内置串行端口:8个,其中4路双向传输RS-232,2路RS-485及2路
单向RS-232接口,任意串行口,可自定义控制各类通讯设备;
内置红外端口:4个凤凰头接口,可独立控制红外遥控设备,红
外可通过前面板的按键和指示灯进行自学习,操作简单;
内置WLAN端口,网卡插槽,选配网卡,可升级为网络中控;
内置AV6×3全切矩阵,3路立体声异步音量控制;
内置VGA5×2全切矩阵,支持传输距离达40M;
带宽:400MHz;
电源范围:AC 100~220V;
标准RS-232/485通讯协议;
整机尺寸:430×300×50 MM;
安装方式:标准19英寸机柜。
Built-in serial port: 8 ports, DB9 female interface, 4 of them are bidirectional transmission RS232 interfaces, 2 of them are RS485 interfaces and 2 of them are unidirectional transmission RS232 interfaces. The serial port can be set at will to control all sorts of communication equipments.
Built-in infrared port: 4 ports, 3.81mm interface, can independently control the infrared remote control equipments. The infrared light can conduct self-study through the buttons and indicator lamps on the front panel, and the operations are very easy.
Built-in WLAN port and network card slot. The unit can be upgraded to network remote controller through adding a network card.
Support various controlling methods such as wireless/cable panels on wall, wireless/cable touch screens, computer software and network control.
Built-in AV4X2 full tangent matrix, and 3 way stereo sound non-synchronous volume control
Built-in VGA5*2 full tangent matrix
The supported transmission distance is up to 40m
Bandwidth: 400MHz
Main indices of the central controller
Standard RS232/485 communication protocol
Input power ≤30W
Dimensions: 430X300X50 MM
Installation method: standard 19 inch machine cabinet
