IC693DNM200
IC693DNS201
IC693DSM302
IC693DSM302RR
IC693DSM314
IC693DSM324
IC693LBR301
IC693LBR302
输入模块
IC693MAR590
IC693MAR590LT
IC693MAR590RR
IC693MCD001
IC693MCD001RR
IC693MCM001
IC693MDL230
IC693MDL230CA
IC693MDL230LT
IC693MDL230RR
IC693MDL231
IC693MDL231LT
IC693MDL231RR
IC693MDL240
IC693MDL240CA
IC693MDL240LT
IC693MDL240RR
IC693MDL241
IC693MDL241CA
IC693MDL241LT
IC693MDL241RR
IC693MDL250
IC693MDL260
IC693MDL310RR
IC693MDL330
IC693MDL330LT
IC693MDL330RR
IC693MDL340
IC693MDL340CA
IC693MDL340LT
IC693MDL340RR
IC693MDL350
IC693MDL390
IC693MDL390CA
IC693MDL390LT
IC693MDL390RR
IC693MDL632
IC693MDL632CA
IC693MDL632LT
IC693MDL632RR
IC693MDL633RR
IC693MDL634
IC693MDL634LT
IC693MDL634RR
IC693MDL640RR
IC693MDL641RR
IC693MDL643RR
IC693MDL644RR
IC693MDL645
IC693MDL645CA
IC693MDL645LT
IC693MDL645RR
IC693MDL646
IC693MDL646CA
IC693MDL646LT
IC693MDL646RR
IC693MDL648
IC693MDL653RR
IC693MDL654
IC693MDL654CA
IC693MDL654LT
IC693MDL654RR
IC693MDL655
IC693MDL655CA
IC693MDL655LT
IC693MDL655RR
IC693MDL660
IC693MDL730
IC693MDL730LT
IC693MDL730RR
IC693MDL731
IC693MDL731LT
IC693MDL731RR
IC693MDL732
IC693MDL732RR
IC693MDL733
IC693MDL733RR
IC693MDL734
IC693MDL734CA
IC693MDL734LT
IC693MDL734RR
IC693MDL740
IC693MDL740CA
IC693MDL740LT
IC693MDL740RR
IC693MDL741
IC693MDL741CA
IC693MDL741LT
IC693MDL741RR
IC693MDL742
IC693MDL742LT
IC693MDL742RR
IC693MDL748
IC693MDL750RR
IC693MDL751RR
IC693MDL752
IC693MDL752CA
IC693MDL752LT
IC693MDL752RR
IC693MDL753
IC693MDL753CA
IC693MDL753LT
IC693MDL753RR
IC693MDL754
IC693MDL758
IC693MDL758CA
IC693MDL758LT
IC693MDL760
IC693MDL916
IC693MDL930
IC693MDL930CA
IC693MDL930LT
IC693MDL930RR
IC693MDL931
IC693MDL931LT
IC693MDL931RR
IC693MDL940
IC693MDL940CA
IC693MDL940LT
IC693MDL940RR
IC693MDR390
IC693MDR390LT
IC693MDR390RR
IC693MLX000
IC693MSC301RR
IC693NIU004
IC693NIU004CA
IC693PBM200
IC693PBS201
IC693PCM300
IC693PCM300CA
IC693PCM300LT
IC693PCM300LTMP
IC693PCM300MP
IC693PCM300RR
IC693PCM301
IC693PCM301LT
IC693PCM301RR
IC693PCM311
IC693PCM311CA
IC693PCM311LT
IC693PCM311RR
IC693PIF301
IC693PIF350
IC693PIF400
IC693PRG300
IC693PRG300RR
IC693PTM100
IC693PTM100CA
IC693PTM101
IC693PTM101CA
在制造工业中存在大量的开关量为主的开环的顺序控制,它按照逻辑条件进行顺序动作号按照时序动作;另外还有与顺序、时序无关的按照逻辑关系进行连锁保护动作的控制;以及大量的开关量、脉冲量、计时、计数器、模拟量的越限报警等状态量为主的—离散量的数据采集监视。由于这些控制和监视的要求,使PLC发展成了取代继电器线路和进行顺序控制为主的产品。PLC厂家在原来CPU模板上提逐渐增加了各种通讯接口,现场总线技术及以太网技术也同步发展,使PLC的应用范围越来越广泛。 PLC具有稳定可靠、价格便宜、功能齐全、应用灵活方便、操作维护方便的优点,这是它能持久的占有市场的根本原因。
PLC控制器本身的硬件采用积木式结构,有母板,数字I/O模板,模拟I/O模板,还有特殊的定位模板,条形码识别模板等模块,用户可以根据需要采用在母板上扩展或者利用总线技术配备远程I/O从站的方法来得到想要的I/O数量。
PLC在实现各种数量的I/O控制的同时,还具备输出模拟电压和数字脉冲的能力,使得它可以控制各种能接收这些信号的伺服电机,步进电机,变频电机等,加上触摸屏的人机界面支持,施耐德的PLC可以满足您在过程控制中任何层次上的需求。
