厦门仲鑫达自动化设备有限公司》
FANUC ACP A16B-1210-0410 A320-1210-T416/?03A BOARD
Fanuc Pulse Coder 2000P A860-0304-T011
Fanuc Pulse Coder Alpha A64 A860-0360-V501 A860-0360-T2...
Fanuc Pulse Coder ABS 2000P A290-0561-V531 (A860-0320-T...
Fanuc A16B-0160-0651 PCB - 3000 Control Board
Fanuc A16B-1210-0460 PCB Panel Control Circuit Board
STANCOR CONTROL TRANSFORMER P-8505
Used Custom Transformer Cat. No. M-13206E12P PRI. V 460...
CPS-18FB YASKAWA YASNAC J50 J100 J300 DC POWER SUPPLY O...
Telemecanique I/O Remote Module ABE-7H16R
TELEMECANIQUE ABE7-H16R50 USPP ABE7H16R50
TELEMECANIQUE ABE7-TES160 15 TERMINAL BLOCK
Telemecanique ABE-7H16R21 LOT of Screw Termainal x 3
Horyu Model: Control-Pack 6X, Type SCH
Horyu Model: Control-Pack 6X, Type -SSE
TEXAS INSTRUMENTS MOUNTING RACK MODEL:505-6508 W/SET O...
CPS-25N Yaskawa Yasnac MX3 Mori Seiki MV45 MATSUURA MC-...
Allen Bradley Pendant 1771HD 91657702
CPS-10NB YASKAWA YASNAC LX3 MX3 CNC DC POWER SUPPLY 200...
Uson Dual XDCR 426-X300 Dual Transducer Converter
Uson CPU 486 MLT 94V-0 0041
Uson XDCR HI 407A HI Resolution Transducer Converter Mo...
Uson Disk Drive 412-X300
Allen Bradley Microprocessor Board 625537 Rev-2
Uson CPU 486 486A300D
Uson Dual Tester Memory Module 430-X300
Uson CPU 486 486A300E
Used Cincinnati Milacron BOARD 3-531-3563A
Used Cincinnati Milacron BOARD 3-531-4009A
Used Cincinnati Milacron BOARD 3-533-0018A Rev.B (3-5...
Gigabyte Motherboard GV9341(GV9314)
IEE Display Module 03601-95B
Fanuc D-A7610-4 AC Servo MotionPack Drive
Siemens Sinumeric 810 M 6FX1125-8AB04, WARRANTY
SIEMENS 6FX1126-1AA03 Video Graphics Monochrome Module
Fanuc A16B-0160-0542 PCB - 3000 Control Board
Fanuc A16B-0190-0010 PCB - 3000 Control Board
Fanuc A20B-0008-0480 6 T/M PCB ROM Control Board
Fanuc A20B-2000-0170 OC Master PC Board
Fanuc A20B-0007-0040 PCB - 6 Control Board
Fanuc A20B-0008-0430 6 CRT Puncher Board
Fanuc A20B-1002-0280 PCB - AC Servo 3 Axis Drive Board
CINCINNATI MILACRON 3-531-4090A. TESTED
Fanuc A16B-0190-0050 PCB - 3000 Memory Control Board
Siemens 6FX1133-0BA00 CPU board , tested
SIEMENS 6FX1121-2BB02 With 6FX1126-2BA00 CARD Video Gra...
Fanuc A16B-0190-0080 PCB - 3000 Memory Control Board
Fanuc A20B-0003-0742 5 Control PCB Board
Siemens Sinumeric 810 M 6FX1120-7BA01 , tested
Fanuc A20B-0002-0942 PCB - 2000 Control Board; Position...
Fanuc A16B-1110-0540 I/O Board
Fanuc A20B-0004-0990 Amplifier Board
Fanuc A16B-1300-0111 Spindle Drive Positioning Card
Fanuc A350-0004-T012/?01 3000C Keyboard Display
Fanuc A20B-1002-0290 Feedback PCB Board
Fanuc A20B-1001-0242 PCB - 10 Control I/O Board
Siemens Sinumeric 810 M 6EV3055-0BC POWER SUPPLY
Fanuc A03B-0807-C011 I/O Interface Module
Fanuc A03B-0807-C156 32 Point DC I/O Module
Fanuc A20B-8001-0900 PCB Board with Ethernet Cable
Fanuc A16B-1211-0301/?02A PCB - 0 Control I/O Board
Fanuc A16B-3200-0056 PCB Board
Fanuc A16B-2200-0091 PCB Board
Fanuc A20B-1002-0050 PCB Board; Graphic Controller
Fanuc A20B-1000-0900 PCB Board; F10/11 Control CTL/ML
Used INTEL Board PWA-1002296-19
Used Monarch Courtland PC Assy Circuit Board 733F101 P0...
