17" SXGA TFT LCD Core™ 2 Duo L7400触摸式平板电脑
Intel® Core™ 2 Duo L7400处理器,高达1.5 GHz
设计紧凑,铝制前面板
无风扇冷却系统
前面板符合NEMA4/IP65防护标准
支持Microsoft® Windows® XP/XPe, Vista
向下I/O出口
千兆网口,支持以太网
产品介绍
该款产品配备17” SXGA TFT 液晶显示器,采用Intel® Core™ 2 Duo L7400 1.5 GHz处理器,并具备坚固的铝制前面板。总厚度小于93mm的超薄设计使得TPC-1780H成为目前触控平板电脑市场上最为小巧而坚固的产品,并依然配备17”显示屏。
Specifications
TPC-1780H-P3AE
Display
Backlight Life (hours)
50,000 hrs
Contrast Ratio
800 : 1
Luminance (cd/m2)
300
Max. Colors
16.7 M
Max. Resolution
1280 x 1024
Size
17"
Type
SXGA TFT LCD
Viewing Angle (H, V)
160, 160
General
BIOS
Award® 4 MB
Certifications
BSMI, CCC, CE, FCC, UL
Cooling System
Fanless design
Dimensions (W x H x D)
414 x 347.5 x 93 mm (16.3" x 13.68" x 3.66")
Enclosure
Front bezel: Die-cast Aluminum alloy, Back housing: ABS + PC
Mounting
Desktop, Wall or Panel Mount
OS Support
Windows XP/XPe, Vista
Power Consumption
100 W Typical
Power Input
18 ~ 32 VDC
Watchdog Timer
1 ~ 255 sec (system)
Weight (Net)
8 kg (17.64 lbs)
System Hardware
Chipset
Intel 945GME + ICH7
CPU
Intel Core 2 Duo L7400 1.5 GHz
Expansion Slots
PCI-104 (Up to 1unit, Optional), RS-422/485 (Optional)
I/O
RS-232 x 3 (COM1, 3, 4)USB 2.0 x 4 (Host), PS/2 Keyboard x 1, PS/2 Mouse x 1, VGA x 1, MIC-in x 1, Line-in x 1, Line-out x 1
LAN
10/100/1000Base-T x 2
Memory
2GB SO-DIMM DDR2 SDRAM, Up to 4GB
Storage
CompactFlash® slot x 1, 2.5" SATA HDD x 1(optional)
Touchscreen
Humidity
10 ~ 95% RH @ 40° C, non-condensing
Lifespan
1 million touches at single point
Light Transmission
Above 75%
Operating Temperature
0 ~ 45° C (32 ~ 113° F)
Resolution
Linearity
Storage Temperature
-20 ~ 60° C (-4 ~ 140° F)
Type
8-wire, analog resistive
Vibration Protection
With HDD: 1 Grms (5 ~ 500 Hz)
订货信息
产品描述
TPC-1780H-P3AE
17" SXGA Touch Panel PC, Core2Due L7400, 2GB
附件
产品描述
PWR-244-AE
Panel Mount Power Supply
晶创越世科技(北京)有限公司主营:研华工控机,三菱液晶屏,三菱阳光下可视液晶屏,三菱LED背光液晶屏,三菱宽温液晶屏,研华ADAM模块,研华一体化工作站,研华板卡,研华采集卡,研华便携式工控机,研祥工控机,研华嵌入式工控机,研华无风扇工控机,松下军工加固笔记本全系列,GETAC军工加固笔记本,清华同方军工加固笔记本,Gcreat自主品牌工控机全系列,Gcreat嵌入式无风扇工控机,Gcreat平板电脑,Gcreat一体化工作站,Gcreat工业显示器。公司网址www.gcreat.com
联系电话:010-82795822/57112818
