25.02.0140
伺服电机
SGMJV—04AAA6C 安川
个
25.02.0141
伺服电机
SGMJV—04AAA61 安川
个
25.03.0160
伺服电机驱动器
SGDV-2R8A01A 安川
个
25.02.0161
安川伺服电机
SGMJV-08AAA61
个
25.02.0179
伺服电机
SGMJV-08AAA6C 安川
个
25.03.0177
伺服电机驱动器
SGDV-5R5A01A
个
60.00.0018
莫莱克斯公头
JZSP-CMP9-1 安川
套
60.00.0020
50P插头
JZSP-CKI9 安川
套
60.05.0139
动力插头
JZSP-CSM9-2-E
个
60.05.0140
编码器插头
JZSP-CSP9-2-E
个
60.05.0143
动力插头
JZSP-CSM9-3-E
个
苏州工业园区三源芯辉电子联系电话:0512-67583820/13913148881徐工 专业维修安川伺服控制器:SGDM-A3AD,SGDM-A3ADA,SGDM-A5AD,SGDM-A5ADA,SGDM-01AD,SGDM-01ADA,SGDM-02AD,SGDM-02ADA,SGDM-04AD,SGDM-04ADA,SGDM-05AD,SGDM-05ADA,SGDM-08AD,SGDM-08ADA,SGDM-10AD,SGDM-10ADA,SGDM-15AD,SGDM-15ADA,SGDM-20AD,SGDM-20ADASGDM-30AD,SGDM-30ADA,SGDM-50ADA,SGDM-60ADA,SGDM-75ADA,SGDM-1EADA,SGDM-A3BD,SGDM-A3BDA,SGDM-A5BD,SGDM-A5BDA,SGDM-01BD,SGDM-01BDA,SGDM-02BD,SGDM-02BDA; SGDA-01AS , SGDA-A5AS , SGDA-01AS , SGDA-02AS , SGDA-04AS , SGDA-08AS , SGDA-A3AP , SGDA-A5AP , SGDA-01AP , SGDA-02AP , SGDA-04AP , SGDA-08AP , SGDB-05ADG , SGDB-10AGDG SGDB-15ADP , SGDB-20ADG , SGDB-30ADG , SGDB-30ADS ,SGDB-75ADG , SGDB-44ADS , SGDB-10ADS , SGDM-05AD , SGDM-01AD , SGDM-02AD , SGDM-04AD , SGDM-08AD , SGDM-10AD , SGDM-15AD , SGDM-20AD , SGDM-30AD , SGDM-50AD , SGDM-60AD , SGDM-A5AD , SGDM-A3AD , SGDH-01AE , SGDM-02AE , SGDH-04AE , SGDH-088AE , SGDH-10AE , SGDH-20AE , SGDH-30AE , SGDH-60AE DIS474 Thermocouple Input Process Indicator DIS871 DC Input Process Indicator DIS 871-24 4/20 mA DC I/P Pricess Indicator W/24 VDC PS for 2 Wire Trans. DIS872 AC Input Process Indicator DIS873 RTD Input Process Indicator DIS874 Thermocouple Inpjt Process Indicator 31/2 & 41/2 Dgt Dsply DIS875 Frequency I/P Process Indicator DIS876 Potentiometer Position I/P Process Indicator DIS878 Strain Gauge (Bridge) I/P Process Indicator DIS971 DC Input Process Indicator DIS971-24 4/20 mA DC I/P Pricess Indicator W/24 VDC PS for 2 Wire Trans. DIS972 AC Input Process Indicator DIS973 RTD Input Process Indicator DIS974 Thermocouple Input Process Indicator 31/2 & 41/2 Dgt Dsply DIS975 Frequency I/P Process Indicator DIS976 Potentiometer Position I/P Process Indicator DIS978 Strain Gauge (Bridge) I/P Process Indicator DM3801 DC I/P Proportional Valve Driver Pulse Width Mod O/P DM4001 RTD Input, Isolated Field Rangeable Transmitter DM4003 Potentiometer Position I/P FLD Rangeable Transmitter DM4051 Strain Gauge (Bridge) I/P FLD Rangeable Isolated Transmitter DM4130 Thermocouple I/P Field Rangeable Isolated Transmitter DM4300A DCInput Fixed Range Isolated Transmitter DM4300A-HS DCInput Fixed Range Isolated Transmitter DM4380A DC Input Field Rangeable Isolated Transmitter DM4391 4/20mA DC I/P / O/P Loop Powered Isolator DM6010 AC True RMS I/P Isolated Field Rangeable Transmitter DM7010 Frequency I/P Field Rangeable Isolated Transmitter FR1000 DC I/p, Field Rangeable Sgl Alarm, DPDT Relay, Latch or NL FR1020 DC Input, Field Rangeable Dual Alarm, Latch or NL IA PCB LP400 Loop Powered Display LP420 Loop Powered Display MM1000 DC Input, Single Alarm, Fixed Range, DPDT Relay MM1000 A DC Input, Single Alarm, Fixed Range, DPDT Relay MM1000-SP Mighty Module MM1000-SP0178 Mighty Module MM1005 DC Input, 4/20 mAdc Single Alarm w/24 VDC PS for Two-Wire TX MM1020 DC Input, Dual Alarm, 2 SPDT Relays, Fixed Range MM1200 Thermocouple Input, Single Alarm, Fixed Range, DPDT Relay MM1220 Thermocouple Input, Dual Alarm MM1400 RTD Input, Single Alarm, Fixed Range, DPDT Relay MM1420 RTD Input, Dual Alarm, 2 SPDT Relays, Fixed Range MM1500 Strain Gauge Input, Single Alarm, Fixed Range, DPDT Relay MM1520 Strain Gauge Input, Dual Alarm, 2 SPDT Relays, Fixed