维修触摸屏ALICE-T4-V1 ALGO 电路板生产厂工控电脑维修
D380 G8/1400 WRG-TFM
AUTOMATION SYSTEMS RLED160
MUNK GMBH水平电镀整流器特约维修商
Ah meter CC 4000
alpha S / 250 W - max. 25 A / Bench case and module
alpha M / 500 W - max. 50 A / Bench case and module
alpha L / 1,5 kW - max. 150 A / Bench case and module
alpha XL / 3 kW - max. 600 A / Bench case and module
alpha L + XL with MFD 1,5/3 kW - max. 150/600 A Bench case
ALU-SPECTRAL
usplating
AS 100 - Process controller for aluminium anodising
AxD - Cabinet Series
AxD - Compact Series
DCAC 100 - Electrolytic colouring of aluminium
Electrolysis Power Supply 1
Electrolysis Power Supply 2
E-Coating Power Supply
ESA 2000 Current Density Control
ESR Power Supply
Remote Control type E
Remote Controls with analogue setpoint setting
gamma S + M with MFD / 8/15 kW - max. 800/1000 A / Bench case
gamma S / 8 kW - max. 800 A / Bench case and module
gamma M / 15 kW - max. 1000 A / Bench case and module
gamma L / 20 kW - max. 1500 A / Module
gamma XL / 30 kW - max. 2000 A / Module/Wall-mounted case
HS 100 - Process control for hard anodising of aluminium
Multi-circuit power supply - omega
Multi-circuit power supply, air-cooled
MFD - Remote control
MPS - Control and Programming Terminal for Plating Rectifiers
omega L / 18 kW - max. 1500 A
omega XL / 30 kW - max. 2000 A
omega XXL / 60 kW - max. 5000 A (separate unit)
PKA 2 - 10 A version
PKA 2 - 5 A version
Polarity inverter - thyristor technology, oil-water cooling
Polarity inverter - thyristor technology, oil cooled
Polarity inverter switch, electro-mechanical
PowerRack - much more than simply a modular switchmode power supply rectifier
Pro Ano Software
Profibus DP interface
Variable ratio rectifier, oil-watercooled (OWA)
Variable ratio rectifier, oilcooled
Thyristor rectifier, aircooled
Thyristor rectifier, oil-watercooled (OWA)
Thyristor rectifier, oilcooled
Thyristor rectifier, watercooled
V-Pilot - Process voltage monitoring
VAR Power Supply
VPC - Visual Plating Controller
AC Power Supply
24小时ELMO伺服驱动维修销售专线:13913148881徐工
驱动器维修,触摸屏维修,电源维修,调速器维修,伺服电路维修
地 址:苏州工业园区唯新路69号一能科技园
联系人:徐生 先生
电 话:86-512-13913148881
手 机:13913148881
E-mail:luckyderui@163.com
邮 编:215021
网 址:http://www.suzhou-pcb.com
通过中国触摸屏网金牌会员认证
