高速双总线结构;
32位处理器;
256MHZ处理速度;
16MB内置记忆体;
具有墙上面板、无线触摸屏、电脑软件、网络集中管理等控制方式;
8个RS232/RS485通讯口(带奇偶校验),每个串口可以级连数台通讯设备;
8路独立可编程红外接口(外置),采用红外自学习方式,并可以导入导出红外设备码,方便保存和批量安装;
8路弱继电器口控制;
8路I/O口控制;
主机间可以连网,可以级连数台;
内置网络模块插槽,方便接入网络控制模块,实现远程控制及远程监视、报警等;
出厂内置标准程序,调试更简单。
主要指标
电源范围:AC:180~240V;
整机尺寸:480×250×65mm;
安装尺寸:标准19英寸机箱。
High speed dual buses structure;
32 bit processor;
256MB processing speed;
16MB built-in memory;
Support various controlling methods such as panels on wall, wireless touch screens, computer software and network central control.
8 RS232/RS485 communication ports (with parity check), each port being able to connect to multiple communication equipments in cascade connection;
The 8 way independent programmable infrared interface (external) adopts infrared self-study method. The infrared equipment codes can be uploaded and downloaded.
8 way weak relay port control;
8 way I/O port control;
The machines can be connected to form a network, and the cascade connection of several machines is permitted.
The built-in network module slot is easy to connect to the network control module to achieve remote control, surveillance and alarm, etc.
The standard program is built in the machines when leaving the factory, making the adjustment easier.
Main parameters
Voltage range of the power supply: AC 180~240V;
Dimensions of the whole machine: 480×280×95mm;
Installation: standard 19 inch machine case.