Range MM1600 AC Input, Single Alarm, Fixed Range, DPDT Relay MM1620 AC Input, Dual Alarm, 2 SPDT Relays, Fixed Range MM1700 Frequency Input, Single Alarm, Fixed Range, DPDT Relay MM1720 Frequency Input, Dual Alarm, 2 SPDT Relays, Fixed Range MM1800 Potentiometer Position Input, Single Alarm, Fixed Range, DPDT Relay MM1820 Potentiometer Position I/p, Dual Alarm, 2 SPDT Relays, F Range MM3200 Valve Actuator / Controller, DC Input MM4001 RTD Input Transmitter, Non- Isolated MM4003 Potentiometer Position Input Transmitter MM4010 DC Input Transmitter, Non-Isolated MM4050 DC Low Input Span, Fixed Range, Non- Isolated Transmitter MM4051 Strain Gauge Input Transmitter, Non-Isolated MM4100 Thermocouple Transmitter MM4100L Thermocouple Transmitter MM4130 Thermocouple Input Transmitter, Non-Linearized MM4130 L Thermocouple Input Transmitter, Linearized MM4300 DC Input Fixed Range Isolated Transmitter MM4300 A DC I/p Fixed Range Isolated Trans, Limited I/P / O/p Ranges MM4310 DC Input Low Input Span, Fixed Range, Isolated Transmitter MM4380 Transmitter Module MM4380 A DC Input Field Rangeable Isolated Transmitter MM4402 Adder Transmitter MM4408 Subtractor Transmitter MM4410 Multiplier Transmitter MM4420 Divider Transmitter MM4431 Power Function (Exponentiator) Transmitter MM6010 AC Input Transmitter, Isolated MM7010 Frequency Input Transmitter MM7501 Integrator MM9046 Regulated DC Power Supply RM9220 RM 9000 Module SC5000 Thermocouple & RTD Input 2 Wire Transmitter SC5010 Thermocouple & RTD Input 2 Wire Transmitter SF1302 RTD Input Slim Profile 2 Wire Transmitter SF1303 RTD Input Slim Profile 2 Wire Transmitter SR2101 DC I/P Isolated 2 Wire Transmitter 50mm Diameter Case SR2300 RTD Input Field Rangeable 2 Wire Transmitter SR2400 Thermocouple Input 2 Wire Transmitter SR2401 Thermocouple Input 2 Wire Transmitter SR2800 Potentiometer Position I/P 2 Wire Transmitter SR8401 Thermocouple I/P High Vibration & G Force Tolerance Trans TW301 Potentiometer Position I/P 2 Wire Transmitter TW303 RTD Input 2 Wire Transmitter TW304 Thermocouple Input 2 Wire Transmitter TW8201 AC I/P Isolated 2 Wire Transmitter TW850X Frequency I/P 2 Wire Transmitter Yaskawa Yaskawa Yaskawa Yaskawa 71616-4G050 AC DRIVE 7.5HP CIMR-G37AS2 5HP JUSPEED-F 949-07-15240 INVERTER SET CIMR-G3A2011 15HP 230V AC DR B836E0163-2-2 GPD402 .75H/230 CIMR-G3A20P7 1HP 230V AC DR B836E0163-3-1 GPD402 .75H/230 CIMR-G3A22P2 3HP 230V AC DR B836E0165 JUSPEED-F BOARD CIMR-G3A23P7 5HP 230V AC DR B836E0273 .75HP JUSPEED-F CIMR-G3A25P5 7.5H 230V AC DR CA133-3 F/V CONVERTER CIMR-G3A4015 20HP 460V AC DR CA141-1 DUAL PWR SUPPLY CIMR-G3A4030 40HP 460V AC DR CA224 ISOLATION BOARD CIMR-G3A40P4 .5H 460V AC DR CACR-HR01BAB12 AC SERVO DRIVE CIMR-G3A43P7 5HP 460V AC DR CACR-HR03AAB12 AC SERVO DRIVE CIMR-G3A45P5 7.5H 460V AC DR CACR-HR05AAB12 SERVOPACK CONTROL CIMR-G3E4015 20HP 460V AC DR CACR-HR05BB AC SERVO DRIVE CIMR-G3S21P5 2HP 230V AC DR CACR-HR10BABY5 SERVOPACK CONTROL CIMR-G3S22P2 3HP 230V AC DR CACR-HR15BB SERVOPACK CONTROL CIMR-G3S27P5 10HP 230V AC DR CACR-HR20BB AC SERVO DRIVE CIMR-G3S40P7 1HP 460V AC DR CACR-HR30UBY4 SERVOPACK CONTROL CIMR-G3S41P5 2HP 460V AC DR CACR-HR44BBY22 AC SERVO DRIVE CIMR-G3S42P2 3HP 460V AC DR CACR-O5-TF2ER SERVOPACK CONTROL CIMR-G3S43P7 5HP 460V AC DR CACR-O5TF1ERBFG SERVOPACK CONTROL CIMR-G3U2011 15HP 230V AC DR CACR-PR02AA4AH SERVOPACK CONTROL CIMR-G3U2015 20HP 230V AC DR CACR-PR05AC3ER SERVOPACK CONTROL CIMR-G3U2018 25HP 230V AC DR CACR-PR10BC3AM SERVOPAK DRIVE CIMR-G3U2022 30HP 230V AC DR Yaskawa Yaskawa Yaskawa Yaskawa