G170EG01-V1_ver1.0基本参数 |
制造商(Productor) |
AUO (友达) |
产品型号(MODEL) |
G170EG01-V1 |
屏尺寸(Size) |
17英寸 |
分辨率(Resolution) |
1280×1024 |
分辨率简称(Resolution Name) |
SXGA |
显示比例(Display scale) |
5:4 |
像素排列(Pixel Arrangement) |
RGB垂直条状 |
点距(Pixel Pitch) |
0.088×0.264 mm |
产品组成(Panel Composition) |
液晶屏 |
面板类型(Technology) |
a-Si TFT-LCD |
主要用途(Applications) |
【工业】 |
显著特征(Panel Features) |
【高色彩饱和度】【表面雾面】【广视角】【白光LED背光】【宽温】【背光寿命大于5万小时带有LED驱动 |
G170EG01-V1_ver1.0光电参数 |
显示模式(Display mode) |
TN,常白显示,透射式 |
亮度(Luminance) |
350 nits |
对比度(Contrast Ratio) |
800 :1 |
颜色(Color) |
16.7M (6-bit + Hi-FRC) |
色彩饱和度(Color Saturation) |
72% |
响应时间(Response) |
20/10 (Typ.)(Tr/Td) ms |
可视角度(Viewing Angle) |
60/80/80/80 (上/下/左/右) |
最佳视角(The Best View) |
6 o'clock |
白场色度(White Field Chroma) |
X:0.313;Y:0.329 |
白场变动(White Field Dynamic) |
1.25/1.33(Typ./Max.)(9points) |
扫描频率(Scanning Frequency) |
60Hz |
反转扫描(Reverse Scan) |
No |
信号类型大类(The kind of Singnal) |
LVDS |
接口类型(Interface) |
LVDS (2 ch, 8-bit) |
信号接口定义(Singnal Interface Definition) |
LVDS |
驱屏电压(Drive-screen voltage) |
5.0V |
面板输入电流(Input Current) |
30 |
信号接口类型(Kind of Singnal Interface) |
LVDS-30P2C8B-190A |
信号接口品牌(Brand of Singnal Interface) |
Connector |
信号接口型号(Model of Singnal Interface) |
JAE |
信号接口脚距(Pitch of Singnal Interface) |
1 mm |
信号接口数量(Quantity of Singnal Interface) |
FI-XB30SSL-HF15 pcs |
信号接口脚数(Pin of Singnal Interface) |
1 pins |
G170EG01-V1_ver1.0结构参数 |
工作温度(Operation Temperature) |
-30 C ~ 70 C |
存储温度(Storage Temperature) |
-30oC ~ 85oC |
面板重量(Weight) |
1.35Kgs (Typ.) |
表面处理(Surface Technology) |
雾面,Hard coating (3H) |
显示区域(Active Area) |
337.92×270.336 mm |
可视区域(Display Area) |
341.6×274.0 |
外形尺寸(Outline) |
358.5×296.5×18 mm |
触摸屏(Touch Panel) |
无 |
灯管位置(CCFL Position) |
侧入式光源(顶部) |
背光类型(Backlight) |
WLED |
灯管形状(CCFL Shape) |
侧入式光源 |
背光寿命(Life Time of Lamp) |
50K Hours |
内置灯管驱动器(Driver of Backlight) |
含LED驱动器 |
背光接口类型(Kind of Backlight Interface) |
端子 |
背光接口品牌(Brand of Backlight Interface) |
E |
背光接口型号(Model of Backlight Interface) |
T |
背光接口数量(Quantity of Backlight Interface) |
3806K-F06Y-03R pcs |
背光接口脚距(Pitch of Backlight Interface) |
1 mm |
北京中视通显示技术有限公司是一家专业开发、设计、及代理销售液晶显示屏LCD(TN、HTN、STN、FSTN、TFT)、液晶显示模块LCM(COB、SMT、COG、TAB、COF)、触摸屏及其他光电产品的高新技术企业,公司位于中关村,成立之初就秉承“诚信、创新、发展、共赢、”的核心理念,致力于平板显示产品的研发和销售,为全球客户提供人机界面显示产品及解决方案。
主要产品有各类高中低档TN/STN-LCD显示屏,各类标准显示 模块和非标准显示模块,OLED及其他光电产品。产品广泛用于 PDA、 IC卡电话、税控机器、加油机、安全报警器、子计价秤、银行点钞机、医疗仪器、工控机等通讯、仪器仪表,交通智能控制等。
销售品牌包括韩国的三星, LG-Philps, 台湾的AUO, CMO,INNOLUX, 日本的SHARP , MITSUBSHI NEC OPTREX KYOCERA 等。
工业显示屏广泛用于军事、机械、数控、医疗、交通、船舶、航空航天、仪器仪表和各类现场控制监视等等工业设备.
现货库存,欢迎垂询:电话:010—85628783 手机:13910131575
北京中视通显示技术有限公司 网址:www.tftlcds.com
