Ninja Blade 高品质HDMI截取器 |
产品介绍说明:(视频)
http://v.youku.com/v_show/id_XNzE3ODExNzM2.html
产品特色:5" SuperAtom IPS高解析触控荧幕,解析度1280x720,325ppi。 400nit高亮度。 多重频率支援(48/50/60Hz)。 记录档案格式Apple ProRes或Avid DNxHD到2.5"硬碟或固态硬碟。 觸控荧幕可应用于录影、监看、回看和编辑。 对焦、黑白纹、错误色彩监控。 使用直流电/电池供电 |
Ninja Blade控制ATOMOS 5.1是采用电容式触控面板提供了闪电般快速的响应时间和姿态的能力。 Ninja Blade是目前世界上最先进的智能生产记录,监控和回放。其物理和操作设计的每一个部分都经过精心雕琢,提供了最佳的操作简单和關鍵任務的可靠性。Ninja Blade結合了多種設備 - 外接顯示器、採集卡、播放和編輯套件 - Ninja Blade是一個單且經濟實惠的工具。 |
| CONSTRUCTION 采用航空级铝合金设计,Samurai blade提供了耐用性和便携性。底部有1/4螺孔可锁定于相机、提笼…等设备上使用。重量仅 380克 Ninja Blade是可搭配于任何相机上,且不管是在攝影棚还是戶外均可。 HOT SWAP DRIVES 在任何時候需操作系統均支持热插拔功能,ATOMOS它會检测因停电损坏或刪除硬碟中的记录文件,并重建档案使您能够恢复到灾难发生之前。 |
产品內容: |
Sharp, Bright Deep Colours just like your Phone and Tablet The new Ninja Blade offers a stunning 1280 x 720 5” SuperAtom IPS touchscreen, at 325ppi 179-degree viewing, 400nit brightness and multi-frequency (48/50/60Hz) operation, you can expect crisp, super smooth monitoring and playback. The capacitive touch panel gives lightning-quick response times and gesture capability. Controlling AtomOS 5.1 on Ninja Blade is silky smooth. Try our User interface online now! The Ninja Blade is the world’s most advanced smart production recorder, monitor and playback deck. Every part of its physical and operational design has been carefully crafted to deliver the ultimate in simple operation and mission critical reliability. The Blade combines multiple devices – external monitor, capture card, playback deck and cut edit suite – into a single affordable tool. It’s lightweight, tough and robust for operation in the field. BREAK THROUGH…… 10-BIT 4:2:2 QUALITY FOR THE MASSES Your affordable DSLR or camcorder is ripping the life out of your sensor with MPEG 420 8-bit recording. Increase the quality of any camera to professional edit friendly codecs – the files are large and the result amazing, only Atomos deliver the ultimate in quality recording to the masses. So why record 10-bit from the sensor of a camera, if it's 8-bit? Well, if you want to edit, use CG or 3D effects, green screen or add titles and transitions, these will all be crushed to 8 bit. We bypass the 8-bit and record 10-bit colour registries to ensure your video plays nicely with all computer effects. YOUR CAMERAS BEST FRIEND Today’s camera sensors and lenses are quite spectacular, and we harness even large 36 MP sensors on Mirrorless, DSLR’s & video cameras to ensure you get the very best from your investment. YES - we support your make and model of Canon, Sony, Nikon, Panasonic! POWERFUL MONITOR AND TEST SUITE Packed into the light and mobile camera-mountable Ninja Blade are all the essential tools you need to set up on-site accurate colors and exposure including full waveform monitor functions - Vectorscope, RGB and LUMA parades. Each provides an intuitive transparent interface offering full screen, lower 3rd or bottom right corner positioning to give you a range of options when setting up, recording and playing back your shot. The Ninja Blade is the world’s most advanced smart production recorder, monitor and playback deck. Every part of its physical and operational design has been carefully crafted to deliver the ultimate in simple operation and mission critical reliability. The Blade combines multiple devices – external monitor, capture card, playback deck and cut edit suite – into a single affordable tool. It’s lightweight, tough and robust for operation in the field. INTRODUCING THE ATOMOS SPYDER COLOR CALIBRATION FOR NINJA BLADE COLORS YOU CAN TRUST Atomos is the worlds first to offer a portable calibration unit for the Ninja Blade - a Monitor, Recording Device and Deck. No other competing device offers this level of color precision. Developed in partnership with Datacolor the Atomos Spyder gives the Ninja Blade one button color calibration normally only found on high end monitors. With Spyder, the Ninja Blade gains the ability to accurately calibrate to the SMPTE Rec 709 color space with a D65 white point with 100% gamut. Being able to trust the colors on a monitor while setting up the shot with RGB, Luma Parade and Vectorscope tools means perfect results every time. Professionals will spend far less time color correcting and finishing in post helping you save time and money. In a time where every client now demands the color grading, you can trust the colors from your camera, to your Blade, to your edit station. We offer the only reliable workflow. Never has it been so easy with one click color calibration anytime, anywhere while recording. CONSTRUCTION Designed using aircraft grade aluminium, the Ninja Blade delivers durability and portability. Locking mechanisms for each removable part means sturdy reliable operation. Weighing a mere 380 grams this pocket rocket will never weigh you down and is completely at home on top of any camera, whether in the studio or up a mountain. COMPLETELY CUSTOM We don’t believe in jigsaw-puzzling a best of breed product, we have designed every circuit, coded every function and invested thousands of hours in testing, quality control, design and manufacturing. We do not buy standard IP cores like codecs, we do not lease HDMI/SDI interfaces – we write everything from scratch to deliver you a finely tuned thoroughbred video machine! UNBELIEVABLY LOW POWER CONSUMPTION Consuming just 6 watts of power – that’s nearly five times less than the nearest competitor - the Ninja Blade is perfect for battery-powered, in-the-field operation. Boasting no less than 4 power options, including the supplied NP series battery, DC power adapter for larger batteries, AC mains power and our patented Continuous Power dual battery system. You’ll never be without power when you need it most. AFFORDABLE 2.5” HDD or SSD 2.5” hard disks are the most affordable digital storage on