VICKERS威格士PVH131柱塞泵型号
PVH131R16AG30B182000001AJ1AA010A PVH131C-RBM-16S-11-C18V-31
PVH131R16AF30A250000001AM100010A PVH131C-RCF-16S-10-C25-31
PVH131R16AF30B252000001AM100010A PVH131C-RCF-16S-10-C25V-31
PVH131R16AF30B252000001AA100010A PVH131C-RCF-16S-10-C25V-31-114
PVH131R16AF30A070000001AM100010A PVH131C-RCF-16S-10-CM7-31
PVH131R16AF30E252012001AM1AA010A PVH131C-RCF-16S-11-C25VT12-31-CD
PVH131R16AF30J002004BD1AM1AA010A PVH131C-RCF-16S-11-ICT4-31-142
PVH131R03AF30B252000009AM1AM010A PVH131C-RCF-3S-10-C25V-31-117
PVH131R03AF30A070000001AM100010A PVH131C-RCF-3S-10-CM7-31
PVH131R03AF30B252000001AM1AA010A PVH131C-RCF-3S-11-C25V-31
PVH131R12AF30A250000001002AA010A PVH131C-RF-12D-11-C25-31
PVH131R12AF30B25200000100100010A PVH131C-RF-12S-10-C25V-31
PVH131R12AF30B252000001001AA010A PVH131C-RF-12S-11-C25V-31
PVH131R12AF30B252000AF1001AA010A PVH131C-RF-12S-11-C25V-31-023
PVH131R13AF30A25000000100100010A PVH131C-RF-13S-10-C25-31
PVH131R13AF30B25200000100100010A PVH131C-RF-13S-10-C25V-31
PVH131R13AF70B25200000100100010A PVH131C-RF-13S-10-C25V-31-057
PVH131R13AF30A07000000100100010A PVH131C-RF-13S-10-CM7-31
PVH131R13AF30B07200000100100010A PVH131C-RF-13S-10-CM7V-31
PVH131R13AF30H002000BD100100010A PVH131C-RF-13S-10-IC-31-CD-142
PVH131R13AF30A250000001001AA010A PVH131C-RF-13S-11-C25-31
PVH131R13AF30A250000001001AN010A PVH131C-RF-13S-11-C25-31-115
PVH131R13AF30D250014001001AA010A PVH131C-RF-13S-11-C25T14-31
PVH131R13AF30D250019001001AA010A PVH131C-RF-13S-11-C25T19-31
PVH131R13AF30B252000001001AA010A PVH131C-RF-13S-11-C25V-31
PVH131R13AF30E252015001001AA010A PVH131C-RF-13S-11-C25VT15-31
PVH131R13AF30E252004001001AA010A PVH131C-RF-13S-11-C25VT4-31
PVH131R13AF30A070000001001AA010A PVH131C-RF-13S-11-CM7-31
PVH131R13AF30A070000001001AN010A PVH131C-RF-13S-11-CM7-31-115
PVH131R02AF30B21200000100200010A PVH131C-RF-2D-10-C21V-31-046
PVH131R02AF30B252000001002AP010A PVH131C-RF-2D-10-C25V-31-165
PVH131R02AF30B252000AL1002AP010A PVH131C-RF-2D-10-C25V-31-206
PVH131R02AF30B252000AL1002AP010A PVH131C-RF-2D-10-C25V-31-210
PVH131R02AF30B252000001002AA010A PVH131C-RF-2D-11-C25V-31-046
PVH131R02AF30A25000000100100010A PVH131C-RF-2S-10-C25-31-046
PVH131R02AF30B25200000100100010A PVH131C-RF-2S-10-C25V-31-046
PVH131R02AF30B192000AA1001AA010A PVH131C-RF-2S-11-C19VB-31-CD
PVH131R02AF30B252600001001AA010A PVH131C-RF-2S-11-C25V26-31
PVH131R02AF30B252000001001AA010A PVH131C-RF-2S-11-C25V-31
PVH131R02AF30B252000001001AA010A PVH131C-RF-2S-11-C25V-31-046
PVH131R02AF30B282000AA1001AA010A PVH131C-RF-2S-11-C28VB-31-046
PVH131R02AF30B282000AR1001AA010A PVH131C-RF-2S-11-C28VB-31-219
PVH131R02AF30B282000BK1001AT010A PVH131C-RF-2S-11-C28VB-31-255
PVH131R03AF30A17000000100100010A PVH131C-RF-3S-10-C17-31
PVH131R03AF30A25000000100100010A PVH131C-RF-3S-10-C25-31
PVH131R03AF30B25200000100100010A PVH131C-RF-3S-10-C25V-31
PVH131R03AF30A07000000100100010A PVH131C-RF-3S-10-CM7-31
PVH131R03AF30A250000001001AA010A PVH131C-RF-3S-11-C25-31
PVH131R03AF30A250000001001AR010A PVH131C-RF-3S-11-C25-31-164