CACR-PR10BC3CSY SERVOPACK CIMR-G3U2030 40HP 230V AC DR CACR-SR01AB1ER SERVOPACK CONTROL CIMR-G3U2037 50HP 230V AC DR CACR-SR02AA2AH SERVOPACK CONTROL CIMR-G3U2045 60HP 230V AC DR CACR-SR03AB1ER SERVOPACK CONTROL CIMR-G3U2055 75HP 230V AC DR CACR-SR03BB1AF SERVOPACK CONTROL CIMR-G3U2075 100H 230V AC DR CACR-SR03SZ1SS SERVOPACK CONTROL CIMR-G3U20P4 .5HP 230V AC DR CACR-SR05AB1ER SERVOPACK CIMR-G3U20P7 1HP 230V AC DR CACR-SR05AB1ERY SERVOPACK CONTROL CIMR-G3U21PS 2HP 230V AC DR CACR-SR05AC1ER SERVOPACK CONTROL CIMR-G3U22P2 3HP 230V AC DR CACR-SR05AC1FR SERVOPACK CONTROL CIMR-G3U23P7 5HP 230V AC DR CACR-SR05BE12GE SERVOPACK CONTROL CIMR-G3U25P2 7.5HP 230V AC DR CACR-SR07AC1ER SERVOPACK CONTROL CIMR-G3U25P5 7.5H 230V AC DR CACR-SR07BB1AM SERVOPACK CONTROL CIMR-G3U27P5 10HP 230V AC DR CACR-SR09TZ0SF SERVOPACK CONTROL CIMR-G3U4011 15HP 460V AC DR CACR-SR10BB1AF SERVOPACK CONTROL CIMR-G3U4015 20HP 460V AC DR CACR-SR10BB1AM SERVOPACK CONTROL CIMR-G3U4018 25HP 460V AC DR CACR-SR10BB1BF SERVOPACK CONTROL CIMR-G3U4022 30HP 460V AC DR CACR-SR10BB1CS SERVOPACK CONTROL CIMR-G3U4030 40HP 460V AC DR CACR-SR10BB1CSY SERVOPACK CONTROL CIMR-G3U4037 50HP 460V AC DR CACR-SR10BC1ESY SERVOPACK CONTROL CIMR-G3U4045 60HP 460V AC DR CACR-SR10BE12GE SERVOPACK CONTROL CIMR-G3U40P4 .5HP 460V AC DR CACR-SR10SB1AF SERVOPACK CONTROL CIMR-G3U40P7 1HP 460V AC DR CACR-SR10SZ1SF SERVOPACK CONTROL CIMR-G3U4110 150H 460V AC DR CACR-SR10SZ1SS SERVOPACK CONTROL CIMR-G3U4160 200H 460V AC DR CACR-SR12BA SERVOPACK CONTROL CIMR-G3U41P5 2HP 460V AC DR Yaskawa Yaskawa Yaskawa Yaskawa CACR-SR15BB1BF SERVOPACK CONTROL CIMR-G3U4220 300H 460V AC DR CACR-SR15BB1BM SERVO DRIVE CIMR-G3U42P2 3HP 460V AC DR CACR-SR15SB1AFY SERVOPACK CONTROL CIMR-G3U4300 400H 460V AC DR CACR-SR15SSY125 SERVOPACK CONTROL CIMR-G3U43P7 5HP 460V AC DR CACR-SR15SZ1SD SERVOPACK CONTROL CIMR-G3U45P5 7.5H 460V AC DR CACR-SR15SZ1SDY SERVOPACK CONTROL CIMR-G3U47P5 10HP 460V AC DR CACR-SR20BB1AF SERVOPACK CONTROL CIMR-G3U4L45 60HP 460V AC DR CACR-SR20BB1AM SERVOPACK CONTROL CIMR-G5A43P7 5HP 460V AC DR CACR-SR20BB1BF SERVOPACK CONTROL CIMR-G5C42P2 3HP 460V AC DR CACR-SR20SB SERVOPACK CONTROL CIMR-G5C45P5 10HP 460V AC DR CACR-SR20SB1AF SERVOPACK CONTROL CIMR-G5C47P5 10HP 460V AC DR CACR-SR-20SB1BF SERVOPAK CIMR-G5E4015 25HP 460V AC DR CACR-SR20SB1BFY SERVOPACK CONTROL CIMR-G5E45P5 10HP 460V AC DR CACR-SR20SZ1SFY SERVOPACK CONTROL CIMR-G5E47P5 10HP 460V AC DR CACR-SR20TZ6SM SERVOPACK CONTROL CIMR-H0.4B .5HP HII DRIVE CACR-SR30BB1AM SERVOPACK CONTROL CIMR-H0.4G2 .5HP 460V AC DR CACR-SR30SB1AS SERVOPACK CONTROL CIMR-H0.75B 1HP HII DRIVE CACR-SR30SB1BSY SERVOPACK CONTROL CIMR-H0.75G2 1HP 460V AC DR CACR-SR30SZ1SD SERVOPACK CONTROL CIMR-H11B 15HP HII DRIVE CACR-SR44BA SERVOPACK CONTROL CIMR-H11B.T 15HP HII DRIVE CACR-SR44BB1AM SERVOPACK CONTROL CIMR-H11G2 15HP 460V AC DR CACR-SR44BE12G SERVO PACK CONTROL CIMR-H15B 20HP HII DRIVE CACR-SR44SZ1SDY SERVO PACK CONTROL CIMR-H15B.D08 20HP HII DRIVE CACR-SR44SZ5DY2 SERVO PACK CONTROL CIMR-H15G2 20HP 460V AC DR CACR-SR60BA SERVO PACK CONTROL CIMR-H15G2-E10 20HP 460V AC DR CACR-SR60BB1AMY SERVO PACK CONTROL CIMR-H18.5B 25HP HII DRIVE CACR-SR80BA SERVO PACK CONTROL CIMR-H18.5G2 25HP 460V AC DR CACR-TM555Z1SP SERVO PACK CONTROL CIMR-H2.2B 3HP HII DRIVE CACR-TS111Z1SR SERVO PACK CONTROL CIMR-H2.2G2 3HP 460V AC DR CACR-W37-FJ2BER DRIVE CIMR-H2.2G2-E10 3HP 460V AC DR Yaskawa Yaskawa Yaskawa Servo Yaskawa Servo CACR-W37-FJ2ER DRIVE CIMR-H2.2G2-T 3HP 460V AC DR CACR-W37-FJ3ER DRIVE CIMR-H22B 30HP HII DRIVE CACR05TF5ERCR SERVOPACK CONTROL