Advance 71A8291 35 MFD 243V Cap. Transformer
Noratel 63854-901 Single Phase Autotransformer (TIMS04 ...
Takagi TT-100 Single Phase 0.1 kVA Transformer; 200-220...
KACON SOLID STATE TIMER Type: TDS-2230 By Korea Auto Co...
Stancor P-8559 115V Transformer
ACDC Electronics Model:ECV 24-4.8 Power Supply, Output:...
SMS 03-54118 Transformer
Condor Inc. Model: HTAA-16W-A, Input-100-240 VAC, Outpu...
Hevi-Duty E1053PBTC 0.105 kVA 50/60 Hz Isolation Class ...
Terminal Block 24 position
MB05308 34A Choke Transformer
Fanuc A290-0141-X035 Plastic Motor Cover
Micron B150BTZ13JK 150VA Control Transformer
Stancor P-8617 Single Phase Transformer
Royal Electric Type 86 Transformer
SOLA Electric 83-05-312-2 5V 12A Power Supply
Square D 9070T50D19 Industrial Control Transformer
Stancor P-6387 500VAC 115V Transformer
Used Socket 478 Full-Size CPU Card W/Processor Model: I...
Takagi TT-1030 Single Phase 1.03 kVA Transformer; 180-2...
Mitsubishi Model: F2-60MR PROGRAMMABLE CONTROLLER
Mitsubishi Model: F2-20ER PROGRAMMABLE CONTROLLER
ENFM Oil Pressure Gauge System Unit
Omron DB4L-3DRA-A Safety Door Lock Switch 24 VDC Coil
Honeywell/Yamat?ake Micro Limit Switch (Lot of 2)
Allen-Bradley Nema type 13 Selector Push Button 800T-KE...
OKUMA MRM 043C MRM043C MRM-043C TDK POWER SUPPLY UNIT
Used Mitsubishi Control Unit UF701B MELDAS -YM2V
New Lithonia Lighting TFR Series Light fixture Lamp Typ...
Cleco Cooper Tools Tightening Manager TM100 Series Fron...
Cleco Cooper Tools Tightening Manager TM100 Series PCB2...
Cleco Cooper Tools Tightening Manager TM100 Series Powe...
Seasonic Model: SS-350HS Active PFC F3 Computer Power S...
Cleco Cooper Tools Tightening Manager TM100 Series ON/O...
Vacon Frequency Converter Model:PP05052
Vacon Frequency Converter Model:PP01007
Used Fanuc Power Unit A14B-0019-C004
Used Siemens Discharge Unit Model:462000.70?33.00
Used FANUC Servo Drive W/BOARD #A20B-0004-0171 #A20B-00...
Used FANUC 3000C Fuse Panel
Used FANUC Velocity Control Unit A06B-6045-H001/?H002
Used FANUC Servo Drive Amplifier A20B-0004-0170
Used FANUC Velocity Control Unit A06B-6045-H004/?H005
Used Cincinnati SLS1C21 Milacron Simoreg D165 G200/25 M...
Gordos Mounting Rack PB16
Ruud Lighting 12" X 12" Light fixture
Fanuc A290-0501-X053 Plastic Motor Cover
Allen-Bradley Nema Type Pilot Light 800T-PT16
Power Supply Model PS1000 Input:115-230 VAC, Output: +5...
Sola Power Supply Model SLS-24-036 Input:100-240 VAC, O...
Power Supply Model 200B24 Input:115/230 VAC, Output: 24...
LEM Model: LA305-S Current Transducer, Swiss made
OPTO 22 - OAC5Q - I/O Module
Used Sungwa Electric Spark Killer SH3CR-22-1, 220VAC 50...
TONG IL COMPANY LTD. TBU1 MODEL: E371-07000 TERMINAL BL...
TONG IL COMPANY LTD. TCN2 MODEL: E371-09000 RELAY BOARD
NEW SPECTROL RELIANCE LTD. MODEL 11 MULTIDIAL MADE IN E...
SIEMENS INPUT MODULE 4POINT DIGITAL 4-PACK MODEL:6ES7-...
