单回路PID控制器 3504 3508 3204 3208 32H8 3216 2704 2604 IO Expander for 26/2704 2404 2408 2416 2204e 2208e 2216e 2116 2132 808/847 902 T630 FKS LDE, LME MKS, TKS 7SD, 7SM, 7SH 7SP 7SF 7SC 7EM 7EF, 7HF 7EC 7ES 多回路的PID控制器 2704 2604 2500 Mini8 PC3000 RFS 显示仪 3204i 32h8i 3216i 2408i 2108i 2116i 2132i 7SI 7HI, 7HK 7HL 7SL 伺服马达和阀门定位器 传感器 EAxx-A EA40-A EA50-A EA70-A Standard EA EA12 EA20 EA31 EA40 EA50 & EA60 EA70 EA 81 Flat Pack MF 系列 Option Kits 附件 V-系列阀 电源控制器 单相 7100L 7100S 7100A TE10S TE10A TE10P TC1027 TC1028 TU1450, TU1470 TU1451, TU1471 7PT, 7PD, 7PA, 7PL 7PM 425S 425A 451, 452, 453, 454 461. 462, 463, 464 470, 471, 472 三相、两线跨接 TE200S TE200A TC2000, TC2001 TU2170 7PE, 7PB, 7PF 三相、三线跨接 7300A 7300S TE300 TC3000, TC3001 RVD3, RVA3 RVM3 固态继电器(Continental) SVDA, SVAA RSDA, RSAA RVD3, RVA3 RVDA, RVAA RVMA SVDD RVM3 IO系列 附件 REMIO EMA PD/CTX Eclipsee Fuse & Fuse Kits EMC Filters 过程自动化产品 EurothermSuite Solutions ESuite InfMG OpsF OpsS OpsW Operations Viewer and Server Operations Serverr T555 T560 LIN 技术产品 T2550 T940X T640 T800 T103/T303 S9576 S9574 T754X T755X App Modules Speed Controllers Part No. Input Signal Frequency DYN1-10652-000-0-12/24 250 - 1200 Hz DYN1-10653-000-0-12/24 1200 - 2500 Hz DYN1-10654-000-0-12/24 2500 - 5000 Hz DYN1-10656-000-0-12/24 5000 - 9500 Hz DYN1-10682-000-0-12/24 250 - 1200 Hz DYN1-10683-000-0-12/24 1200 - 2500 Hz DYN1-10684-000-0-12/24 2500 - 5000 Hz DYN1-10686-000-0-12/24 5000 - 9500 Hz TYPICAL APPLICATIONS •;Speed governing •;Remote throttle control •;Test stand throttle control •;Generator sets •;Power carts •;Pump sets AVAILABLE MODELS Actuators: Part No. DYNC-11020-000-0-12 Standard Clockwise DYNC-11020-000-0-24 Output Shaft Rotation DYNC-11024-000-0-12 Standard Counter Clockwise DYNC-11024-000-0-24 Output Shaft Rotation DYNC-70025-000-0-12/24 DYNC-70025-200-0-12/24 Available Models: DYNC 70000-000-0-12 Clockwise Rotation DYNC 70000-000-0-24 Clockwise Rotation DYNC 70001-000-0-12 Counterclockwise Rotation DYNC 70001-000-0-24 Counterclockwise Rotation DYNC 70002-000-0-12 Clockwise Rotation DYNC 70002-000-0-24 Clockwise Rotation DYNC-70003-000-0-12 Counterclockwise Rotation DYNC-70003-000-0-24 Counterclockwise Rotation DYNC 70100-000-0-12 Clockwise Rotation/ Position Feedback DYNC 70100-000-0-24 Clockwise Rotation/ Position Feedback DYNC 70101-000-0-12 Counterclockwise Rotation/ Position Feedback DYNC 70101-000-0-24 Counterclockwise Rotation/ Position Feedback DYNC-10202-000-0-(12 or 24) select voltage required. DYNC-10502-000-0-(12 or 24) select voltage required. DYNC-10202-000-0-(12 or 24) select voltage required. DYNC-10502-000-0-(12 or 24) select voltage required. Controllers: Speed Input Signal Frequency DYN1 -10652-000-0-24 DYN1 -10653-000-0-24 DYN1 -10654-000-0-24 DYN1 -10656-000-0-24 250-1200 Hz 1200-2500 Hz 2500-5000 Hz 5000-9500 Hz Available Actuator Models •;Plus 1 units with clockwise output shaft rotation: DYNC 11000 Standard DYNC 11001 Actuator head rotated 180° DYNC 11002 Actuator head rotated 90° counterclockwise •;Plus 1 units with counterclockwise output shaft rotation: DYNC 11004 Standard DYNC 11005 Actuator head rotated 90°clockwise DYNC 11006 Actuator head rotated 180° Available Actuator Models •;Plus 4 unit with through output shaft: DYNC 14000 PART NUMBERS DYN2-94025-001 (module with display and programming panel) DYN2-94026-001 (module without display and programming panel) DYNK-55100 (display and programming panel) DYNA 29900 (includes both DYN2-94026-001 and DYNK-55100) •; Automatic Frequency and Phase Matching •; Microprocessor Reliability •;Visual Indication of Frequency, Phase and Voltage Differentials •;Built-in Synch Check Relay •;Voltage Matching Relays •;Adjustable Phase Angle Differential •;Adjustable Voltage Matching Window •;Remote Reset •;Electric Governor Compatibility The DYNA II Auto-Synchronizer will function with the Barber-Colman DYNA I All-Electric