GenRad 124 Card - UltraPin 1
Pin Board - 128 shelf pins, 32 real pins, mux ratio 2 to 8 ..
GenRad Combo I Card - Part Number: 2277-4014-00
GenRad Combo I Pin Board - 128 shelf pins, 32 real pins, mux ratio 2 to 8 ..
GenRad ICA with High Voltage Option
The GenRad ICA with High Voltage Option is used in the following Test Systems: 228X, TS8X, ..
GenRad Fixed P.S. 5V +/-15V
Fixed Power Supply - Required for
GenRad DSM
Deep Serial Memory 64 MB Condition: New ..
GenRad Fixed P.S. 5V +/-12V
GenRad AFTM
Analog Functional Test Module Condition: Used Weight: N/..
GenRad Combo I Card for Sale
GenRad Combo I Pin Board - 128 shelf pins, 16 real pins, mux ratio 2 to 16 ..
GenRad Zif Connector 160 Pin
Standard Receiver Zif Connector Condition: Used ..
GenRad HSC Board - Slot 1
High Speed Controller Board ..
GenRad MTG - Slot 0 for Sale
MTG Board, MXI-to-GR ..
GenRad Zif Connector - 320 Pin
High Density Receiver Zif Connector Condition: Used ..
GenRad CST Board - Slot 2
Clock Sync Trigger Board Condition: Condition: Used ..
GenRad FTI Board for Sale
FTI-CFB Assembly - Frequency/Time Interval Instrument Module ..
GenRad Zif Connector - 160 Pin
**Call: 1-303-628-7722 for Repair/Exchange Pricing. Condition: Used ..
GenRad DS Reference Board- Slot 3
Driver/Sensor Reference Board Availability: Condition: New Parts and prici..
GenRad High Density Card - 2
Pin Board - 256 shelf pins, 64 real pins, mux ratio 2 to 8 Condition: New ..
GenRad ICA
ICA without High Voltage option Condition: Used ..
GenRad Alliance I
0-7 Volt, 15 Amp Programmable Power Supply Condition: New ..
GenRad 124LX Card UltraPin 1
Pin Board - 256 shelf pins, 64 real pins, mux ratio 2 to 8 ..
GenRad Combo IA Card
GenRad Combo IA Pin Board - 128 shelf pins, 16 real pins, mux ratio 2 to 16 Availabilit..
GenRad Alliance II
0-20 Volt, 8 Amp Programmable Power Supply Condition: Used ..
GenRad High Density Card - 1
Pin Board - 256 shelf pins, 32 real pins, mux ratio 2 to 16 Condition: New ..
GenRad 128 Card - UltraPin 1
Pin Board - 128 shelf pins, 16 real pins, mux ratio 2 to 16 Condition: Used ..
GenRad Alliance III
0-60 Volt, 2.5 Amp Programmable Power Supply Condition: Used ..
GenRad-128L-Card-UltraPin-1
Pin Board - 256 shelf pins, 32 real pins, mux ratio 2 to 16 ..
GenRad 121 Card - UltraPin 1
Pin Board - 128 shelf pins, 128 real pins, mux ratio 1 to 1 Availability: Parts and p..
GenRad Fixture adapter
Standard Adapter Condition: New ..
GenRad Combo IIA Card
GenRad Combo IIA "SMT" Card for Sale Pin Board - 128 shelf pins, 32 real pins, mux rati..
GenRad Combo II Card
GenRad Combo II Card Pin Board - 128 shelf pins, 32 real pins, mux ratio 2 to 8 Condition: Us..
通过中国触摸屏网金牌会员认证
