PD050OX1 液晶屏TCON板 双30PIN TTL输出
最后更新: 2021-02-23 09:18
 源头厂家 PD050OX1 液晶屏TCON板 双30PIN TTL输出 支持定制
nfig="{"showOn":["mod-detail-description"],"title":"产品属性"}" data-feature-json="[{"fid":100000729,"values":["是"],"name":"加工定制","id":100000729,"value":"是"},{"fid":1398,"values":["KYV-TCON V1.7_G070VVN01.2"],"name":"货号","id":1398,"value":"KYV-TCON V1.7_G070VVN01.2"},{"fid":2176,"values":["KYV"],"name":"品牌","id":2176,"value":"KYV"},{"fid":3151,"values":["KYV-TCON V1.7"],"name":"型号","id":3151,"value":"KYV-TCON V1.7"},{"fid":3567,"values":["显示配件组件"],"name":"种类","id":3567,"value":"显示配件组件"},{"fid":8885,"values":["LED"],"name":"光源形状","id":8885,"value":"LED"},{"fid":8886,"values":["LED发光二极管"],"name":"光源种类","id":8886,"value":"LED发光二极管"},{"fid":8887,"values":["直下式"],"name":"光源分布位置","id":8887,"value":"直下式"},{"fid":3079,"values":["16:9"],"name":"显示模式","id":3079,"value":"16:9"},{"fid":7897,"values":["RGB"],"name":"显示颜色","id":7897,"value":"RGB"},{"fid":1235,"unit":"mm","values":["74*54"],"name":"规格尺寸","id":1235,"value":"74*54"},{"fid":44,"values":["可以"],"name":"OEM","id":44,"value":"可以"},{"fid":182282223,"values":["否"],"name":"是否跨境出口专供货源","id":182282223,"value":"否"}]" ready-to-show="true" style="word-break: normal; overflow-wrap: break-word; margin-bottom: 22px; position: relative; color: rgb(51, 51, 51); border-bottom: 1px solid rgb(229, 229, 229); border-image: initial; border-left: none; border-right: none; border-top: 0px; clear: both; zoom: 1; width: auto !important;">
显示颜色
RGB
规格尺寸
74*54(mm)
OEM
可以
是否跨境出口专供货源
否
nfig="{"showOn":["mod-detail-description"],"title":"详细信息","tabConfig":{"trace":"tabdetail","showKey":"mod-detail-description"} ,"catalog":[{"contentUrl":"https://img.alicdn.com/tfscom/TB1ui8ce7cx_u4jSZFlXXXnUFXa","id":"0","title":"图文详情"}] }" data-spm="descBanner" ready-to-show="true" style="word-break: normal; overflow-wrap: break-word; margin: 0px auto; overflow: hidden; position: relative; width: 790px !important;">
55
22
33
工业级LVDS转EDP信号转接板, EDP驱动板 工业级EDP液晶屏通用驱动板 支持HDMI VGA 输入 EDP接口液晶屏测试盒, 自动识别分辨率, 支持彩图显示 4K EDP信号液晶屏测试仪, EDID烧写, 电流电压监控 厂家直销EJ080NA-04C 8寸液晶屏TCON板 AT070TN92/94系列 7寸 液晶屏TCON板 AT050TN43 V1 5寸液晶屏LVDS TCON板 AT102TN03 10.2寸LCD液晶屏LVDS TCON
0 条相关评论
