Technical Parameters
Touch screen(standard): 22 inch IR touch screen(SAW, IR, Resistance touch screen optional);Use the most advanced IR touch screen, high stability, no excursion as the change of time and environment; high light transmission and no impurity, the highest is 98%; long service life and durability, not afraid scratch, long life for touching; good performance, the touch force is less than 3 ounces, can use everything to touch the monitor; resolution:4096*4096; Operating system is Win2000/XP/98/NT/VISTA/LINUX/Win7,it has good compatibility
Display: 22 inch (16:10) Samsung LCD panel(AU, Samsung LCD optional);Use 22 inch LCD panel; Resolution:1680*1050;field frequency: 60-75HZ;Pixel pitch:0.282mm; Brightness: 300cd/㎡; contrast Ratio: 1000:1;Response time:5ms; View angle:160°/160°(horizontal/vertical);Active area: 473.76mm*296.1mm.
PC configuration: You can choose the similar or the higher configuration for the mainboard
Standard industrial mainboard:2*PS2 Ports;
1*COM Port;1*LAN;1*LPT;1*VGA;4*USB2.0 Ports;1* Audio Input Port;1*Audio Output Port; Integrated sound card, integrated network card; dual graphics card; Intel® AtomTM CPU,1.6GHz; Huntkey 150W; Hard disk Hitachi 320G; RAM Kingston DDR2,1GB.
Operating System: Windows95/98/2000/NT/XP/LINUX/Win7,etc.
Working Environment: temperature +0℃-+40℃, relative humidity 10%-90% (relative, non-compression)
Storage temperature: -10℃-50℃
Power Supply: Input:110-240V,50-60HZ;Output:12.0V-4.16A
Physical size: 542mm*375mm*71mm
Packing size: 620mm*440mm*210mm
Total weight: 9.0kg
Agency Approval: CCC,CE,CB
Products Functions:
1. No pedestal design, the display does not swag when being touched on the desk, with good stability.
2. Own mold, the level of technology in line with international standards; use of ergonomic and aesthetic Principles of design.
3. Light and handy and ultra-thin fashion design, greatly expanded the field of computer application area; Convenient angle adjustment, the touch screen can be randomly adjusted in the range of 15°-90°.
4. Widely used in government, financial institution,transportation, public system, shopping malls, hotels, airports, gas stations, railways stations, post offices, telecommunications, banks, medical institutions, museums, exhibition halls, offices, KTV/VOD entertainments, catering industry and so on..
Note: multi-touch
基本参数
触摸屏(标配) 22寸红外触摸屏(声波屏,红外屏、电阻屏可选);采用世界上最先进的红外触摸屏;高度的稳定性,不会因时间、环境的变化产生飘移;高透光性无中间介质,最高可达标98%;使用寿命长,高度耐久,不怕刮伤,触控寿命也长;使用特性好,触摸无须力度,对触摸体无特殊要求;分辨率是4096(W)*4096(D);兼容性好Wn2000/XP/98/NT/VISTA/LINUX/Win7等均可使用
显示器 22寸(16:10)三星液晶面板(可选配AU.或三星液晶面板);采用22英寸液晶面板;屏幕分辨率:1680*1050;场频:60-75HZ;点距:0.282mm;亮度:300cd/m2;对比度:1000:1;响应时间:5ms;可视角度:160°/160°(水平/垂直) 可视面积:473.76mmX296.1mm
PC配置 可选配同类型或同类型更高配置的主板;标配工业级主板:2ⅹPS2接口;1ⅹcom接口;1ⅹ网线接口;1ⅹ并行接口;1ⅹVGA接口;4ⅹ USB2.0接口;1ⅹ音频输出接口;1ⅹ音频输入接口;集成声卡,网卡;双显卡Intel® AtomTM CPU,1.6GHz ;150W航嘉电源;320G日立硬盘;金士顿内存DDR2,1G;
运行环境 Windows95 /98/2000/NT / XP/ LINUX / Win7 等操作界面
工作环境 温度+0℃-+40℃,相对湿度10%-90%(相对,非压缩)
储存温度 -10℃-50℃
电 源 输入:110-240V、50-60HZ;输出12.0V—4.16A
物理尺寸 宽542mmX高375mmX厚71mm
包装尺寸 长620mmX宽440mmX高210mm
总 重 9.0kg
认证规范 CCC,CE,CB
产品功能及运用
1.无底座设计,在桌面使用触摸时显示器不晃动,极具稳定性。
2.自行开模,工艺水平符合国际标准;采用人体工程学和美学原理设计。
3.轻巧超薄的时尚外观设计,大大拓展了电脑的应用领域;可以在15°- 90°之间调整显示屏,应用方便。
4.广泛应用于政府、金融、交通、公共系统、商场、酒店、机场、加油站、车站、邮局、电信、银行、医疗、博物馆、展览馆、写字楼、KTV/VOD娱乐行业/餐饮行业等。
备注:多点触摸
