530-2000-001新增530-2000-001
厦门岳航计算机工程有限公司
contact: 胡玲
Tel: +86-5 9 2-5 8 5 6 2 0 9 +86-1 8 0 3 0 2 3 5 3 1 1
Fax: +86-5 9 2-5 1 6 5 5 6 1(传真时请注明胡玲收,谢谢!)
QQ: 1 6 0 0 9 2 6 1 8 5
mail: 1 6 0 0 9 2 6 1 8 5 @qq.com
联系地址:厦门市思明区湖滨东路湖光大厦18楼B单元
2 Kepco 0024782 Robot Power Supply 27-053701-00. one un...Lot of 3, New BECO MAN-103307, PTFE dual solenoid fluid...
3 NEW Norcal product AMAT 3870-01244, Isolation valve K...
3 Asyst 9701-2490-02 Pittman Motor Encoder, Radial, LWR...
Lot of 7, HBC 824-3, new Heater controller assy w/ 2 op...
VAT pressure controller PM-6 810-49867 with VAT 93728-...
VAT pressure controller PM-6 810-49867 650PM-24CG-AD..?.
3 AMAT 0200-09482 West Coast Collar Quartz Alum 150MM...
3 NEW Kalrez sahara Oring K17120 8375 KALREZ, 22-10407-...
4 new AMAT 0021-09874 plenum cathode liner rps
QM soft co. Ltd. VEO-04EF, VEO491 servo controller
10 NEW Carlo Gavazzi EDM TC TYPE J INPUT PROG LOCK, 510...
5 Unit MFC, UFC-1660, O2 and 4 unknown gases.
2 Stec SEC-4400 MFC, O2 gas, 400 SCCM range, Repaired, ...
10 AMAT 0020-06090 Insulator Spindle Screw Spinning Hea...
Lambda LFS-48-24 Power Supply, LSF4824, Novellus 0150-7...
new AMAT 0150-36144 C/A lamp driver PCB interface
150 Micron 1 GB memory, 1RX8 PC3-8500P-7-00-?AP
AMAT 0240-86688 Centura Polycide C/R Manual Set
