近几年旗舰机的标配似乎除了双摄、全面屏、人脸识别,还新增了一个防水(防水可能作为卖点上的比较早)。
In recent years, the standard of the flagship aircraft seems to have added a waterproof (waterproof as a selling point) in addition to double shot, full screen and face recognition.
无论是索尼、还是苹果、三星在机器中都配备了防水功能,今天就来聊聊防水技术的那些事。
Whether SONY, apple or Samsung are equipped with waterproof function in the machine, today we will talk about those waterproof technologies.
首先IP68是什么意思?
What does IP68 mean first?
IP68的首位数字(6)代表防尘等级,0~6,数字越大代表等级越高;
The number of IP68's first (6) represents the level of dust prevention, 0~6, the greater the number, the higher the level.
而IP68的末位数字(8)代表防水等,0~8,数字越大代表等级越高。
The last digit of IP68 (8) represents waterproof, etc. 0~8, the greater the number, the higher the level.
顺便普及下防水的等级:
By the way, the grade of waterproof is popularized by the way:
0:没有保护
0: no protection
1:水滴滴入到外壳无影响
1: the dro of water drops into the shell without influence
2:当外壳倾斜到15度时,水滴滴入到外壳无影响
2: when the shell tilts to 15 degrees, droplet dripping into the shell has no effect.
3:水或雨水从60度角落到外壳上无影响
3: water or rain has no effect from 60 corners to the shell.
4:液体由任何方向泼到外壳没有伤害影响
4: the liquid splashed into any in any direction without damage.
5:用水冲洗无任何伤害
5: rinse with water without any harm
6:可用于船舱内的环境
6: can be used in the cabin environment
7:可于短时间内耐浸水(1m)
7: water resistant in short time (1m)
8:于一定压力下长时间浸
8: for a long time under certain pressure
1、实现原理
1. Principle of realization
特殊的密封胶条以及纳米涂层技术。
Special sealant and nano coating technology.
2、什么是纳米涂层
2. What is nanoscale coating
纳米涂层实际上就是一种原理相当于半透膜的一种物理结构,它的孔隙体积是水分子体积的700倍,但是是水滴体积的两万分之一。
Nanoscale coating is actually a physical structure that is equivalent to a semi permeable membrane. Its pore volume is 700 times the volume of water molecules, but it is 1/20000 of the volume of water droplets.
3、两者的区别以及优缺点
3, the difference between the two and the advantages and disadvantages
区别:
Difference:
密封胶条主要用于接缝处以及经常活动的外部件比如按钮以及卡槽。
Sealant strips are mainly used for joints and frequently moving external parts such as buttons and card slots.
纳米涂层主要用于内部密封,其作用是保证触点的正常工作并且密封内部形成固定的气压,主要用于外部开孔部件如耳机孔、充电接口、听筒等。
The nano coating is mainly used for internal seal. Its function is to ensure the normal work of the contact and to form a fixed air pressure inside the seal. It is mainly used for external opening parts, such as earphone holes, charging interfaces, and the receiver.
优点:
Advantage:
密封胶条的优点主要是耐用,较外接刺激做出的反应较为稳定,造价较低,维修后可以再造。
The advantages of the sealant strip are mainly durable, and the reaction is more stable than external stimulation, the cost is lower, and the repair can be rebuilt after maintenance.
纳米涂层的优点就是可以保持外形以及结构的不变,所有元器件贴完后加入浸泡pcb的工序或喷涂即可,维修方便,散热,而且防水性能优越。
The advantage of the nano coating is that it can keep the shape and the structure unchanged. After all the components are attached, the PCB process is added or sprayed. It is convenient for maintenance, heat dissipation, and the waterproof performance is superior.
缺点:
Shortcomings:
密封胶条的缺点给设备带来更大的体积,散热性较差,外部胶圈容易脱落。
The disadvantages of the sealant strip bring more volume to the equipment, less heat dissipation, and easy to fall off the outer aprons.
纳米涂层技术的缺点就是防水性能随着使用时间而衰减,成本较高,对外界的动作反应敏感。
The drawback of nano coating technology is that waterproofing performance is attenuated with the use time, high cost and sensitive to external action.
虽然这两者都有优点缺点,但是在防水手机中,两者的身影都会出现,由于两者的不同分工,手机的防水才得以实现。
Although both have the advantages and disadvantages, but in the waterproof phone, both of the figure will appear, because of the different division of labor, the mobile phone water can be realized.
声明:该文观点仅代表作者本人
Statement: the point of view is only the author himself
如果您有任何问题,请和我们联系:18664141553
免费样品试用
庄先生:1866 4141 553(微信同号 )
电 话:0769-33852759
邮 箱:2372971996@qq.com
地 址:东莞市寮步镇横坑松溪路123号
如觉得不错,敬请转发和分享!!
