SLS1F51 GE Adjustable必能信维修
BRANSON(必能信)PC-620超声波清洗机 BRANSON(必能信)超声波清洗剂 BRANSON(必能信)超声波破碎仪探头和隔音箱 Merck清洗剂 BRANSON(必能信)Slp超声波破碎仪 BRANSON(必能信)sonifier系列超声波破碎仪 BRANSON(必能信)2000bdc连续流大功率超声波破碎… BRANSON(必能信)超声波清洗机B8510/5510/3510/2… BRANSON(必能信)DHA1000型大容量超声波清洗器 BRANSON(必能信)IC系列大容量超声波清洗系统 BRANSON(必能信)B200超声波清洗机
ULTRAWELD L20/L40超声波点焊机
SLS1C22 Teledyne Hyson Nitrogen Die System QPM-1555 QPM-2055 4 station 694MO
SLS1C22 E615 04410C Beijer 24VDC 450MA 12525EL
SLS1C22 Viewtronix IC 1500T-07-16-24-45 PC and Screen Windows 98 528WT
SLS1C22 Viewtronix XT1501T-A Flat Panel Monitor 513WT
SLS1C22 XYCOM Automation Model 3535 KPM 788LR
SLS1C22 XYCOM Automation Proface XT 1502 Flat Panel Monitor 512WT
SLS1C22 Xycom Control Panel 9465 KPM 7500DC
SLS1C22 XYCOM ViewTronix VT 1040 Flat Panel Monitor 529WT
SLS1C23 Atlas CoPco model ETVS7-40-10-C+ADS 12209LR
SLS1C23 Jesco Degassing Valve 5KP0-12600 9456LR
SLS1C23 1771 HT Termination Panel for Controls 6236LR
SLS1C23 1789271 Voltage Temp TP: Eq PS1000 6973LR
SLS1C23 Allen - Bradley Power Supply cat 1771-P2 SER B 8073MO
SLS1C23 Allen Bradley 1791-8AC Controller 6141LR
SLS1C23 Allen-Bradley Guard Master Safety Relay MSR131RTP 440R-C23139 7988LR
SLS1C23 Allen-Bradley Inductive Proximity Sensor Cat 871TM-D5NP18-N4 8110MO
SLS1C23 Allen-Bradley T11 Hand Held Terminal 8151MO
SLS1C23 ATLAS COPCO Cable 36' 652WT
SLS1C23 ATLAS COPCO Cable 4231506701 6' Power Supply to Drive 659WT
SLS1C23 ATLAS COPCO Cable 9040104410-10M 671WT
SLS1C23 ATLAS COPCO Cable Approx 18' Extention 653WT
SLS1C23 ATLAS COPCO Power MACS TC52P 654WT
SLS1C23 ATLAS COPCO Power Supply 9040120203 655WT
SLS1C23 Auto Mation Direct PCB 125v AC 15A FA-REC3 7989LR
SLS1C23 Balluff BIS C-600-007-00-KL1 12201LR
SLS1C23 Banner IVU Series TG Camera 532WT
SLS1C23 Card MC68020RC20 OC10H QEZD9045 5BE MPU-28 9011-97 12265SY
SLS1C23 CCS Illuminator 541WT
SLS1C23 Cincinnati Milacron Maximum 500 M/2033/0991/03 KCC9316 717LR
SLS1C23 Cognex - In Sight model insight 5100 12208SO
SLS1C23 Cognex Camera Case Protector 539WT
SLS1C23 Cognex In-Sight 1000 800-5740-1 Camera 534WT
SLS1C23 Cognex In-Sight 1000 800-5741-1 Camera 536WT
SLS1C23 Cognex In-Sight 3000 Processor 800-5745-1 800-5712-2 542WT
SLS1C23 Cognex In-Sight 3000 Processor 800-5745-1 800-5712-2 543WT
SLS1C23 Cognex In-Sight Digital CCD 800-5715-1 Camera 533WT
SLS1C23 Contactor Light Bar model GMMSDINT-1T2 12152LR
