产品型号:JLT32012PCBA01
A.产品概述(Description of products)
- 产品型号(Product model):JLT32012PCBA01
- 分辨率(Resolution):240*320
- 面板尺寸(Panel size):3.2英寸
- 面板品牌(Panel manufacturers):CMO.台湾奇美
- 驱动芯片(Drive chip):ILI9325.ILI9338.ILI9341.HX8347
- 接口数量(Interface PIN):32PIN 2*16 2.54mm间距双排针
- 接口方式(Interface type) :并行接口(8位.16位)
- 活动区域(Active area):49.05*64.8 mm
- 产品厚度(thickness):5.2 mm MAX
- 触摸类型(Touch type):可带触摸(R Touch pad)
B.产品图片(Product pictures)
点我选购样品
点我了解其它2.8英寸TFT液晶模块
点我了解其它3.2英寸TFT液晶模块
C.接口定义( Interface definition)
| 1—3.3V | Power supply |
| 2—GND | Power ground |
| 3~18—DATA BUS | DB0-DB15 16BIT DATA BUS |
| 19-CS | Chip selec pin |
| 20-RS | Command/data selec pin |
| 21_WR | Write execution control pin |
| 22-RD | Read execution control pin |
| 23—RESET | LCM Reset PIN |
| 24-BL_EN | Back Light En PIN |
| 25-MISO | SPI MISO PIN |
| 26—TP_IRQ | TP IRQ PIN |
| 27—MOSI | SPI MOSI PIN |
| 28—NC | NC |
| 29—CLK | SPI CLK PIN |
| 30—SPIFLASH_CS | SPI Flash Chip selec PIN |
| 31—TP_CS | TP Chip selec PIN |
| 32—SD_CS | SD Card selec PIN |
点我
下载全套资料(Demo程序.规格书.参考设计资料) !!ILI9325驱动16位接口!!
D.其他信息( Other information)
更详细规格书及配套代码.应用资料.可直接咨询晶力泰销售人员.(联系方式在左边喲)
