伦茨变频器武汉代理
我公司长期代理伦茨变频器,常年货源充足,价格优惠,欢迎来电咨询。
联系电话:027-83997366 027-83314566 传真:027-83999020-808 027-61111383 手机:15327281918 15327266536 QQ:371690156 李经理 网址:http://www.sjdz.net http://www.001gk.com/
武汉市硚口区古田五路17号新科技材料企业孵化器3-102
本公司代理伦茨lenze全系列产品,库存充足,价格优惠,欢迎来电咨询选购,我将竭诚为您服务:
ESMD251X2SFA,ESMD371X2SFA,ESMD551X2SFA,ESMD751X2SFA,ESMD152X2SFA,ESMD222X2SFA,ESMD371X2TXA,ESMD751X2TXA,ESMD112X2TXA,ESMD152X2TXA,ESMD222X2TXA,ESMD302X2TXA,ESMD402X2TXA,ESMD552X2TXA,ESMD752X2TXA,ESMD113X2TXA,ESMD153X2TXA,ESMD371L4TXA,ESMD751L4TXA,ESMD112L4TXA,ESMD152L4TXA,ESMD222L4TXA,ESMD302L4TXA,ESMD402L4TXA,ESMD552L4TXA,ESMD752L4TXA,ESMD113L4TXA,ESMD153L4TXA,ESMD183L4TXA,,ESMD223L4TXA;8200vectorE82CV251_2B,E82CV371_2B,E82CV551_2B,E82CV751_2B,E82CV152_2B,E82CV222_2B,E82CV551_4B,E82CV751_4B,E82CV152_4B,E82CV222_4B,E82EV251K2C200,E82EV371K2C200,E82EV551K2C200,E82EV751K2C200,E82EV152K2C200,E82EV222K2C200,E82EV551K2C200,E82EV751K2C200,E82EV152K2C200,E82EV222K2C200,E82EV302K2C200,E82EV402K2C200,E82EV552K2C200,E82EV752K2C200,E82EV551K4C200,E82EV751K4C200,E82EV152K4C200,E82EV222K4C200,E82EV302K4C200,E82EV402K4C200,E82EV552K4C200,E82EV752K4C200,E82EV113K4C200;E82EV551K4C,E82EV751K4C,E82EV152K4C,E82EV222K4C,E82EV302K4C,E82EV402K4C,E82EV552K4C,E82EV752K4C,E82EV113K4C,E82EV153K4B,E82EV223K4B,E82EV303K4B,E82EV453K4B,E82EV553K4B,E82EV753K4B,E82EV903K4B;E82EV251_2C,E82EV371_2C,E82EV551_2C,E82EV751_2C,E82EV152_2C,E82EV222_2C,E82EV302_2C,E82EV402_2C,E82EV552_2C,E82EV752_2C,E82EV551_4C,E82EV751_4C,E82EV152_4C,E82EV222_4C,E82EV302_4C,E82EV402_4C,E82EV552_4C,E82EV752_4C,E82EV113_4C,E82EV153_4B,E82EV223_4B,E82EV303_4B,E82EV453_4B,E82EV553_4B,E82EV753_4B,E82EV903_4B;EVF8201-E,EVF8202-E,EVF8203E,EVF8204-E,EVF8211-E,EVF8212-E,EVF8213-E,EVF8214-E,EVF8215-E,EVF8216-E,EVF8217-E,EVF8218-E,EVF8215-CV003,EVF8216-CV003,EVF8217-CV003,EVF8218-CV003,EVF8211-EV020,EVF8212-EV020,EVF8213-EV020,EVF8214-EV020,EVF8215-EV020,EVF8216-EV020,EVF8217-EV020,EVF8218-EV020;EVF8221-E,EVF8222-E,EVF8223-E,EVF8224-E,EVF8225-E,EVF8226-E,EVF8227-E,EVF8244-E,EVF8245-E,EVF8246-E,EVF8241-E,EVF8242-E,EVF8243-E,EVF8221-C-V003,EVF8222-C-V003,EVF8241-C-V003,EVF8242-C-V003,EVF8243-C-V003,EVF8244-C-V003,EVF8245-C-V003,EVF8246-C-V003;
9300 工程型高性能矢量变频器
E82MV251_2B,E82MV3
型号/规格:8200Vector矢量闭环变频器,三相交流电机,以及大功率范围减速机构成一套完整的传动系统。在现代工业传动应用中,这种“一步到位”的选择具有明显的优势,同时也是对伦茨提出的“上至电网,下至输出轴的传动”这一先进理念最为有利的诠释。 转矩控制 · 过载能力高-瞬间(60s)过载能力达180%,其中15.OkW-90.0kW变频器可在3s内保持210%的过载能力。· 转矩设定范围-1:10· 转矩上升时间短一负载骤升时, 转矩上升时间仅为200ms左右,因此, 在整个负载范围内,均可保持
商品简介:稳定的运转速度。速度控制 · 速度设定范围宽:不加外部反馈,速度设定范围亦可高达1:50 · 稳速精度高:不加外部反馈,在整个负载范围内,调速精度可稳定在0.5% 多种功能模块即插即用,功能扩展方便。 具备友好的用户接口,可轻松接入各种自动化系统 拥有强大的软件工具,便于开发完善的驱动系统解决方案 整个系统采用模块化设计,安装灵活,节省空间,并可有效降低系统安装的工作强度及成本 可驱动三相异步电机,三相磁阻电机,中频电机等多种电机 系统设计符合CE、UL、cUL、DIN等国际认证标准,适于全球应用
产品特性:
转矩控制
· 转矩设定范围-1:10
· 转矩上升时间短一负载骤升时, 转矩上升时间仅为200ms左右,因此, 在整个负载范围内,均可保持稳定的运转速度。
速度控制
多种功能模块即插即用,功能扩展方便。
额定功率 0.25—0.75kW (230V);0.55—90.OkW (400V/500V)
控制方式 V/f特性控制(线性、平方),矢量控制,转矩控制
斩波频率 0.25—11.OkW:2,4,8,16KHz
15.0—90.OkW:1,2,4,8,16KHz
封装等级 IP20
电磁兼容性(EMC) 内置RFI滤波器
环境温度 -10℃~+55℃
转矩特性 转矩设定范围 1: 10 (3-50Hz)
最大转矩 电机额定功率等于变频器额定功率的条件下,可在60s内承受180%过载,其中15.OkW-90.OkW变频器可在3S内保持210%过载.
无传感器速度控制特性 最小输出频率 1 .0 Hz(0-Mr)
速度设定范围 1:50
稳速精度 ±0.5%(3—50Hz)
速度偏差 ±0.1Hz
输出频率 输出频率范围 -650Hz~+650Hz
分辨率 0.02Hz
数字式给定位精度 ±0.005Hz(=±100ppm)
模拟式绐定数值线性度 ±0.5%(信号电平:5V或10V)
标准特性 PTC保护,PID控制器,内置制动斩波器,电机参数自整定,可编程继电器输出,S形曲线发生器……
输入/输出 模拟输入 模拟输出 数字输入 数字输出
标准1/0 1 2 4 1
扩展1/0 2 2 6 2
总线模块 LECOM-B(RS485), INTERBUS,PROFIBUS,系统总线(CAN),DeviceNet/CANopen,AS接口
通讯模块 LECOM-A/B(RS232/485),LECOM-L1(光纤),系统总线(CAN),DeviceNet/CANopen,LON
INTERBUS,INTERBUS-Loop PROFIBUS-DP
1、 斩波频率:8kHz
2、 斩波频率:2/4kHz
3、 电源频率:45Hz±0%~65Hz±0%
