奥普士OPTEX维修
所在地: 江苏 苏州市
最后更新: 2015-01-22 12:32
    MODEL DESCRIPTION BEF-130SM Mounting bracket for R series BEF-130SP Fitting Metal for RD-150 BEF-130ST Mounting bracket for R series BEF-W100A Z series Fixture for wall-installation BEF-W100B Z series Fixture for floor-installation BEF-W140A S2 series Fixture for wall-installation BEF-W140B S2 series Fixture for floor-installation BEF-W150-A Mounting bracket for S series BEF-W150-B Fitting Metal for SR-150N BEF-W170 Fitting Metal for KD-L09N BEF-W190 Mounting bracket for BGS-10 & BGS-30 series BEF-W250 Mounting bracket for V2 series BEF-WLL160 Mounting bracket for JRF series BEF-WLL170 Mounting bracket for VRF series BF-WLL160-1.0 Adapter for fibers with 1.3mm Dia. BF-WLL160-1.3 Adapter for fibers with 1.0mm Dia. BF-WLL170 Top Cover of VRF series BGS-10CN BGS, NPN, Connector, 100mm BGS-10CP BGS, PNP, Connector, 100mm BGS-10N BGS, NPN, Cable, 100mm BGS-10P BGS, PNP, Cable, 100mm BGS-2S15N* Anti-Inverter Noise, BGS, 15cm, cable BGS-2S30CN BGS, NPN, M8 Conne.4pin BGS-2S30CNT BGS with Timer, 30cm, connector, NPN BGS-2S30CP BGS, PNP, M8 Conne.4pin BGS-2S30CPT BGS with Timer, 30cm, connector, PNP BGS-2S30N BGS, NPN, 2m cable BGS-2S30NT BGS Timer, NPN, 2m cable BGS-2S30P BGS, PNP, 2m cable BGS-2S30PT BGS Timer, PNP, 2m cable BGS-30CN BGS, NPN, Connector, 300mm BGS-30CP BGS, PNP, Connector, 300mm BGS-30N BGS, NPN, Cable, 300mm BGS-30P BGS, PNP, Cable, 300mm BGS-3JH05CP TEACH-IN, Narrow view BGS, 5cm, connector, PNP BGS-3JH05N TEACH-IN, Narrow view, BGS, 5 cm, cable, NPN BGS-3JH05P TEACH-IN, Narrow view BGS, 5cm, cable, PNP BGS-3JS05CP TEACH-IN, Narrow view BGS, 5cm, connector, PNP BGS-3JS05N TEACH-IN, Narrow view BGS, 5cm, cable, NPN BGS-3JS05P TEACH-IN, Narrow view BGS, 5cm, cable, PNP BGS-D10CN BGS 10cm, connector, NPN BGS-D10CP BGS 10cm, connector, PNP BGS-D10N BGS 10cm, 2 meter cable, NPN BGS-D10N-5 BGS 10cm, 5 meter cable, NPN BGS-D10P BGS 10cm, 2 meter cable, PNP BGS-D10P-5 BGS 10cm, 5 meter cable, PNP BGS-D30CN BGS 25cm, connector, NPN BGS-D30CP BGS 25cm, connector, PNP BGS-D30N BGS 25cm, 2 meter cable, NPN BGS-D30N-5 BGS 25cm, 5 meter cable, NPN BGS-D30P BGS 25cm, 2 meter cable, PNP BGS-D30P-5 BGS 25cm, 5 meter cable, PNP BGS-DL10N LASER BGS, 10cm, NPN, cable BGS-DL10CN LASER BGS, 10cm, NPN, M8 connector BGS-DL10P LASER BGS, 10cm, PNP, cable BGS-DL10CP LASER BGS, 10cm, PNP, M8 connector BGS-DL30N LASER BGS, 30cm, NPN, cable BGS-DL30CN LASER BGS, 30Cm, NPN, M8 connector BGS-DL30P LASER BGS, 30cm, PNP, cable BGS-DL30CP LASER BGS, 30cm, PNP, M8 connector BGS-DL10TN Teach-in, LASER BGS, 10cm, NPN, cable BGS-DL10TCN Teach-in, LASER BGS, 10cm, NPN, M8 connector BGS-DL10TP Teach-in, LASER BGS, 10cm, PNP, cable BGS-DL10TCP Teach-in, LASER BGS, 10cm, PNP, M8 connector BGS-DL25TN Teach-in, LASER BGS, 25cm, NPN, cable BGS-DL25TCN Teach-in, LASER BGS, 25cm, NPN, M8 connector BGS-DL25TP Teach-in, LASER BGS, 25cm, PNP, cable BGS-DL25TCP Teach-in, LASER BGS, 25cm, PNP, M8 connector BGS-DL70N   BGS-H15CN TEACH-IN BGS, 15cm, connector, NPN BGS-H15CP TEACH-IN BGS, 15cm, connector, PNP BGS-H15N TEACH-IN BGS, 15cm, cable, NPN BGS-H15P TEACH-IN BGS, 15cm, cable, PNP BGS-S03N BGS, 3cm, cable, NPN BGS-S08CN BGS, NPN, Connector BGS-S08CP BGS, PNP, Connector BGS-S08N* BGS, 8cm, cable, NPN, Bulk packing, Special bracket BGS-S08N-5 BGS, 8cm, 5 meter cable, NPN BGS-S08NIR BGS, IR LED type, 8cm, cable, NPN BGS-S08P* BGS, 8cm, cable, PNP, Bulk packing, Special bracket BGS-S08P-5 BGS, 8cm, 5 meter cable, PNP BGS-S15CN TEACH-IN BGS, 15cm, connector, NPN BGS-S15CP TEACH-IN BGS, 15cm, connector, PNP BGS-S15N TEACH-IN BGS, 15cm, cable, NPN BGS-S15P TEACH-IN BGS, 15cm, cable, PNP BGS-V2000 BGS/FGS, 2m Relay output BGS-V2000CN BGS/FGS, 2m NPN,M12 4-pin plug BGS-V2000CP BGS/FGS, 2m PNP,M12 4-pin plug BGS-V2000N BGS/FGS, 2m NPN BGS-V2000P BGS/FGS, 2m PNP BGS-V2000T BGS/FGS, 2m Relay output Timer BGS-V30 BGS, Relay, 300mm BGS-V30CN BGS, NPN, 300mm BGS-V30CP BGS, PNP, 300mm BGS-V30N BGS, NPN, 300mm BGS-V30P BGS, PNP, 300mm BGS-V50 BGS, Relay, 550mm BGS-V50CN BGS, NPN, 550mm BGS-V50CP BGS, PNP, 550mm BGS-V50N BGS, NPN, 550mm BGS-V50P BGS, PNP, 550mm BGS-V80 BGS, 80cm, Relay output, cable BGS-V80CN BGS, 80cm, NPN, connector BGS-V80CP BGS, 80cm, PNP, connector BGS-V80N BGS, 80cm, NPN, cable BGS-V80P BGS, 80cm, PNP, cable BL-130S-SK Slits for RT-1500 (Width 0.5, 1.0, 2.0mm) BL-140 Slit for S2T-1200N/P BL-140-POLE Polarizing filter for S2R-350 BL-150-10 Slits for ST400 (Width 4.5, 1.0, 2.0mm) BL-160-10 Slit for JT-1000NR BL-160-SK Slit for JT (Through-beam Type) BL-170-10 Slit for KT-700 BL-170-POLF Polarizinf filter for KR-250N BL-260-SK Slit Lit consisting of 3 pcs(1mm,2mm,5mm) BRF Series Standard alone Type BRF-N Trimmer type, cable, NPN BRF-CN Trimmer type, M8 connector, NPN BRF-P Trimmer type, cable, PNP BRF-CP Trimmer type, M8 connector, PNP BRF-HN Trimmer type, High Speed, cable, NPN BRF-CHN Trimmer type, High Speed, M8 connector, NPN BRF-HP Trimmer type, High speed, cable, PNP BRF-CHP Trimmer type, High speed, M8 connector, PNP BGF-N Mark Sensor Trimmer Type, cable, NPN BGF-CN Mark Sensor Trimmer Type, M8 connector, NPN BGF-P Mark Sensor Trimmer Type, cable, PNP BGF-CP Mark Sensor Trimmer Type, M8 connector, PNP BIF-WN Moisture Sensor, cable, NPN BIF-CWN Moisture Sensor, M8 connector, NPN BIF-WP Moisture Sensor, cable, PNP