| 品名 | 规格 | 电压(V) | 容量(MAH ) | 尺寸 | |
| 松下 | CR2032 | 3V | 225mAH | (20.0mm x 3.2mm) | |
| 松下 | CR-2032L/F1N | 3V | 225mAH | (28.3mm x 20.3mm x 4.2mm) | |
| 松下 | CR-2032/HF1N | 3V | 225mAH | (21.5mm x 20.3mm x 4.3mm) | |
| 松下 | CR-2032/HFN | 3V | 225mAH | (21.5mm x 20.3mm x 4.3mm) | |
| 松下 | CR-2032/F2N | 3V | 225mAH | (36.0mm x 20.3mm x 4.2mm) | |
| 松下 | CR-2032/HSN | 3V | 225mAH | (21.5mm x 20.3mm x 4.3mm) | |
| 松下 | CR-2032/VCN | 3V | 225mAH | (20.3mm x 4.5mm x 22.3mm) | |
| 松下 | CR-2032/F4N | 3V | 225mAH | (28.4mm x 20.3mm x 4.2mm | |
| 松下 | CR-2025 | 3V | 165MAH | 20.0mm x 2.5mm) | |
| 松下 | CR2016 | 3V | 90MAH | (20.0mm x 1.6mm) | |
| 松下 | CR-2016/F2N | 3V | 90MAH | (38.7mm x 20.3mm x 2.3mm | |
| 松下 | CR-2025L/BN | 3V | 165MAH | (20.0mm x 2.5mm) | |
| 松下 | CR1616 | 3V | 55MAH | (16.0mm x 1.6mm) | |
| 松下 | CR-1616/F2N | 3V | 56MAH | (26.1mm x 16.1mm x 2.6mm) | |
| 松下 | CR1220 | 3V | 35MAH | (12.5mm x 2.0mm) | |
| 松下 | CR-1220/HFN | 3V | 35MAH | (14.5mm x 12.8mm x 3.1mm) | |
| 松下 | CR-1220/FCN | 3V | 35MAH | ||
| 松下 | CR1632 | 3V | 140MAH | (16.0mm x 3.2mm) | |
| 松下 | CR-1632/V1AN | 3V | 140MAH | (16.3mm x 4.3mm x 18.3mm) | |
| 松下 | CR-1632/G1AN | 3V | 140MAH | ||
| 松下 | CR-1025/BN | 3V | 30MAH | (10.0mm x 2.5mm) | |
| 松下 | CR-1216/BN | 3V | 25MAH | (12.5mm x 1.6mm) | |
| 松下 | CR2450 | 3V | 620mAH | (24.5mm x 5.0mm) | |
| 松下 | CR-2450/G1AN | 3V | 620mAH | (26.0mm x 24.8mm x 6.0mm | |
| 松下 | CR-2450/H1AN | 3V | 620mAH | (26.0mm x 24.8mm x 6.0mm) | |
| 松下 | CR2012 | 3V | 620mAH | (20.0mm x 1.2mm) | |
