供应台达变频器及维修,价格可以浮动 报价表 价格单位台达VFD-L系列 VFD002L21A 0.2KW 220V 1,358 VFD004L21A 0.4KW 220V 1,482 VFD007L21A 0.75KW 220V 1,632 台达VFD-M系列 VFD004M21A 0.4KW 220V 1,715 VFD007M21A 0.75KW 220V 1,929 VFD015M21A 1.5KW 220V 2,215 VFD022M21A 2.2KW 220V 3,011 VFD007M43B 0.75KW 380V 2,725 VFD015M43B 1.5KW 380V 2,942 VFD022M43B 2.2KW 380V 3,618 VFD037M43A 3.7KW 380V 4,343 VFD055M43A 5.5KW 380V 6,062 台达VFD-A系列 VFD007A21A 0.75KW 220V 2,060 VFD015A21A 1.5KW 220V 2,300 VFD022A21A 2.2KW 220V 3,080 VFD007A43A 0.75KW 380V 2,740 VFD015A43B 1.5KW 380V 3,040 VFD022A43A 2.2KW 380V 3,910 VFD037A43A 3.7KW 380V 4,600 VFD055A43B 5.5KW 380V 6,270 VFD075A43B 7.5KW 380V 7,140 VFD110A43A 11KW 380V 9,800 VFD150A43A 15KW 380V 12,900 VFD185A43A 18.5KW 380V 14,886 VFD220A43A 22KW 380V 17,367 台达VFD-B系列 VFD007B21A 0.75KW 220V 2,268 VFD015B21A 1.5KW 220V 2,520 VFD022B21A 2.2KW 220V 3,556 VFD007B43A 0.75KW 380V 2,936 VFD015B43A 1.5KW 380V 3,270 VFD022B43A 2.2KW 380V 4,232 VFD037B43A 3.7KW 380V 5,026 VFD055B43A 5.5KW 380V 7,003 VFD075B43A 7.5KW 380V 7,929 VFD110B43A 11KW 380V 10,840 VFD150B43A 15KW 380V 13,941 VFD185B43A 18.5KW 380V 16,029 VFD220B43A 22KW 380V 18,519 VFD300B43A 30KW 380V 28,677 VFD375B43A 37.5KW 380V 35,599 VFD450B43A 45KW 380V 39,159 VFD550B43A 55KW 380V 52,130 VFD750B43A 75KW 380V 70,976 台达VFD-F系列 VFD055F43A 5.5KW 380V 6,719 VFD075F43A 7.5KW 380V 7,410 VFD110F43A 11KW 380V 8,380 VFD150F43A 15KW 380V 11,850 VFD185F43A 18.5KW 380V 14,500 VFD220F43A 22KW 380V 17,086 VFD300F43A 30KW 380V 19,760 VFD375F43A 37.5KW 380V 24,950 VFD450F43A 45KW 380V 30,850 VFD550F43A 55KW 380V 37,420 VFD750F43A 75KW 380V 49,275 型号 说明 ES系列主机 DVP14ES00R2 8点入,6点出,AC电源 810 DVP14ES00T2 8点入,6点出,AC电源 919 DVP14ES01R2 8点入,6点出,DC电源 1008 DVP14ES01T2 8点入,6点出,DC电源 1008 0 DVP24ES00R2 16点入,8点出,AC电源 1095 DVP24ES00T2 16点入,8点出,AC电源 1226 DVP24ES01R2 16点入,8点出,DC电源 1371 DVP24ES01T2 16点入,8点出,DC电源 1371 0 0 DVP32ES00R2 16点入,16点出,AC电源 1275 DVP32ES00T2 16点入,16点出,AC电源 1435 DVP32ES01R2 16点入,16点出,DC电源 1645 DVP32ES01T2 16点入,16点出,DC电源 1645 0 DVP60ES00R2 36点入,24点出,AC电源 1935 DVP60ES00T2 36点入,24点出,DC电源 2137 0 EX系列主机 0 型号 说明 0 0 DVP20EX00R2 20点主机,8DI/6DO出,4AI/2AO,AC电源 1758 