SLS1C23 Contactor Light Bar Mini-Screen model GMMDSDINT-1L2 12158LR
SLS1C23 Cosel Power Supply 24v 22A 8023LR
SLS1C23 COSEL Power Supply RU150U-24 24v 65A 8013LR
SLS1C23 Efector 150 KG5047 TAA 0806 010 Capacitive Sensor 12719EL
SLS1C23 Efector 200 Through Beam Senor Transmitter O
SLS1C23 Elco Power Supply 12v 42A 8019LR
SLS1C23 ELCO Power Supply 15v 34 amps 8018LR
SLS1C23 ELCO Power Supply 24v 11amps 8017LR
SLS1C23 Elco Power Supply 5v 20A 8020LR
SLS1C23 Elco Power Supply 5v 3A 8022LR
SLS1C23 ELCO Power Supply K50A-15 15v 34A 8016LR
SLS1C23 EMCO Genius PM 93-P-0-D-S-F 827SY
SLS1C23 EYELA Micro Tube Pump MP-3 N-H 12718EL
SLS1C23 FreqRol Mitsubishi Inverter FR-Z024-So75K 6970LR
SLS1C23 Fuji Electric AU-CW U160V 2mm 2 Terminal Block 647SO
SLS1C23 Grayhill Relay Board 15 Slot 70GRCK16-HL 70G-IDC5S 876MP
SLS1C23 Heidenham EXE 610C 263-383-01 651SO
SLS1C23 Hirschmann Spider-5tX Rail Switch 12186LR
SLS1C23 Honeywell FF-SRE30812 Expansion Module 24 VDC 721LR
SLS1C23 Honeywell FF-SRS59352 Two Channel Emergency Stop Module 24 VDC 722LR
SLS1C23 Honeywell FF-SRT101R2 Time Delay Module 24 VDC 723LR
SLS1C23 I/O Plexer- DuTec BD040-E 12279SY
SLS1C23 I/O Plexer-DuTec IOP-AD 603TL63 12278SY
SLS1C23 IDEC Control Unit Type 233 NA 12713EL
SLS1C23 IDEC Control Unit Type APW233A 12714EL
SLS1C23 IDEC Control Unit Type ASLW23320GT 12715EL
SLS1C23 IFM TT1250 D-45127 Essen 12720EL
SLS1C23 Ingersoll-Rand 99386260 torquer Control Rack 0172DC
SLS1C23 Ingersoll-Rand 99388019 R04 Torquer Control Rack 0173DC
SLS1C23 Ingersoll-Rand 99388019 R08 Torquer Control Rack 0174DC
SLS1C23 JBL Systems Proximity Sensor DDZT30 11380MO
SLS1C23 Key Board 177344 PS1001073C 6638514A1 12316SY
SLS1C23 LANDAC 16 Channel Analog Termination Panel Valmet 819SY
SLS1C23 Lauer TSN100 Modem 6971LR
SLS1C23 LEEDS Northrup Instruments Dissovled Oxygen PPB 825SY
SLS1C23 LEEDS Northrup Instruments PPB Sodium 056434 7082-34 826SY
SLS1C23 Light Bar / Curtain Fiessler 6972LR
SLS1C23 Load Control PH-3A-R 460V 30A C-10V 718LR
SLS1C23 Mag Gard GJL36003M01 3 Amp Breaker 3 Pole 12726EL
SLS1C23 MARPOSS 8304850010 6830311203 650SO
SLS1C23 Montronix 460V 100A 0-10V Power Supply Module PH-3A 646SO
SLS1C23 Namco Proximity Switch Cat ET120-23420 8109MO
SLS1C23 Nemic - Lambda Noise Filter MBS-1340-33 7755LR
SLS1C23 ABB Entrelec 1SNA034087R0000 Wiring Harness 12522EL
SLS1C23 ATLAS COPCO EL Nutrunner Torquer ETD S4-04-10CTADS 715SO
