T5375 SEO65 TH1 Board list |
T5375 SEO65 TH1 UPS list |
SLOT No |
Board Name |
Board code |
S/N |
SLOT No |
Board Name |
Board code |
S/N |
1 |
PPS |
BIR-026903 |
002443228 |
1 |
UPS1 |
WUN-2R5V5VW |
400475579 |
2 |
PPS |
BIR-026903 |
002438821 |
2 |
UPS2 |
WUN-9V11VW |
400475828 |
3 |
PPS |
BIR-026903 |
002178584 |
3 |
UPS3 |
WUN-5V7VW |
400475732 |
4 |
CAL/SIG |
BGR-026746 |
002425811 |
4 |
UPS4 |
WUN-2R5V5VW |
400475578 |
5 |
CAL/SIG |
BGR-026746 |
002413747 |
5 |
UPS5 |
WUN-9V11VW |
400475827 |
6 |
DR PE |
BIR-026805 |
002260182 |
6 |
UPS6 |
WUN-5V18VW |
400475650 |
7 |
DR PE |
BIR-026805 |
002388749 |
7 |
UPS7 |
WUN-2R5V5VW |
400475576 |
8 |
DR PE |
BIR-026805 |
002436840 |
8 |
UPS8 |
WUN-9V11VW |
400475825 |
9 |
DR PE |
BIR-026805 |
002443373 |
9 |
UPS9 |
WUN-5V7VW |
400475731 |
10 |
I/O PE |
BIR-026804 |
002411555 |
10 |
UPS10 |
WUN-2R5V5VW |
400475574 |
11 |
I/O PE |
BIR-026804 |
002412530 |
11 |
UPS11 |
WUN-2R5V5VW |
400475573 |
12 |
I/O PE |
BIR-026804 |
002405525 |
12 |
UPS12 |
WUN-5V7VW |
400475733 |
13 |
I/O PE |
BIR-026804 |
002381776 |
13 |
UPS13 |
WUN-9V11VW |
400475826 |
14 |
I/O PE |
BIR-026804 |
002409639 |
14 |
UPS14 |
WUN-2R5V5VW |
400475572 |
15 |
I/O PE |
BIR-026804 |
002287464 |
15 |
UPS15 |
WUN-5V18VW |
400475649 |
16 |
I/O PE |
BIR-026804 |
002273547 |
16 |
UPS16 |
WUN-9V11VW |
400475824 |
17 |
I/O PE |
BIR-026804 |
002214598 |
17 |
UPS17 |
WUN-2R5V5VW |
400475571 |
18 |
DR PE |
BIR-026805 |
002218344 |
18 |
UPS18 |
WUN-5V7VW |
400475734 |
19 |
DR PE |
BIR-026805 |
002388719 |
19 |
UPS19 |
WUN-9V11VW |
400475823 |
20 |
DR PE |
BIR-026805 |
002367132 |
20 |
UPS20 |
WUN-2R5V5VW |
400475570 |
21 |
DR PE |
BIR-026805 |
002370952 |
22 |
DR PE |
BIR-026805 |
002381449 |
23 |
DR PE |
BIR-026805 |
002260156 |
24 |
DR PE |
BIR-026805 |
002270943 |
25 |
DR PE |
BIR-026805 |
002443376 |
26 |
I/O PE |
BIR-026804 |
002260068 |
27 |
I/O PE |
BIR-026804 |
002188936 |
28 |
I/O PE |
BIR-026804 |
002178765 |
29 |
I/O PE |
BIR-026804 |
002429908 |
30 |
I/O PE |
BIR-026804 |
002381767 |
31 |
I/O PE |
BIR-026804 |
002259981 |
32 |
I/O PE |
BIR-026804 |
002382032 |
33 |
I/O PE |
BIR-026804 |
002398779 |
34 |
DR PE |
BIR-026805 |
002529196 |
35 |
DR PE |
BIR-026805 |
002192780 |
36 |
DR PE |
BIR-026805 |
002393863 |
37 |
DR PE |
BIR-026805 |
002443777 |
38 |
CAL/SIG |
BGR-026746 |
002425814 |
39 |
CAL/SIG |
BGR-026746 |
002237911 |
40 |
PPS |
BIR-026903 |
002542777 |
41 |
PPS |
BIR-026903 |
002443222 |
42 |
PPS |
BIR-026903 |
002436705 |
ADVANTEST T2000 Test System PE CARD BGL-018817数据fail 维修排除.找徐工13913148881 给你最低的价格及最快的服务.另有大量ADVANTEST 板卡出售 地 址:苏州工业园区星港街263号
联系人:徐生 先生
电 话:86-512-13913148881
手 机:13913148881
E-mail:luckyderui@163.com
邮 编:215021
网 址:http://www.suzhou-pcb.com
| Product ID | JAD-15727 |
| Manufacturer | Advantest |
| Vintage | 2005 |
| Model | T2000 |
| Condition | Good |
| Configuration | |
| De |
T2000 Test System |
| Comments | |
| Detailed Specifications |
Advantest T5377,T5593, T5588 维修
** T3347A MEC12 SYSTEM DIAGNOSTICS REV.5.06B2 **
** START AT 2012/12/20 13:27:03 **
** STN1 TEST PIN= 1 - 256 **
** STN2 TEST PIN= 1 - 256 **
TH2 INIT DR GAIN FAIL**
110057. 57PIN IN1 (H) BINARY SEARCH DATA=#5700
210057. 57PIN IN1 (L) BINARY SEARCH DATA=#5700
TEST 56100 TH2 ( 9) CLAMP CHECK FAIL**
10057 PIN= 57 LIMIT= 9.500V , 8.500V MDATA= 0.000V FAIL
20057 PIN= 57 LIMIT=-3.000V ,-4.000V MDATA= 0.000V FAIL
HV2 57PIN BGQ-020732 (AAA) IS DOUBTFUL
TEST 53000 TH2 ( 2) DR OFFSET VOLTAGE (NORMAL MODE) CHECK FAIL**
120057. 57PIN IN2 (H) LIMIT= 29.00MV ,-29.00MV MDATA=-1.018V FAIL
220057. 57PIN IN2 (L) LIMIT= 29.00MV ,-29.00MV MDATA= 1.012V FAIL
TG SLOT 2 BGR-020842 (BKE) IS DOUBTFUL
HV2 SLOT 5 BGQ-020841 (AAA) IS DOUBTFUL
HV2 SLOT 10 BGQ-020840 (AAA) IS DOUBTFUL
TEST 53100 TH2 ( 2) DR IN1-16 SELECT CHECK FAIL**
110057. 57PIN IN 1 (H) LIMIT= 542.1MV , 481.9MV MDATA=-752.0MV FAIL
TEST 53410 TH2 ( 2) TH-MDC CABLE CONNECTION CHECK ***PASS
TH2 INIT PL OFFSET FAIL**
10057. 57PIN IL1 (H) SEQUENTIAL SEARCH DATA=#445
20057. 57PIN IL1 (L) SEQUENTIAL SEARCH DATA=#445
维修时间 标准时间10个工作日,加急3个工作日,对修复部位保修三个月。 本公司回收各种损坏的变频器、触摸屏、电源、伺服驱动等。贵单位如有上述各方面的维修需求,请带坏电路板来我公司考察、维修,以便建立长期的业务关系。我们将以高度的热情、精湛的技术为贵单位排除一切因电路板故障造成的诸多不便,竭尽全力保障生产顺利进行。
地 址:苏州工业园区唯新路69号一能科技园1-202室
联系人:徐生 先生
手 机:13913148881
邮 编:215021
通过中国触摸屏网金牌会员认证
