
90248
90241
RO20P
6.430.01-1111-41
6.430.01-1111-38
6.430.01-1111-17
2.841.01-1011-41
6.430.01-111-47
512945
CH10BA176-600*GK1
A178 Q53190/001
DataVS2-08-DE-OBJ
MZ 2D 26577706
DUM/A-250 G 6/4''
MX2031-040-01-05
MX2031-040-01-05
T63B4 05006399001
Deutronic DBL800-14
572-451 sn.W001817
572-451 sn.W001817
WDS-1000-P60-SR-I
fscb22a
ST98-B25MTOWCOCBA
26085
SKP3-L/S90 5M
WWAK3-L-Q 5M
VITON 52X3.5
FPM 10.77X2.62
VITON 50X5
VITON 94X5
VITON 112X5
VITON 130X5?
40X5.3 N EPDM
125X5.3 N EPDM
63X5.3N EPDM
144X5 NBR
M05743 2903002C6
21852-4128
UMS 18 KDS
UMS 8 KDSA
DINA 62011
DNDS1ES7-1
786990
787000
PVP16304R26A212
TE0165MP260AAAA
GT400S
3619131310
SVH121S10
M4B01512S20NB
PRH121S20V
RAH081S50V
D3A20BN
3619141306
PVP23362R21
PVP23302R6A121
CPOM2BB25V56
D1VW020BVUPG
PV202R1EC02
D1VW001CNYPF
TG0785HV460AAAB
H06SDV
D1VL001CN4K
HC34/1.5-A1/400
OMX-39AC-1A3
OM-402PWR
OM-652UC
RV300/155/200
X130-20L
TE144/220+001
RS20-0800M2T1SDAPHC
RS20-0400M2M2SDAPHC
K300
SQ07996
RDOP001G2P
RDOP005G2P
102290PE
5122-45-2F
311178
57250WD N.31766-4
ADXL322-E102.102
Freqcon_AS4
HD67552
634.1 230v 50HZ
634.3 230V 50HZ
26.4025/20L
26.4025/20R
CL80LFECC-2
GFK 15R10-6
GFK 25R10-6
GFK 25R40-6
GFK 40R10-6
GFK 50R10-6
CY8/B-320403
CY17/B-2204101
CY17/E-2425000
P/N S2720902A
MC2 106-O-40A0
MC2 245-O-40A1
MC2 930-H-10B1
DP-11/4"-50-32-5
PT100L40
PSTM16F4
EPN100.0A
INFO-4KP 94161
52005916
52248130
53440560
52157020
53232805
53232965
53580500
53579004
53117020
53450912
53450918
53450924
53450936
53642500
62300305
51284500
50535516
50535519
50535534
50535529
54420120
54420210
73594612
75032220
51151020
75014240
75002215
11115010
11115012
11115016
11063085
11063165
11067900
11150900
13399312
57001500
21316240
13557420
13545040+13545050
35185070
35213021
35350080
51315500
35350580
46999073
42160115
46135020
75024335
50019920
50111830
50027108
50203999
51045050
55400010
59499831
56925760
56926760
76102115
76102180
76109115
76109180
79100030
70574050
78042010
69791010
54202115
54031100
54031230
54031240
54031250
54031260
54031270
54031280
54031410
54041010
54068010
54070010
54077060
54079010
54201045
54201315
54201060
75736010
69780901+69780902
29501023
29502002
29502009
77995036
77995040
77995010
50268140
55023010
55023020
55023030
55043010
55043020
55043030
55026020
55026090
50260310
50260370
57560025
77180010
56305010
56235005
56235200
56235210
58999010
56070020
56077110
56830070
69729110
56580005
69767101
69666010
75240040
75534040
56036250
51551035
51550135
CA10A005-600E
55SSM16RMEN
K113-1
114270
E 25183018-6
P1BAN3040HL10B03
TB40 9404-407-46021
BGE 28-1-2-AB3-4
69-00056
24-01182
24-31036
05-03081
404100
407200
409200
1213-0001-P1
1121-0463-5P
50*50*10CM
1121-0462-P5
VP1P-WG230
PSL31D140/70-3
V 671.1 sn.83 880
UMPC45TVK2
B13AXCP00N
0MB-8M12-5P3-2/S366
MSP0 I=4.0
28.07.2010
MU60-11/4
XV-1P-D/C 9.8ML/R
0975 254 101/2m
0975 254 103/3m
0906 UTP 201
RKU 6-204/3m
0979 PTX 101
ASBS 2 M12-5
RST 5-RKT 5-259/2m
art-nr.16952-220
本公司专业维修,不收任何检测费,本公司是福禄克公司委托我司在苏州办理的维修站,可随时和我联系,随时为你解决问题,欢迎来电咨询。维修,以便建立长期的业务关系。我们将以高度的热情、精湛的技术为贵单位排除一切因电路板故障造成的诸多不便,竭尽全力保障生产顺利进行。
联系人:徐生 先生
电 话:86-512-13913148881
手 机:13913148881
E-mail:luckyderui@163.com
邮 编:215021
网 址:http://www.suzhou-pcb.com
通过中国触摸屏网金牌会员认证
