Technical Parameters
Touch screen(standard): 20.1 inch surface acoustic wave screen(SAW, Resistance touch screen optional);Use the most advanced surface acoustic wave screen with the resolution of 4096*4096 and light Transmittance 98% above; the touch force is less than 85g; response time is less than 5ms; calibrate one time, never excursion; Mao`s hardness test is 7-grade; single-point touch for 50 million times; the response is rapid and the utility time is durable. Agency Approval is CE, FCC, CCC.
Display: 20.1 inch AU LCD panel;Use 20.1 inch LCD panel; Resolution:1680*1050;Field frequency: 60-75HZ;Pixel pitch:0.28mm; Brightness: 300cd/㎡; Contrast Ratio: 800:1;Response time:5ms; View angle:160°/160°(horizontal/vertical);Active area: 434mm*271mm.
PC configuration: Standard industrial mainboard:2*PS2 Ports;1*COM Port;1*LAN;1*LPT;1*VGA;4*USB2.0 Ports;1* Audio Input Port;1*Audio Output Port; Integrated sound card, integrated network card; dual graphics card; Intel® Atom TM CPU,1.6GHz; Huntkey 150W; Hard disk Hitachi 320G; RAM Kingston DDR2,1GB.
Operating System: Windows95/98/2000/NT/XP/LINUX/Win7,etc.
Working Environment: temperature +0℃-+40℃, relative humidity 10%-90% (relative, non-compression)
Storage temperature: -10℃-50℃
Power Supply :Input:110-240V、50-60HZ;Output:12.0V-4.16A
Physical size: 500mm*345mm*70mm
Packing size: 575mm*410mm*210mm
Total weight: 8.5kg
Agency Approval: CCC,CE,CB
Products Functions :
1. No pedestal design, the display does not swag when being touched on the desk, with good stability.
2. Own mold, the level of technology in line with international standards; use of ergonomic and aesthetic Principles of design.
3. Light and handy and ultra-thin fashion design, greatly expanded the field of computer application area; Convenient angle adjustment, the touch screen can be randomly adjusted in the range of 15°-90°.
4. Widely used in government, financial institution,transportation, public system, shopping malls, hotels, airports, gas stations, railways stations, post offices, telecommunications, banks, medical institutions, museums, exhibition halls, offices, KTV/VOD entertainments, catering industry and so on.
Note: can not make two or multi-touch
基本参数
触摸屏(标配) 20.1寸表面声波屏 (声波屏、电阻屏可选);采用世界上最先进的表面声波屏,分辨率4096*4096;透光率98%以上;触摸反应力度<85g;响应时间低于5ms;一次校准,永无漂移;表面硬度莫氏7级;寿命单点触摸5000万次以上;反应更快寿命更长。通过CE、FCC、CCC认证
显示器 20.1寸三星液晶面板(可选配AU.LG或三星液晶面板);采用20.1英寸液晶面板;屏幕分辨率:1680*1050;场频:60-75HZ;点距:0.28mm;亮度:300cd/m2;对比度:800:1;响应时间:5ms;可视角度:160°/160°(水平/垂直);可视面积:434mm*271mm
PC配置: 标配工业级主板:2ⅹPS2接口;1ⅹcom接口;1ⅹ网线接口;1ⅹ并行接口;1ⅹVGA接口;4ⅹ USB2.0接口;1ⅹ音频输出接口;1ⅹ音频输入接口;集成声卡,网卡;双显卡Intel® AtomTM CPU,1.6GHz ;150W航嘉电源; 320G日立硬盘;金士顿内存DDR2,1G;
运行环境 Windows95 /98/2000/NT / XP/ LINUX / Win7 等操作界面
工作环境 温度+0℃-+40℃,相对湿度10%-90%(相对,非压缩)
储存温度 -10℃-50℃
电 源 输入:110-240V、50-60HZ;输出12.0V—4.16A
物理尺寸 500mm*345mm*70mm
包装尺寸 575mm*410mm*210mm
总 重 8.5kg
认证规范 CCC,CE,CB
产品功能及运用
1.无底座设计,在桌面使用触摸时显示器不晃动,极具稳定性。
2.自行开模,工艺水平符合国际标准;采用人体工程学和美学原理设计。
3.轻巧超薄的时尚外观设计,大大拓展了电脑的应用领域;可以在15°- 90°之间调整显示屏,应用方便。
4.广泛应用于政府、金融、交通、公共系统、商场、酒店、机场、加油站、车站、邮局、电信、银行、医疗、博物馆、展览馆、写字楼、KTV/VOD娱乐行业/餐饮行业等。
备注:不能进行两点和多点触摸
