| FDS26-29 | Power Supply 26V-29A |
| FDS11+11 | Power Supply 11V-34A |
| BGR-018838 | SDIST BOARD T5365P |
| BGR-018842 | IF BOARD T5365P |
| WBL-PS15V15A | POWER SUPPLY T5365P 15V15A |
| SR200-5/5G | POWER SUPPLY T5365P 5V40A |
| FDS11+26 | POWER SUPPLY T5365P 11V/34A/26V/14.5A |
| FDS5+5 | POWER SUPPLY T5365P 5V75A |
| SR300-12/5G | POWER SUPPLY T5365P 12V27A |
| SR200-18/5G | POWER SUPPLY T5365P 15V11.5A |
| WBL-P65V11R5A | POWER SUPPLY T5365P 65V5A |
| WBL-PS36V21A | POWER SUPPLY T5365P 36V21A |
| SR600-5/5G | POWER SUPPLY T5365P 5V120A |
| BGR-018931 | Main Board Section |
| BGR-016793 | IFL Board |
| IFA Board | |
| BGR-017579 | BGR-017579 |
| BGR-017575 | Main system board |
| BGR-017578 | Main system board |
| BGR-018839 | DDIST Board T5365P |
| SR50-5/5G | POWER SUPPLY T5365P 5V10A |
| BGR-018837X02 | IOVD BOARD T5365P |
| BGR-018836 | DRVD BOARD T5365P |
| WBL-PS11V68A | POWER SUPPLY T5365P 11V68A |
| SR50-15/5G | POWER SUPPLY T5365P 15V4A |
| TKS-26-29A | POWER SUPPLY T5365P 26V29A |
| BGH-018826 | T5365P TEST HEAD BOARD |
| BGH-018827 | T5365P TEST HEAD BOARD |
| BGH-018830 | T5365P TEST HEAD BOARD |
| BGH-018828 | T5365P TEST HEAD BOARD |
| BGH-018825 | T5365P TEST HEAD BOARD |
| BGR-016797 | IFA Board |
| WBL-PS2V150A | Power Supply 2V |
| NA | T5365 Mother Board (8 rows) |
| BGH-018829 | T5365P TEST HEAD BOARD |
| BGL--18831 | T5365P TEST HEAD BOARD |
| WBL-PS3750W | Power Supply 270V AC/DC |
| FDS15-50 | POWER SUPPLY T5365P 15V50A |
| BGR-019486 | DC Board |
| BGH-019207 | T5365P TEST HEAD BOARD |
| BGR-018840X02 | SC Board |
| WBL-PS5V150A | Power Supply 5V |
| BGL-018817 | PE CARD T5365P |
| MKX-F9228B-1 | SC Fan Shaft (MKX-F9228B-1) (M6541) |
| WBL-023084 | BOARD, REPAIR CPU(RCUP)H,P |
| WBL-023086 | BOARD,MASTER CPU(H,P) |
| NLD-000357-1 | LED |
| MKX-F1590A-1 | SHAFT,LOWER |
| YBB-006653-1 | BEARING YBB-006653-1 |
| YBB-006652-1 | MANIPULATOR BEARING (YBB-006652-1) |
| DCB-EP5675X03-1 | SWITCH,AUTO (DCB-EP5675X03-1) |
| DCB-MM7420X01B-1 | FUSE,THERMAL (DCB-MM7420X01B-1) |
| YEE-002697-1 | BEARING YEE-002697-1 |
| DCB-EE4574X01-1 | Fuse, Thermal (DCB-EE4574X01-1) |
| DCB-EE5398X01A-1 | FUSE,THERMAL (DCB-EE5398X01A-1) |
| MKX-F1558B-1 | SHAFT,HOOK |
| DEE-003235-1 | VALVE, SOLENOID |
| SEE-EESPZ302-1 | AMPLIFIER, SENSOR |
| YBB-006318-1 | BEARING YBB-006318-1 |
| YBB-006075-1 | BEARING YBB-006075-1 |
| MKX-F1563A-1 | GUIDE,POLE |
| MKX-D5296B-1 | SHAFT MKX-D5296B-1 |
| DCB-EP5676X05-1 | SENSOR,CYLINDER (DCB-EP5676X05-1) |
| YCY-005415-1 | CYLINDER,AIR (YCY-005415-1) |
| DEE-003218-1 | AMPLIFIER, SENSOR |
| DEE-003229-1 | VALVE, SOLENOID |
| MEX-D5291A-1 | SPRING MEX-D5291A-1 |
| MKX-F1659A-1 | GUIDE,TRAY |
| YVP-006533-1 | PAD,VACUUM (YVP-006533-1) |
| DSP-001782-1 | POWER SUPPLY, 270V |
| DSP-001784-1 | POWER SUPPLY VEE |
| DSP-001629-1 | POWER SUPPLY VCC |
| JCI-CD004JX01-2 | BASE, OIB |
| MPX-92485B-1 | BELLOFRAM MODIFY (MPX-92485B-1) |
| NLP-000148-1 | CMBLAMP (NLP-000248-1) |
| BIR-021939 | BOARD,TGFC (BIR-021939)H |
| BGR-016793 | BOARD, DPU IFL (H) |
| BGR-021614 | BOARD,SC (H) |
| BGR-021619 | BOARD, VIO Cont (H,P) |
| BGR-022681 | BOARD, SC (P) |
| BGR-022841 | BOARD, TG I/F (H,P) |