the planet. They outperform SSDs, SD card, SxS and P2 cards in terms of cost and reliability for video use. In normal video shooting environments the 2.5” HDD is your new tape. Extremely low running costs, long record times (up to 30 hours) and limitless supply. For those vibration sensitive shoots, around the racetrack or in the helicopter, we of course support modern SSDs. ATOM OS5 Like our hardware, the OS used on Atomos products is smart. It’s lightning-fast, simple to operate and robust. It encompasses all aspects of video production, from recording, to playback and review, monitoring assist and even simple cut and tag editing. AtomOS gives us the flexibility to deliver regular functionality improvements and operational enhancements to our existing users. For example, new to AtomOS 5 is alpha channel and transparency support, full waveform monitor RGB parade and Luma overlay display, and vectorscope with zoom (AtomOS 5 only available for the Blade series). RECORD DIRECT FROM THE SENSOR Direct from the sensor – the best quality from your great lens and sensor, no matter when it was made. Old and new cameras alike can get the benefit of higher quality recording, enhancing new cameras and breathing new life into older ones. SYNCED REC TRIGGER AND TIMECODE Triggering record and capturing timecode in sync with your camera is essential to smooth production with external devices. We have teamed up with all the leading camera manufacturers, including Canon, Sony, Panasonic, Nikon, JVC, RED and Arri to give you We include LANC and rolling timecode trigger for those older cameras that don’t have start/stop flag protocols on board – we monitor the timecode and trigger record when the camera starts rolling! EASY TO ENCODE FOR CPU - APPLE PRORES AND AVID DNXHD! Editing codecs are made for editing video, not delivering video. MPEG is great for finishing and delivery – but not for post-production. We give you post-production quality recording on set. The codec choice we offer – Apple ProRes or Avid DNxHD – gives you universal non-linear editing support. Both are routinely used for film and TV production, as well as ProAV, event and independent film making. We have you covered, on Mac and PC. THE LONGEST RECORDING TIME AROUND Using HDD up to 1TB means we can record high quality footage, free you from the hassle of changing memory cards and increase the quality of your footage at the same time. A 500GB drive costs $50 and records 5hrs of the highest bit-rate Apple ProRes and Avid DNxHD formats. Using Avid 36 you can record up to 60 hrs on a 1TB drive! Flexible and affordable long and short recording, the adaptability you need in the field, on the road and in the studio. HOT SWAP DRIVES The way the OS is designed is very intuitive, you can hot-swap drives at any time without having to play games with the OS. Eject and change drives or even take a drive from an edit suite or recorder (even non Atomos ones) and you can play out to any monitor or on screen for review - a true digital deck. SAFETY FIRST! ATOMOS FILE RECOVERY ON THE FLY! When recording the last thing you want is to lose the file you have been recording for the past hour, however if you pull the power or remove the disc, even though we have safety latches.. what happens? Well AtomOS is smart. It will detect the broken file from power outage or removal of disc mid record and reconstruct the This is the peace of mind professionals need. AUDIO MONITORING All audio, even analog audio, is locked With up to 2 channels of digital and 2 of analog audio always available to view and monitor on headphone jacks or line out, audio is taken care of. From mixing desks and line out to XLR adaptor boxes like Beachtek and juiced THE MONITOR THAT THINKS IT’S A RECORDER & DECK! Professional monitoring & signal testing – recording included for free! Probably the most surprising thing SHOT SET UP AND SIGNAL TEST TOOLS! We offer a comprehensive tool set that any test engineer would be proud of – a full waveform monitor, RGB parade display, luma overlay, vectorscope with zoom and test pattern generator for signal calibration. You get focus peaking with multiple levels and colors for ease of use, false color in two modes, zebra 0-100% fully adjustable and blue-only for that quick exposure check! PLAY - DIRECTOR'S CUT THE SMART WAY INSTANT SHOT REVIEW ANYTIME ANYWHERE. Play back your shots and takes on the fly - on set, in the field in a restaurant or on the plane after the production. Check framing, focus and exposure in any part of the footage with the same powerful tools offered by AtomOS monitor tools. Review each and every shot and take using the SuperAtom screen, or to a large monitor for crew and clients to make sure you get what you need. DIRECTORS CUT AND TAG AtomOS gives you speedy navigation, cutting and tagging on short and long clips with transport controls and finite PLAY APPLE PRORES or DNXHD FILE FROM ANYWHERE We call it 3rd-party playback support, what it means for you is your Apple ProRes file with 16-bit audio or Avid DNxHD file from any system, recorder or edit suite can be played back using AtomOS – take rushes from the edit suite on the road in a convenient super high quality deck that fits in your hand. MAC & PC REVIEW The files can be reviewed by any PC or Mac with QuickTime or the system codec installed. Laptop review is simple even without an editing package installed. EDIT - DOCK AND PRODUCE! The coolest part of the process is the instant editing and post production of such large files in one easy step. Simply dock, open your cut footage or any take and you are editing in 10-bit 4:2:2 quality instantly. This really is a pipeline to your timeline. No transcoding, no capturing and no MPEG degradation or 4:2:0 issues. |
保固 Warranty:一年 品牌 Brand:ATOMOS