Governor. It will operate with any governor actuator in the DYNA Series. •;Safety The DYNA II Auto-Synchronizer eliminates the risk of human error that might occur with manual paralleling. Operating personnel need not be present. •;Proportional Plus Integral Output The Auto-Synchronizer has a proportional plus integral output which allows it to be used with a wide variety of engine generator sets. •;Voltage Matching Relay Outputs The auto-synchronizer provides two N.O. relay contracts to indicate direction of voltage error. This can be used with a motorized potentiometer or any other device which increases or decreases generator voltage based on up/down signals. •;Capture Range ±3.0 Hz; synchronizes equally well from both directions. •;High Reliability The DYNA II Auto Synchronizer employs integrated circuits and digital components for high reliability. Each unit is subjected to thorough functional testing under operating conditions. •;Chassis Design The chassis is sturdily constructed of steel and is intended for behind-the-panel mounting. AB ABB ASCON 温控仪 BUSSMANN 熔断器 DOLD 继电器 DRUCK 德鲁克 EATON 伊顿 EUROTHERM 欧陆 FAG FINDER 继电器 FUJI 富士 GE HACH 哈希 H&B HENGSTLER 亨士乐 HIOKI 日置 HOFFMAN 霍夫曼 HUMMEL 胡默尔 IDEC 和泉电器 KRIWAN 仪表 KUBLER 仪表 MENNEKES 曼耐柯斯 METTLER 梅特勒托利多 MITSUBISHI 三菱 MODICON 莫迪康 MOELLER 金钟默勒 OMRON 欧姆龙 PANASONIC 松下电器 PHOENIX 菲尼克斯 PILZ 皮尔茨 RED-LION 红狮 RKC 温控仪 RITTAL 威图 SCHMERSAL 施迈赛 SCHNEIDER 施奈德 SIEMENS 西门子 SIKA 仪表 SOLA HEVI-DUTY 电源, 变压器 维修产品 直流调速器、变频器、控制器、温度控制器、过程控制器、可编程控制器(PLC)、信号转换隔离器、显示报警设定器、记录仪、过程自动化产品、控制系统、OEM控制器、阀门控制器、油门执行器、固态继电器和电源控制器、调功器、可控硅 同时提供各种产品的备品备件、各种板、卡件等。 直流调速器变频器 506、507、508、512C、514C、650系列、650V系列、690系列、605系列、630系列890、590系列、591系列、TS8000 油门执行器 DYNA 2000、DYNA 2500、DYNA 7000、DYNA 70025、DYNA 8000、DYNA8200 DYNA 8400、DYNA Plus1、DYNA Plus4、DYNA Pow-R-Con、DYN2 温度和过程控制器 3200系列、3500系列、2100系列、2200系列、2400系列、2604/2704、808系列、815/818系列、90系列、902系列 记录仪和数据采集设备-印刷线路板、电缆插件及打印组件等 6180A、6100A、5180A、5100V、5100E、5000B、392、394、Bridge 5000、4103C、4103M、 4102M、4102C、4101M、4101C、4100、4250M、4181M、4181G、4000R、4250D、4250C、4250G 固态继电器和电源控制器(保险底座及保险丝) SVDA、SVAA、RVDA/RSDA、RVMA、 RVAA/RSAA、7100L、7100S、7100A、TE10S、TE10A、 TE10P、460、470、TC1027、TC1028、TE200S、TE200A、TC2000、TC2001、RVD3/RVM3RVA3、 TE300、7300S、7300A、TC3000、TC3001、TU Series 直流调速器和变频器 506、507、508、512C、514C、590系列、591系列、650系列、650V系列、690系列、605系列、630系列、890、TS8000 6180A 180mm Paperless Graphic Recorder 6100A 100mm Paperless Graphic Recorder 5180V 180mm Graphic Data Acquisition Recorder 5100V 100mm Graphic Data Acquisition Recorder 5100e 100mm Graphic Data Acquisition Recorder Data Acquisition Units 5000B Data Acquisition Unit Circular Chart Recorders 392 Continuous Trace Circular 394 Multipoint Circular Chart Recorder Software Bridge 5000 Review Software Configuration Software Strip Chart Recorders 4103C 100mm Continuous Trace Strip Chart Recorder 4103M 100mm Multipoint Strip Chart Recorder 4102M 100mm Multipoint Strip Chart Recorder 4102C 100mm Continuous Trace Strip Chart Recorder 4101M 100mm Multipoint Strip Chart Recorder 4101C 100mm Continuous Trace Strip Chart Recorder 4100 Power Monitor Kit 4250M 250mm Multipoint Strip Chart Recorder 4181M 180mm Multipoint Strip Chart Recorder I/O Rack and Display 4000R Intelligent I/O Rack 4250D Graphic Network Display Unit Pens and Charts Indicators 2408i 1/8 DIN Intelligent Indicator and Alarm Unit 2108i 1/8 DIN Indcator and Alarm Unit 2132i and 2116i 1/32 and 1/16 DIN Indicator and Alarm Units Obsolete Products ———————————————————————————————————————— Video Graphic/Paperless Recorders 4100G 12-channel Video Graphic Recorder Video Graphic/Paperless Recorders Obsolete April 1, 2005 4181G 180mm Video Graphic Recorder 4250G 250mm Video Graphic Recorder Strip Chart Recorders Obsolete April 1, 2005 4250C 250mm Continuous Trace Strip Chart Recorder I/O Rack and Display Obsolete April 1, 2005 4250D Graphic Network Display Unit
通过中国触摸屏网金牌会员认证