CIMR-H22G2 30HP 460V AC DRIVE CACRPR15BC3CS48 SERVOPACK CONTROL CIMR-H3.7B 5HP HII DRIVE CDBR-4045 BRAKING UNIT CIMR-H3.7B.T 5HP HII DRIVE CDBR-4045B BRAKING UNIT CIMR-H3.7B/JOHB 5HP HII DRIVE CDBR-4220 BRAKING UNIT CIMR-H3.7G2 5HP 460V AC DR CDBR-H45H 616H BRAKE UNIT CIMR-H3.7G2-E-10 5HP GII CDMR-MR-11K 505MT DRIVE CIMR-H3.7GII 5HP GII CDMR-MR-22K DC DRIVE CIMR-H30B 40HP HII DRIVE CDMR-MR-30K DC DRIVE CIMR-H30G2 40HP 460V AC DR CDMR-ZII VARISPEED 505 CIMR-H37B 50HP HII DRIVE CDMR-ZII-230-35 230V 35A CIMR-H37G2 50HP 460V AC DR CDMR-ZII-460-50 460V 50A CIMR-H3A22P2 616H3 VARISPEED CIMR-0.4B .5HP HII DRIVE CIMR-H3A23P7 616H3 VARISPEED CIMR-0.4G2 .5HP 230V AC DR CIMR-H3A43P7 5HP 460V AC DR CIMR-0.75B 1HP HII DRIVE CIMR-H45B 60HP HII DRIVE CIMR-0.75B.501 1HP HII DRIVE CIMR-H45D.T 60HP HII DRIVE CIMR 7.5B.D06 AC DRIVE CIMR-H45G2 60HP 460V AC DR CIMR-0.75G2 1HP 230V AC DR CIMR-H5.5B 7.5HP HII DRIVE CIMR-0.75G2-20 1HP 230V AC DR CIMR-H5.5B.D05 7.5HP HII DRIVE CIMR-04AS2 0.4KW 220V AC DRIVE CIMR-H5.5G2 7.5H 460V AC DR CIMR-04AS3 .75HP JUSPEED-F CIMR-H55B 75HP HII DRIVE CIMR-08AS3 1HP JUSPEED-F CIMR-H7.5B 10HP HII DRIVE CIMR-08AS4 JUSPEED-F .8KW CIMR-H7.5B.D06 10HP HII DRIVE CIMR-11B 15HP HII DRIVE CIMR-H7.5G2 10HP 460V AC DR CIMR-11G2 15HP 230V AC DR CIMR-H7.5G2-E10 10HP 460V AC DR Yaskawa Yaskawa Yaskawa Yaskawa CIMR-15AS2 1.5KW JUSPEED-F CIMR-H7.GII AC DRIVE CIMR-15AS3 2HP 230V AC DR CIMR-H75B 100HP HII DRIVE CIMR-15AS3-0020 2HP 230V AC DR CIMR-J04AS2 .75HP 120V AC DRIVE CIMR-15B 20HP HII DRIVE CIMR-MT-15K 20HP VS626MT DR CIMR-15G2 20HP 230V AC DR CIMR-MT1-15K.01 20HP VS626MT DR CIMR-18.5B 30HP HII DRIVE CIMR-MT111-15K AC SPINDLE DR CIMR-18.5G2 25HP 230V AC DR CIMR-MTII-11K 626MTII DRIVE CIMR-2.2B 3HP HII DRIVE CIMR-MTII-15K 626MTII DRIVE CIMR-2.2G2 3HP 230V AC DR CIMR-MTII-18.5 626MTII DRIVE CIMR-2.2GII AC DRIVE CIMR-MTII-18.5K 20HP SPINDLR DRIVE CIMR-2.2G2-E20 3HP 230V AC DR CIMR-MTII-22K 25HP SPINDLE DRIVE CIMR-22AS2 JUSPEED-F BOARD CIMR-MTII-22K.B 626MTII DRIVE CIMR-22AS3 2.2KW 220VAC DRIVE CIMR-MTII-26K 626MTII DRIVE CIMR-22B 30HP HII DRIVE CIMR-MTII-5.5K 626MTII DRIVE CIMR-22G2 30HP 230V AC DR CIMR-MTII-7.5KB 626MTII DRIVE CIMR-22S3 2.2KW JUSPEED-F CIMR-MTIII-11K 15HP VS626 DR CIMR-3.7B 5HP HII DRIVE CIMR-MTIII-15K 20HP VS626 DR CIMR-3.7B-C04 5HP HII DRIVE CIMR-MTIII-3.7K 5HP VS626 DR CIMR-3.7G2 5HP 230V AC DR CIMR-MTIII-5.5K 7.5HP VS626 DR CIMR-3.7G2LN-20 5HP 230V AC DR CIMR-MTIII-7.5K 10HP VS626 DR CIMR-3.7TW 5HP HII DRIVE CIMR-P5C41P5 616PC5 AC DRIVE CIMR-30B 50HP HII DRIVE CIMR-P5U47P5 INVERTER CIMR-30G2 40HP 230V AC DR CIMR-PBA20P7T VS-606PB3 AC DR CIMR-37AS2 JUSPEED-F BOARD CIMR-PCA20P7 1HP 230V AC DR CIMR-37AS3 JUSPEED-F 3.7KW CIMR-PCA41P5 2HP 460V AC DR CIMR-37B 50HP HII DRIVE CIMR-PCA42P2 CONTROL CIMR-37C 5HP HII DRIVE CIMR-PCC40P4 .75H 460V AC DR CIMR-37JP-1207 5HP JUSPOINT DR CIMR-PCD21P5 606PC3 DRIVE CIMR-45B 60HP HII DRIVE CIMR-PCD40P2 606PC3 DRIVE CIMR-5.5B 7.5HP HII DRIVE CIMR-PCE41P5 2HP 460V AC DR CIMR-5.5B/JOHB 7.5HP HII DRIVE CIMR-PCE42P2 3HP 460V AC DR CIMR-5.5G2 7.5H 230V AC DR CIMR-PCEB1P5 2HP 230V AC DR CIMR-5.5G2-E10 7.5H 230V AC DR CIMR-PCU-23P7 5HP 230V AC DR CIMR-55AS4-2020A 7.5HP AC DRIVE 230V 24A CIMR-PCU40P2 CONTROL CIMR-55B 75HP HII DRIVE CIMR-PCU43P7 DRIVE Yaskawa Yaskawa Yaskawa Yaskawa CIMR-7.5B 10HP HII DRIVE CIMR-SVJ-15AA 866 V/S DRIVE CIMR-7.5G2 10HP 230V AC DR CIMR-TYT22P2 INVERTER CIMR-7.5G2-10 10HP 230V AC DR CIMR-V7CC41P5 2HP 460V AC DR CIMR-7.5TW 10HP HII DRIVE CIMR-VGA42P2 3HP 460V AC DR CIMR-7.5TW1 10HP HII DRIVE CIMR-VGU42P2 3HP 460V