| 镍氢电池组 | 标准电压 | 标准容量 | 标准尺寸 |
| 电池组 | 3.6V | 650mAh | 31.5mm x 10.5mm x 44.5mm |
| 电池组 | 4.8V | 650mAh | 21.0mm x 21.0mm x 44.5mm |
| 电池组 | 6V | 650mAh | 52.5mm x 10.5mm x 44.5mm |
| 电池组 | 7.2V | 650mAh | 31.5mm x 10.5mm x 89.0mm |
| 电池组 | 8.4V | 650mAh | 73.5mm x 10.5mm x 44.5mm |
| 电池组 | 9.6V | 650mAh | 84.0mm x 10.5mm x 44.5mm |
| 电池组 | 12V | 650mAh | 105.0mm x 10.5mm x 44.5mm |
| 电池组 | 10.8V | 650mAh | 94.5mm x 10.5mm x 44.5mm |
| 电池组 | 12V | 740mAh | 52.5mm x 10.5mm x 88.0mm |
| 电池组 | 12V | 930mAh | 73.5mm x 10.5mm x 44.5mm |