| BGR-021616 | BOARD,SC DIST(H) |
| BGR-016797 | BOARD,DC CONT(H) |
| BGR-021938 | BOARD,TGFC I/F(H,P) |
| BGR-022720 | BOARD,SC DIST(P) |
| BGR-022363 | BOARD,DPU I/F(P) |
| BIR-021588 | BOARD,TG CORE(H,P) |
| BIR-021765 | BOARD,ALPG(H,P) |
| BGR-021618 | BOARD,VIO I/F(HP) |
| BGR-021613 | BOARD,SC I/F(H,P) |
| BGR-021800 | BOARD,PDS(H,P) |
| BIR-013610 | BOARD, TG CONT (T5365) |
| BGR-026378X03 | th i/f x03 T5377 |
| BGR-026378X04 | th i/f x04 T5377 |
| BGR-019380 | Board, MMUX (T5365) |
| BGR-018821 | Board, LOG (T5365) |
| BGR-019378 | Board, AMUX (T5365) |
| BGR-018203X02 | Board, DIST (T5365) |
| BGR-019390 | Board, SCR (T5365) |
| BGR-018201 | Board, DGEN |
| BGR-018200 | Board, AGEN |
| BGR-018198 | Board, PGCONT |
| BGR-018199 | Board, PC |
| BGR-018197 | Board, PGIF |
| BGR-018841 | Board, FTUIF |
| BGR-016138 | Board, CLK (T5365) |
| BGR-015467X02 | Board, STRBCONT |
| BIR-015398X02 | Board, RATE |
| BGR-018125 | Board, THOPTIF (T5365) |
| BGR-015554X02 | Board, TG I/F (T5365) |
| MAX-F7018B-1 | MATCH PLATE, LEAD PUSHER |
| DCB-MM5888X01-1 | FUSE,THERMAL (DCB-MM5888X01-1) |
| BGR-019486 | BOARD,DC (H) |
| BGM-021555 | BOARD, TH CONT (H,P) |
| BGM-021556 | BOARD,CLAMP(H,P) |
| BGR-019383 | Board, DFM (T5365) |
| BGR-019379 | Board, DMUX (T5365) |
| BGR-018834 | Board, PDS |
| BGR-015470X02 | Board, DELAY |
| BGR-015466X02 | Board, CLK (T5365) |
| YSN-005428-1 | SPRING |
| BGM-021558 | BOARD,DC MUX (H,P) |
| BGR-016795 | Board, PSL |
| YSB-005396-1 | WASHER, THRUST |
| BGR-018822 | BOARD, VIO IFA (T5365) |
| BGR-023085 | BOARD,SHARED MEMORY(P) |
| BGR-015839 | BOARD, FC (T5365) |
| MEE-72827A-1 | WIRE, GND (MEE-72827A-1) |
| MEE-72854A-1 | WIRE, GND 100 (MEE-72854A-1) |
| MEX-D7587A-1 | SPRING MEX-D7587A-1 |
| YBB-007413-1 | BEARING YBB-007413-1 |
| YBB-007414-1 | BEARING YBB-007414-1 |
| YSN-006286-1 | SPRING |
| MBX-F1579A-1 | GUIDE, BEARING (MBX-F1579A-1) |
| YEE-002695-1 | BEARING YEE-002695-1 |
| YSN-004152-1 | SPRING |
| YSN-004296-1 | SPRING |
| YSN-004297 | SPRING |
| MEE-72824A-1 | BRUSH,GND (MEE-72824A-1) |
| YSN-007390-1 | SPRING |
| YST-004623-1 | BOLT, STOP |
| A09438 | ADVANTEST TSOP66 PROSHEET |
| MKX-1574A-1 | SHAFT,BEARING MKX-F1574A-1 |
| YBB-007412-1 | BEARING YBB-007412-1 |
| YBB-007410-1 | BEARING YBB-007410-1 |
| A09198 | HC SOCKET TSOP2 54P |
| MMX-92414A-1 | INSERT FASTNER |
| MPX-D5294B-1 | BUSH MPX-D5294B-1 |
| BGR-026902 | 32CH DC (DPU) T5377 |
| JTE-BC001PX04-1 | POGO PIN ADVANTEST 5571P |
ADVANTEST 备件 特价销售维
PE-CARD (BGL-019917) VIO_IO (BGR-018824)
PPS BOARD (BGL-016796)
ADVANTEST(T3324)测试机的PINCARD 型号BIK-012107
相关型号
T7315 TESTER Q"ty:3座
R8240 DIGITAL ELECTROMETER
R6581T DIGITAL MULTIMETER Q"ty:1
WORK STATION V0713+KEYBOARD MODEL:TYPE 6 Q"ty:3
H3-7707 Q"ty:2
KH3-6070 USER I/F UNIT+BLP-OII855 Q"ty:1
BGK-011702 REV.BCD UNIVERSAL BUS I/F Q"ty:1
BGK-017719 REV.BAA 2ND BPIB Q"ty:1
KH3-71149 Input:AC200V 50/60Hz 3PH 50A MAX+Hitachi EX50B EARTH-LEAKAGE BREAKER 3P
ADVANTEST T5581 BIR-024515 BGR-024252 BGR-024351
地 址:苏州工业园区星港街263号
联系人:徐生 先生
电 话:86-512-13913148881
手 机:13913148881
E-mail:luckyderui@163.com
邮 编:215021
网 址:http://www.suzhou-pcb.com
通过中国触摸屏网金牌会员认证