BIF-CWP Moisture Sensor, M8 connector, PNP BRF Series Inter-connection Type B2RF-N Trimmer type, cable, NPN B2RF-CN Trimmer type, M8 connector, NPN B2RF-P Timmer type, cable, PNP B2RF-CP Trimmer type, M8 connector, PNP B2RF-HN Trimmer type, High speed, cable, NPN B2RF-CHN Trimmer type, High speed, M8 connector, NPN B2RF-HP Trimmer type, High speed, cable, PNP B2RF-CHP Trimmer type, High speed, M8 connector, PNP B2GF-N Mark Sensor Trimmer type, cable, NPN B2GF-CN Mark Sensor Trimmer Type, M8 connector, NPN B2GF-P Mark Sensor Trimmer Type, cable, PNP B2GF-CP Mark Sensor Trimmer Type, M8 connector, PNP B2IF-WN Moisture Sensor, cable, NPN B2IF-CWN Moisture Sensor, M8 connector, NPN B2IF-WP Moisture Sensor, cable, PNP B2IF-CWP Moisture Sensor, M8 connector, PNP BRF Accessory refer to DRF series CD1-100CN(E) PSD, 100+/-35mm, connector, NPN CD1-100CP(E) PSD, 100+/-35mm, connector, PNP CD1-100N(E) PSD, 100+/-35mm, cable, NPN CD1-100P(E) PSD, 100+/-35mm, cable, PNP CD1-130CN(E) PSD, 130+/-50mm, connector, NPN CD1-130CP(E) PSD, 130+/-50mm, connector, PNP CD1-130N(E) PSD, 130+/-50mm, cable, NPN CD1-130P(E) PSD, 130+/-50mm, cable, PNP CD1-250CN(E) PSD, 250+/-150mm, connector, NPN CD1-250CP(E) PSD, 250+/-150mm, connector, PNP CD1-250N(E) PSD, 250+/-150mm, cable, NPN CD1-250P(E) PSD, 250+/-150mm, cable, PNP CD1-30CN(E) PSD, 30+/-4mm, connector, NPN CD1-30N(E) PSD, 30+/-4mm, cable, NPN CD1-30P(E) PSD, 30+/-4mm, cable, PNP CD1-30CP(E) PSD, 30+/-4mm, connector, PNP CD1-50CN(E)# PSD, 50+/-10mm, connector, NPN CD1-50CP(E)# PSD, 50+/-10mm, connector, PNP CD1-50N(E)# PSD, 50+/-10mm, cable, NPN CD1-50N(E)#   CD1-50N-5(E)# PSD, 50+/-10mm, 5meter cable, NPN CD1-50P(E)# PSD, 50+/-10mm, cable, PNP CD1-50P-5(E)# PSD, 50+/-10mm, 5meter cable, PNP CD3-100CN(E) CCD, 100+/- 40mm, NPN, connector CD3-100CP(E) CCD, 100+/- 40mm, PNP, connector CD3-100N(E) CCD, 100+/- 40mm, NPN, 2 meter cable CD3-100N-5(E) CCD, 100+/- 40mm, NPN, 5 meter cable CD3-100P(E) CCD, 100+/- 40mm, PNP, 2 meter cable CD3-100P-5(E) CCD, 100+/- 40mm, PNP, 5 meter cable CD3-30CN(E) CCD, 30+/- 4mm, NPN, connector CD3-30CP(E) CCD, 30+/- 4mm, PNP, connector CD3-30N(E) CCD, 30+/- 4mm, NPN, 2 meter cable CD3-30N-5(E) CCD, 30+/- 4mm, NPN, 5 meter cable CD3-30P-5(E) CCD, 30+/-4mm, 5 meter cable, PNP CD3-30P(E) CCD, 30+/- 4mm, PNP, 2 meter cable CD3-50CN(E) 50+/- 10mm, NPN, 12 meter cable CD3-50CP(E) Ditto, but PNP CD3-50N(E) CCD, 50+/- 10mm, NPN, 2 meter cable CD3-50N-5(E) CCD, 50+/- 10mm, NPN, 5 meter cable CD3-50P(E) CCD, 50+/- 10mm, PNP, 2 meter cable CD3-50P-5(E) CCD, 50+/- 10mm, PNP, 5 meter cable CD3-80CN(E) CCD, 80+/- 15mm, NPN, connetor CD3-80CP(E) CCD, 80+/- 15mm, PNP, connetor CD3-80N(E) CCD, 80+/- 15mm, NPN, 2 meter cable CD3-80N-5(E) CCD, 80+/- 15mm, NPN, 5 meter cable CD3-80P(E) CCD, 80+/- 15mm, PNP, 2 meter cable CD3-80P-5(E) CCD, 80+/- 15mm, PNP, 5 meter cable CD3-250N(E) CCD, 250+/- 150mm, cable, NPN CD3-250P(E) CCD, 250+/- 150mm, cable, PNP CD3-250CN(E) CCD, 250+/- 150mm, connector, NPN CD3-250CP(E) CCD, 250+/- 150mm, connector, PNP CD3CN-S Exclusive cable for CD1 & CD3 series, 2m, M12, 8pin CD3CN-5S Exclusive cable for CD1 & CD3 series, 5m, M12, 8pin     CD4-30 Sensing Head CD4, 30+/-5mm CD4-85 Sensing Head CD4, 85+/- 20mm CD4-350 Sensing Head CD4, 350+/- 100mm CD4-L25 Glass Type Sensor Head CD4A-N CD4 amplifier, NPN CD4A-P CD4 amplifier, PNP CD4A-LN Glass Type Amplifier, NPN CD4A-LP Glass Type Amplifier, NPN CD3CN-S CD3 connector cable, 2meter CD3CN-5S CD3 connector cable, 5meter CD4CN-S CD4 connector cable, 2meter CD4CN-5S CD4 connector cable, 5meter     CDD-11CN* CDD-11CN but No Box, No manual, 100pcs a lot CDD-11CP#   CDD-11N* CDD-11N but No Box, No manual, 100pcs a lot CDD-11P#   CDD-40CN#   CDD-40CP#   CDD-40N#   CDD-40P#   CRD-300CN#   503.00   CRD-300N* CRD-300N but No Box, No manual, No mirror 100pcs a lot CRD-300P* CRD-300P but No Box, No manual, No mirror 100pcs a lot CRDF-100CN#   CRDF-100CP#   CRDF-100N#   CRDF-100P#   CTD-1500CN#   CTD-1500CP#   CTD-1500N#   CTD-1500P#   CVS1-N10 View angle 10 degree, NPN CVS1-N20 View angle 20 degree, NPN CVS1-N40 View angle 40 degree, NPN CVS1-P10 View angle 10 degree, PNP CVS1-P20 View angle 20 degree, PNP CVS1-P40 View angle 40 degree, PNP OMD-80 Dome Light for CVS1 Special Fixture for CVS1 & OMD-80 CVS2-N10 CVS2, View angle 10 degree, NPN CVS2-N20 CVS2, View angle 20 degree, NPN CVS2-N40 CVS2, View angle 40 degree, NPN CVS2-P10 CVS2, View angle 10 degree, PNP CVS2-P20 CVS2, View angle 20 degree, PNP CVS2-P40 CVS2, View angle 40 degree, PNP CVS2-C2C PC cable for CVS1 and 2 CVS1-N21 Narrow View type of CVS1-N20 CVS1-P21 Narrow View type of CVS1-P20 CVS2-N21 Narrow View type of CVS2-N20 CVS2-P21 Narrow View type of CVS2-P20 CVS3-N20 Edge Sensor, 20 degree, NPN CVS3-N21 Edge Sensor, 20 degree, NPN CVS3-P20 Edge Sensor, 20 degree, NPN CVS3-P21 Edge Sensor, 20 degree, NPN CVS4-P20 OCR Vision sensor PNP CVS4-N20 OCR Vision sensor NPN CVS4-P21 OCR Vision sensor PNP CVS4-N21 OCR Vision sensor NPN CVS4-P23 OCR Vision sensor PNP CVS4-N23 OCR Vision sensor NPN CVS4-P23R OCR Vision sensor PNP CVS4-N23R OCR Vision sensor NPN   Accessory (common) for CVS series CVS-LW1 White LED, outer Lighting System CVS-LU1 Luminescence Light for CVS1 and 2 CVS-M1 Remote monitor CVS-C2C RS-232C PC Cable CVS-C3S Extension cable 3 meter OMD-65 External Light