美国UDM L200C浓缩切削液
产品特性:
l L200C lubricant Series is a biodegradable water based, non caustic material
L200C系列润滑剂是一种可生物降解、水性、非碱性物质
l Dilution ratio of DI /RO water: Cutting Fluid – 500:1 to 800:1
去离子水/反渗透水溶液比例:切削液 – 500:1至800:1
l Excellent wetting and rinsing properties
极好的湿润和冲洗功能
l Increases heat transfer (heat dissipation) hence reduces heat buildup and thermal stress
可以加快传热(散热)速度,减少生热和热应力
l High speed water surface tension reducer
迅速降低水表面张力
l Prevents silicon dust (swarf) agglomeration, allowing for easier cutting
防止硅尘(硅屑)堆积,更加容易切削
联系人:陈先生
手机:13602588976
