良品率高,无耗材,环保,可靠稳定
High quality, No consumable item, Environment, Stable.
玻璃基底上薄膜处理,手机、触摸屏、薄膜太阳能电池、其他显示屏、PET基底上导电银浆、ITO薄膜处理。
Processing graphene, film on glass substrate, ITO and conductive silver paste on PET; application fields including mobile phones, touch screen, thin-film solar cells and other screen
激光波长: 1064nm、355nm、532nm
Laser wavelength: 1064nm、355nm、532nm
激光功率: 10W/20W
Laser power: 10W/20W
加工范围: 550 × 550mm(可定制)
Working area: 550 × 550mm (customizable)
刻蚀线宽: <40μm
Line width: <40μm
产品特点/Features
已获多项专利
Obtaining many patents
高灵活性、高精度、高速度
High flexibility、high speed、high accuracy
可大范围内进行各种图案、各种尺寸的精密高速刻蚀
Processing on wide-range of working area
良品率高
High reliability and quality
无耗材,环保
no consumable item, environmental
稳定可靠
Stable and friendly
技术参数/Specification
激光器Laser |
光纤激光器 Fiber Laser |
激光波长 Laser Wavelength |
1064nm |
激光功率 Laser Power |
10/20W |
聚焦光斑 Focus laser spot |
≤0.02mm |
激光频率调节范围Frequency range |
20K-100KHz |
刻蚀线宽 Etching line width |
<40μm |
刻蚀速度 Etching speed |
2500mm/s |
加工范围 Processing area |
500mmX500mm(可根据客户要求定制) 550mm*550mm(Customizable) |
单次最大幅面 Working area per one process |
140mmX140mm (可选配) 140mmX140mm (Customizable) |
功率消耗 Power consumption |
<2KW |
CCD自动定位精度 CCD automatic location precision |
±2μm |
直线电机工作台定位精度 Positioning precision of worktable of linear motor |
±2μm |
直线电机工作台重复精度 Prepetition precision of linear motor |
±1um |
设备尺寸 Dimension |
1650mmL×1300mmW×1670mmH |
设备重量 Weight |
2000kg |
可处理文件格式 File format |
标准Gerber文件,DXF文件,PLT文件等 |
ITO激光刻蚀机www.whtopwin.com
样品展示/Samples