for CVS S1CH Power Supply for OMD-65 BEF-OLR-CVS Fixture for OMD-65 (右) BEF-OLL-CVS Fixture for OMD-65 (左)     OPDB-50X15WS Bar Light, White (2.9W) OPDB-50X15RS Bar Light, Red (1.5W) OPDB-100X15WS Bar Light, White (5.8W) OPDB-100X15RS Red (2.9W) OPWTD-10D-V Power Supply, 10W, CE Type OPDPW-30DV Power Supply, 30W, Non-CE Type OP-CB-S3 Extension Cable for 1pce of OPDB, 3 meter OP-CB-S5 Extension Cable for 1pce of OPDB, 5 meter OP-CB-D3 Extension Cable for 2pcs of OPDB, 3 meter OP-CB-D5 Extension Cable for 2pcs of OPDB, 5 meter OPC-CB-D3 External Controller, ON/OFF switch, with 3 meter cable OPC-CB-D5 External Controller, ON/OFF switch, with 5 meter cable CVS-OPDB-2000 Mounting Bracket for CVS, vertical CVS-OPDB-3040 Mounting Bracket for CVS, horizontal CVS-OPDB-6080 Mounting Bracket for CVS, horizontal     DR-500N LASER Retro Reflection, 5m, NPN, cable DR-500N(E)# LASER Retro Reflection, 5m, NPN, cable DR-500CN LASER Retro Reflection, 5m, NPN, M8 connector DR-500P LASER Retro Reflection, 5m, PNP, cable DR-500CP LASER Retro Reflection, 5m, PNP, M8 connector     DSA-MN Master amplifier, High Function Type, NPN, cable 6 cores DSA-MP Master amplifier, High Function Type, PNP, cable 6 cores DSA-MN3 Master amplifier, Economical Type, NPN, cable 6 cores DSA-MP3 Master amplifier, Economical Type, PNP, cable 6 cores DSA-MN-M8 Master amplifier, Economical Type, NPN, M8 QD DSA-MP-M8 Master amplifier, Economical Type, PNP, M8 QD     DSA-SN Slave Amplifier, High Function, NPN, Cable 4 cores DSA-SP Slave Amplifier, High Function, PNP, Cable 4 cores DSA-SN1 Slave Amplifier, Economical Type, NPN, cable 1 core DSA-SP1 Slave Amplifier, Economical Type, PNP, cable 1 core     DSR-800 Sensor Head, Retro Reflective Head DSD-100 Sensor Head, Diffuse Reflective Head DSTC-200 Sensor Head, Thru-Beam Head, round spot DSTC-200-M8 Sensor Head, Thru-Beam Head, round spot, M8 QD DSTA-200 Sensor Head, Thru-Beam Head, Line Beam DSTA-200-M8 Sensor Head, Thru-Beam Head, Line Beam, M8 QD     DSL-8L04-2-130 Accessory for DS series, QD cable for Thru-beam Head BL-W130L-1 Accessory for DS series, Lens Attachment as Beam Selector M-45 Accessory for DS series, Laser Reflector STE-WLL190-03P Accessory for DS series, Extension connector for cable type STE-WLL190-05P Accessory for DS series, Extension connector for M8 DQ type BEF-EB01-W190 DIN rail Fixture for Amplifier (2pcs)     DT-4000N LASER Thru-beam, 40m, NPN, cable DT-4000CN LASER Thru-beam, 40m, NPN, M8 connector DT-4000P LASER Thru-beam, 40m, PNP, cable DT-4000CP LASER Thru-beam, 40m, PNP, M8 connector DGF-TN Digital Fiber Amplifier, Green LED, cable, NPN DGF-TCN Digital Fiber Amplifier, Green LED, connector, NPN DGF-TP Digital Fiber Amplifier, Green LED, cable, PNP DGF-TCP Digital Fiber Amplifier, Green LED, connector, PNP DOL-LL1903-02M 2meter cable for Master unit DOL-LL1903-05M 5meter cable for Master unit DOL-LL1901-02M 2meter cable for Slave unit DOL-LL1901-05M 5meter cable for Slave unit DRF-TN Digital Fiber Amplifier, Red LED, cable, NPN DRF-TN   DRF-TCN Digital Fiber Amplifier, Red LED, connector, NPN DRF-TP Digital Fiber Amplifier, Red LED, cable, PNP DRF-TCP Digital Fiber Amplifier, Red LED, connector, PNP DR-Q150TN Glass detection, LASER Retro Reflection, 1.5 m, NPN, cable DR-Q150TCN Glass detection, LASER Retro Reflection, 1.5 m, NPN, M8 connector DR-Q150TP Glass detection, LASER Retro Reflection, 1.5 m, PNP,cable DR-Q150TCP Glass detection, LASER Retro Reflection, 1.5 m, NPN, M8 connector DR-Q400TN Glass detection, LASER Retro Reflection, 4 m, NPN, cable DR-Q400TCN Glass detection, LASER Retro Reflection, 4m, NPN, M8 connector DR-Q400TP Glass detection, LASER Retro Reflection, 4m, PNP, cable DR-Q400TCP Glass detection, LASER Retro Reflection, 4m, NPN, M8 connector DM-18TN   DM-18TCN Color Mark, LASER, 18mm, NPN, M8 connector DM-18TP Color Mark, LASER, 18mm, PNP, cable DM-18TCP Color Mark, LASER, 18mm, PNP, M8 connector STE-WLL1901-05P Connection terminal for cable type STE-WLL1901-03P Connection terminal for connector type BF-WLL190-01 Side cover BEF-EB01-W190 Fixture E Series Miniature Flat Sensor ET-SD100N Thru-beam type, detecting distance 1meter ET-500NL Thru-beam type, sensing distance 500mm, NPN, 2m cable, Light-ON ET-500NL3 Thru-beam type, sensing distance 500mm, NPN, M8 Pig tail, 3-pins, Light-ON ET-500NL4 Thru-beam type, sensing distance 500mm, NPN, M8 Pig tail, 4-pins, Light-ON ET-500ND Thru-beam type, sensing distance 500mm, NPN, 2m cable, Dark-ON ET-500ND3 Thru-beam type, sensing distance 500mm, NPN, M8 Pig tail, 3-pins, Dark-ON ET-500ND4 Thru-beam type, sensing distance 500mm, NPN, M8 Pig tail, 4-pins, Dark-ON ET-500PL Thru-beam type, sensing distance 500mm, PNP, 2m cable, Light-ON ET-500PL3 Thru-beam type, sensing distance 500mm, PNP, M8 Pig tail, 3-pins, Light-ON ET-500PL4 Thru-beam type, sensing distance 500mm, PNP, M8 Pig tail, 4-pins, Light-ON ET-500PD Thru-beam type, sensing distance 500mm, PNP, 2m cable, Dark-ON ET-500PD3 Thru-beam type, sensing distance 500mm, PNP, M8 Pig tail, 3-pins, Dark-ON ET-500PD4 Thru-beam type, sensing distance 500mm, PNP, M8 Pig tail, 4-pins, Dark-ON ED-100NL Diffuse Reflective Type, sensing distance 100mm, NPN, 2m cable, Light-ON ED-100NL3 Diffuse Reflective Type, sensing distance 100mm, NPN, M8 Pig tail, 3-pins, Light-ON ED-100NL4 Diffuse Reflective