AC DR CIMR-708AS2 1HP 120VAC AC DRIVE CIMR-VGU43P7 5HP 460V AC DR CIMR-75B 100HP HII DRIVE CIMR-VMC25P5 5.5KW 230V ACDR CIMR-F04AS2 0.75HP 460VAC DRIVE CIMRG3N47P5 460V 10HP CIMR-F04AS3 JUSPEED-F .4KW CIMRH2.2G2M-10 2HP 460V CIMR-F08AS2 JUSPEED-F .8KW CM-A2/P PCB CIMR-F08AS3 JUSPEED-F .8KW CPCR-01SD1A SERVOPACK CONTROL CIMR-F08AS4 JUSPEED-F .8KW CPCR-AN051B SERVOPACK CONTROL CIMR-F15AS2 JUSPEED-F 1.5KW CPCR-AN222A SERVOPACK CONTROL CIMR-F15AS3 JUSPEED-F 1.5KW CPCR-FR01B SERVOPACK MODULE CIMR-F15AS4 JUSPEED-F 1.5KW CPCR-FR02B SERVOPACK MODULE CIMR-F22AS2 JUSPEED-F 2.2KW CPCR-FR02TF1A SERVOPACK MODULE CIMR-F22AS3 JUSPEED-F 2.2KW CPCR-FR05RB SERVOPACK MODULE CIMR-F22AS4 JUSPEED-F 2.2KW CPCR-FRO1B97R2M SERVOPACK CIMR-F37AS2 JUSPEED-F 3.7KW CPCR-IN08B SERVOPACK CONTROL CIMR-F37AS3 JUSPEED-F 3.7KW CPCR-MR SERVOPACK CIMR-F37AS4 JUSPEED-F 3.7KW CPCR-MR021 SERVOPACK CONTROL CIMR-F55AS2 JUSPEED-F 5.5KW CPCR-MR02CJ SERVOPACK CONTROL CIMR-F55AS3 7.5H 460V AC DR CPCR-MR05CC SERVOPACK CONTROL CIMR-F55AS4 JUSPEED-F 5.5KW CPCR-MR07C SERVOPACK CONTROL CIMR-F75AS2 JUSPEED-F 7.5KW CPCR-MR22CH SERVOPACK CONTROL CIMR-F7AS2 10HP 460V AC DR CPCR-MR 55C SERVOPACK CIMR-G04AS2 .75HP JUSPEED-F CPCR-MR-052 SERVOPACK CIMR-G08A52 1HP 230V AC DR CPCR-MRCA01C SERVOPACK CONTROL CIMR-G08AS2 1HP JUSPEED-F CPCR-MR-CA055 SERVOPACK CIMR-G08AS2-1 1HP JUSPEED-F CPCR-MR0-CA085 CONTROL BOARD CIMR-G15AS2 2HP JUSPEED-F CPCR-MR05C-C SERVOPACK CIMR-G22A-20 3HP JUSPEED-F CPCR-MR085K2 SERVO DRIVE CIMR-G22AS2 3HP JUSPEED-F CPCR-MR75CL SERVOPACK CPCR-MRCA222 SERVO CTRL BD JPAC-C270 BASE DRIVER HII CPS-10NB DC POWER SUPPLY JPAC-C272 BASE DRIVER HII CPS-15 DC POWER SUPPLY JPAC-C341.A CONTROL BOARD CPS-25 DC POWER SUPPLY JPAC-C342 DRIVER PCB D11-A91290-5 PCB JPAC-C343 VS626 CTRL BD DDSCR-684B-206 PROGRAM CONTROL JPAC-C356.01 CONTROL BOARD DDSCR-GL20 MEMOCON-SC CPU JPAC-C356.02 CONTROL BOARD DDSCR-GL40S MEMOCON-SC CPU JPAC-C356.FF G SERIES BASE DR PCB DDSCR-GL40S3 MEMOCON-SC CPU JPAC-C357.02 CONTROL BOARD DDSCR-GL60H MEMOCON-SC CPU JPAC-C357.FF G SERIES BASE DR PCB DDSCR-GL60H1 MEMOCON-SC CPU JPAC-C358.01 CONTROL BOARD Yaskawa Yaskawa Yaskawa Yaskawa DDSCR-GL60HT MEMOCON-SC CPU JPAC-C358.02 CONTROL BOARD DDSCR-GL60S2 MEMOCON-SC CPU JPAC-C358.FF G SERIES BASE DR PCB DDSCR-GL60S3 MEMOCON-SC CPU JPAC-C360.01 CONTROL BD GII DDSCR-GL60V MEMOCON-SC CPU JPAC-C360.02 CONTROL BD GII DDSCR-GL60VA MEMOCON-SC CPU JPAC-C360.FF G SERIES BASE DR PCB DDSCR-GL70H MEMOCON-SC CPU JPAC-C361.01 CONTROL BOARD DDSCR-GL70H1 MEMOCON-SC CPU JPAC-C361.02 CONTROL BOARD DDSCR-GL70HT MEMOCON-SC CPU JPAC-C361.FF G SERIES BASE DR PCB DISCT-ACGC411D MONITOR JPAC-C362.01 CONTROL BOARD Yaskawa Yaskawa Yaskawa Yaskawa DISCT-J2040 I/O SLAVE MOD. JPAC-C362.02 CONTROL BOARD DR1-08AA-NOOA SERVOPACK JPAC-C362.FF G SERIES BASE DR PCB ERSD-6S-10 DB TIME UNIT JPAC-C362/JOGB 2-BD ASSEMBLY ERSD-6S-20 DB TIME UNIT JPAC-C405 G SERIES BASE DR PCB ETC613010 GIII CONTROL BD JPAC-C405.02 CONTROL BOARD ETC613014 GIII CONTROL BD JPDC-A001-T DUAL OP AMP BD ETC613021 VS616G3 G/D BD JPDC-C021 520B CONTROL BD ETC613032 VS616G3 G/D BD JPDC-C030 MAIN CONTROL BOARD ETC613041 CHOPPER BOARD JPDC-C036 CONTROL BOARD Yaskawa Yaskawa Yaskawa Yaskawa ETC613050 PWR SUPPLY & DRIVER PCB JRCV-021F CLUTCH CONTROL ETC613062 VS616G3 PWR BD JRCV-021F-3B MOTOR REGULATOR ETC613080 VS616G3 G/D BD JRCV-041F CLUTCH CONTROL ETC613081 VS616G3 G/D BD JRMSI-MB20 MOUNTING BASE ETC613110 GIII CONTROL BD JRMSI-MB20S MOUNTING BASE ETC613121 CONTROL BOARD JRMSI-MB21 MOUNTING BASE ETC613130 GIII CONTROL BD JRMSI-MB21S MOUNTING