A.产品概述(Description of products)
- 产品型号(Product model):JLT32009PCBA06
- 分辨率(Resolution):240*320
- 面板尺寸(Panel size):3.2英寸
- 面板品牌(Panel manufacturers):HSD
- 驱动芯片(Drive chip):ILI9341
- 接口数量(Interface PIN):34PIN 2.54双排针
- 接口方式(Interface type) :并行接口(8位.16位)
- 活动区域(Active area):49.05*64.8 mm
- 产品厚度(thickness):5.2 mm MAX
- 触摸类型(Touch type):可带触摸(R Touch pad)
B.产品图片(Product pictures)
点我选购样品点我了解其它3.2英寸TFT液晶显示模块
点我了解其它2.8英寸TFT液晶显示模块
C.接口定义( Interface definition)
| 1—3.3V | Power supply |
| 2—GND | Power ground |
| 3~18—DATA BUS | DB0-DB15 16BIT DATA BUS |
| 19-CS | Chip selec pin |
| 20-RS | Command/data selec pin |
| 21_WR | Write execution control pin |
| 22-RD | Read execution control pin |
| 23—RESET | LCM Reset PIN |
| 24-BL_EN | Back Light En PIN |
| 25-MISO | SPI MISO PIN |
| 26—TP_IRQ | TP IRQ PIN |
| 27—MOSI | SPI MOSI PIN |
| 28—NC | NC |
| 29—CLK | SPI CLK PIN |
| 30—SPIFLASH_CS | SPI Flash Chip selec PIN |
| 31—TP_CS | TP Chip selec PIN |
| 32—SD_CS | SD Card selec PIN |
| 33—GND | Power ground |
| 34—GND | Power ground |
D.其他信息( Other information)
更多产品信息请详见【产品规格书】或联系【晶力泰】客服人员
更详细规格书及配套代码.应用资料.可直接咨询晶力泰销售人员.(联系方式在左边喲)