Type, sensing distance 100mm, NPN, M8 Pig tail, 4-pins, Light-ON ED-100ND Diffuse Reflective Tape, sensing distance 100mm, NPN, 2m cable, Dark-ON ED-100ND3 Diffuse Reflective Type, sensing distance 100mm, NPN, M8 Pig tail, 3-pins, Dark-ON ED-100ND4 Diffuse Reflective Type, sensing distance 100mm, NPN, M8 Pig tail, 4-pins, Dark-ON ED-100PL Diffuse Reflective Type, sensing distance 100mm, PNP, 2m cable, Light-ON ED-100PL3 Diffuse Reflective Type, sensing distance 100mm, PNP, M8 Pig tail, 3-pins, Light-ON ED-100PL4 Diffuse Reflective Type, sensing distance 100mm, PNP, M8 Pig tail, 4-pins, Light-ON ED-100PD Diffuse Reflective Type, sensing distance 100mm, PNP, 2m cable, Dark-ON ED-100PD3 Diffuse Reflective Type, sensing distance 100mm, PNP, M8 Pig tail, 3-pins, Dark-ON ED-100PD4 Diffuse Reflective Type, sensing distance 100mm, PNP, M8 Pig tail, 4-pins, Dark-ON EL-30NL Convergent Type, sensing distance 30mm, NPN, 2m cable, Light-ON EL-30NL3 Convergent Type, sensing distance 30mm, NPN, M8 Pig tail, 3-pins, Light-ON EL-30NL4 Convergent Type, sensing distance 30mm, NPN, M8 Pig tail, 4-pins, Light-ON EL-30ND Convergent Type, sensing distance 30mm, NPN, 2m cable, Dark-ON EL-30ND3 Convergent Type, sensing distance 30mm, NPN, M8 Pig tail, 3-pins, Dark-ON EL-30ND4 Convergent Type, sensing distance 30mm, NPN, M8 Pig tail, 4-pins, Dark-ON EL-30PL Convergent Type, sensing distance 30mm, PNP, 2m cable, Light-ON EL-30PL3 Convergent Type, sensing distance 30mm, PNP, M8 Pig tail, 3-pins, Light-ON EL-30PL4 Convergent Type, sensing distance 30mm, PNP, M8 Pig tail, 4-pins, Light-ON EL-30PD Convergent Type, sensing distance 30mm, PNP, 2m cable, Dark-ON EL-30PD3 Convergent Type, sensing distance 30mm, PNP, M8 Pig tail, 3-pins, Dark-ON EL-30PD4 Convergent Type, sensing distance 30mm, PNP, M8 Pig tail, 4-pins, Dark-ON EL-15NL Convergent Type, sensing distance 15mm, NPN, 2m cable, Light-ON EL-15NL3 Convergent Type, sensing distance 15mm, NPN, M8 Pig tail, 3-pins, Light-ON EL-15NL4 Convergent Type, sensing distance 15mm, NPN, M8 Pig tail, 4-pins, Light-ON EL-15ND Convergent Type, sensing distance 15mm, NPN, 2m cable, Dark-ON EL-15ND3 Convergent Type, sensing distance 15mm, NPN, M8 Pig tail, 3-pins, Dark-ON EL-15ND4 Convergent Type, sensing distance 15mm, NPN, M8 Pig tail, 4-pins, Dark-ON EL-15PL Convergent Type, sensing distance 15mm, PNP, 2m cable, Light-ON EL-15PL3 Convergent Type, sensing distance 15mm, PNP, M8 Pig tail, 3-pins, Light-ON EL-15PL4 Convergent Type, sensing distance 15mm, PNP, M8 Pig tail, 4-pins, Light-ON EL-15PD Convergent Type, sensing distance 15mm, PNP, 2m cable, Dark-ON EL-15PD3 Convergent Type, sensing distance 15mm, PNP, M8 Pig tail, 3-pins, Dark-ON EL-15PD4 Convergent Type, sensing distance 15mm, PNP, M8 Pig tail, 4-pins, Dark-ON EL-08NL Convergent Type, sensing distance 8mm, NPN, 2m cable, Light-ON EL-08NL3 Convergent Type, sensing distance 8mm, NPN, M8 Pig tail, 3-pins, Light-ON EL-08NL4 Convergent Type, sensing distance 8mm, NPN, M8 Pig tail, 4-pins, Light-ON EL-08ND Convergent Type, sensing distance 8mm, NPN, 2m cable, Dark-ON EL-08ND3 Convergent Type, sensing distance 8mm, NPN, M8 Pig tail, 3-pins, Dark-ON EL-08ND4 Convergent Type, sensing distance 8mm, NPN, M8 Pig tail, 4-pins, Dark-ON EL-08PL Convergent Type, sensing distance 8mm, PNP, 2m cable, Light-ON EL-08PL3 Convergent Type, sensing distance 8mm, PNP, M8 Pig tail, 3-pins, Light-ON EL-08PL4 Convergent Type, sensing distance 8mm, PNP, M8 Pig tail, 4-pins, Light-ON EL-08PD Convergent Type, sensing distance 8mm, PNP, 2m cable, Dark-ON EL-08PD3 Convergent Type, sensing distance 8mm, PNP, M8 Pig tail, 3-pins, Dark-ON EL-08PD4 Convergent Type, sensing distance 8mm, PNP, M8 Pig tail, 4-pins, Dark-ON     EZ-1000 Scope 1 meter EZ-13 Easy Mirror EZ-3000 Scope 3 meter EZ-350 Scope 35cm EZ-46 Easy Checker EZ-67 Easy Pick-up EZ-72 Easy Light EZ-ACC Side View Attachment EZ-ADP Video Adaptor     FGS-D10CN FGS 10cm, connector, NPN FGS-D10CP FGS 10cm, connector, PNP FGS-D10N FGS 10cm, 2meter cable, NPN FGS-D10N-5 FGS 10cm, 5meter cable, NPN FGS-D10P FGS 10cm, 2 meter cable, PNP FGS-D10P-5 FGS 10cm, 5 meter cable, PNP FGS-D25CN FGS 25cm, connector, NPN FGS-D25CP FGS 25cm, connector, PNP FGS-D25N FGS 25cm, 2 meter cable, NPN FGS-D25N-5 FGS 25cm, 5 meter cable, NPN FGS-D25P FGS 25cm, 2 meter cable, PNP FGS-D25P-5 FGS 25cm, 5 meter cable, PNP FHAI series Absolute, 0-600KPa, 4-20mA FHAV series Absolute, 0-600KPa, 1-5V DC FCAI series Absolute, 0-600KPa, 4-20mA, Connector type FCAV series Absolute, 0-600KPa, 1-5V DC, Connector type FTAI series Absolute, 0-600KPa, 4-20mA, Box type FTAV series Absolute, 0-600KPa, 1-5V DC, Box type FHTI series Gauge, -100-500KPa, 4-20mA FHTV series Gauge, -100-500KPa, 1-5V DC FHTIC series Gauge, -100-500KPa, 4-20mA, Compound type FHTVC series Gauge, -100-500KPa, 1-5V DC, Compound type FHGI series Gauge, 0-2MPa, 4-20mA FHGV series Gauge, 0-2MPa, 1-5V DC FHLI series Guage, Weld type, -100 - 1MPa, 4-20mA FHLV series Guage, Weld type, -100 - 1MPa, 1-5V DC FHLIC series Gauge, Weld type, -100 - 1MPa, 4-20mA, Compound type FHLVC series Gauge, Weld type, -100 - 1MPa, 1-5V DC, Compound type FHSI series Shield Gauge, 0-35MPa, 4-20mA FHSV series Shield Gauge, 0-35MPa, 1-5V DC FHXI series Gauge, -100KPa - 1MPa, 4-20mA FHXV series Gauge, -100KPa - 1MPa, 1-5V DC FHXIC series Gauge, -100KPa - 1MPa, 4-20mA, Compound type FHXVC series Gauge, -100KPa - 1MPa, 1-5V DC, Compound type FHJI series Gauge, -100KPa - 1MPa, 4-20mA FHJV series Gauge, -100KPa -1MPa, 1-5V DC FHJIC series Gauge, -100KPa - 1MPa, 4-20mA, Compound type FHJVC series Gauge, -100KPa -1MPa, 1-5V DC, Compound type FHFE series Gauge, -100KPa - 1MPa, Stainless FHFET series Gauge, -100KPa - 1MPa, Titanium FTTI series Gauge, -100KPa - 2MPa, 4-20mA, Box type FTTIC series Gauge, -100KPa - 2MPa, 4-20mA, Compound type, Box type FTLI series Gauge, -100KPa - 1MPa, 4-20mA, Box type FTLIC series Gauge, -100KPa - 1MPa, 4-20mA, Compound type, Box type FTSI series Shield Gauge, 0 - 35MPa, 4-20mA, Box type FHM-300 series Water level sensor, Stainless, 4-20mA FHM-200 series Water level sensor, Stainless, 1-5V DC FHM-700 series Water level sensor, Titanium, 4-20mA FHM-600 series Water level sensor, Titanium, 1-5V DC FHM-920 series Water level sensor, Titanium for indoor use, 4-20mA FHM-900 series Water level sensor, Titanium, for indoor use, 1-5V DC FAH-10 Anchor for FHM series (Large size) FAH-20 Anchor for FHM series (Midium size) FG3R3-DSM5 Damper Junction (G3/8 to R3/8) FG3R3 Joint accessory (G3/8 to R3/8)     J2D-H100CN TEACH-IN, Diffuse, IR LED, 100cm, connector, NPN J2D-H100CP TEACH-IN, Diffuse, IR LED, 100cm, connector, PNP J2D-H100N TEACH-IN, Diffuse, IR LED, 100cm, cable, NPN J2D-H100P TEACH-IN, Diffuse, IR LED, 100cm, cable, PNP J2D-H10CN TEACH-IN, Narrow view, Diffuse, 10cm, connector, NPN J2D-H10CP TEACH-IN, Narrow view, Diffuse, 10cm, connector, NPN J2D-H10N TEACH-IN, Narrow view, Diffuse, 10cm, cable, NPN J2D-H10P TEACH-IN, Narrow view, Diffuse, 10cm, cable, PNP J2D-H70CN TEACH-IN, Diffuse, Red LED, 70cm, connector, NPN J2D-H70CP TEACH-IN, Diffuse, Red LED, 70cm, connector, PNP J2D-H70N TEACH-IN, Diffuse, Red LED, 70cm, cable, NPN J2D-H70P TEACH-IN, Diffuse, Red LED, 70cm, cable, PNP J2D-S100CN TEACH-IN, Diffuse, IR LED, 100cm, connector, NPN J2D-S100CP TEACH-IN, Diffuse, IR LED, 100cm, connector, PNP J2D-S100N TEACH-IN, Diffuse, IR LED, 100cm, cable, NPN J2D-S100P TEACH-IN, Diffuse, IR LED, 100cm, cable, PNP J2D-S10CN TEACH-IN, Narrow view, Diffuse, 10cm, connector, NPN J2D-S10CP TEACH-IN, Narrow view, Diffuse, 10cm, connector, NPN J2D-S10N TEACH-IN, Narrow view, Diffuse, 10cm, cable, NPN J2D-S10P TEACH-IN, Narrow view, Diffuse, 10cm, cable, PNP J2D-S70CN TEACH-IN, Diffuse, Red LED, 70cm, connector, NPN J2D-S70CP TEACH-IN, Diffuse, Red LED, 70cm, connector, PNP J2D-S70N TEACH-IN, Diffuse, Red LED, 70cm, cable, NPN J2D-S70P TEACH-IN, Diffuse, Red LED, 70cm, cable, PNP J3M-GH01CN TEACH-IN, Mark Sensor, 10mm, connector, NPN J3M-GH01CP TEACH-IN, Mark Sensor, 10mm, connector, PNP J3M-GH01N TEACH-IN, Mark Sensor, 10mm, cable, NPN J3M-GH01P TEACH-IN, Mark Sensor, 10mm, cable, PNP J3M-GS01CP TEACH-IN, Mark Sensor, 10mm, connector, PNP J3M-GS01N TEACH-IN, Mark Sensor, 10mm, cable, NPN J3M-GS01P TEACH-IN, Mark Sensor, 10mm, cable, PNP J3R-H100CP TEACH-IN, Narrow view, Retro Reflection, 1 meter, connector, PNP J3R-H100N TEACH-IN, Narrow view, Retro Reflection, 1 meter, cable, NPN J3R-H100P TEACH-IN, Narrow view, Retro Reflection, 1 meter, cable, PNP J3R-S100CP TEACH-IN, Narrow view, Retro Reflection, 1 meter, connector, PNP J3R-S100N TEACH-IN, Narrow view, Retro Reflection, 1 meter, cable, NPN J3R-S100P TEACH-IN, Narrow view, Retro Reflection, 1 meter, cable, PNP JCN-10L L-shaped Connector Cable, 10m JCN-10S Straight Connector Cable, 10m JCN-5L L-shaped Connector Cable, 5m JCN-5S Straight Connector Cable, 5m JCN-L L-shaped Connector Cable, 2m JCN-S Straight Connector Cable, 2m JD-HL03CN Limited range, NPN,M8 4-pin plug JD-HL03CP Limited range,M8 4-pin plug JD-HL03N Limited range,NPN.cable JD-HL03P Limited range,PNP cable JD-HR80CN Diffused reflection NPN,M8 4-pin plug JD-HR80CP Diffused reflection,M8 4-pin plug JD-HR80N Diffused reflection,NPN.cable JD-HR80P Diffused reflection PNP cable JD-HW08CN Wide angle, NPN,M8 4-pin plug JD-HW08CP Wide angle,M8 4-pin plug JD-HW08N Wide angle,NPN.cable JD-HW08P Wide angle,PNP cable JD-SL03CN Limited range, NPN,M8 4-pin plug JD-SL03CP Limited range,M8 4-pin plug JD-SL03N Limited range,NPN.cable JD-SL03P Limited range,PNP cable JD-SR80CN Diffused reflection NPN,M8 4-pin plug JD-SR80CP Diffused reflection,M8 4-pin plug JD-SR80N Diffused reflection,NPN.cable JD-SR80P Diffused reflection PNP cable JD-SW08CN Wide angle, NPN,M8 4-pin plug JD-SW08CP Wide angle,M8 4-pin plug JD-SW08N Wide angle,NPN.cable JD-SW08P Wide angle,PNP cable JRF-N* Trimmer type, cable, NPN, Special price JRF-NC Trimmer type, connector, NPN JRF-P Trimmer type, cable, PNP JRF-PC Trimmer type, connector, PNP JRF-TCN Teach-in, Remote, NPN, connector JRF-TCP Teach-in, Remote, PNP, connector JRF-TN Teach-in, Remote, NPN, cable JRF-TP Teach-in, Remote, PNP, cable JR-H300CN 3meter,through-beam NPN,M84-pin plug JR-H300CP 3meter,through-beam.PNP.M84-pin plug JR-H300N 3meter,through-beam.NPN.cable JR-H300P 3meter,through-beam.PNP cable JR-HQ50CNW TFT application, 50cm, Retro, connector, NPN JR-HQ50CPW TFT application, 50cm, Retro, connector, PNP JR-HQ50NW TFT application, 50cm, Retro, cable, NPN JR-HQ50NW-5 TFT application, 50cm, Retro, 5 meter cable, NPN JR-HQ50PW TFT application, 50cm, Retro, cable, PNP JR-HQ50PW-5 TFT application, 50cm, Retro, 5 meter cable, PNP JR-S300CN 