BASE ETC613130-S0020 GIII CONTROL BD JRMSI-MB40 MOUNTING BASE ETC613130-S5140 GIII CONTROL BD JRMSI-MB60 MOUNTING BASE ETC613130-S5145 GIII CONTROL BD JRMSI-MB70 MOUNTING BASE Yaskawa Yaskawa Yaskawa Yaskawa ETC613131-S0042 PCB JRMSP-8052 MEMOCON-SC P/S ETC613140 CONTROL BOARD JRMSP-8054 MEMOCON-SC P/S ETC613150 CONTROL BOARD JRMSP-PS20 GL20 PWR SUPPLY ETC613180-S6140 DRIVE BOARD JRMSP-PS21 GL20 PWR SUPPLY ETC613180-S6141 DRIVE BOARD JRMSP-PS40 GL40 PWR SUPPLY ETC613180-S6142 DRIVE BOARD JRMSP-PS60 GL60/70 SUPPLY ETC613180SS1010 DRIVE BOARD JUSP-DCP10B DCP UNIT ETC613181-S4140 GIII+ CTRL BD JUSP-FC600 CLOSED LOOP MOD ETC613182-S4140 GIII+ CTRL BD JUSP-NS300 INDEXER MODULE ETC613182-S4141 GIII+ CTRL BD JUSP-NS600 INDEXER MODULE ETC613182-S4410 GIII+ CTRL BD JUSP-R001 REGEN RES UNIT ETC61318X 616G3 CTRL BD JVOP-114 KEYPAD ETC613210 CONTROL BOARD JVOP-131U DIGITAL KEYPAD ETC613230 CONTROL BOARD JVOP-71 DIGITAL KEYPAD Yaskawa Yaskawa Yaskawa Yaskawa ETC615020-S1012 YPLT31002-1A BD JZNC-MPP20E TEACH PENDANT ETC615040 YPZT31161 BOARD JZNC-TB24L TEACH PENDANT ETC615050 YPZT31161 BOARD M1003 WELD CTRL BOARD ETC615130 PCB P140-10 PROGRAMMER ETC615160-S1010 YPZT31150 BOARD P140-20 PROGRAMMER ETC615270 YPCT21105-1 BD P150 PROGRAMMER ETC615572 YPZT31326 BD P180 PROGRAMMER ETC615580 YPZT31161 BD P190 PROGRAMMER ETC615581 YPZT31161 BD PMES-12-RD13 PRINT MOTOR ETC615991-S1113 CONTROL BOARD SGD-08AS SERVOPACK CTRL ETC616010-S5030 GATE DRIVER BD SGDA-01BS SERVOPACK ETC616010-S5092 GATE DRIVER BD SGDA-02BS SERVOPACK ETC616021 GATE DRIVER BD SGDB-10ADG SERVOPACK CTRL ETC616031 GATE DRIVER BD SGDB-15VD SERVOPACK CTRL ETC616041 GATE DRIVER BD SGDB-2BDD 30HP SERVO AMP Yaskawa Yaskawa Yaskawa Yaskawa ETC670380 YPCT31130-1 BD SGDB-3GDD 50HP SERVO AMP ETP613261 616G3 POWER BD SGDB-3ZDD 40HP SERVO AMP ETP613271 616G3 POWER BD SGDB-4EDD 60HP SERVO AMP ETP613291 616G3 POWER BD SGDB-5EDD 75HP SERVO AMP ETP61330X 616G3 POWER BD SGDF-A1CP MINI SERVO AMP ETP61331X 616G3 POWER BD SGDF-A1CS MINI SERVO AMP Yaskawa Yaskawa Yaskawa Yaskawa ETP61333X 616G3 POWER BD SGDF-A2CP MINI SERVO AMP ETP61334X 616G3 POWER BD SGDF-A2CS MINI SERVO AMP ETP61335X 616G3 POWER BD SGDH-01AE SERVO AMPLIFIER ETP61336X 616G3 POWER BD SGDH-02AE SERVO AMPLIFIER ETP615040 PCB SGDH-04AE SERVO AMPLIFIER ETP615640 GATE DRIVER BD SGDH-05AE SERVO AMPLIFIER ETP6U3241 616G3 POWER BD SGDH-05DE SERVO AMPLIFIER ETP6U3251 616G3 POWER BD SGDH-08AE SERVO AMPLIFIER Yaskawa Yaskawa Yaskawa Yaskawa ETP6U3291 616G3 POWER BD SGDH-08AES SERVO AMPLIFIER ETP6U3300 616G3 POWER BD SGDH-10AE SERVO AMPLIFIER ETP6U3310 616G3 POWER BD SGDH-10DE SERVO AMPLIFIER ETP6U3311 616G3 POWER BD SGDH-15AE SERVO AMPLIFIER ETP6U3400 616G3 POWER BD SGDH-15AES SERVO AMPLIFIER ETP6U3491 616G3 POWER BD SGDH-15DE SERVO AMPLIFIER JAFMC-HSP02 PCB SGDH-1AAE SERVO AMPLIFIER JAMQQ-A001B AMPLIFIER BOARD SGDH-1ADE SERVO AMPLIFIER JAMQQ-C001C CONTROL BOARD SGDH-1EAE SERVO AMPLIFIER JAMQQ-D001B CONTROL BOARD SGDH-1EDE SERVO AMPLIFIER JAMQQ-M002A CONTROL BOARD SGDH-20AE SERVO AMPLIFIER Yaskawa Yaskawa Yaskawa Yaskawa JAMSC-B1065 INPUT MODULE SGDH-20DE SERVO AMPLIFIER JAMSC-B2611 16PT 48VDC IN SGDH-30AE SERVO AMPLIFIER JAMSC-B2705 INSTRUMENT MOD. SGDH-30DE SERVO AMPLIFIER JAMSC-B2800 PID CTRL MODULE SGDH-50AE SERVO AMPLIFIER JAMSC-B2803 POSITIONING MOD SGDH-50DE SERVO AMPLIFIER JAMSC-B2804 MASTER MEMO
LINK SGDH-60AE SERVO AMPLIFIER Yaskawa Yaskawa Yaskawa Yaskawa JAMSC-B2806 INTERFACE MOD SGDH-60DE SERVO AMPLIFIER JAMSC-B2813 POSITIONING MOD SGDH-75AE SERVO AMPLIFIER JAMSC-B2823 POSITIONING MOD SGDH-75DE SERVO AMPLIFIER JAMSC-B2902 32PT RELAY OUT SGDH-A3AE SERVO AMPLIFIER JAMSC-IF41A COMM MODULE SGDH-A5AE SERVO AMPLIFIER JAMSC-IF61 COMM MODULE SGM-02A314 SERVO MOTOR JAMSC-IF64 PC