SLS1C23 BALLUFF BFO-48G-TLF-SB-1 12528EL
SLS1C23 Balluff BGL 50A-0030S49 10-35VDC 0346DE 12536EL
SLS1C23 BALLUFF BGL-50A-001-SA1-S49 Photo Electric Sensor 12850EL
SLS1C23 Balluff BLE 6K-PU-1E S75-C Through Beam Sensor 12831EL
SLS1C23 Balluff Bos 18E-PS-1N2M-S4-D 828 472 0449DE 12538EL
SLS1C23 Balluff Bos 18K-1-C30-20-02 0542IT 952056260 12535EL
SLS1C23 Balluff Bos 18MR-PA-1HA-S4-C 554 274 0448DE 12537EL
SLS1C23 Balluff Data Logic DL 952201050 SDS5-5-M10-90 X1 12532EL
SLS1C23 Banner Q60AFV SERIES SENSORS w/VISIBLE RED EMITTER 8096MO
SLS1C23 Brad Harrison Daniel Woodhead Co Micro-Change Extension 8123MO
SLS1C23 Brad Harrison Daniel Woodhead Co Micro-Change Splitter 8122MO
SLS1C23 Brad Harrison Device Net 5P Recepticle Cat DN5000-M005 8120MO
SLS1C23 Brad Harrison Mini Change Molded Connector Cat 41103T 8114MO
SLS1C23 Brad Harrison Mini Change Part 41311 600v 8 amp 8114MO
SLS1C23 Branson Compact Control Cooling Housing 12883EL
SLS1C23 Branson PG PGB220A 2KW/20KHZ 12877EL
SLS1C23 Communications LCM 100 Line Carrier Modem 8092MO
SLS1C23 Control PILZ Electrical Box Enclosure Robot 11401MO
SLS1C23 Daniel Woodhead Device Net Recepticle Cat DN5100-M005 8119MO
SLS1C23 Data Logic DL SDS10-5-M12-32 12534EL
SLS1C23 Digital Gateway Model 6120800 12546EL
SLS1C23 DMB01 Multifunction Timer DMB01DM24 12773EL
SLS1C23 Efector 200 E20829 Through Beam Sensor 12846EL
SLS1C23 Efector 200 Photo Electric Sensor OB5026 OBF-FPKG/T/US-100 12851EL
SLS1C23 Efector 200 Photo Electric Sensor OG5116 OGS-00KGN4A/US-100 12852EL
SLS1C23 Efector 200 Photo Electric Sensor OG5117 OGE-FPKG/V4A 12853EL
SLS1C23 Efector 300 Flow Monitor S15002 SID10ADBFPKGIUS 12845EL
SLS1C23 Efector 600 Temperature Sensor TRZ432 TR-KDBRIZ-MFRKG/US/N 12842EL
SLS1C23 Efector E21028 12848EL
SLS1C23 Efector E21028 90 Degree 12847EL
SLS1C23 Efector UE006 12849EL
SLS1C23 Elopak Control 20HB180-2E-E1 12879EL
SLS1C23 Emerson-Rosemont Sensor 00809-0400-2654 Rev-CA 12319SY
SLS1C23 ENDRESS HAUSER Liqvicap T FM121-A1A2B1 12547EL
SLS1C23 Entrelec 001012112 RB122AV-24AC-DC 12856EL
SLS1C23 Festo SDE1-D10-G2-HB-C-PI-M12 12772EL
SLS1C23 Festo SDE1-D6-G2-H18-C-P1-M8 12771EL
SLS1C23 Festo VPPM-6L-L-1-G18-OL6H-A4P-S1C1 12779EL
SLS1C23 GAI-Tronics Horn Driver Part 13314-002 12321SY
SLS1C23 GE Photo Electric Limit Switch 8131MO
SLS1C23 GLI International Model 63 E63F1N1A1NNN 12766EL
