可为您提供专业的测试方案及高精密多通道测试仪器;漏气检测仪器及探伤自动检测设备。
客户群有嘉联益、维胜科技、富士康、紫翔电子、臻鼎、华东电子、 TPK、京东方、长信、安特、纬创、Fujikura、Japan Display、LG Display、Mektec、Sharp、Shinpoly、Sumiden等知名企业.数字电位测试仪基本功能
数字电位测试仪系统功能
LCR Tester Roadmap
LCR Tester |
ST7610 |
ST9311C |
ST8320 |
ST8420 |
ST8520 |
Parameters |
RDC, L, C, Z, R, D, Q, Phase, Linearity, VDC, ADC, Calc. |
Output Frequency |
20Hz-300KHz |
20Hz-1MHz |
Accuracy: ±0.02% |
Output Voltage |
0.05Vrms-2Vrms, Accuracy: ±0.2% at 1KHz |
CV Output |
0.01-24.00V, Accuracy: ±1% + 3counts |
CC Output |
0.1-100.0mA, Accuracy: ±1% + 3counts |
Parameters |
RDC |
0.1mΩ ~ 99.99MΩ |
L |
1nH ~ 99.99KH |
C |
0.001pF ~ 999.99mF |
Z |
1.0mΩ ~ 99.99MΩ |
R |
1.0mΩ ~ 99.99MΩ |
D |
0.001 ~ 999.99 |
Q |
0.001 ~ 999.99 |
Phase |
-90.00°~ +90.00° |
Resonance Mode |
Series , Parallel |
VDC |
0.01V ~ 24.00V |
ADC |
0.1mA ~ 100.0mA |
Test Speed |
Test time at Max Speed |
20ms |
12ms |
Test time at Fast Speed |
25ms |
15ms |
Test time at Medium Speed |
30ms |
20ms |
Test time at Slow Speed |
40ms |
30ms |
Accuracy |
RDC |
Refer to Accuracy Chart |
LCR |
VDC at All Speed |
±1% + 3 counts |
ADC at All Speed |
±1% + 3 counts |
Repeatability tolerance at All Speed |
±0.1% + 5 counts |
Remote Port |
Test Trigger port |
Left-Test, Stop, Right-Test |
Test in Progress Port |
Left-Test, Right-Test |
Pass Result port |
Left-DUT, Right-DUT |
Fail Result port |
I2C port |
Dual Port, 100KHz/150KHz/200KHz/250KHz Clock, 1.8V/3.0V/3.3V |
Scanner Board |
Measurement Type |
2-Wire, 4-Wire |
Channel Port |
SCSI Connector |
Channel Mode Selection |
High, Low, Ground, Open |
Relay Switching Time |
1ms |
Max. Channel |
40 |
360 |
360 |
360 |
Dual 180 |
General |
2 DUT Parallel Test |
No |
No |
No |
No |
Yes |
LCR Universal Software |
Yes |
Yes |
Yes |
No |
No |
Controller |
Mini PC |
Operating System |
Windows 8.1 |
Display |
19" Wide-Screen LCD |
Keyboard & Mouse |
Wireless Keyboard & Mouse |
Interface |
NI-USB-GPIB Card |
Dimension(LxWxH), Unit : mm |
400335x180 |
600760995 |
440400356 |
440400356 |
440400400 |
Accessories |
Each scanner board are included SCSI test cable with length 0f 0.6m, 1m or 1.6m |
Options |
ST80360A RF Scanner, can expand the test channel to maximum 360 channel with each ST80360A |