LINK MODULE SGM-02L3B2L SERVO MOTOR JAMSC-IF66 SERVO INTF MOD SGM-04A314 SERVO MOTOR JANCD-1021 CONTROL BOARD SGM-08A314 ENCODER/MOTOR JANCD-CP03 CPU BOARD SGMS-10A6AB SERVO MOTOR Yaskawa Yaskawa Yaskawa Yaskawa JANCD-CU01 CONNECTION BD SMC-2000-4IJ SMC CONTROLLER JANCD-E1001B I/O BOARD SMC-2000-4IM SMC CONTROLLER JANCD-E1002B I/O BOARD SRCA30DZSY230 CONTROL BOARD JANCD-E100ZB I/O BOARD SRCA44DZSY180 CONTROL BOARD JANCD-ECP02-11 CONTROL BOARD SRCB30DZS DRIVER BOARD JANCD-ECP02-22 CPU BOARD SRCB44DZS DRIVER BOARD JANCD-ESR03B PCB TFUE-04ZC7 MOTOR+FEEDBACK JANCD-IO03E I/O BOARD TFUE-05ZC7 FEEDBACK UNIT JANCD-M821 CPU BOARD TFUE-05ZD7 FEEDBACK UNIT JANCD-MIO04 MIO04 BOARD TFUE-08ZC7 FEEDBACK UNIT JANCD-SP17B PCB TFUE-10ZC7 FEEDBACK UNIT Yaskawa Yaskawa Yaskawa Yaskawa JANCD-TU01 RELAY BOARD TFUE-10ZD7 FEEDBACK UNIT JASPD-DS004 POSITIONPACK BD TFUE-100SE FEEDBACK UNIT JGSM-01 SOFT STARTER TFUE-15ZC7 FEEDBACK UNIT JGSM-06 POSITION CONTROLLER TFUE-15ZD7 FEEDBACK UNIT JGSM-09/JZSP-16 PREAMPLIFIER TFUE-20ZC7 FEEDBACK UNIT Yaskawa Yaskawa Yaskawa Yaskawa JOHB-C01 MACHINE CONTROL TFUE-20ZD7 FEEDBACK UNIT JOHB-C03 MEMORY MOD TFUE-25ZC7 FEEDBACK UNIT JOHB-C05 PG SPEED CTRL TFUE-25ZD7 FEEDBACK UNIT JOHB-C07.2 A/D BOARD HII TFUE-30ZC7 FEEDBACK UNIT JOHB-C08 PG SPEED CTRL TFUE-30ZD7 FEEDBACK UNIT JPAC-250.ETL BASE DRIVER HII TM3209 WIRE MEMORY BD JPAC-362.02 PCB UGTMEM-06LSF51 MOTOR JPAC-C026 CONTROL BOARD USAFED-03FA2KE AC SERVO MOTOR JPAC-C031 CONTROL BOARD USAFED-09FB10X SERVO MOTOR JPAC-C043 SYNC STARTER USAGED-13-MU11 SERVO MOTOR JPAC-C056.1 CONTROL BOARD USAGED-13A22K AC SERVO MOTOR JPAC-C061 CONTROL BOARD USAGED-20L22KF AC SERVO MOTOR JPAC-C220 BASE DRIVER BD USAMED-20MA2 AC SERVO MOTOR JPAC-C221.TO BASE DRIVER BD USAMED-20MAZK SERVO MOTOR Yaskawa Yaskawa Yaskawa Yaskawa JPAC-C231 CONTROL BD HII USAREM-01AE2K SERVO MOTOR JPAC-C231.02 CONTROL BD HII USAREM-01DE2K SERVO MOTOR/ENC JPAC-C231.03 CONTROL BD HII USAREM-02AE2K SERVO MOTOR JPAC-C231.520 H SERIES CONTROL BOARD USAREM-03BYA11 AC SERVO MOTOR JPAC-C231.533 CONTROL BD HII USAREM-05AE2K SERVO MOTOR/ENC JPAC-C231/79U24 CTRL BD/KEYPAD USAREM-09TF33-B AC SERVO MOTOR JPAC-C233.507 CONTROL BD HII USASEM-02YR32 AC SERVO MOTOR JPAC-C233.533 CONTROL BD HII USASEM-08CY12 AC SERVO MOTOR JPAC-C235.03 CONTROL BD HII YFY822F7261H PCB JPAC-C238.534.T CONTROL BD HII YPAT21008-1 TRANSISTOR BD JPAC-C241.533 CONTROL BD HII YPAT31020-1 MOV BOARD JPAC-C244 BASE DRIVER HII YPCT11065 PCB Yaskawa Yaskawa Yaskawa Yaskawa JPAC-C246.ETL BASE DRIVER HII YPCT21001-1-4 BRAKE BOARD JPAC-C250 BASE DRIVER 15-40HP 230V YPCT21074*1 POWER SUPPLY DRIVER PCB JPAC-C253 BASE DRIVER 50-75HP 230V YPCT21084-2 BASE DRIVER BOARD JPAC-C257.ETL BASE DRIVER HII YPCT21097-1-0 BASE DRIVER BOARD JPAC-C259.ETL BASE DRIVER HII YPCT31093-1 VS616G3 G/D BD JPAC-C261 BASE DRIVER HII YPCT31094-1 VS616G3 G/D BD JPAC-C261.ETL BASE DRIVER HII YPCT31097-1 CHOPPER BOARD JPAC-C263 BASE DRIVER HII YPCT31097-1-2 CHOPPER BOARD JPAC-C263.ETL BASE DRIVER HII YPCT31099-1 POWER SUPPLY BD JPAC-C266 BASE DRIVER GII YPCT31103-1-2 GATE DRIVER JPAC-C266.ETL BASE DRIVER GII YPCT31106-1 POWER BOARD JPAC-C268 BASE DRIVER HII YPCT41004-1 POWER SUPPLY BD JPAC-C268-ETL BASE DRIVER HII YPCT41013-1A PCB Yaskawa Yaskawa Yaskawa Yaskawa YPTC21085-2-0 GATE DRIVER BD Yokogawa Yokogawa Yokogawa Yokogawa 103131LSNL PANEL METER B9573SF CPU