SLS1C23 Honeywell Photo Electric Sensor Micro Switch CP18D1AAL2R0 8103MO
SLS1C23 IFM Electronic E33001 TM9061 45127 ESSEN 12843EL
SLS1C23 IFM Electronic E3302 TM0061 45127 ESSEN 12844EL
SLS1C23 Mitsubishi CC
SLS1C23 Mitsubishi FFR-E54-15A-SF1 12557EL
SLS1C23 Mitsubishi MR-JTBL05M 12859EL
SLS1C23 Moore Electronic Valve Positioner model: 750E111GNNNF 12312IISY
SLS1C23 Multilin Motor Management Relay 269 PLUS-D/O-10P-125v DC 12306SY
SLS1C23 Namco Proximity Switch Cat ET320-32420 8112MO
SLS1C23 Photo Electric Limit Switch 8130MO
SLS1C23 Potter Electric Signal Co model VSR-F 12313SY
SLS1C23 Prox Sensor Cord CSI V322em-1 8124MO
SLS1C23 Rafael Control Board 519 032 001 12305SY
SLS1C23 Rosemont Sensor Probe 00079-0335-0002 12318SY
SLS1C23 Sick IM18-10BPS-NC1 6027577 12778EL
SLS1C23 Sick Optic Electronic Sensor MHL1-P122 1019709 12792EL
SLS1C23 Sick Sensor CM18-08PP-KC1 (Missing Jam Nuts) 12780EL
SLS1C23 Turck Combi Prox 8099MO
SLS1C23 Turck Wire Lead Part FKB3-05/1825 8113MO
SLS1C23 Numatics 041SA4Z2MQ00061 Solenoid Valve 5 Piece One Price 663MO
SLS1C23 Nymex Tellabs Westell Bell Atlantic 820SY
SLS1C23 Ohmite Resistors DZ5K150 12254SY
SLS1C23 OIS 20 - OMT 6637257E1 1292 12310SY
SLS1C23 OIS 20 198888 PS1587441 IIADPOZ 12-92-22 195499 PS1536295 12308SY
SLS1C23 OIS 20 199712 PS1588039 C 6638229C1 12309SY
SLS1C23 OIS 20 Card IIMCLO1 663843782 PS1007107C 6638438A1 12266SY
SLS1C23 OIS 20 Card 1453761/CD81/3100-HPTD 12270SY
SLS1C23 OIS 20 Card 5BE MPU-28 9011-97 Rev E1 25129 Rev E 12272SY
SLS1C23 OIS 20 Card 6638226C1 670-INFI90-3682A 12268SY
SLS1C23 OIS 20 Card ASSY 6638511E1 IIMKM01 67-INFI90 3429A 12273SY
SLS1C23 OIS 20 Card ASSY-6638511E1-IIMKM01 12271SY
SLS1C23 OIS 20 Card Matrox MOD=SX-900/64-81B2 12269SY
SLS1C23 OIS 20 Cards IIMLM01 ASSY No 6630230C1 12267SY
SLS1C23 OMRON Power Supply 24v DC S82J-60024 781LR
SLS1C23 PC Board Memtron 35-12-191 (25096) SCPB-T 0171DC
SLS1C23 Pelco Camera Case EH4010 538WT
SLS1C23 Phenix Contact PSR-SCP-24UC ESA41/3x1/1x2/B 661WT
SLS1C23 PILZ PNOZ X8P 24 VDC 666SO
SLS1C23 PILZ PNOZ X9P 24 VDC 665SO
SLS1C23 Positron 4 Wire Data Isolator 7501-24 816SY
SLS1C23 Positron Fiberline Isolator Telephone 751311 817SY
SLS1C23 Positron Teleline Isolator Basic Rate ISDN 751333A 815SY
SLS1C23 Positron Teleline Isolator HDSL 751229R2 814SY
SLS1C23 Potter & Brumfield CNM5 Programmable Multifuction relay 12264SY
SLS1C23 Potter & Brumfield OAC-24A Relay 12303SY
