特性:胶带表面洁净度高、韧性好、不残胶、拉力轻、不翘边,为了方便取下液晶面板上贴附的保护膜专门设计的胶带
用途:主要用于撕手机模组,模块,MP4,GPS导航仪的显示屏上偏光片的保护膜。适用于TFT-LCD液晶荧幕显示器(撕除偏光膜上之PET,PE保护膜)保护膜撕除,偏光板保护膜撕除流程,具良好的粘性及离型力,能将板面保护膜迅速撕除。
Features: Tape surface cleanliness, high toughness, no incomplete glue, pull light, not become warped edge.
and using on the POL to tear the protective film. The tape has good adhesion and can tear the protective film quickly.
Usage: This product is easy to take down the protective film on the LCD POL with special design of tape, mainly for the tear the protective film from the mobile phone, modules, MP4, GPS navigators etc.
Using on the LCD screen displays (tear the Polyester, PE protective film) to tear the protective film , Good adhesion, suitable for die cutting into pull tape.
型号
Model NO.
基材
Carrier
颜色
Color
胶系
Adhesive base
总厚Total thickness
(mm)
总长
Length
(M)
粘着力
Adhesion to steel
(kg/25mm)
抗张强度
Tensile strength
(KG/25mm
伸长率
Elongation at break(%)
剥离率
Release force
PET
白色
White
亚克力
Acrylic
0.045
500
126-156
23±4
120
0.8
PET
浅黄色
Yellowish
0.065
200/300/
500/800
160-229
24±2
105
1.2