DVP20EX00T2 20点主机,8DI/6DO出,4AI/2AO,AC电源 1758 DVP20EX11R2 20点主机,8DI/6DO出,4AI/2AO,AC电源 1758 0 0 ES-EX系列扩充机 0 型号 说明 0 DVP32XP00R 16点入,16点出,AC电源 1371 DVP32XP00T 16点入,16点出,AC电源 1371 DVP32XP01R 16点入,16点出,DC电源 1371 DVP32XP01T 16点入,16点出,DC电源 1371 DVP32XP11R 16点入,16点出,DC电源 1371 DVP32XP11T 16点入,16点出,DC电源 1371 0 DVP24XN00R 24点出,AC电源 1290 DVP24XN00T 24点出,AC电源 1290 DVP24XN01R 24点出,AC电源 1290 DVP24XN01T 24点出,AC电源 1290 DVP24XN11R 24点出,AC电源 1290 DVP24XN11T 24点出,AC电源 1290 0 DVP24XP00R 16点入,8点出,AC电源 1056 DVP24XP01R 16点入,8点出,DC电源 1056 DVP24XP01T 16点入,8点出,DC电源 1056 DVP24XP11R 16点入,8点出,DC电源 1056 DVP24XP11T 16点入,8点出,DC电源 1056 0 0 DVP16XN01R 16点出,DC电源 855 DVP16XN11R 16点出,DC电源 806 DVP16XN01T 16点出,DC电源 855 DVP16XN11T 16点出,DC电源 806 DVP16XM01N 16点入,DC电源 613 DVP16XM11N 16点入,DC电源 600 DVP08XM11N 8点入,DC电源 293 DVP08XN01R 8点出,DC电源 565 DVP08XN11R(T) 8点出,DC电源 450 DVP08XP11R 4点入,4点出,DC电源 435 DVP08XP11T 4点入,4点出,DC电源 460 0 SS系列主机 0 型号 说明 0 DVP14SS11R2 8点入,6点出,DC电源 SLIM 766 DVP14SS11T2 8点入,6点出,DC电源 SLIM 766 0 SA系列主机 0 DVP12SA11R 8点入,4点出,DC电源 SLIM TYPE SRAM 968 DVP12SA11T 8点入,4点出,DC电源 SLIM TYPE SRAM 968 DVP12SC11T 8点入,4点出,100KHZ脉冲输出,DC电源 SLIM TYPE SRAM 1000 0 SX系列主机 0 DVP10SX11R 4DI/2DO,2AI/2AO(12BIT/12BIT),DC, SLIM… 1452 DVP10SX11T 4DI/2DO,2AI/2AO(12BIT/12BIT),DC, SLIM… 1452 0 SS/SA/SX系列扩充机 0 型号 说明 0 DVP04AD-S 4路AI,14bit,DC电源,自带RS485 SLIM 1081 DVP02DA-S 2路AO,12bit,DC电源,自带RS485 SLIM 1161 DVP04DA-S 4路AO,12bit,DC电源,自带RS485 SLIM 1548 DVP06XA-S 4路AI,2路AO,12bit,DC电源,自带RS485 SLIM 1161 DVP04PT-S 4路PT100,14bit(0.1度),DC电源,自带RS485 SLIM 1161 DVP08SM11N 8点入,DC电源, SLIM 323 DVP08SN11R(T) 8点出,DC电源, SLIM 484 DVP08SP11R(T) 4点入,4点出,DC电源, SLIM 484 DVP16SP11R(T) 8点入,8点出,DC电源, SLIM 565 0 0 SS系列电源模块 0 型号 说明 0 DVPPS01 AC220V输入,DC24V输出,最大1A输出,SLIM 210 DVPPS02 AC220V输入,DC24V输出,最大2A输出,SLIM 298 0 0 型号 说明 0 DVPAADP01 HPP专用电源(含DVPACAB315) 468 DVPHPP02 手持编程器(含DVPACAB115) 1532 DVP-256FM FLISH MEMORY 256K(EH机种可用) 205 DVPDU01 数位设定显示器 468 DVPACAB115 HPP与PLC连接电缆 1.5M 85 DVPACAB215 PC与PLC连接电缆 1.5M 85 DVPACAB230 PC或TP02/04与PLC连接电缆 8pin—9pin/25pin D-SUB 3.0M 85 DVPACAB2A30 PC或TP02/04与PLC连接电缆 8pin—9pin D-SUB 3.0M 85 DVPACAB315 HPP与PC连接电缆 1.5M 85 DVPACAB403 扩充机连接电缆 30CM 