STANCOR TRANSFORMER MODEL:P-8617, INPUT: 115-230V ; OUT...
DG4V-3S-0A-M-FW?-B5-60 VICKERS DIRECTIONAL CONTROL VALVE
CUSTOM POWER SUPPLY 115VAC IN AND 24 VDC OUT AT 6.5 AMP...
Used Fanuc Reactor Model:A81L-0001?-0083, AC253V 24A 0.1...
Used Transformer Model:DE8401368 Removed from Working e...
PlexiGlass Machine Cover; From Okuma Cadet-L1420 Type L...
SPECTRONICS EPROM ERASING SAFETY CABINET MODEL PC-1100
OPTIMA TECHNOLOGY 75-200 WATT INVERTER CABLE
Used POWER-ONE POWER SUPPLY IN ENCLOSURE BOX INPUT: 120...
TEAC CD-W552GB 52X CD-R/RW CDROM Drive IDE BLACK Intern...
FEDERAL VIBRATONE HORN MODEL:450 SERIES:B3, INPUT 24 VD...
Huntron HSR 410 Switcher No leads and cable
Allen-Bradley SLC 500 10-Slot Rack CAT.1746-A10
Yaskawa Remote Interface Model JVOP-104
ADVANTECH AWS-8420TP Industrial Workstation with 12.1"...
3.496" X 1.75" Blank Aluminum ID Tags (Box of 500)
Trygon DC Power Supply HR40-2.5 40V 2.5A
Kikusui W/I Auto Tester 860AS Hi-Pot Megger
Harpster Tarps 12' X 30' Silver Tarp
Iwatsu Synchroscope SS-5702
Sanyo Denki Position Controller Model: APC-1
Siemens AC Drive 6SC6101-5B-Z
Sanyo Denki San Driver unit Model: PDT-203G-19N
Allen-Bradley Bulletin DC Servo Controller 1388-AV20
Allen-Bradley Bulletin DC Servo Controller 1388B-AV40
New Power-One MAP55-4000 Power supply
New Yaskawa DC Power Supply
New SOLA SLS-05-060-1 Regulated Power Supply
New LFE Metric Dial Indicator
Used SOLA SDN8-5-24
NEW SOLA SDN8-5-24
Used SOLA SDN5-24-100
Used GE Power Supply Module
Used Norand 851-027-001 Power Supply Model #: SP235
Used Siemens 6EP1436-3BA00 SITOP Modular Power
Used Telemecanique TSX-SUP-702 Power Supply
Used Nemic Lambda RWS200A-24 Power Supply
Fanuc Pulse Coder Alpha A64 A860-0360-T101
Todensha Co. DXG-41B1 AC600V, 20A Operator Joystick
Yaskawa FELQ-5 230V, 60Hz, 1.87A, 1720 RPM 3 Phase Indu...
AEG AM 71 FY6 120/208 V, 3.35/1.92 A, 0.25kW Motor
Yaskawa BDBQ 0.75 kW, 4 Pole, 3-Phase Quick Brake Motor
Electro-Craft E19-1 Servo Motor
Fanuc A80L-0001-0176-?02 1 KVA Cap. Type 07155 Transform...
GENERAL RADIO CO. VARIABLE RESISTOR TYPE 471-A OHMS 200...
Dale Model: PH-100 6.5 OHM 100W
Bayer Industries Inc. CPU Assembly Board #116-444
Bayer Industries Inc. I/O Assembly Board #116-541 rev.3...
Bayer Industries Inc. PCB 117-131
Bayer Industries Inc. PCB 118-012
Bayer Industries Inc. PCB 117-182
Fanuc- Module board A20B-3900-0181/?02A
Allan-Bradley CAT.#1785-LT B PLC-5/15 Processor Module
Allan-Bradley Personal Computer Interface Converter CA...
Allan-Bradley Used Programming Terminal CAT# 1336-MOD-E...
Allan-Bradley New IMC-120 Servo Controller CAT. # 1771-...
Allan-Bradley CAT.#1785-LT4A PLC-5/10 Processor Module
Allan-Bradley Used Mini PLC-2/15 Programmable Controlle...
Fanuc- Servo Module board A20B-2902-0070/?070A
Fanuc-Servo Module board A20B-3300-0248/?03A
Fanuc- Module board Memory A20B-2900-0531/?02A
Fanuc- Servo Module board A20B-3900-0181/?02A
FANUC A16B-1310-0300 ACP BOARD
Horyu Key board with Membrane p/n 7804-101
Horyu Eng. Used Board p/n 4019-100C/4E
Horyu Eng. Used Board p/n 7804-100A
Horyu Eng. Used Board p/n 7804-IO3A-1A
Horyu Eng. Used Key Board with Control from Sugino CNC ...