SLS1C23 Pressure Switch ISE5B-02-67L SUS630 12735EL
SLS1C23 RG 1318 Type: FZP 135x35 7992LR
SLS1C23 Rosemont Analytical SCL-C--002-M2 822SY
SLS1C23 Rosemont Analytical Solu Comp Water Quality Analyzer 821SY
SLS1C23 Rosemont Analytical Solu Comp Water Quality Analyzer 823SY
SLS1C23 Rosemont Analytical Solu Comp Water Quality Analyzer 824SY
SLS1C23 Sanyo Denk Tape Reader 2401-1 809INK
SLS1C23 SCHMERSAL EOT Laser Scanner LSS 300-2110 Light Guard 634WT
SLS1C23 SCHMERSAL EOT Laser Scanner LSS 300-2110 Light Guard 636WT
SLS1C23 SICK AG Laser Scanner PLS101-312 Light Guard 632WT
SLS1C23 Siemens 3RF2440-1AB45 E01 Contactor 12739EL
SLS1C23 Siemens 9300 Access Power Meter 9300DC-116-ZZZZA 863MP
SLS1C23 Siemens D-76181 6DR5210-0EN00-0AA0 PS2 I/P Positioner 12742EL
SLS1C23 Siemens DS1E-XHF 3RK1301-0BB10-0AA4 G1080902 12741EL
SLS1C23 Siemens Simatic Connector 6ES7 392-1BJ00-0AA0 Stecker 12725EL
SLS1C23 Siemens Simatic S7 1P6ES7 350-2AH00-0AA0 SC-S2A08376 12738EL
SLS1C23 Siemens SITOP Power 40 24 VDC 731LR
SLS1C23 Siemens XPRESS CARD 9700TC-116-OE100ZA 868MP
SLS1C23 Signal Transformers Tone Generator 12232SY
SLS1C23 SMC PSE550-28 Low Differential Pressure Sensor 12729EL
SLS1C23 SMC PSE550-28 Low Differential Pressure Sensor 12730EL
SLS1C23 SMC PSE550-28 Low Differential Pressure Sensor 12731EL
SLS1C23 SMC SV SI NO: EX126D-SMJ1 12736EL
SLS1C23 Spectrum Illumination LL16-850 540WT
SLS1C23 Spindle Speed Load Meters 811NK
SLS1C23 Staco Energy Products type-501 8095MO
SLS1C23 Tape Feeder Switch & Counter 810NK
SLS1C23 TBS C3200-NIA-12500 818SY
SLS1C23 TDK Noise Filter ZGB2201-01V 12196LR
SLS1C23 Telebyte Superventer & Interface Converter 12312SY
SLS1C23 Telemecanique XCK-PH7 067936 Limit Switch with Roller 12722EL
SLS1C23 Telemecanique XCK-PH7 067936 Limit Switch with Roller 12723EL
SLS1C23 Telemecanique XCK-PH7 067936 Limit Switch with Roller 12724EL
SLS1C23 Tempatrue Test Control Cinco Series 21 Model A21CG 871MP
SLS1C23 Touch Pad F P2-YE1 853INK
SLS1C23 Turck Proximity Switch Bi2-CRS260-ADZ30X2-B3131/S34 11332HT
SLS1C23 Turck Proximity Switch Bi2-CRS317-ADZ30X2-B1131/S34 11333HT
SLS1C23 Turck Proximity Switch Bi5-GT18-ADZ30X2-B1331/S34 11334HT
SLS1C23 Turck Proximity Switch Part Ni10-G18-AZ3X-B1331 11331HT
SLS1C23 Clippard Instrument EMC-08 9595LR
SLS1C23 Yaskawa Varispeed 505 CDMR-MR-30K 851INK
SLS1C26 Fluitron Filtration Elements model H 4306-10N1T Code 106 8139MO