3meter,through-beam NPN,M84-pin plug JR-S300CP 3meter,through-beam.PNP.M84-pin plug JR-S300N 3meter,through-beam.NPN.cable JR-S300P 3meter,through-beam.PNP cable JR-SQ50CNW TFT application, 50cm, Retro, connector, NPN JR-SQ50CPW TFT application, 50cm, Retro, connector, PNP JR-SQ50NW TFT application, 50cm, Retro, cable, NPN JR-SQ50NW-5 TFT application, 50cm, Retro, 5 meter cable, NPN JR-SQ50PW TFT application, 50cm, Retro, cable, PNP JR-SQ50PW-5 TFT application, 50cm, Retro, 5 meter cable, PNP JT-H1000CNR 10meter,through-beam NPN,M84-pin plug JT-H1000CPR 10meter,through-beam.PNP.M84-pin plug JT-H1000NR 1, 0meter,through-beam.NPN.cable JT-H1000PR 10meter,through-beam.PNP cable JT-S1000CNR 10meter,through-beam NPN,M84-pin plug JT-S1000CPR 10meter,through-beam.PNP.M84-pin plug JT-S1000NR 10meter,through-beam.NPN.cable JT-S1000PR 10meter,through-beam.PNP cable KD-40CN Diffuse, 40cm, NPN, connector KD-40CP Diffuse, 40cm, PNP, connector KD-40N Diffused reflection, NPN KD-40P Diffused reflection, PNP KD-L09CN Convergent, 9cm, NPN, connector KD-L09CP Convergent, 9cm, PNP, connector KD-L09N Fine-spot, NPN KD-L09P Fine-spot, PNP KR-250CN Retro, 2.5 meter, NPN, connector KR-250CP Retro, 2.5 meter, PNP, connector KR-250N Retro-reflection, NPN KR-250N-42 KR-250N with V-42 mirror KR-250N-5 5 meter cable of KR-250N KR-250P Retro-reflection, PNP KR-Q150CNW TFT application, 1.5 meter, NPN, connector KR-Q150CPW TFT application, 1.5 meter, PNP, connector KR-Q150NW TFT application, 1.5 meter, NPN, cable KR-Q150NW-42 KR-Q150NW with V-42 mirror KR-Q150PW TFT application, 1.5 meter, PNP, cable KR-Q300CNW TFT application, 3 meter, NPN, connector KR-Q300CPW TFT application, 3 meter, PNP, connector KR-Q300NW TFT application, 3 meter, NPN, cable KR-Q50CN TFT application, 50cm, NPN, connector KR-Q50CNW TFT application, 50cm, NPN, connector KR-Q50CP TFT application, 50cm, PNP, connector KR-Q50CPW TFT application, 50cm, PNP, connector KR-Q50N Retro-reflection, NPN, for Transparent Object KR-Q50NW TFT application, 50cm, NPN, Cable KR-Q50NW-5 5 meter cable of KR-Q50NW KR-Q50P Retro-reflection, PNP, for Transparent Object KR-Q50PW TFT application, 50cm, PNP, cable KT-700CN   KT-700CP   KT-700N Through-beam, NPN KT-700N-5 5 meter cable of KT-700N KT-700P Through-beam, PNP LJ-H01 Metal protector, Head-on type LJ-H02 Metal protector, Head-on type LJ-S01 Metal protector, Side-on type LJ-S02 Metal protector, Side-on type LK-S01 Protective bracket (Right-angle end) LK-S02 Protective bracket (Straight end) LS2-S01 Protection Housing for S2 series LS-S01 Protective bracket (Right-angle end) LS-S02 Protective bracket (Straight end) LV2-S01 Protection Housing for V2 series LV2-S02 Protection Housing for V2 series M3KIT Mounting bracket for J seies, M3 screw M4KIT Mounting bracket for J seies, M4 screw NF-DA01 Fine-spot Attachment NF-DA02 Small-spot Attachment NF-DB01 Reflection, M6 Coaxial (1) NF-DB01-10 Reflection, M6 Coaxial, Length: 10m NF-DB02 Reflection, M6 Coaxial with Sleeve NF-DB03 Reflection, M6 Coaxial (2) NF-DB03 Reflection, M6 Coaxial (2) NF-DB04 Standard low cost NF-DC01 Convergent NF-DC02   NF-DC02   NF-DF02 φ6 Teflon, For Cloudy Liquid NF-DF03 Liquid sensor NF-DH01 M6 Heat-resistance up to 180℃ NF-DH02 M6 Heat-resistance up to 125℃ NF-DH83 Heat proof 300C NF-DK04 Tubular long NF-DK04Z Multicore tubular NF-DK06 Standard M3 Sleeve NF-DK21 Coaxial M3 NF-DK22 Fine Sleeve NF-DK23 Coaxial fine sleeve NF-DK33 Side view NF-DK43 Fine Sleeve NF-DK63Z Multicore long sleeve NF-DK66 Multicore M4 NF-DK67 Multicore M6 NF-DM01 Reflection, M4 Long Distance NF-DM02 Reflection, M4 Coaxial NF-DM03 M4 Sleeve NF-DR01 Reflection, M6 Multi-cores NF-DR02 Reflection, M3 2Fine-cores NF-DR03 Reflection, φ3mm, 4 Fine-cores NF-DR04 Reflection, φ1.5mm, 4 Cores NF-DR04 (2M FIBER) Reflection, φ1.5mm, 4 Cores, 2M fiber length NF-DR05 Reflection, φ3mm Sleeve, 2 Cores NF-DR06 R4 flexible M4 NF-DS06 M3 Standard NF-DT01 Reflection, M3 Coaxial, Fine Head NF-DT02 Reflection, M3 Sleeve NF-DT03 Reflection, φ2.5mm Cylindrical, Fine Head NF-DT04 M3 Sleeve Length: 15mm NF-DT05 Sleeve 28mm M4 NF-DV01 φ5 Standard Side View NF-DV02 φ3 Standard Side View NF-DV03 M6 Standard Side View NF-DY01 φ6 Teflon, Heat-resistance up to 125℃ NF-TA01 Long-distance Attachment NF-TA02 Side-view Attachment NF-TB01 Through-beam, M4 Long Distance NF-TB01-10 Through-beam, M4 Long Distance NF-TB02 Through-beam, M4 Standard NF-TB03 Sleeve 90mm NF-TH01 Through-beam, M4 Heat-resistance 100℃ NF-TH02 Through-beam, M4 Heat-resistance 180℃ NF-TH84 Heat proof 300C NF-TK05 Multicore tubular NF-TK16 Side view NF-TK34 Side view NF-TK75 Sleeve 15mm NF-TK77 Multicore M4 NF-TM01 Through-beam, M3 Long Distance NF-TM02 Through-beam, M3 Standard NF-TM03 Through-beam, φ1.5mm Cylindrical NF-TR01 Through-beam, M4 Mullet-cores NF-TR02 Through-beam, M3,4 Fine-cores NF-TR03 Through-beam, φ1.5mm 4 Fine-cores NF-TS07 φ3 Cylindrical NF-TS08 φ3 Side View NF-TS10 Alley Fiber, Width: 15mm NF-TS12 φ4 Side View NF-TS14 Area sensor NF-TT01 φ3 Sleeve Length: 5mm NF-TV01 φ3 Side View NF-TV02 Through-beam, Side-view NF-TV04 M3 Side View Fine NF-TY01 Through-beam, φ6mm Fluororesin NF-TY02 φ6mm Teflon, Side View P250 Mirror, 42mm P250F Standard Reflector for D series PL20F Small Reflector for D series PL10F Miniature Reflector for D series P45 Small mirror