CINCINNATI MILACRON Control Panel With Membrane and Key...
GOULD MODICON DIVISION USED PCB's p/n S02M Rev.D and P...
USED PICMG INDUSTRIAL COMPUTER MOTHER BOARD P/N PCI-14S...
USED 5VC OPERATOR PANEL-900V2; 3-525-0886A
Used Fanuc X, Y, Z 3000C Display Assembly
Cincinnati Milacron 3 531 3697A 35313697A Rev J
Kardex Extractor Power Control 3 Assy # 6002281-001 Rev...
Uson CPU 386 386SX CPU
Central Data Corp. CPU Board CD21/3038
Uson Power Supply 402A302H
Uson SSD HD 476A300C SSHD Prom
Modicon Memory Module Prom AS-521P-008
Modicon CNC Memory Board AS-506P-F12
Used SLS1C21 Cincinnati Milacron Simoreg D165 G200/25 M...
Used Cincinnati Milacron BASE BOARD 3-531-4008A
Used Cincinnati Milacron BOARD 3-5313568A
Used Cincinnati Milacron BOARD 3-5313569A
Used Cincinnati Milacron BOARD 3-5313636A
Used Cincinnati Milacron MEMORY BOARD 3-531-4003A (3-5...
Used Cincinnati Milacron BOARD 3-531-3611A
Used Cincinnati Milacron BOARD 3-531-3680A
Used Cincinnati Milacron BOARD 3-531-3630A
Used Cincinnati Milacron BOARD 3-531-3561A
Used Cincinnati Milacron BOARD 3-531-3513A
Used Cincinnati Milacron BOARD 3-531-3859A
Used Cincinnati Milacron BOARD 3-531-3567A
Siemens I/O Modul 64E/32 DC20V-30V, 7W
Potter&Brumfiel?d Relay PRD5DY0-24V
Potter&Brumfiel?d Relay PRD7DY0-12VDC
Potter&Brumfiel?d Mercury Wetted Contact Relay JM2-115-2...
Sanyo Denki PWM Amplifier Model:PU-P050X0 Input: AC 200...
MITSUBISHI TRA 31A TR 23E-10-A
Used Okuma TH604 Drive
Used Hitachi Seiki Mother Board with
Used Fanuc Discharge unit A06B-6050-H050
TR-15A BN624B055D NF30-SB S-A12RM MITSUBISHI TR15A POWE...
BRADY DATAB MARKERS DOT-MATRIX PRINTABLE LABELS DAT-67...
BRADY BMXRP-2 PRINTER ASSEMBLY FOR PARTS P/N 29552
Fuji Electric Motherboard DSR Compact Drive FSD-15-DN
Giddings & Lewis Jog Functions Control Box p/n 840-2067...
Sugino Machine Limited Used JOG BOX
Fanuc A81L-0001-0120-?03 Transformer Reactor 130A
Fanuc A80L-0001-0080 5 KVA Transformer
International Power Model: IHD24-4.8 Power Supply, Outp...
W5503 Shape Laminated Core Transformer
Takagi TT-700 Single Phase 0.7KVA Transformer; 200-220V...
Takagi TT-500 Single Phase 0.5KVA Transformer; 200-220V...
Yaskawa CPT020010 150VA Control Transformer
Yaskawa CPT020082 Type USNB Single Phase 750VA Transfor...
Stancor GIS-150 Power Transformer; 115V 150VA
Sola CAT.NO.83-24225?-03 Power Supply Input: 120/240 VAC...
Hevi-Duty W300J Type SBW Transformer
Fanuc A80L-0001-0111-?02 1.2 kVA Transformer
Allen Bradley K7E1C 1000VA Primary, 30VA Secondary Tran...
Daiwa Dengyo Type TF-500 0.5kVA 1PH 520V Transformer
Royal Electric Type 135 500VA Transformer
Magnetek-Triad N-59M Isolation Transformer; 115V 1000VA
Condor Inc. Model HE24-7.2-A Power Supply,Input:10?0-240...
Fanuc A80L-0001-0074H?E-04 1.5kVA Transformer
Fanuc A80L-0001-0080-?07 5kVA Transformer
Sola Electric CAT.No. 83-24-260-2 Power Supply,Input:12?...