BOARD 103211A WATTMETER B9578WD SCANNER BOARD 103211ABUW1AED WATTMETER B9579PZ SSR SCANNER BD 103221ARHC7DAC AB40 WATTMETER B9579XW A-D CONVERTER BOARD 235300 DIGITAL METER B9579YX A-D CONVERTER BOARD 235905-4004-55 AC WATTMETER B9579YY A-D CONVERTER BOARD 2404 MEGGER B9628XF CPU BOARD 2404-14 MEGGER B9628XG CONTROL BOARD 2404-15 MEGGER B9628XG/XF CONTROL BOARD 2405-04 INSULATION TESTER B9628XJ A-D CONVERTER BOARD 2405-13 INSULATION TESTER B9900XB PCB 2406A INSULATION TESTER CA100 CALIBRATOR 2426A07 DIG INSULATION TESTER CR123-3/H1/21 CR1200 RECORDER 2455-12 THERMOMETER E7000DA POWER SUPPLY 2554 DC V/C STANDARD E7000DB POWER SUPPLY 2555-00 DC VOLT/CUR STD E7000FN AV8G CPU MODULE 3087 CHART RECORDER E7000HT I/O MODULE 3207-31 INSULATION TEST E7000JA CHANNEL BOARD 3213-15 RESISTANCE TEST E7000JK-03 CONTROL BOARD 370184 CHART RECORDER E7003EN-02 CONTROL BOARD 388060 HR2500 RECORDER E7056EA POWER SUPPLY 408133-3/AK-08 CHART RECORDER E7056FG-00 CPU BOARD Yokogawa Yokogawa Yokogawa Yokogawa 408811-3/AK-02 CHART RECORDER E7056HE-00 ADC BOARD 4151 CHART RECORDER EJA310A TRANSMITTER 4152 CHART RECORDER F9276AA 3-BD ASSEMBLY 4153 CHART RECORDER F9286BJ 3-BD ASSEMBLY 4153-333 CHART RECORDER F9286BX 3-BD ASSEMBLY 4153-333-32/BU CHART RECORDER F9286E5-00 3-BD ASSEMBLY 4153-555-32/BU CHART RECORDER F9286EC-02 3-BD ASSEMBLY 4153-555/BU CHART RECORDER F9286EJ-00 3-BD ASSEMBLY 4156 CHART RECORDER F9286LJ-00 3-BD ASSEMBLY 4156-500 CHART RECORDER F9290LA 3-BD ASSEMBLY 4156-600 CHART RECORDER F9328EA-02 3-BD ASSEMBLY 4171-100-32/BU CHART RECORDER F9328EA-07 4-BD ASSEMBLY 4176 CHART RECORDER FT5A SIGNAL ISOLATOR 4178 CHART RECORDER G1314-66521 VWM BOARD 4266-83-72/BD CHART RECORDER HR2400 CHART RECORDER 436002 CHART RECORDER LIT 30-131 CONTROLLER 436003 CHART RECORDER M2092-0 TEMP CONTROLLER 436006 CHART RECORDER MY40-01 DIGITAL INSULATION TESTER 436024-2\A2 INTELLIGENT RECORDER OPR1200 CHART RECORDER 437001 CHART RECORDER PH200G-PUEB CONTROL MODULE 50-103131LSZZ AMP METER PH400-P-U-1*A CONTROL MODULE 5142FA895 PROGRAMMABLE CONTROLLER PS40/B POWER SUPPLY 783001 CHART RECORDER PS402 POWER SUPPLY 942D CLAMP-ON METER SBSD-201-E/NPR CONTROLLER 95025/95015-01 CONTROL MODULE SLCD-281E/MTS IND. CONTROLLER AB-40 WATTMETER SLPC-210-A CONTROLLER Yokogawa Yokogawa Yokogawa Yokogawa AS-E9714LA-04 CONTROL BOARD SP-6JT SPEED CTRL PACK AS-E9716PH-00 INTERFACE BOARD SRHD-100E INTELLIGENT RECORDER AS-E9716RJ-00 TUNING MODULE SRHD-200E/MTS CONTROLLER AS-E9716RK-01 INTERFACE BOARD UP40 CONTROLLER AS-K9290-TK CPU ASSEMBLY UP40-131B CONTROLLER AS-K9290-TL CPU ASSEMBLY UT14 CONTROLLER AW640 CONTROL BOARD UT15 CONTROLLER B9538WC-0 4088 SCAN BOARD UT15L CONTROLLER B9541WN SUB CPU CARD ASSEMBLY UT30 CONTROLLER B9541WNCM/3087 CPU BOARD UT320 CONTROLLER B9544WB POWER BOARD UT350 CONTROLLER B9544WE PCB UT35-A1330N CONTROLLER B9544WL MAIN CPU CARD ASSEMBLY UT35-A41301 CONTROLLER B9544WY MV.TC SCANNER CARD UT35-A4130N CONTROLLER B9565L 4150 SERVO AMP UT35-A41401 CONTROLLER B9565LE 4150 SERVO AMP UT35-B13111 CONTROLLER B9565LE-05 4150 SERVO AMP UT37 CONTROLLER Yokogawa Yokogawa Yokogawa Yokogawa B9565LF 4150 SERVO AMP UT38 CONTROLLER B9565LH-08 4150 SERVO AMP UT40 CONTROLLER B9565LH-09 4150 SERVO AMP UT40-111B UT CONTROLLER B9565LH-10 4150 SERVO AMP UT40-111B/EX UT CONTROLLER B9565LH-11 4150 SERVO AMP UT550 UT CONTROLLER B9565LH-12 4150 SERVO AMP YA53F-SAS3 UNI TRANSMITTER B9565LH-OJ 4150 SERVO AMP YA53F-SBS4 UNI TRANSMITTER B9565XG/XE 2-BD ASSEMBLY YF101-AAUB1AS3S FLOWMETER Yokogawa repair Yokogawa repair YS150-001 MULTI-CONTROLLER