PFK-01 Pol. Filter for KT (Through-beam Type) RD-150 Sensor Head, Diffuse-reflection (Long) RD-F50 Sensor Head, Diffuse-reflection (Flat) RM-16G Sensor Head, Diffuse-mark, Green RM-16R Sensor Head, Diffuse-mark, Red RS-16G Sensor Head, Diffuse-focused, Green RS-20R Sensor Head, Diffuse-focused, Red RSA-CN Amplifier, NPN, Connector RSA-CP Amplifier, PNP, Connector RSA-N Amplifier, NPN, Cable RSA-P Amplifier, PNP, Cable RT-1500 Sensor Head, Through-beam (Long) RT-F300 Sensor Head, Through-beam (Flat) S2D-80CN Diffuse(RED), NPN, M8 Conne.4pin S2D-80CNIR Diffuse, IR LED type, 80cm, connector, NPN S2D-80CP Diffuse(RED), PNP, M8 Conne.4pin S2D-80CPIR Diffuse, IR LED type, 80cm, connector, PNP S2D-80N Diffuse(RED), NPN, 2m cable S2D-80NIR Diffuse, IR LED type, 80cm, cable, NPN S2D-80P Diffuse(RED), PNP, 2m cable S2D-80PIR Diffuse, IR LED type, 80cm, cable, PNP S2R-350CN Mirror, NPN, M8 Conne.4pin S2R-350CP Mirror, PNP, M8 Conne.4pin S2R-350N Mirror, NPN, 2m cable S2R-350N/D Mirror, NPN, 2m cable S2R-350P Mirror, PNP, 2m cable S2R-350P/D Mirror, PNP, 2m cable S2T-1200CN T/Beam, NPN, M8 Conne.4pin S2T-1200CP T/Beam, PNP, M8 Conne.4pin S2T-1200N   S2T-1200N/D T/Beam, NPN, 2m cable S2T-1200P T/Beam, PNP, 2m cable S2T-1200P/D T/Beam, PNP, 2m cable SD-20CN Diffused reflection, NPN, Connector SD-20CP Diffused reflection, PNP, Connector SD-20N* Diffused reflection, NPN, Cable, No Box, Special fixture SD-20N-5 Diffuse, 20cm, 5 meter cable, NPN SD-20P Diffused reflection, PNP, Cable SD-20P-5 Diffuse, 20cm, 5 meter cable, PNP SJ-01 Slit for JT (Through-beam Type) SK-01 Slit for KT (Through-beam Type) SR-150CN Retro-reflection, NPN, Connector SR-150CP Retro-reflection, PNP, Connector SR-150N Retro-reflection, NPN, Cable SR-150N# Retro-reflection, NPN, Cable, P45 mirror SR-150N-5 Retro reflection, 5 meter cable, 1.5meter, NPN SR-150P Retro-reflection, PNP, Cable SR-150 (w/o V-61)   SR-150P-5 Retro reflection, 5 meter cable, 1.5meter, PNP SR-Q50CNW NPN, M8 4-pin Plug SR-Q50CPW PNP, M8 4-pin Plug SR-Q50NW NPN, 2m Cable SR-Q50NW-5 TFT application, 50 cm, 5 meter cable, NPN SR-Q50PW PNP, 2m Cable SR-Q50PW-5 TFT application, 50 cm, 5 meter cable, PNP ST-400CN Thru-beam, 4 meter, connector, NPN ST-400CP Thru-beam, 4 meter, connector, PNP ST-400N* Thru-beam, 4 meter, cable, NPN, No Box, Special fixture ST-400N-5 Thru-beam, 4 meter, 5 meter cable, NPN ST-400P Thru-beam, 4 meter, cable, PNP ST-400P-5 Thru-beam, 4 meter, 5 meter cable, PNP T000 Side-on Attachment for CTD T110 Side-on Attachment for CDD-11 T400 Side-on Attachment for CDD-40     SHP-100CN Shape Sensor, NPN SHP-100CP Shape Sensor, PNP SHP-M1 Monitor     TGF-CN Teach-in, NPN, M8 Conne. 4pin TGF-CP Teach-in, PNP, M8 Conne. 4pin TGF-N Teach-in, NPN, 2m cable TGF-N5 Teach-in, NPN, 5m cable TGF-P Teach-in, PNP, 2m cable TGF-P5 Teach-in, PNP, 5m cable TGF-ZCN Teach-in, NPN, M8 Conne. 4pin TGF-ZCP Teach-in, PNP, M8 Conne. 4pin TGF-ZN Teach-in, NPN, 2m cable TGF-ZN5 Teach-in, NPN, 5m cable TGF-ZP Teach-in, PNP, 2m cable TGF-ZP5 Teach-in, PNP, 5m cable TRF-CN NPN, M8 4-pin Plug TRF-CP PNP, M8 4-pin Plug TRF-N NPN, 2m Cable TRF-N5 NPN, 5m Cable TRF-P PNP, 2m Cable TRF-P5 PNP, 5m Cable TRF-ZCN Different Frequency, NPN, M8 4-pin Plug TRF-ZCP Different Frequency, PNP, M8 4-pin Plug TRF-ZN Different Frequency, NPN, 2m Cable TRF-ZN5 Different Frequency, NPN, 5m Cable TRF-ZP Different Frequency, PNP, 2m Cable TRF-ZP5 Different Frequency, PNP, 5m Cable     TMC-N11 Timing Comparator, NPN TMC-P11 Timing Comparator, PNP CVS-M1 Monitor     V2R-800 Retro-reflection, Relay V2R-800-3A Retro-reflection, UK-Made 3A Relay V2R-800CDN Retro-reflection, NPN V2R-800CDP Retro-reflection, PNP V2R-800DN Retro-reflection, NPN V2R-800DP Retro-reflection, PNP V2T-2000 Through-beam, Relay V2T-2000-3A Through-beam, UK-Made 3A Relay V2T-2000CDN Through-beam, NPN V2T-2000CDP Through-beam, PNP V2T-2000DN Through-beam, NPN V2T-2000DP Through-beam, PNP V3T-4000 T/B, 40 meter, Relay output, cable V3T-4000* T/B, 40 meter, Relay output, cable V4T-4000 T/B, 40 meter, Relay output, Terminal Chamber V3R-1000 Retro, 10 meter, Relay output, cable V3R-1000* Retro, 10 meter, Relay output, cable V4R-1000 Retro, 10 meter, Relay output, Terminal Chamber V3D-130 Diffuse, 1.3 meter, Relay output, cable V4D-130 Diffuse, 1.3 meter, Relay output, Terminal Chamber UR-34 Replacement unit for Retro, V3/V4 common UD-34 Replacement unit for Diffuse, V3/V4 common US-34 Replacement emitter of Thru-beam, V3/V4 common UE-34 Replacement Receiver of Thru-beam V3/V4 common V-42 Compact Mirror, for KR (Retro-refection) V-60K Anti-blur reflector, 60mm V-61 Reflective Mirror, 61mm VD-100CN Diffused reflection, 100cm, NPN, M12 4-pin plug VD-100CP Diffused reflection, 100cm, PNP, M12 4-pin plug VD-100N Diffused reflection, 100cm, NPN VD-100P Diffused reflection, 100cm, PNP VD-130* Diffused Reflection, 1.3m Relay VD-130T* Diffused Reflection, 1.3m, ON/OFF Delay VD-250CN Diffused reflection, 2.5m, NPN, M12 4-pin plug VD-250CP Diffused reflection, 2.5m, PNP, M12 4-pin plug VD-250N Diffused reflection, 2.5m, NPN VD-250P Diffused reflection, 2.5m, PNP VD-300* Diffused Reflection, 3m VD-300T* Diffused Reflection, 3m, ON/OFF Delay VGF-TCN Teach-in with Trimmer, NPN, M8 Conne. 4pin VGF-TCP Teach-in with Trimmer, PNP, M8 Conne. 