PVH131R03AF30D250004001001AA010A PVH131C-RF-3S-11-C25T4-31
PVH131R03AF30E252015001001AA010A PVH131C-RF-3S-11-C25VT15-31
PVH131R03AF30J002000BD1001AA010A PVH131C-RF-3S-11-ICT4-31-142
PVH131R13AF30A25000000200100010A PVH131C-RSF-13S-10-C25-31
PVH131R13AF30B25200000200100010A PVH131C-RSF-13S-10-C25V-31
PVH131R13AF30A07000000200100010A PVH131C-RSF-13S-10-CM7-31
PVH131R13AF30A250000002001AR010A PVH131C-RSF-13S-11-C25-31-164
PVH131R02AF30B252000002001AA010A PVH131C-RSF-2S-11-C25V-31
PVH131R03AF30A25000000200100010A PVH131C-RSF-3S-10-C25-31
PVH131R03AF30A250000002001AA010A PVH131C-RSF-3S-11-C25-31
PVH131R16AF70E252004001AD1AG010A PVH131QC3-RAF-16S-11-C25VT4-31-087
PVH131R16AF70E162005001AD1AE010A PVH131QIC3-RAF-16S-11-C16VT5-31
PVH131R16AF70E252004001AD1AE010A PVH131QIC3-RAF-16S-11-C25VT4-31
PVH131R16AF70F252004001AD1AE010A PVH131QIC3-RAF-16S-11-C25VT4S-31
PVH131R16AF70E072004001AD1AE010A PVH131QIC3-RAF-16S-11-CM7VT4-31
PVH131R13AF70E182005001001AE010A PVH131QIC3-RF-13S-11-C18VT5-31
PVH131R13AF70B252000001001AE010A PVH131QIC3-RF-13S-11-C25V-31
PVH131R13AF70E252004001001AE010A PVH131QIC3-RF-13S-11-C25VT4-31
PVH131R13AF70A070000002001AE010A PVH131QIC3-RSF-13S-11-CM7-31
PVH131L16AF30B252000001AD1AB010A PVH131QIC-LAF-16S-10-C25V-31
PVH131L16AF30A250000001AD1AE010A PVH131QIC-LAF-16S-11-C25-31
PVH131L03AF30B252000001AD1AB010A PVH131QIC-LAF-3S-10-C25V-31
PVH131L16AF30A250000001AJ1AE010A PVH131QIC-LBF-16S-11-C25-31
PVH131L16AF30A250000001AM1AE010A PVH131QIC-LCF-16S-11-C25-31
PVH131L16AF30D250004001AM1AE010A PVH131QIC-LCF-16S-11-C25T4-31
PVH131L03AF30A250000001AM1AE010A PVH131QIC-LCF-3S-11-C25-31-CD
PVH131L13AF30A250000001001AB010A PVH131QIC-LF-13S-10-C25-31
PVH131L13AF30B252000001001AB010A PVH131QIC-LF-13S-10-C25V-31
PVH131L13AF30A070000001001AB010A PVH131QIC-LF-13S-10-CM7-31
威格士叶片泵系列(Q)V10、V20 、20V、25V、35V、45V。
威格士双联叶片泵:2520V、3520V、3525V、4520V、4525V、4535V。
威格士变量柱塞泵:
PVQ系列:PVQ5、PVQ10、PVQ15、PVQ20、PVQ25、PVQ29、PVQ45。
PVB系列:PVB5、PVB10、PVB15、PVB20、PVB25、PVB29、PVB45。
PVH系列:PVH57、PVH74、PVH98、PVH131、PVH141等。
PFB柱塞泵:PFB5、PFB10、PFB20、PFB45,PFB5-FRY-22-S124。
威格士轴向柱塞泵:PVB5/6、PVB10/15、PVB20/29、PVB45、PVB90;PVB20-F-MRSFXN-10-CM-CVP-C-G-L-11-GE1。
PV/PF柱塞泵:PF066、PF090、PF130、PF180、PF250、PV066、PV090、PV130、PV180、PV250;PV 060M2 R 1A 1A 1N1V20EU1710 PV250、PV360、PV500、PV750、PF250、PF360、PF500、PF750、TPV130、TPV180、TPV250、TPV360、TPV500、TPF130、TPF180、TPF250、TPF360、TPF500;PV 250M 。
PVH柱塞泵:PVH57QIC,PVH63QIC,PVH74QIC,PVH81QIC等油泵及配件.
威格士为工业用途提供最齐全的液压子母叶片泵。各种品种的单联泵和多联泵配置使你可以选择最合适于你的用途的准确的泵或泵组。
VICKERS威格士PVH系列柱塞泵特点:
PVH大流量,高性能泵是变量直轴威格士柱塞泵中的一个家族,这种泵包含了其他威格士柱塞泵的经过考验的设计。高质量制造技巧及工作特征,而型体较小,重量较轻。这种威格士柱塞泵是高效的、可靠的、具有可任选控制方式的最大使用灵活性。经针对艰苦应用的特殊设计,这种泵提供土方机械、建筑机械、机床、灵活的塑料机械和所有其他重视能量的市场中想要的生产率增加和可控性改进正像所有的威格士产品一样,这种泵经过充分试验和现场考核。
威格士柱塞泵是液压系统的一个重要装置。它依靠柱塞在缸体中往复运动,使密封工作容腔的容积发生变化来实现吸油、压油。柱塞泵具有额定压力高、结构紧凑、效率高和流量调节方便等优点,被广泛应用于高压、大流量和流量需要调节的场合,诸如液压机、工程机械和船舶中。VICKERS柱塞泵是利用与传动轴平行的柱塞在柱塞孔内往复运动所产生的容积变化来进行工作的。由于柱塞和柱塞孔都是圆形零件,加工时可以达到很高的精度配合,因此具有容积效率高,运转平稳,流量均匀性好,噪声低,工作压力高等优点,但对液压油的污染较敏感,结构较复杂,造价较高。
