| Specifications规格参数 | ||
| Processor/处理器 | CPU/处理器 | Intel J1900/ Gen Celeron 3865U/Core 6th 7th i3/i5/i7 /Android |
| Cooling System/散热系统 | Fanless | |
| Memory/内存 | 4GB/8GB DDR3 | |
| Storage/硬盘容量 | mSATA SSD | |
| I/O Ports/I/O端口 | USB: 4*USB2.0,optional 6*USB(4*USB2.0+2*USB3.0) | |
| COM: 2*RS232, optional 4*RS232 | ||
| Display: 1*VGA/1*HDMI | ||
| Audio: 1*Line-Out、1*Line-In | ||
| Expansion: 1*MINI-PCIE | ||
| Network/LAN/网卡 | 2*10/100/1000Mbps Ethernet | |
| Input Voltage/输入电压 | Input Voltage/输入电压 | 12V DC(Aviation Connector) |
| LCD Display/LCD 显示 | Display Type:/面板类型 | 21.5Inch a-Si TFT-LCD Panel( LED Backlight) |
| Max. Resolution:/最大分辨率 | 1920x1080 FHD/ 16:9 | |
| Luminance/cd/㎡/流明 | 250 cd/m² | |
| Touchscreen/触摸屏 | Touch Type/触摸板类型 | Capacitive Touch |
| OS Support/操作系统支持 | OS Support/操作系统支持 | Microsoft Windows 7/ 8/ 10/ Linux |
| Environment/环境要求 | Operating Temperature/工作温度 | -10℃~60℃(14~ 140 °F)(extend temperature optional) |
| Storage Temperature/耐受温度 | -20℃~70℃(-4 ~ 158 °F) | |
| Front Panel Protection/前面板保护 | IP65 compliant | |
| Mechanical/机箱参数 | Dimensions/尺寸 | 525*317*82mm |
| Color/颜色 | Black/Silvery/Gray | |
| Material/材质 | Aluminum + SUS/Sheet metal | |
| N.W./净重 | 6.0Kg | |
| Custom Service/可定制服务 | Custom Service/可定制服务 | Custom BIOS, System Encryption, Custom LOGO |