SLS1C26 Watts Water Seperator Filter F602-02BJ M5 9458LR
SLS1CF571 Allen-Bradley Control SLC-500 Power Supply Cat 1746-P2 Ser C 12197LR
SLS1D30 Heat Wave model-FES-1548-3D Max watts 15000 12223SY
SLS1D30 Leister CH-6056 3x220V 6 KW 16A 12878EL
SLS1D30 Leister CH-6060 Sarnen Heater 10000 Without Electronics 13005EL
SLS1D30 Leister HE326061200S 102730 3x230Vx 3x3300w 12885EL
SLS1D30 Leister Heater CH 6056 10000 g 12876EL
SLS1D38 Cooper Lighting 1000watts MHNK-Y76-1000-MT 0168DC
SLS1E45 Gear Box Transmission John Deere 4039T Diesel Engine
SLS1E45 4EKF63AX-4 12861EL
SLS1E45 C-C1354C2 Motor & Multi Speed Drive 11402MO
SLS1E45 Motovario Gear box 0010734 9474LR
SLS1E45 Motovario Gear box 5018442 9467LR
SLS1E45 Motovario Gear box 5052994 9471LR
SLS1E45 Motovario Gear box 5094826 9465LR
SLS1E45 Motovario Gear box 5241674 9470LR
SLS1E45 Motovario Gear box 5247032 9469LR
SLS1E45 Motovario Gear box 5327285 9472LR
SLS1E45 Motovario Gear box PH/081 9473LR
SLS1E45 Motovario Gearbox HA42FB 9466LR
SLS1E45 Motovario Motor & Gearbox 9477LR
SLS1E45 Motovario Motor & Gearbox 9478LR
SLS1E45 Motovario Motor & Gearbox & Brake 9475LR
SLS1E45 Motovario Motor & Gearbox & Brake 9476LR
SLS1E45 Motovario Motor & Gearbox & Brake 9480LR
SLS1E45 Reliance Electric Motors w/Force Control Gearbox 11514WT
SLS1E45 SEW Eurodrive 9431LR
SLS1E45 Perfection Speed Reducing Gear Box 25:1 Ratio 6747LR
SLS1E45 Reman - Manmesmann Demag Motorized Gearbox 11565WT
SLS1E45 Sew Eurodrive Electric Motor 75 HP
SLS1E45 Sew Eurodrive Electric Motor and Reduction Gear 5 HP
SLS1E45 Sew Eurodrive Electric Motor and Reduction Gear 1 HP
SLS1E45 Sew Eurodrive Electric Motor and Reduction Gear 10 HP
SLS1E45 Sew Eurodrive Electric Motor and Reduction Gear 2 HP
SLS1E45 Sew Eurodrive Electric Motor and Reduction Gear 3 HP
SLS1E45 Sew Eurodrive Reduction Gear 1584 Ratio
SLS1E45 Sew Eurodrive Reduction Gear 3130 Ratio
SLS1F50 3 Stage Process Controller Plastic Injection CPC-3200
SLS1F51 AEG PLC PC-A984-145 13 Slot Racks PC 510WT
SLS1F51 GE Adjustable AC Speed Drive Cabinet 7VND050CD01 6610L
维修时间 标准时间10个工作日,加急3个工作日,对修复部位保修三个月。 本公司回收各种损坏的变频器、触摸屏、电源、伺服驱动等。贵单位如有上述各方面的维修需求,请带坏电路板来我公司考察、维修,以便建立长期的业务关系。我们将以高度的热情、精湛的技术为贵单位排除一切因电路板故障造成的诸多不便,竭尽全力保障生产顺利进行。
地 址:苏州工业园区唯新路69号一能科技园1-202室
联系人:徐生 先生
电 话:86-512-13913148881
手 机:13913148881
E-mail:luckyderui@163.com
邮 编:215021
网 址:http://www.suzhou-pcb.com
通过中国触摸屏网金牌会员认证