4pin VGF-TN Teach-in with Trimmer, NPN, 2m cable VGF-TN-5 Teach-in with Trimmer, NPN, 5m cable VGF-TP Teach-in with Trimmer, PNP, 2m cable VGF-TP-5 Teach-in with Trimmer, PNP,5m cable VGF-ZTCN Teach-in with Trimmer, NPN, M8 Conne. 4pin VGF-ZTCP Teach-in with Trimmer, PNP, M8 Conne. 4pin VGF-ZTN Teach-in with Trimmer, NPN, 2m cable VGF-ZTN5 Teach-in with Trimmer, NPN, 5m cable VGF-ZTP Teach-in with Trimmer, PNP, 2m cable VGF-ZTP5 Teach-in with Trimmer, PNP,5m cable VR-1000* Retro-reflection, 10m VR-1000T* Retro-reflection, 10m, ON/OFF Delay VR-800CN Retro-reflection, 8m, NPN, M12 4-pin plug VR-800CP Retro-reflection, 8m, PNP, M12 4-pin plug VR-800N Retro-reflection, 8m, NPN VR-800P Retro-reflection, 8m, PNP VRF-A 1-5V, 2m Cable VRF-CA 1-5V, M8 4-pin Plug VRF-CN NPN, M8 4-pin Plug VRF-CP PNP, M8 4-pin Plug VRF-HCN NPN, M8 4-pin Plug VRF-HCP PNP, M8 4-pin Plug VRF-HN NPN, 2m Cable VRF-HN5 Trimmer type, High speed, 5 meter cable, NPN VRF-HP PNP, 2m Cable VRF-HP5 Trimmer type, High speed, 5 meter cable, PNP         VRF-SN2   VRF-N* VRF-N in bulk shipment VRF-N5 Trimmer type, 5 meter cable, NPN VRF-P PNP, 2m Cable VRF-P5 Trimmer type, 5 meter cable, PNP VRF-TCN NPN, M8 4-pin Plug VRF-TCP PNP, M8 4-pin Plug VRF-TN NPN, 2m Cable VRF-TN5 NPN, 5m Cable VRF-TP PNP, 2m Cable VRF-TP5 PNP, 5m Cable VRF-ZTCN Different Frequency, NPN, M8 4-pin Plug VRF-ZTCP Different Frequency, PNP, M8 4-pin Plug VRF-ZTN Different Frequency, NPN, 2m Cable VRF-ZTN5 Different Frequency, NPN, 5m Cable VRF-ZTP Different Frequency, PNP, 2m Cable VRF-ZTP5 Different Frequency, PNP, 5m Cable VT-3000CN Through-beam, 30M NPN M12 4-pin plug VT-3000CP Through-beam,30M PNP M12 4-pin plug VT-3000N Through-beam, 30M NPN VT-3000P Through-beam,30M PNP VT-4000* Through-beam, 40m VT-4000T* Through-beam, 40m, ON/OFF Delay ZD-70CN Diffuse, NPN, VR, M8 Conne.4pin ZD-70CP Diffuse, PNP, VR, M8 Conne.4pin ZD-70N Diffuse, NPN, VR, 2m cable ZD-70N-B Diffuse, 70cm, cable, NPN, No bracket ZD-70P Diffuse, PNP, VR, 2m cable ZD-70P-B Diffuse, 70cm, cable, PNP, No bracket ZD-L06N-B* Convergent, 6cm, cable, NPN, No bracket ZD-L06N-B/LG* No Label, Convergent, 6cm, cable, No bracket ZD-L09CN Convergent, NPN, VR, M8 Conne.4pin ZD-L09CN-B Convergent, 9cm, connector, NPN, No bracket ZD-L09CP Convergent, PNP, VR, M8 Conne.4pin ZD-L09CP-B Convergent, 9cm, connector, PNP, No bracket ZD-L09N Convergent, NPN, VR, 2m cable ZD-L09N-B Convergent, 9cm, cable, NPN, No bracket ZD-L09P Convergent, PNP, VR, 2m cable ZD-L09P-B Convergent, 9cm, cable, PNP, No bracket ZR-350CN Retro, NPN, VR, M8 Conne.4pin ZR-350CN-B Retro, 3.5 meter, connector, NPN, No bracket, No mirror ZR-350CND Retro, NPN, No VR, M8 Conne.4pin ZR-350CND-B Retro, 3.5 meter, connector, NPN, Dark-On fixed, No bracket, No mirror, No trimmer ZR-350CP Retro, PNP, VR, M8 Cconne.4pin ZR-350CP-B Retro, 3.5 meter, connector, PNP, No bracket, No mirror ZR-350CPD Retro, PNP, No VR, M8 Conne.4pin ZR-350CPD-B Retro, 3.5 meter, connector, PNP, Dark-On fixed, No bracket, No mirror, No trimmer ZR-350N Retro, NPN, VR, 2m cable ZR-350N Retro, NPN, VR, 2m cable ZR-350N Retro, NPN, VR, 2m cable ZR-350N-B Retro, 3.5 meter, cable, NPN, No bracket, No mirror ZR-350ND Retro, NPN, No VR, 2m cable ZR-350ND-B Retro, 3.5meter, cable, NPN, Dark-On fixed, No bracket, No mirror, No trimmer ZR-350P Retro, PNP, VR, 2m cable ZR-350P-B Retro, 3.5 meter, cable, PNP, No bracket, No mirror ZR-350PD Retro, PNP, No VR, 2m cable ZR-350PD-B Retro, 3.5meter, cable, PNP, Dark-On fixed, No bracket, No mirror, No trimmer     ZD-70CN-B Diffuse, 70cm, connector, NPN, No bracket ZD-70CP-B Diffuse, 70cm, connector, PNP, No bracket ZT-1200CN Thru-Beam, NPN, VR, M8 Conne.4pin ZT-1200CN-B T/B, 12 meter, connector, NPN, No bracket ZT-1200CND Thru-Beam, NPN, No VR, M8 Conne.4pin ZT-1200CND-B T/B, 12 meter, connector, NPN, Dark-On fixed, No bracket, No trimmer ZT-1200CP Thru-Beam, PNP, VR, M8 Conne.4pin ZT-1200CP-B T/B, 12 meter, connector, PNP, No bracket ZT-1200CPD Thru-Beam, PNP, No VR, M8 Conne.4pin ZT-1200CPD-B T/B, 12 meter, connector, PNP, Dark-On fixed, No bracket, No trimmer ZT-1200N Thru-Beam, NPN, VR, 2m cable ZT-1200N-B T/B, 12 meter, cable, NPN, No bracket ZT-1200ND Thru-Beam, NPN, No VR, 2m cable ZT-1200ND-B T/B, 12meter, cable, NPN, Dark-On fixed, No bracket, No trimmer ZT-1200P Thru-Beam, PNP, VR, 2m cable ZT-1200P-B T/B, 12 meter, cable, PNP, No bracket ZT-1200PD Thru-Beam, PNP, No VR, 2m cable ZT-1200PD-B T/B, 12meter, cable, PNP, Dark-On fixed, No bracket, No trimmer BL-100-POLF Polarizing Filter for ZT-1200, including 2pcs of filters     ZD-L40P 2mm spot diffuse, PNP, cable ZD-L40N 2mm spot diffuse, NPN, cable ZD-L40CP 2mm spot diffuse, PNP, M8 connector ZD-L40CN 2mm spot diffuse, NPN, M8 connector ZR-L1000P Laser, Retro, 10 meter, PNP, cable ZR-L1000N Laser, Retro, 10 meter, NPN, cable ZR-L1000N   ZR-L1000CP Laser, Retro, 10 meter, PNP, M8 connector ZR-L1000CN Laser, Retro, 10 meter, NPN, M8 connector ZT-L3000P Laser, T/B, 30 meter, PNP, cable ZT-L3000N Laser, Retro, 10 meter, NPN, cable ZT-L3000CP Laser, T/B, 30 meter, PNP, M8 connector ZT-L3000CN Laser, T/B, 30 meter, NPN, M8 connector ZR-Q200N   ZR-Q200P   ZR-Q200CN   ZR-Q200CP       FA 照明 SERIES   OPDR-90-50R IMAC IDR-90-50R Equivalent
半导体设备工业电源维修WBL-PS15V50A 研华触摸屏维修 捻线机细纱机开清棉机高产梳棉机系精梳机条并卷机并条机维修 苏州美能达广博柏色差计机维修 苏州供应AST-121A触摸屏三菱触摸屏维修 美国Aries伺服驱动器维修 GF阿奇夏米尔机床驱动器维修 西威变频器维修报警AVY2075-KBLM