85 DVPACAB530 HPP与PC连接电缆 3.0M 85 0 OIP操作截面 0 TP02G-AS1 单色STN LCD 2行显示 160*32点阵 256K FLASH COM1/COM2没有电池 774 TP04G-AS1 单色STN LCD 3行显示 128*64点阵 256K FLASH COM1/COM2有电池,RS232/RS 1032 TP04G-AS2 单色STN LCD 3行显示 128*64点阵 256K FLASH COM1/COM2有电池RS232/RS 935 0 EC系列主机 0 DVP24EC00R 12点入,12点出(继电器),AC电源,无RS232/RS 1210 DVP32EC00R 16点入,16点出(继电器),AC电源,无RS232/RS 1140 0 EH系列主机 0 DVP16EH00R 8点入,8点出,AC电源 1855 DVP16EH00T 8点入,8点出,AC电源 1855 DVP20EH00R 12点入,8点出,AC电源 2016 DVP20EH00T 12点入,8点出,AC电源,高速输出(Y0/Y2 200KHZ), 2016 DVP32EH00R 16点入,16点出,AC电源 2371 DVP32EH00T 16点入,16点出,AC电源,高速输出(Y0/Y2 200KHZ), 2100 DVP48EH00R 24点入,24点出,AC电源 2629 DVP48EH00T 24点入,24点出,AC电源 2629 DVP64EH00R 32点入,32点出,AC电源 2968 DVP64EH00T 32点入,32点出,AC电源 2968 DVP80EH00R 40点入,40点出,AC电源 3548 DVP80EH00T 40点入,40点出,AC电源 3548 0 EH系列扩充机 0 DVP08HM11N 8点入,DC电源 427 DVP08HP11R 4点入,4点出,DC电源 492 DVP08HP11T 4点入,4点出,DC电源 492 DVP08HN11R 8点出,DC电源 548 DVP08HN11T 8点出,DC电源 548 DVP16HM11N 16点入,DC电源 645 DVP32HP00R 16点入,16点出,AC电源 1774 DVP32HP00T 16点入,16点出,AC电源 1774 DVP48HP00R 24点入,24点出,AC电源 2387 DVP48HP00T 24点入,24点出,AC电源 2387 DVP04AD-H 4路AI,14bit,DC电源,自带RS485 1258 DVP04DA-H 4路AO,12bit,DC电源,自带RS485 1726 DVP04PT-H 4路PT100,14bit(0.1度),DC电源,自带RS485 1726 DVP06XA-H 4路AI,2路AO,12bit,开关量与模拟量隔离,DC电源,自带RS485 1726 0 EH系列特殊模块 0 DVP01PU-H 单轴定位模块,最高输出脉冲200KHZ,差动输出方式 1613 DVP01HC-H 1通道高速计数模块,最高计数脉冲200KHZ 1371 DVP02HC-H 2通道高速计数模块,最高计数脉冲200KHZ 2065 0 EH系列功能扩充卡 0 DVP-F232 RS232卡(Master/Slave) COM2 9PIN D-SUB 137 DVP-F422 RS422卡(Master/Slave) COM2 5PIN G型端子 137 DVP-F6VR 6路电位器输入卡 137 DVP-F8ID 8路DIP输入卡 137 DVP-F4IP 4路开关量输入卡 5PIN G型端子 137 DVP-F2OT 2路晶体管输入卡 5PIN G型端子 137 DVP-F2AD 2路AD卡 12bit 0-10v 4-20mA 5PIN G型端子 306 DVP-F2DA 2路DA卡 12bit 0-10v 4-20mA 5PIN G型端子 306 DVP-F232S RS232 卡(Slave)COM3 9PIN F-SUB 306 DVP-F485S RS422卡(Slave) COM3 5PIN G型端子 306 0 台达人机界面 0 型号 说明 0 DOP-A57GSTD 5.7"\16灰皆STN人机界面 2325 DOP-A57CSTD 5.7''''''''''''''''\256色STN人机界面 3570 DOP-A75CSTD 7.5"256色STN人机界面 7305 DOP-A10TCTD 10.4"256色TFT人机截面 9975 0 伺服电机 0 0.1KW 低惯量 5452 0.2KW 低惯量 5756 0.4KW 低惯量 5912 0.75KW 低惯量 7192 1KW 低惯量 8440 2KW 低惯量 12730 3KW 低惯量 14602 1KW 中惯量 8814 1.5KW 中惯量 10062 2KW 中惯量 12761 3KW 中惯量 14586
通过中国触摸屏网金牌会员认证