Kasuga M59691 Type DVS Transformer
Jensen 70CV10 37.4 KM 200 Watt Transformer
Assembly Products INC 2061-1-75 Current Transformer
LH Research Model:MM25-E088?5/115, Input:115VAC, Output:...
PC-24-450 Signal Transformer; 115V, 24VC @ 450MA
Sorensen Power Supply Model: DCR300-1.5B, Input 115VAC,...
Stancor TP-1 Transistor Power Transformer; 117 V, 60 Cy...
Signal Transformer Co. DL-46-4 Signal Rectifier Single ...
6K30VG Laminated Core Transformer
Sorensen Power Supply Model:DCR20-115?B, Input 115VAC, O...
Sola 20-13-060 Constant Voltage Transformer; 120V 60VA
Yaskawa Resolver PG Transducer Model: PRPT-01D2.
Acme Electric TA-81215 Machine Tool Control Transformer...
Sola Electric Power Supply 83-15-3216 Input:120/240 VAC...
JVC Color Video Monitor TM-41AU
Opto 22 Mounting Rack with 16 AC Outputs PB16A
Machine Monitor Cover
CONTROL UNIT WITHOUT HOOK 550DSM5-2.8CB FOR MANNESMANN ...
Farrand Controls Pre-Amp Board 219200
Farrand Controls I/O Converter Board 219100-31
Farrand Controls Distribution I/O Quad Control Interfac...
PowerVolt BVA-24FS12 Linear Power Supply; 24/28 VDC at ...
Cuda Fiberoptics Model I-150 without fiber optic cable
GN6T Maintenance Manual
Ikegami CCD Color Camera W/ Power Supply ICD-840 & TM14...
TECHMALUX LUMOLUX K2E/213 ILLUMINATION MACHINE LIGHTING
Heavy Duty Road Case Trunk
Magnetek E-Plus III 10 HP Motor
Hitachi LTD Induction Motor EFOUP w/ Start/Stop pedal
Custom Power Supply; Input:120, Output: 60VDC 10VDC 24V...
Nisshin SQ23150SF CNC Machine Surge Protector
12 Position Turret For Okuma Cadet-L1420; Type LNC10 Ma...
Oriental Motors 51K90GS-ST3F-E1 Induction Motor
SCHNEIDER TSXPACC01 TERMINAL ISOLATION BOX USED
Kep Electronic Counter INT66xxx15x
SCE Industrial Control Panel Enclosure Unit Type 12, 4
PROXIMITY SWITCH INDUCTIVE 4X UPDATABL 2 SCREW HOLES US...
Telemecanique XGS-K6204321 XGSK6204321 Inductel Proximi...
Opto 22 Mounting Rack PB16
Oriental Motors 51K90GS-ST3F-E1 Induction Motor *FOR PA...
MODICON PC-A984-145 PROCESSOR MODULE PCA984145
PIO-12 PC6062 14005 Rev.J ISA Card
GOULD MODICON ASSY S480-201 Rev.B10 PCB MEMORY CPU
Bayer Industries 116-741-3 BOARD ASSY
A.G. Davis Board assy Model: ECD-1000-044
Opto 22 Mounting Rack PB16A
Sanyo Denki Stepping Motor 103Z708-0440
Sanyo Denki AC Servo Motor 102-528-3904
Sanyo Denki AC Servo Motor 102-528-1817
Dual Motors w/ Gearbox 115 V; 60 Hz; 16 MFD; 13 RPMs
WARLOK Model TKP-10B Trailer King Pin Lock
Oriental Motors 5GS18K Gearhead w/ 51K90GU-STF 3 Phase ...
Oriental Motors 5GU18K Gearhead w/ 51K90GS-ST3F-E1 Indu...
Siemens 3ZX1012-0NP50-1?AA1 Fuse Switch-Disconne?ctors. 3...
Tugi Toyogiken Model: PCFK-5H34-012, 34 Position Termin...
Tugi Toyogiken Model: PCFK-5H16-012, 16 Position Termin...
Yaskawa Magnetic Proximity Switch Type: PSMO-25D2 250V ...
Lambda Power Supply Model LOS-X-28, Input: 105-125VAC O...
Power Supply Model: ICP131 Input: 110-240VAC,Out:?+/- 5V...
Power Supply Model:HE24-7.2-?A Input: 100-240VAC, Output...
Used Efector. Inc, N600 Switching Amplifier
